Polo 6R 09 1.4 85KM
dcgumis
Re: Polo 6R 09 1.4 85KM
Post by dcgumis »
Hello, I have made installations for BCM max
Did I do something wrong?I will check the installations tomorrow.
Sunday,15,March,2020,19:21:02:05031
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 15.7.1.0 (x64)
Data version: 20150904
www.Ross-Tech.com
VIN: License Plate:
Chassis Type: 6R (7E0)
Scan: 01 03 08 09 15 17 19 25 37 44 56
VIN: Mileage: 172200km-107000miles
03-ABS Brakes -- Status: Sporadic communication error 1000
25-Immobilizer -- Status: Malfunction 0010
37-Navigation -- Status: Not registered 0001
44-Steering Assist -- Status: Not registered 0001
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: Malfunction 0010
Address 01: Engine
Cannot be reached
Address 03: ABS Brakes (J104)       Labels: None
   Part No SW: 6R0 907 379 AC    HW: 6R0 907 379 AC
   Component: ABS8.2 front  H04 0001
   Revision: --------
   Coding: 200228E3016F00B2042C14E280D800000200
   Shop #: WSC 02069 123 12345
   VCID: 7F0A9BD3EAEEDBC624-802A
Address 08: Auto HVAC (J301)       Labels: 6R0-820-045-9AP.clb
   Part No SW: 6R0 820 045 A    HW: 6R0 820 045 A
   Component: Climatic       23 0500
   Revision: 00 09 23
   VCID: 2C509C9F4F18905ED1-8078
2 Faults Found:
00457 - Control Module for Network (J519)
            013 - Check DTC Memory - Intermittent
                    Fault Status: 00101101
                    Fault Priority: 6
                    Fault Frequency: 2
                    Reset counter: 223
                    Mileage: 172205 km
                    Time Indication: 0
                    Date: 2020.03.15
                    Time: 00:00:00
16372 - Control Module; Unspecified Internal Error
            014 - Defective
                    Fault Status: 01101110
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 2234 km
                    Time Indication: 0
                    Date: 2020.01.09
                    Time: 17:45:52
Address 09: Cent. Elect. (J519)       Labels: None
   Revision: B9080001    Serial number: 0771 014162029
   Coding: 398001B820F32400923800003D2B1CC00080000020800000200000000000
   Shop #: WSC 02737 022 00190
   VCID: 68D8208F9B607C7EF5-803C
   Subsystem 1 - Part No SW: 6R0 959 801 H    HW: 6R0 959 801 H  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  002 0803
   Coding: 08BC30
   Subsystem 2 - Part No SW: 6R0 959 802 K    HW: 6R0 959 802 K  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  002 0803
   Coding: 08BC30
   Subsystem 3 - Part No: 1K8 951 171 A
   Subsystem 4 - Part No: 1K8 951 605
   Component: LIN BACKUP HO  H09 9002
   Subsystem 5 - Part No: 1K8 951 171 A
   Subsystem 6 - Part No SW: 5K0 959 542     HW: 5K0 959 542
   Component: E221__MFL-TAS  H05 0010
   Coding: 020000
   Subsystem 7 - Part No SW: 6R0 959 811 B    HW: 6R0 959 811 B
   Component: J388__TSG_HL  002 0803
   Coding: 08BC32
   Subsystem 8 - Part No SW: 6R0 959 812 B    HW: 6R0 959 812 B
   Component: J389__TSG_HR  002 0803
   Coding: 08BC32
3 Faults Found:
03444 - Ignition Starter Switch
                    Fault Status: 00101000
                    Fault Priority: 3
                    Fault Frequency: 3
                    Reset counter: 223
                    Mileage: 172205 km
                    Time Indication: 0
                    Date: 2020.03.15
                    Time: 01:14:20
01134 - Alarm Horn (H12)
            000 -  -
                    Fault Status: 01100000
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 183
                    Mileage: 172205 km
                    Time Indication: 0
                    Date: 2020.03.15
                    Time: 01:12:21
01504 - Bulb for License-Plate Light (X)
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 183
                    Mileage: 172205 km
                    Time Indication: 0
                    Date: 2020.03.15
                    Time: 01:12:16
Address 15: Airbags
Cannot be reached
   Part No SW: 6R0 920 870 B    HW: 6R0 920 870 B
   Component: KOMBI         H05 0607
   Coding: 140A00
   Shop #: WSC 00788 648 00255
   ROD: EV_Kombi_UDS_VDD_RM09_SK35.rod
   VCID: 346084FF9F28C89E89-8060
   Revision: B9080001
