UK-POLOS.NET - THE VW Polo Forum • Help needed for Cluster swap on a Polo 6C - Page 2
Page 2 of 2
Re: Help needed for Cluster swap on a Polo 6C
Posted: Wed Feb 15, 2023 4:09 pm
by POLOZ
iichel wrote: Wed Feb 15, 2023 2:53 pm I don't think it's possible to read it: https://mhhauto.com/Thread-Where-is-the ... K7-Cluster
Oh dear looks like am out of luck :)
Posted: Sat Feb 18, 2023 1:06 pm
by POLOZ
Anybody have a guide on how to retrofit lowline camera? I got the wiring but there is no instructions on where the wiring goes?
Posted: Mon Feb 20, 2023 1:19 am
by POLOZ
All sorted and got the RVC working.
Wiring was very easy
VCDS just 1 tick to get it working
Posted: Mon Feb 20, 2023 12:41 pm
by iichel
Well done. This means all your problems solved?
Posted: Mon Feb 20, 2023 2:58 pm
by POLOZ
iichel wrote: Mon Feb 20, 2023 12:41 pm Well done. This means all your problems solved?
Thanks iichel
Yes all problems solved. Am much happy with the DSG after changing the hub. Car cruises absolutely fine and goes into D7 on Highway.
If am keeping car then will add F/R parking sensors
Posted: Sat Apr 22, 2023 5:13 am
by mubmoh
POLOZ wrote: Tue Feb 14, 2023 10:03 pm Well finally sorted out the cluster :) Ended up getting 6C0920940A and a very kind gentlemen came and sorted out the coding. Correct speed output is now shown :D
No errors or faults in VCDS
Hi mate,
I am looking to do the same procedure. I right now have a cluster in KMH and would like to purchase one in MPH. Did you just buy a used mph cluster on eBay, then get it adjusted for your car? I am worried about the immobiliser's not matching and the vehicles milage being lost/confused. If possible could you link me to this gentleman you used?
Many thanks
Also I think you can read the EEPROM on your old cluster, you need to read it directly off the processor, this can be done using a device such as Xprog. Let me know your old clusters part number and maybe I can clarify a bit more.
Posted: Wed May 03, 2023 12:24 am
by POLOZ
mubmoh wrote: Sat Apr 22, 2023 5:13 am
Hi mate,
Many thanks
Hi Pal, yes I bought a used Cluster from Ebay that matched the vehicle in question.
You will need somebody with Online access tool i.e. ODIS. My recommendation will be to find somebody local who can do the swap for you and is experienced.
I was mislead many times by a person in wales and I wasted time going back and forth.
