Oh dear looks like am out of luckiichel wrote: Wed Feb 15, 2023 2:53 pm I don't think it's possible to read it: https://mhhauto.com/Thread-Where-is-the ... K7-Cluster
Help needed for Cluster swap on a Polo 6C
Re: Help needed for Cluster swap on a Polo 6C
Anybody have a guide on how to retrofit lowline camera? I got the wiring but there is no instructions on where the wiring goes?
All sorted and got the RVC working.
Wiring was very easy
VCDS just 1 tick to get it working
Well done. This means all your problems solved?
Thanks iichel
Yes all problems solved. Am much happy with the DSG after changing the hub. Car cruises absolutely fine and goes into D7 on Highway.
If am keeping car then will add F/R parking sensors
Hi mate,POLOZ wrote: Tue Feb 14, 2023 10:03 pm Well finally sorted out the clusterEnded up getting 6C0920940A and a very kind gentlemen came and sorted out the coding. Correct speed output is now shown
No errors or faults in VCDS
I am looking to do the same procedure. I right now have a cluster in KMH and would like to purchase one in MPH. Did you just buy a used mph cluster on eBay, then get it adjusted for your car? I am worried about the immobiliser's not matching and the vehicles milage being lost/confused. If possible could you link me to this gentleman you used?
Many thanks
Also I think you can read the EEPROM on your old cluster, you need to read it directly off the processor, this can be done using a device such as Xprog. Let me know your old clusters part number and maybe I can clarify a bit more.
Hi Pal, yes I bought a used Cluster from Ebay that matched the vehicle in question.mubmoh wrote: Sat Apr 22, 2023 5:13 amHi mate,POLOZ wrote: Tue Feb 14, 2023 10:03 pm Well finally sorted out the clusterEnded up getting 6C0920940A and a very kind gentlemen came and sorted out the coding. Correct speed output is now shown
Many thanks
You will need somebody with Online access tool i.e. ODIS. My recommendation will be to find somebody local who can do the swap for you and is experienced.
I was mislead many times by a person in wales and I wasted time going back and forth.