   Coding: 042207
10 Faults Found:
            000 -  -
                    Fault Priority: 2
                    Fault Frequency: 3
                    Reset counter: 255
                    Mileage: 70552 km
                    Time Indication: 0
                    Date: 2022.08.03
                    Time: 19:48:13
01315 - Transmission Control Module
            004 - No Signal/Communication
                    Fault Status: 01100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 183
                    Mileage: 70552 km
                    Time Indication: 0
                    Date: 2022.08.03
                    Time: 19:48:14
01316 - ABS Control Module
                    Fault Status: 00100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 223
                    Mileage: 138507 km
                    Time Indication: 0
                    Date: 2021.06.09
                    Time: 00:00:00
01324 - Control Module for All Wheel Drive (J492)
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 183
                    Mileage: 70552 km
                    Time Indication: 0
                    Date: 2022.08.03
                    Time: 19:48:14
01319 - Control Module for Distance Control (J428)
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 183
                    Mileage: 138507 km
                    Time Indication: 0
                    Date: 2021.06.09
                    Time: 00:02:21
03604 - Control Module Auomatic Sliding Door, Rear Left
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 183
                    Mileage: 70552 km
                    Time Indication: 0
                    Date: 2022.08.03
                    Time: 19:47:53
03605 - Control Module Auomatic Sliding Door, Rear Right
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 183
                    Mileage: 70552 km
                    Time Indication: 0
                    Date: 2022.08.03
                    Time: 19:47:53
01207 - Control Module for Auxiliary Heater (J364)
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 183
                    Mileage: 138507 km
                    Time Indication: 0
                    Date: 2021.06.09
                    Time: 00:00:02
03406 - Control Module for Battery Monitoring
                    Fault Priority: 2
                    Fault Frequency: 4
                    Reset counter: 223
                    Mileage: 138507 km
                    Time Indication: 0
                    Date: 2021.06.09
                    Time: 00:01:59
03158 - Control Module for Information Electronics 1 (J794)
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 183
                    Mileage: 138507 km
                    Time Indication: 0
                    Date: 2021.06.09
                    Time: 00:00:06
   Component: IMMO          H05 0607
   Serial number:
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_Immo_DUS_VDD_RM09 A03709
   ROD: N/A
   VCID: 6ADC5A878D6C4E6EE3-803E
No ASAM data for: "EV_Immo_DUS_VDD_RM09" (VW36 *)
1 Fault Found:
9456681 - ROD - Unknown Error Code
          - 00 [008]
                    Fault Status: 00000001
                    Fault Priority: 6
                    Fault Frequency: 1
                    Mileage: 172205 km
                    Date: 2020.03.15
                    Time: 00:22:30
Address 37: Navigation (J0506)       Labels: 1T0-035-680.clb
   Part No SW: 1T0 035 680 R    HW: 1T0 035 680 R
   Component: RNS-MID       H24 6276
   Revision: AB001001    Serial number: VWZ6Z7S0418589
   Coding: 00010000010000A00000
   Shop #: WSC 01357 011 00200
   VCID: 3D76A1DBA46209D676-8068
   Subsystem 1 - Part No: 1T0 919 859 C
   Component: EU East V15  8522
   Part No: 6R0 423 156 A
   Component: LenkhilfeTRW        V275
   Coding: 10150
   Shop #: WSC 00000
   VCID: 2E549697ED04E24EFF-807A
Address 56: Radio (J0506)       Labels: 1T0-035-680.clb
End-------------------------(Elapsed Time: 02:29)--------------------------
dcgumis
Post by dcgumis »
Hi, I made a BCM installation today. I have some mistakes. The light switch works as if I had a key in the ignition: did I mistake the wires?
