UK-POLOS.NET - THE VW Polo Forum • 6r GTI factory Bi-Xenon Issue - Page 2
Page 2 of 2
Re: 6r GTI factory Bi-Xenon Issue
Posted: Fri Jun 09, 2023 9:20 am
by Maarten
But if the shutter and the bulb work, it should work correctly right?
1 bulb for dipped and high.
The shutter blocks the bottom part when only dipped are required AFAIK
Or am I missing something?
(this was how it worked in my home made projector headlights on my 9N3, H1 Xenon bulb for dipped and highbeam changed by the shutter)
Posted: Fri Jun 09, 2023 11:37 am
by ciclo
That's exactly how it works ("bi-xenon") 👍,
so it's hard to determine what's causing the lamp to go off when the shutter is activated.🤷‍♂️
Posted: Fri Jun 09, 2023 9:25 pm
by Maarten
Maybe a faulty wire?
Double ground?
Short to plus or ground?
I would suggest to check the loom to the non working side.
Maybe when activating high beam the lamp loses power?
Posted: Sat Jun 10, 2023 2:34 am
by ciclo
