Stage 3
Re: Stage 3
You can't, there are mechanicals parts forcing the budack cycle, even the golf 7 with the 3B perf version has less potential. You better try your luck with the facelift (ea 888 gen 4) or swap the whole engine with the old GEN3 performance ... With the gen 3 with mpi ports, you can perform the bi injection tuning for more power
Re: Stage 3
surely you would be able to change the timing on the engine and uprate a bit of the internals to make it act like the normal gen 3? the issue is it may cost as much as buying a golf