I made the installations according to the instructions
https://www.youtube.com/watch?v=hcJeleQu1lo
Wl0
"SB20 to SB17
- Remove SB20b original 0.5mm2 wire (yellow/red) and insert in SB17b.
- Insert in SB20b the new two wires crimped in the same terminal, black and yellow. Install a new 30A fuse in SB20.
- Insert in SB17a the new yellow wire. Install a new 5A fuse in SB17"
WL1
T73B/54 to T32/28
T73B/57 to T32/29
WL2A
orginal (yellow/black) SB59b connected SB59b
connected SB57b
orginal(yellow) SB39b connected SB39b
Orginal(white/green)SB34b connected SB34b
WL2B
j331 remove.Install electric Brigde
WL2C
T73B/11
T73B/68
T73B/2
T73A/62
T73A/63
T73A/2
Sunday,15,March,2020,20:56:56:05031
www.Ross-Tech.com
VIN: WVWZZZ6R   License Plate:
VIN: WVWZZ  Mileage: 172200km-107000miles
Address 01: Engine
Cannot be reached
   Revision: --------
   Revision: 00 09 23
1 Fault Found:
            014 - Defective
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 2234 km
                    Time Indication: 0
                    Date: 2020.01.09
                    Time: 17:45:52
   Coding: 08BC30
   Coding: 08BC30
   Coding: 020000
   Coding: 08BC32
   Coding: 08BC32
2 Faults Found:
            000 -  -
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 184
                    Mileage: 172205 km
                    Time Indication: 0
                    Date: 2020.03.15
                    Time: 00:21:22
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 184
                    Mileage: 172205 km
                    Time Indication: 0
                    Date: 2020.03.15
                    Time: 00:21:19
   Part No SW: 6R0 959 655 C    HW: 6R0 959 655 C
   Component: VW10Airbag005 H09 0018
   Revision: --------    Serial number: 003DW003YHK-
   Coding: 003035
   Shop #: WSC 124697 483 00190
   ASAM Dataset: EV_AirbaVW10BPVAW250 A01001
   ROD: N/A
   VCID: 428CD227D59C762E0B-8016
   Subsystem 1 - Serial number: 3572SRB40000911C8A98
   Subsystem 2 - Serial number: 3582SRB4000091185980
   Subsystem 3 - Serial number: 3516GRB401V9F7IH9SA3
   Subsystem 4 - Serial number: 3526GRB40219F7IH1K1-
No ASAM data for: "EV_AirbaVW10BPVAW250" (VW25)
   Coding: 140A00
   Revision: B9080001
   Coding: 042207
1 Fault Found:
            000 -  -  - Intermittent
                    Fault Status: 00100000
                    Fault Priority: 2
                    Fault Frequency: 3
                    Reset counter: 255
                    Mileage: 172205 km
                    Time Indication: 0
                    Date: 2020.03.15
                    Time: 00:22:34
   Serial number:
   ROD: EV_Immo_UDS_VDD_RM09_SE25.rod
   Coding: 10150
   Shop #: WSC 00000
End-------------------------(Elapsed Time: 02:39)--------------------------
Well, for the new 7E0 BCM Max and electrical installation to work correctly, the Gateway (address 19), the RLS (BCM subsystem) and new BCM (address 09) must be correctly coded.
To send you the new codings I must know if you have installed the rain light sensor... :?:
Gateway coding
002200
RLS coding
New BCM coding
Have you installed the WL3, WL4 and automatic light wiring? It is mandatory.
Complete the electrical installations according to the installation guides.
(https://drive.google.com/file/d/1KUJmjT ... Ng1Gb/view)
Waiting for your reply. :wink:
dcgumis
Post by dcgumis »
Thank you for your response, :D :D
I will install WL3 WL4 today
Will the problem with the light switch be solved during the installation of WL3 / WL4? As I showed in the movieI had to remove the batteries for the night
:shock: :shock: did i make a mistake during installation?
I don't have a rain light sensor.
Do I need to install automatic lighting wiring now?.I haven't thought about automatic lights yet, will this change?
The next step I wanted to take after installing BCM max full LED polo 6C
Install everything, no matter you don't have the light sensor installed at the moment.
