I don't yet, but I have an 8000k front and rear module to fitexantas wrote: Wed Jan 29, 2020 7:41 pm Then your car does have OPS.
Do you have a VCDS auto scan with the current configuration of your car?
There you can see if the ops module you have, support front parking sensors.
Front parking sensors
Aquavalver
- Drives: 2013 Polo Blue GT
Re: Front parking sensors
The low versions were only installed in the 6R family of china, india, and I think in russia too. Your BlueGT has the high version.Aquavalver wrote: Wed Jan 29, 2020 10:09 amGood shout! They have a front one and although I don't need it, it looks like the parking control module is Valeo.exantas wrote: Wed Jan 29, 2020 12:15 am Have you checked aliexpress?
https://www.aliexpress.com/item/-/32980 ... 2e0euM4HGV
But is says: "This kit is only for Polo with high version radar sensors(support ops).if your rear radar sensors are low version which do not support OPS,please do not order." Not sure what mine is! Didn't know there were more than one version!
This is what I did in my 6R LHD for the front parking sensors in case it can be useful for someone.
Note: Sometimes the links do not work correctly and direct you to something different, look in the posts above or below on the subject in which you are interested. In the topic dedicated to my 6R there is some witchcraft ...
viewtopic.php?f=56&t=58703&start=4305#p533766
viewtopic.php?f=56&t=58703&start=4320#p533884
viewtopic.php?f=56&t=58703&start=4395#p538024
viewtopic.php?f=56&t=58703&start=4395#p538090
viewtopic.php?f=56&t=58703&start=4455#p538948
viewtopic.php?f=56&t=58703&start=4470#p539361
viewtopic.php?f=56&t=58703&start=4485#p539857
viewtopic.php?f=56&t=58703&start=4515#p540623
viewtopic.php?f=56&t=58703&start=4530#p540784
viewtopic.php?f=56&t=58703&start=4530#p540844
viewtopic.php?f=56&t=58703&start=4530#p540845
viewtopic.php?f=56&t=58703&start=4530#p540886
viewtopic.php?f=56&t=58703&start=4545#p540977
viewtopic.php?f=56&t=58703&start=4560#p541105
VCDS
Address 10: Park/Steer Assist (J446) Labels:| 7E0-919-475.clb
Part No SW: 7E0 919 475 AA HW: 7N0 919 475
Component: PARKHILFE 8K H06 0212
Revision: -------- Serial number: 28231708304294
Coding: 308001
Shop #: WSC 02739 790 50316
ASAM Dataset: EV_VW75XParkAssis8K 001012
VCID: 71BF28B8612EF1EF369-8024
