Att: Ciclo... not sure where to put this....
Mookistar
Drives: Passat GTE
Re: Att: Ciclo... not sure where to put this....
Post by Mookistar »
Link access fixed. Sorry about that.
I was finally able to review/study this thread with the ETKA and images on the net (somewhat confusing due to poor clarity).
It was just an incompatibility issue with the C ring you installed at the beginning.
I bought the 2 rings of the F version along with the 2 stalks suitable for my Golf 'FL' (mk 7.5) from the beginning, and once everything was coded, I did not have any problems related to the operation of the heated steering wheel. I remember that together with the ETKA I had to look at many images on the net (all possible ring/stalk sets) to decide that the right ring was the F version.
Everything that can be coded works perfectly (100%), that is, both through the button on the multifunction steering wheel and in the infotainment system (automatic -recommended, perfect-, heating levels, ON/OFF).You can see it in the videos I made in my thread.
The most interesting thing about this thread 'for the rest of the world' and MQB 'FL' models is that there is compatibility between the F rings and the original stalks, that is, that the heated steering wheel will work without changing the original stalks... hmm... in the same way you did it (NOT 100%?).
Mookistar
Drives: Passat GTE
Post by Mookistar »
This is useful to know as I can attempt to sell the "spare" ring now. And it's nice to be able to contribute to the knowledge base on the F compatibility.
Once question I did have, you fitted a wheel with push buttons to one of yours, what "heated wheel type" did you choose for this in HVAC 08?
I have MIB3 and matched coding seen elsewhere to choose the "LRH Gen2 mod longpush" With this wheel there is no on screen button or control. I haven't tried switching it to any of the other wheel types as I'm terrified to touch it after my ordeal. But I did notice when messing about that "LRH Gen2" gave the on screen button. Is this what you selected? I assume I can't use this?
In the following link you can see the Coding that I applied at that time... :arrow: viewtopic.php?p=589445#p589445
This is my current coding for HVAC 08:
Byte00:
0000 0000 ($00)
Byte01:
0000 0010 ($02)
Byte02:
0000 0000 ($00)
Byte03:
0000 0011 ($03)
Byte04:
0010 0000 ($20)
Byte05:
0000 0001 ($01)
Byte06:
0001 0000 ($10)
Byte07:
0000 1101 ($0D)
Byte08:
0001 0001 ($11)
Byte09:
0001 0101 ($15)
Byte10:
0000 0000 ($00)
Byte11:
0100 1100 ($4C)
Byte12:
0000 0000 ($00)
Byte13:
0001 1000 ($18)
Byte14:
0101 0100 ($54)
Byte15:
0010 1010 ($2A)
[LN]_Vehicle variant:	[VN]_Short rear (multivan)
[LN]_Chassis version:	[VN]_A_platform
[LN]_Brand:	[VN]_VW
[LN]_Steering side of vehicle:	[VN]_Left-hand drive vehicles
[LN]_Type of fuel:	[VN]_Petrol
[LN]_type_of_drive:	[VN]_combustion_engine
[LN]_Number of cylinders:	[VN]_3 cylinder
[LN]_Roof:	[VN]_Standard
[LN]_Save air recirculation status at terminal 15 off:	[VN]_resttime_dependent_storage
[LN]_Credit_circulating_air:	[VN]_Not_activated
[LN]_glazing:	[VN]_glazing_green
[LN]_Additional_Heater:	[VN]_not installed
[LN]_Auxiliary_heating:	[VN]_not installed
[LN]_Sunlight_sensor:	[VN]_verbaut
[LN]_cinematics_ram_air_air_recirculation:	[VN]_air_recirculation_ram_air_flap_positioning_motor
[LN]_refrigerant:	[VN]_HFO1234yf
[LN]_Climate_style:	[VN]_display
[LN]_Climate zones second seat row:	[VN]_not installed
[LN]_coolant_shut_off_valve:	[VN]_not installed
[LN]_Camera heating:	[VN]_installed
[LN]_Activating_start_stop_function:	[VN]_aktive
[LN]_sensor_for_air_quality_outside:	[VN]_installed
[LN]_sensor_for_air_humidity_inside:	[VN]_installed
[LN]_sensor_for_air_humidity_outside:	[VN]_installed
[LN]_remotestart:	[VN]_not installed
[LN]_seat_ventilation_rear:	[VN]_not installed
[LN]_operating_unit_rear:	[VN]_not installed
[LN]_indirect_ventilation:	[VN]_not installed
[LN]_Windshield defroster:	[VN]_not installed
[LN]_steering wheel heater:	[VN]_installed
[LN]_Heated_steering_wheel_steps:	[VO]_mehrstufig
[LN]_Frequency_shift:	[VN]_Not_activated
[LN]_Blower display during auto mode:	[VN]_activated
[LN]_Blower_characteristic:	[VN]_Setup_normal
[LN]_Temperature_setup:	[VN]_Normal_setup
[LN]_fresh_air_blower_front:	[VN]_According to function preconditions
[LN]_Reinforced_overshoot_heating_mode:	[VN]_Not_activated
[LN]_Heated_steering_wheel_automatic_mode:	[VO]_Aussentemperatur
[LN]_Compressor_start_reduction:	[VN]_activated
[LN]_Seat_Heating_rear:	[VN]_not installed
[LN]_Reduction of window misting outside at high humidity:	[VN]_close over characteristic
[LN]_Blower_logic_manual_adjustment:	[VN]_Blower stage, absolut
[LO]_Heated_steering_wheel_version:	[VO]_LRH_Gen_2
[LN]_menu_seat:	[VN]_display
[LN]_magnetic_clutch_air_conditioning_compressor:	[VN]_not installed
[LN]_personalization:	[VN]_activated
[LN]_Filtering interior air:	[VN]_installed
Mookistar
Drives: Passat GTE
Post by Mookistar »
Thanks, once the PTSD subsides I'll have a play with the steering wheel types.
...feel free to ask me here about any other coding/adaptations you need by then.
patil
Post by patil »
Hi Mike.. did you ever wonder why 5Q1 "c" slipring didn't work for you?
Mookistar
Drives: Passat GTE
Post by Mookistar »
As per Ciclo’s post the assumption is it wasn’t compatible and that software version F is required.
Happy to sell it to you if you like 😂😂😂
patil
Post by patil »
Mookistar wrote: Sat Jan 13, 2024 8:56 pm As per Ciclo’s post the assumption is it wasn’t compatible and that software version F is required.
Thanks but no thanks..5Q1 C slipring doesn't work in my T-roc either😁
Devil is in the details :wink:
Mookistar
Drives: Passat GTE
Post by Mookistar »
My wheel came from a T-roc so I’d suggest getting an F version if you can. Use the sheet I shared prior to identify an assembly with the F spring then search for that code as well. I picked mine up for £60!!
patil
Post by patil »
Mookistar wrote: Sat Jan 13, 2024 9:06 pm My wheel came from a T-roc so I’d suggest getting an F version if you can. Use the sheet I shared prior to identify an assembly with the F spring then search for that code as well. I picked mine up for £60!!
It doesn't matter from where the wheel comes from!
I did my own internal research on sliprings before you posted your problem. This 5Q1 C slipring is peculiar due to the fact that, it was installed with combi switch in which Cruise control buttons are installed in stalks ( DE/DG/DH etc..) and not on wheel buttons.
5Q1 B/F/K/L.. heated these sliprings are compatible with combi switches in which Cruise buttons are from wheel 😊
Mookistar
Drives: Passat GTE
Post by Mookistar »
Interesting. The cruise functions on wheel worked fine, just not the heat.
Lesson learned.