New BCM coding will fix whatever is possible to fix (you won't have to leave the battery disconnected at night). :wink:
dcgumis
Post by dcgumis »
I did the rest of the installation :) :)
I did not install WL 4 T6/5 which should be inserted into the 6C rear lights adapter.
car trunk I can't open it with the remote control the lock does not open
All doors open and close normally
I did Gateway coding
002200
Monday,16,March,2020,13:48:43:05031
www.Ross-Tech.com
VIN: WVWZ License Plate:
VIN: WVWZZZ6
Address 01: Engine
Cannot be reached
Cannot be reached
   Revision: 00 09 23
1 Fault Found:
            014 - Defective
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 2234 km
                    Time Indication: 0
                    Date: 2004.14.22
                    Time: 17:45:52
   Coding: 08BC30
   Coding: 08BC30
   Coding: 020000
   Coding: 08BC32
   Coding: 08BC32
2 Faults Found:
            000 -  -
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 184
                    Mileage: 172205 km
                    Time Indication: 0
                    Date: 2006.14.24
                    Time: 00:07:28
            010 - Open or Short to Plus - Intermittent
                    Fault Status: 00101010
                    Fault Priority: 3
                    Fault Frequency: 57
                    Reset counter: 224
                    Mileage: 172205 km
                    Time Indication: 0
                    Date: 2006.14.24
                    Time: 00:07:25
   Coding: 003035
   ASAM Dataset: EV_IarbaVW10BPAVW250 A01001
   ROD: N/A
No ASAM data for: "EV_IarbaVW10BPAVW250" (VW25)
Address 17: Instruments        Labels: None
   Serial number: 00000050000005
   Coding: 110A00424920
   ASAM Dataset: EV_Komgi_UDS_DSD_RM0< A04716
   ROD: N/A
   VCID: 55A6197B3412F1965E-8000
No ASAM data for: "EV_Komgi_UDS_DSD_RM0<" (SE41)
   Coding: 140A00
   ASAM Dataset: EV_Kombi_UD_SVDD_RM09 A04716
   ROD: N/A
No ASAM data for: "EV_Kombi_UD_SVDD_RM09" (VW36 *)
   Revision: B9080001
   Coding: 042207
1 Fault Found:
                    Fault Priority: 2
                    Fault Frequency: 16
                    Reset counter: 255
                    Mileage: 172205 km
                    Time Indication: 0
                    Date: 2006.14.24
                    Time: 00:04:20
   Serial number:
   ASAM Dataset: EV_Immo_UD_SVDD_RM09 A03709
   ROD: N/A
No ASAM data for: "EV_Immo_UD_SVDD_RM09" (VW36 *)
   Coding: 10150
   Shop #: WSC 00000
New BCM coding (without RLS, so, without Automatic lights and CH/LH)
3DB02BB828F32400923800B02C2B1CD01BC0610F60802001200000020000
Please, check all the lights one by one, post a new autoscan and comment out your lights check to make a new BCM coding. Thanks.
