Page 2 of 2
Re: Cruise Control Emulator
Posted: Wed Apr 22, 2026 10:16 am
by ciclo
The concept behind this T6 connector was clear, but I insist, what do you intend to do?
With the diagram and a multimeter, you can determine the function of each pin on that T6 connector.
Posted: Thu Apr 23, 2026 7:48 pm
by Screw_Diver
some one speaks russian , or what kind of language is this?
Posted: Fri Apr 24, 2026 2:15 am
by ciclo
This video was created by a valued user of this forum, Drive2.ru, and I assume a few others as well. (click LIKE! :))
He shows/demonstrates, using measurement values, that a model of MQB multifunction buttons (ACC) works on the PQ25 platform without any adapter/emulator using BCM version 1S0.
Specific coding and a specific LIN are required.✌
Therefore, the only requirement, or magic touch, is that your ECU also understands the signal from those multifunction buttons. πŸ˜„
There are many beautiful and easy-to-understand languages, especially one of the best languages ​​on this planet.
Posted: Fri Apr 24, 2026 1:36 pm
by Screw_Diver
ciclo wrote: Wed Apr 22, 2026 10:16 am The concept behind this T6 connector was clear, but I insist, what do you intend to do?
Connect this pins direct to module
Posted: Fri Apr 24, 2026 7:51 pm
by ciclo
I understand, but I don't quite get it.
This CCE module is meant to allow you to operate the cruise control from the multifunction buttons on the steering wheel.
However, I don't think what you're suggesting is a good idea. The turn signal/cruise control stalk/lever is a movable part and is logically better connected as it was designed.πŸ€·β€β™‚οΈ
Posted: Sat Apr 25, 2026 12:17 pm
by Screw_Diver
your T10 Coupling , your way 8E0971980 and 1K0971992
i haveT 6 😁 and my LIN-Bus also 30/15
Posted: Sat Apr 25, 2026 6:16 pm
by ciclo
When you finish your divine work, show it to the world for them to judge... Please use your own photos, not stolen ones, and amaze us with a clear explanation of how your system will work in any situation. Thanks!
Posted: Sun Apr 26, 2026 12:28 pm
by Screw_Diver
But of course, for the 4 plus 2 plug contacts LIN (in out) and a ground connection and plus, I don't need any kindergarten photos. The pictures I have already sent say it all! Incidentally, I have already written that the T6 plug is connected directly to the cables from the CC module. A line T41/10 for the LINBUS and T41/9 PLUS connected. Where is your problem? :mrgreen:
Posted: Sun Apr 26, 2026 3:38 pm
by ciclo
In this international kindergarten, we love not to fuel any potential discrimination against anyone, and therefore, we want children, adults, and enthusiasts of all backgrounds and nationalities to be able to repair or improve their vehicles easily, simply, and in the most affordable way possible.
-What makes you think this is a kindergarten? So why are you asking questions in this kindergarten?
-Why are you taking pictures from other places without crediting their authors/creators?
-Why don't you want to 'share' your wisdom?
-Honestly, I apologize if anything I told you that is true bothered you, but I would like to know what bothered you more, that I told you that you were a thief or a bungler/botcher person?
You don't need to answer this previous questionnaire, we all imagine the possible reasons:
-Superiority complex: An unconscious mechanism in which a person projects an image of grandeur to hide their own feelings of inferiority.
-Narcissism: A personality disorder or trait characterized by an excessive need for admiration, a lack of empathy, and a firm belief that one is special and superior to others.
-Arrogance and pride: Attitudes of contempt toward others based on an exaggerated sense of one's own importance or abilities.
-Snobbery: The attitude of a person who recreates and adopts the mannerisms of a high social or intellectual class to which they do not belong, looking down on those they consider "inferior."
Please understand that as a moderator, I will not tolerate disrespect toward the name of this kindergarten (an internationally recognized institution) or any of its users. Thank you.
