Skoda Rapid BCM Max Adaptation. 6R093708P upgrade 7h0937090d BUT!
Re: Skoda Rapid BCM 6R093708P upgrade 7h0937090d BUT!
Have you checked that this AUTO switch fits correctly in your SK Rapid? Please take a photo already installed.
I'm afraid that switch is for PQ26/MQB, it won't work for PQ25, the electronics are not compatible.
SK PQ25 viewtopic.php?p=558939#p558939
- omerkartal
- Drives: Skoda Rapid & VW Tiguan 5N
Türkiye also has this piece. I put it on and it fits. I'm away from the car now.ciclo wrote: Tue Dec 10, 2024 1:54 pm Have you checked that this AUTO switch fits correctly in your SK Rapid? Please take a photo already installed.
The headlight switch you shared is not sold in Türkiye. Skoda Rapid appears on Aliexpres.
Sure, I'm sure it fits, but correctly?
I don't know what the internal shape of the Rapid PQ25 dashboard is where the switch fits, but on all VW Group PQ25s the AUTO letters are on the top of the switch.
If it fits crooked, it's not compatible.
The connector that corresponds to it is a red 10 pin connector (not the usual black one we use on PQ25), it indicates that it is for other models, PQ26/MQB.
I've seen it on Ali, it says for Rapid, but which one? PQ25 or PQ26?
Very few Ali sellers know what they sell, they don't have the slightest idea.
I even think that I am the only one on the entire planet who knows absolutely everything about this model of switches, I even know of some atrocities that are sold on Ali with VW original part number for one platform and then turn out to be for another ...which implies... blah, blah, blah...
- omerkartal
You are so right. Well, can you find the appropriate key from the chassis? I also agree that you are a geniusciclo wrote: Tue Dec 10, 2024 2:42 pm Sure, I'm sure it fits, but correctly?
- omerkartal
Hello again, I added the pictures of the headlight switch to Google Drive. I think what you said is true, this switch is not PQ25. I tried it on a Skoda Scala brand vehicle the other day and it worked. Can you tell me the part number of the headlight switch on your Polo? I think its substructure is PQ25.
Ok, this is very interesting, the switch you show fits perfectly. It is not turned/twisted/croocked, so it is the correct one in terms of the way it fits into the dash, even though the AUTO position icon is not on the top.
Now you'll have to verify if it is electronically compatible once the wiring adaptation for BCM Max has been carried out. Obviously you should first test with AUTO switches that we know work correctly (ALL functions) for the PQ25, it doesn't matter if they are VW or SK, but the ones we know work would not be compatible with your dashboard.
I highly doubt the AUTO switch you have is compatible for all platforms, although it would be a pleasant surprise if it were.
You have a big challenge ahead of you, and although it is totally possible, you or your electronics technician friend are going to have to fight hard.
I will soon begin to explain my interpretation for the adaptation of BCM Max wiring and Auto lights for your 2014 SK Rapid Spaceback PQ25.
By the way, what type of headlights does your SK Rapid have, H7 or H4?