dcgumis
Post by dcgumis »
Hello :)
I finished the WL4 installation today
I did the coding above
Position 0 Lights do not come on
position 2 auto - Off
Position 3 The parking lamps work
Position 4
the low lights beam comes on
I have a problem with the dimmer flashing
https://www.youtube.com/watch?v=pxcBEH817B0
Tuesday,17,March,2020,17:26:02:05031
www.Ross-Tech.com
VIN: WVWZZZ  License Plate:
VIN: WVWZZZMileage: 172230km-107018miles
Address 01: Engine
Cannot be reached
   Revision: --------
   Revision: 00 09 23
1 Fault Found:
            014 - Defective
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 2234 km
                    Time Indication: 0
                    Date: 2020.01.11
                    Time: 17:45:52
   Coding: 3DB02BB828F32400923800B02C2B1CD01BC0610F60802001200000020000
   Coding: 08BC30
   Coding: 08BC30
   Coding: 020000
   Coding: 08BC32
   Coding: 08BC32
2 Faults Found:
            000 -  -
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 189
                    Mileage: 172225 km
                    Time Indication: 0
                    Date: 2020.03.17
                    Time: 16:14:32
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 189
                    Mileage: 172225 km
                    Time Indication: 0
                    Date: 2020.03.17
                    Time: 16:14:28
   Coding: 003035
   ASAM Dataset: EV_AirbaV1W0BPAVW250 A01001
   ROD: N/A
No ASAM data for: "EV_AirbaV1W0BPAVW250" (VW25)
   Coding: 140A00
   Revision: B9080001
   Coding: 002200
1 Fault Found:
                    Fault Priority: 2
                    Fault Frequency: 4
                    Reset counter: 255
                    Mileage: 172233 km
                    Time Indication: 0
                    Date: 2020.03.17
                    Time: 17:19:37
   Serial number:
   Coding: 10150
   Shop #: WSC 00000
End-------------------------(Elapsed Time: 02:48)--------------------------
[/cocde]
This will give you DRL via dipped beam, if you like:
3DB02BB828F32400923800B02C2B1CD01BC0610F60802045200000020000
DRL via cornering lights:
3DB02BB828F32400923800B02C2B1CD01BC0610F60802049200000020000
As far as the dimmer goes, I'm not sure what the problem is. Can you measure the voltage on T6/3 (pin 3 of the dimmer)?
dcgumis wrote: Tue Mar 17, 2020 5:18 pm Hello :)
Position 4
www.Ross-Tech.com
VIN: WVWZZZ6RZAY020707   License Plate:
VIN: WVWZZZ6RZAY020707   Mileage: 172230km-107018miles
Address 01: Engine
Cannot be reached
   Revision: --------
   Revision: 00 09 23
1 Fault Found:
            014 - Defective
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 2234 km
                    Time Indication: 0
                    Date: 2020.01.11
                    Time: 17:45:52
   Coding: 08BC30
   Coding: 08BC30
   Coding: 020000
   Coding: 08BC32
   Coding: 08BC32
2 Faults Found:
            000 -  -
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 189
                    Mileage: 172225 km
                    Time Indication: 0
                    Date: 2020.03.17
                    Time: 16:14:32
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 189
                    Mileage: 172225 km
                    Time Indication: 0
                    Date: 2020.03.17
                    Time: 16:14:28
   Coding: 003035
   ROD: N/A
   Coding: 140A00
   Revision: B9080001
   Coding: 002200
1 Fault Found:
                    Fault Priority: 2
                    Fault Frequency: 4
                    Reset counter: 255
                    Mileage: 172233 km
                    Time Indication: 0
                    Date: 2020.03.17
                    Time: 17:19:37
   Serial number:
   Coding: 10150
   Shop #: WSC 00000
Perfect! 8) Thank you.
Because your BCM Max is second hand ... do the following.
1. Remove address 61 (Battery Regul) from the GW installation list. Process.
- Go to address 19. GW installation list.
- Enable address 61 in the GW install list. Save.
- Go back to address 61.
- Code all Bytes at address 61 to 00 Hex.
- Go back to address 19. GW installation list.
- Remove address 61 from the GW installation list. Save.
- Autoscan button, GW installation list, Clear all DTCs.
- New Autoscan. Start. Save.
2. BCM adaptation channels.
- Do this procedure: https://drive.google.com/open?id=0B2nv9 ... 3V1bHBIblU
- Send the resulting log (.CSV file) to my email. If you don't have excel, it doesn't matter, you send the log to my email. :wink:
Once I receive the new autoscan and the BCM adaptation channels log, I will post a new BCM coding here.
By the way, do you want to activate the DRLs through the H7 headlights at this point in the installation?
dcgumis
Post by dcgumis »
To da ci DRL za pomocą świateł mijania, jeśli chcesz:
3DB02BB828F32400923800B02C2B1CD01BC0610F608020 45 200000020000
zakrętowych : 3DB02BB828F32400923800B02C2B1CD01BC0610F608020 49 200000020000
Problemem jest to, że nie jestem pewien. Czy możesz zmierzyć napięcie na T6 / 3 (styk 3 ściemniacza)?
voltage 0.96
Doskonały! 8) Dziękuję Ci.
Ponieważ Twój BCM Max jest używany ... wykonaj następujące czynności.
