Re: When should my air con have its first service?
Posted: Thu Jun 11, 2020 10:49 pm
So will my warranty be void if i take my car for the 10k service to a non vw garage?
Probably the Worlds greatest Polo resource
https://uk-polos.net/
Monkeyhanger I agree with you my dad had a rover 75 from new and never had the air conditioning regassed into the car was 9 years old. If you run the air conditioning regularly it shouldn’t lose the gas.monkeyhanger wrote: Tue Jun 09, 2020 6:57 pm If it doesn't blow very cold it needs charging. If it does but it smells a bit feisty, it needs an antibacterial treatment.
Otherwise, save your money.
If you use the aircon regularly the seals won't dry out and leak refrigerant for many years (5 or 6).
There is a certain amount of aircon activity happening in the background all the time, most noticeably during the early part of your journey and more so when windscreen rather than cabin blowing is selected. If you look in "convenience consumers" screen within the "car" set of screens on the infotainment system, you'll see a red bar that measures in 1/4 gallon per hour. Aircon on mine (even when I don't have aircon selected).runs at about 1/3 of that bar, contributing to 1/12 of a gallon per hour.Steve_2019 wrote: Fri Jun 12, 2020 2:34 amMonkeyhanger I agree with you my dad had a rover 75 from new and never had the air conditioning regassed into the car was 9 years old. If you run the air conditioning regularly it shouldn’t lose the gas.monkeyhanger wrote: Tue Jun 09, 2020 6:57 pm If it doesn't blow very cold it needs charging. If it does but it smells a bit feisty, it needs an antibacterial treatment.
Running AC systems frequently was very relevant back in the days when the compressors were not run all the time, ie there was a clutch built into the drive pulley, for at least the past 15 years all new models of VW Group cars have been fitted with variable displacement compressors and so they get run at all times but at low displacement when no chilling is required, so all system surfaces are getting coated with system oil and so leakage is minimal regardless if the AC is used or not. Though there will always be slight, but acceptable leakage in any automobile AC chiller systems because the compressors can not be hermetically sealed and the necessary plastic flexible connecting pipes will always allow some gas to pass across their material. It does make you wonder if with less damaging gas being used, less effort is being taken to keep leakage to a minimum.Steve_2019 wrote: Fri Jun 12, 2020 2:34 amMonkeyhanger I agree with you my dad had a rover 75 from new and never had the air conditioning regassed into the car was 9 years old. If you run the air conditioning regularly it shouldn’t lose the gas.monkeyhanger wrote: Tue Jun 09, 2020 6:57 pm If it doesn't blow very cold it needs charging. If it does but it smells a bit feisty, it needs an antibacterial treatment.
