Page 2 of 3
Re: Coding ESP9.0i E03 0003
Posted: Thu May 30, 2024 4:55 pm
by danterak
Coding rejected
Posted: Thu May 30, 2024 4:58 pm
by iichel
just to check
LHD
Polo 6R hatchback
1.2 TDI
no start/stop
manual gearbox (obviously)
Posted: Thu May 30, 2024 5:01 pm
by danterak
Yes , that's it
Posted: Thu May 30, 2024 5:04 pm
by iichel
What do you think? Yellow fields are input parameters
Posted: Thu May 30, 2024 5:12 pm
by danterak
Is there a way to know the parameters?
Posted: Thu May 30, 2024 5:14 pm
by iichel
Posted: Thu May 30, 2024 5:20 pm
by iichel
You can try to make a coding with TPMS/HHC/ESP button/XDS off
21DD2485412800C58415246D825300420100
Posted: Thu May 30, 2024 5:31 pm
by danterak
The code is still rejected
One question, to your knowledge, can the ECU accept the coding with the engine ECU errors?
Posted: Thu May 30, 2024 6:04 pm
by iichel
yes it can
Posted: Thu May 30, 2024 6:34 pm
by danterak
I think the unkown parameters are the byte 16 and 17.
What is the best way to find the corrent coding?
Posted: Thu May 30, 2024 6:41 pm
by iichel
they best way would have been for you to save old coding before you put in a wrong instrument cluster
Posted: Thu May 30, 2024 6:45 pm
by danterak
I didn't know that the ABS would lose the coding when trying another cluster
Posted: Sun Jun 02, 2024 6:19 am
by prtvrk
danterak wrote: Thu May 30, 2024 6:45 pm
Perhaps there's a prior autoscan somewhere?
Posted: Mon Jun 03, 2024 4:26 am
by danterak
I searched, but there aren't any with the ABS already coded.
Posted: Tue Jun 04, 2024 9:17 pm
by Shakeeb1
iichel wrote: Thu May 30, 2024 4:32 pm
Cool, try this ABS coding: 21DD2485412800C58415246D825300421905
Any chance you can help me
Ecu changed originally as suspected ecu faulty but original ecu and clocks were put back
Polo 6R 1.2 CGPA Manual with hill hold but no tpms
Vin number: WVWZZZ6RZAU055630
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 AF HW: 6R0 907 379 AF
Component: ESP8.2i front H05 0005
Revision: --------
Coding: 000000000000000000000000000000000000
Shop #: WSC 31414 790 31414
VCID: 020B3F0F990F189BD5-8056
3 Faults Found:
03306 - Coding Not Valid
000 - -
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 6
Reset counter: 96
Mileage: 182831 km
Time Indication: 0
Date: 2024.06.04
Time: 02:32:15
Hex Value: 0x0002
Hex Value: 0x0002
Hex Value: 0x32E7
Hex Value: 0x25AF
Hex Value: 0x00FF
Hex Value: 0x7F7F
Hex Value: 0x7F00
00778 - Steering Angle Sensor (G85)
005 - No or Incorrect Basic Setting / Adaptation
Fault Status: 01100101
Fault Priority: 0
Fault Frequency: 2
Reset counter: 96
Mileage: 182831 km
Time Indication: 0
Date: 2024.06.04
Time: 02:37:02
Hex Value: 0x0007
Hex Value: 0x0002
Hex Value: 0x3251
Hex Value: 0x1BAF
Hex Value: 0x00FF
Hex Value: 0x7F7F
Hex Value: 0x7F00
01042 - Control Module; Not Coded
000 - -
Fault Priority: 0
Fault Frequency: 2
Reset counter: 96
Mileage: 182831 km
Time Indication: 0
Date: 2024.06.04
Time: 02:37:02
Hex Value: 0x0007
Hex Value: 0x0002
Hex Value: 0x3211
Hex Value: 0x14AF
Hex Value: 0x00FF
Hex Value: 0x7F7F
Hex Value: 0x7F00