1. Usuń adres 61 (Battery Regul) z listy instalacji GW. Proces.
- Idź do adresu 19. Lista instalacji GW.
- Włącz adres 61 na liście instalacji GW. Zapisać.
- Wróć do adresu 61.
- Koduj wszystkie bajty pod adresem 61 do 00 Hex.
- Wróć do adresu 19. Lista instalacji GW.
- Usuń adres 61 z listy instalacji GW. Zapisać.
- Przycisk automatycznego skanowania, lista instalacji GW, Kasowanie wszystkich kodów DTC.
- Nowy Autoscan. Początek. Zapisać.
2. Kanały adaptacyjne BCM.
- Wykonaj tę procedurę: https://drive.google.com/open?id=0B2nv9 ... 3V1bHBIblU
- Wyślij wynikowy dziennik (plik .CSV) na mój e-mail . Jeśli nie masz programu Excel, nie ma znaczenia, wyślesz dziennik na mój e-mail.:Puść oczko:[/qoute]
Did i do it right?
Wednesday,18,March,2020,17:51:58:05031
www.Ross-Tech.com
VIN: WVWZZZ6RZAY020707   Mileage: 172240km-107024miles
Address 01: Engine
Cannot be reached
   Revision: --------
   Revision: 00 09 23
1 Fault Found:
            014 - Defective
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 2234 km
                    Time Indication: 0
                    Date: 2020.01.11
                    Time: 17:45:52
   Coding: 3DB02BB828F32400923800B02C2B1CD01BC0610F60802049200000020000
   Coding: 08BC30
   Coding: 08BC30
   Coding: 020000
   Coding: 08BC32
   Coding: 08BC32
4 Faults Found:
00446 - Function Limitation due to Under-Voltage
            002 - Lower Limit Exceeded - Intermittent
                    Fault Status: 00100010
                    Fault Priority: 6
                    Fault Frequency: 2
                    Reset counter: 231
                    Mileage: 172239 km
                    Time Indication: 0
                    Date: 2020.03.18
                    Time: 15:36:29
            000 -  -
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 191
                    Mileage: 172239 km
                    Time Indication: 0
                    Date: 2020.03.18
                    Time: 15:35:40
                    Fault Priority: 3
                    Fault Frequency: 23
                    Reset counter: 232
                    Mileage: 172239 km
                    Time Indication: 0
                    Date: 2020.03.18
                    Time: 15:35:37
03022 - Local databus 4
            012 - Electrical Fault in Circuit - Intermittent
                    Fault Status: 00101100
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 231
                    Mileage: 172239 km
                    Time Indication: 0
                    Date: 2020.03.18
                    Time: 16:09:16
   Coding: 003035
   ASAM Dataset: EV_AirbaWV10BPAVW250 A01001
   ROD: N/A
No ASAM data for: "EV_AirbaWV10BPAVW250" (VW25)
   Coding: 140A00
   Revision: B9080001
   Coding: 002200
2 Faults Found:
                    Fault Priority: 2
                    Fault Frequency: 4
                    Reset counter: 255
                    Mileage: 172239 km
                    Time Indication: 0
                    Date: 2020.03.18
                    Time: 17:14:22
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 232
                    Mileage: 172244 km
                    Time Indication: 0
                    Date: 2020.03.18
                    Time: 17:48:26
   Serial number:
   ASAM Dataset: EV_Mimo_UDS_VDD_RM09 A03709
   ROD: N/A
No ASAM data for: "EV_Mimo_UDS_VDD_RM09" (VW36 *)
   Coding: 10150
   Shop #: WSC 00000
End-------------------------(Elapsed Time: 02:40)--------------------------
Yes ,I did the coding iichel , thank you :D
Your BCM adaptation channels:
	SW:7E0-937-090   HW:7E0-937-090 ---  Cent. Elect.
	Component:BCM PQ25 Max4 H80 0736, Coding:3DB02BB828F32400923800B02C2B1CD01BC0610F60802049200000020000
	Wednesday,18,March,2020,15:26:50:05031
	VCDS Version: Release 15.7.1 (x64)  Data version: 20150904
Channel,,Field 1,Field 2,Field 3,Field 4,
01,0,N/A,N/A,N/A,N/A,
02,,ERROR:,Channel 02,Not,Available,
03,1,N/A,N/A,N/A,N/A,
04,1,N/A,N/A,N/A,N/A,
05,0,N/A,N/A,N/A,N/A,
06,1,N/A,N/A,N/A,N/A,
07,0,N/A,N/A,N/A,N/A,
08,1,N/A,N/A,N/A,N/A,
09,1,N/A,N/A,N/A,N/A,
10,0,N/A,N/A,N/A,N/A,
11,1,N/A,N/A,N/A,N/A,
12,1,N/A,N/A,N/A,N/A,
13,1,N/A,N/A,N/A,N/A,
14,0,N/A,N/A,N/A,N/A,
15,0,N/A,N/A,N/A,N/A,
16,,ERROR:,Channel 16,Not,Available,
17,,ERROR:,Channel 17,Not,Available,
18,,ERROR:,Channel 18,Not,Available,
19,,ERROR:,Channel 19,Not,Available,
20,1,N/A,N/A,N/A,N/A,
21,,ERROR:,Channel 21,Not,Available,
22,1,N/A,N/A,N/A,N/A,
23,1,N/A,N/A,N/A,N/A,
24,0,N/A,N/A,N/A,N/A,
25,0,N/A,N/A,N/A,N/A,
26,,ERROR:,Channel 26,Not,Available,
27,0,N/A,N/A,N/A,N/A,
28,1,N/A,N/A,N/A,N/A,
29,1,N/A,N/A,N/A,N/A,
30,2,N/A,N/A,N/A,N/A,
31,0,N/A,N/A,N/A,N/A,
32,40,N/A,N/A,N/A,N/A,
33,80,N/A,N/A,N/A,N/A,
34,30,N/A,N/A,N/A,N/A,
35,2,N/A,N/A,N/A,N/A,
36,2,N/A,N/A,N/A,N/A,
37,80,N/A,N/A,N/A,N/A,
38,21,N/A,N/A,N/A,N/A,
39,15,N/A,N/A,N/A,N/A,
40,14,N/A,N/A,N/A,N/A,
41,20,N/A,N/A,N/A,N/A,
42,10,N/A,N/A,N/A,N/A,
43,3,N/A,N/A,N/A,N/A,
44,5,N/A,N/A,N/A,N/A,
45,80,N/A,N/A,N/A,N/A,
46,1,N/A,N/A,N/A,N/A,
47,15,N/A,N/A,N/A,N/A,
48,15,N/A,N/A,N/A,N/A,
49,,ERROR:,Channel 49,Not,Available,
50,0,N/A,N/A,N/A,N/A,
51,0,N/A,N/A,N/A,N/A,
52,0,N/A,N/A,N/A,N/A,
53,0,N/A,N/A,N/A,N/A,
54,1,N/A,N/A,N/A,N/A,
55,0,N/A,N/A,N/A,N/A,
56,0,N/A,N/A,N/A,N/A,
57,0,N/A,N/A,N/A,N/A,
58,0,N/A,N/A,N/A,N/A,
59,1,N/A,N/A,N/A,N/A,
60,200,N/A,N/A,N/A,N/A,
61,200,N/A,N/A,N/A,N/A,
62,,ERROR:,Channel 62,Not,Available,
63,21,N/A,N/A,N/A,N/A,
64,1,N/A,N/A,N/A,N/A,
65,1,N/A,N/A,N/A,N/A,
66,2,N/A,N/A,N/A,N/A,
67,24,N/A,N/A,N/A,N/A,
68,0,N/A,N/A,N/A,N/A,
69,1,N/A,N/A,N/A,N/A,
70,20,N/A,N/A,N/A,N/A,
71,0,N/A,N/A,N/A,N/A,
72,0,N/A,N/A,N/A,N/A,
73,0,N/A,N/A,N/A,N/A,
74,0,N/A,N/A,N/A,N/A,
75,0,N/A,N/A,N/A,N/A,
76,0,N/A,N/A,N/A,N/A,
77,0,N/A,N/A,N/A,N/A,
78,0,N/A,N/A,N/A,N/A,
79,0,N/A,N/A,N/A,N/A,
80,0,N/A,N/A,N/A,N/A,
81,0,N/A,N/A,N/A,N/A,
82,0,N/A,N/A,N/A,N/A,
83,0,N/A,N/A,N/A,N/A,
84,0,N/A,N/A,N/A,N/A,
85,0,N/A,N/A,N/A,N/A,
86,0,N/A,N/A,N/A,N/A,
87,0,N/A,N/A,N/A,N/A,
88,0,N/A,N/A,N/A,N/A,
89,0,N/A,N/A,N/A,N/A,
90,0,N/A,N/A,N/A,N/A,
91,0,N/A,N/A,N/A,N/A,
92,0,N/A,N/A,N/A,N/A,
93,0,N/A,N/A,N/A,N/A,
94,0,N/A,N/A,N/A,N/A,
95,0,N/A,N/A,N/A,N/A,
96,0,N/A,N/A,N/A,N/A,
97,0,N/A,N/A,N/A,N/A,
98,,ERROR:,Channel 98,Not,Available,
99,0,N/A,N/A,N/A,N/A,
100,,ERROR:,Channel 100,Not,Available,
101,,ERROR:,Channel 101,Not,Available,
... to 250 Channel
There are values in some BCM adaptation channels that are incorrect for your 6R. (channels: 54, 69, ...)
Wait, I am studying it carefully to later post the correct values and a new BCM coding here.
Do the process of removing Address 61 again, don't skip anything I wrote here. :arrow: viewtopic.php?f=56&t=74062&start=15#p567466
(please copy the text and do it step by step)
Remember that before making a new autoscan you must CLEAR ALL DTCs.
Address 61 should disappear from the GW installation list.
Image for you information:
Not for you dcgumis, it's for others:
Well, to eliminate flickering from the interior lights you showed in the video, you need to do the following:
In Adaptation of 09-Cent Elect (No security access required):
- Change the value of channel 69 from 1 to 0
- Also, at the same time, you need to change channel 54 from 1 to 0.
Once this is done, copy and paste this new BCM coding:
3DB02BB828F32400923800902C2B1CD01BC0610F60802049200000030000
I await a report of the results. (how about the lights work, if you need anything else, or concerns about any of the lights)
Please, if you use the google translator and as much as possible try to interpret the translation, google translations are not always correct.
Sometimes the google translator even skips parts of the text. Please, keep it in mind. Thanks.
dcgumis
Post by dcgumis »
Hi, you're awesome! :o :D I did everything what you recommended. I delete Battery Regul. I did everything you wrote earlier. I did a new encoding BCM. The results below. The interior lights no longer blink :D :D
Thursday,19,March,2020,18:49:38:05031
www.Ross-Tech.com
VIN: WVWZZZ6RZAY020707   Mileage: 172250km-107031miles
Address 01: Engine
Cannot be reached
   Revision: --------
   Revision: 00 09 23
1 Fault Found:
            014 - Defective
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 2234 km
                    Time Indication: 0
                    Date: 2020.01.11
                    Time: 17:45:52
   Coding: 3DB02BB828F32400923800902C2B1CD01BC0610F60802049200000030000
   Coding: 08BC30
   Coding: 08BC30
   Coding: 020000
   Coding: 08BC32
   Coding: 08BC32
1 Fault Found:
            000 -  -
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 195
                    Mileage: 172252 km
                    Time Indication: 0
                    Date: 2020.03.19
                    Time: 18:47:02
   Coding: 003035
   ASAM Dataset: EV_AirbaVW10BPAWV250 A01001
   ROD: N/A
No ASAM data for: "EV_AirbaVW10BPAWV250" (VW25)
   Coding: 140A00
   Revision: B9080001
   Coding: 002200
1 Fault Found:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 172252 km
                    Time Indication: 0
                    Date: 2020.03.19
                    Time: 18:47:00
   Serial number:
   ASAM Dataset: EV_Immo_USD_VDD_RM09 A03709
   ROD: N/A
No ASAM data for: "EV_Immo_USD_VDD_RM09" (VW36 *)
   Coding: 10150
   Shop #: WSC 00000