i think H7 + H15 (ntegrated DRL into high beam)
Main headlamps
8JM
Twin headlamps for driving on the
right, with integrated high beam
Main headlamps
8JM
Doors
0A2
4 doors
Front stabilizer bar
0AS
Rear stabilizer bar
0BC
Rear stabilizer bar
CO2 variant
0C0
Standard
Vehicle class differentiation
powertrains/platform parts
0CA
Vehicle class differentiation -605-
Installation differentiation for
vehicle parts
0EG
dual-clutch transv. transmission DQ200
-- vehicle components --
Fuel systems
0F9
Cooled fuel system for diesel engine
Differentiation for manufacturing
process
0FA
Standard manufacturing sequence
Rear axle
0N5
Standard rear axle
Tailpipes
0P0
Rear exhaust tailpipe (standard)
Nameplate set
0PZ
Nameplate set "R"
Ignition locking system/electronic
steering column lock
0RA
Without ignition/starter switch locking
system
Special labels
0SS
Labels in English and French
foot mats
0TD
Front and rear floor mats
Owner's manuals
0XA
Information kit in Turkish
Climate zones
0Y2
Tropical zones
Weight category for rear axle
0YC
Weight range 3
installation control only, no
requirement forecast
Brand-specific/class-specific features
0Z6
SKODA brand-specific/class-specific
features
Brake systems
1AT
Electronic stability control (ESC)
Antifreeze agent
1C1
Antifreeze up to -25 degree Celsius
tolerance up to -30 degree C
Trailer hitch
1D0
Without trailer hitch
Activated carbon canister/gasoline
particulate filter
1E0
Without activated carbon canister
Identification labels
1EX
Special identification label for EC
for M1 passenger vehicles
Spare wheel/breakdown kit
1G1
Space-saving spare wheel
Shock absorption in rear
1JA
Rear shock absorption, basic version 1
Rear brakes
1KT
Disc brakes in rear (Geomet D)
Steering system
1N3
Speed-related variable steering assist
(Servotronic)
Wheel trims
1NL
Trims for alloy wheels
Lockable wheel bolts
1PF
Standard wheel bolts
Vehicle tools and jack
1S6
Tool kit and heavy-duty jack
Front-end underbody cladding
1SA
Without additional front underbody guard
First aid kit/warning triangle
1T0
Without first aid kit and warning
triangle
Cool box
1W2
Glove compartment cooling system
Fuel filling volume
1Z2
Increase in initial standard fuel
filling
Front brakes
1ZC
Disc brakes in front (Geomet D)
Delivery equipment
2A0
Without delivery equipment
Sound insulation measures for outside
noises
2B1
Additional exterior noise insulation
Steering column systems
2C5
Axial and vertical adjustable steering
column
Tank filler neck for unleaded fuel/fuel
type
2G5
Filler neck module 1 without insert
Bumper
2JG
bumper in colour of vehicle
Fuel tank material treatment
2LA
Fuel tank without special material
treatment
Steering wheels
2PP
Leather-wrapped multi-function steering
wheel
Fresh air intake for vehicle interior
(with particle filter)
2V5
Fresh air intake system with combination
filter
Fuel cap/fuel filler door closing
mechanism
2W6
Fuel filler cap
Additional tires (snow tires)
2WA
without spare tyre
Additional child seat anchorage
3B3
Child seat anchors
Center seat belts in rear
3C7
Three-point inertia reel belt for rear centre seat
Partition
3CA
with no partition
Roof insert/convertible top
3FA
Without roof insert (standard roof)
Luggage/load compartment floor in rear
3GA
Without luggage compartment floor
Backrest release
3H0
Without backrest release for front seats
Head restraints
3J1
Hight-adjustable head restraints for
front seats
Seat adjustment
3L3
Manual height adjustment for front seats
Flaps/storage compartments in the
luggage compartment
3N3
Storage compartments in trunk
Rear seats
3NZ
Rear bench seat, not split, split backrest, folding
Head restraints in rear
3Q6
3 rear head restraints
Rear doors/tailgate/trunk lid
3RC
Tailgate with window aperture
Sound insulation measures for interior
noises
3W6
Additional interior noise suppression
Outer seat belts in rear
3ZB
3-point seat belts, outer rear with ECE
label
seat heater
4A0
without seat heater
Door and side trim panels
4AM
door and side trim panels
Protective side molding
4B0
with no protective side strip
Windshield
4GF
Heat-reflecting windshield
Door and tailgate/trunk lid locking
mechanism
4I2
Central locking w/ radio remote control,
interior controls, without SAFELOCK
Side and rear windows
4KF
heat protective glass for door, side and rear
windows, darkened from b-pillar
Breakaway interior rearview mirror
4L2
Breakaway interior rearview mirror,
dimming
Controls (steering wheel/steering column)
4LC
Controls for radio and telephone
Beverage holders
4M4
Beverage holder in center console
Rear floor panel platform module
4P4
Rear floor panel module, type 5
Restraint systems in front
4QU
3-point seat belts in front, with
pretensioner and electric height
adjustment
Window regulator
4R3
Power windows with comfort operation
Vanity mirror on the left
4SB
Vanity mirror left
Vanity mirror on the right
4TB
Vanity mirror, right
Luggage net/bag on backrest(s)
4U4
Luggage pocket on backrest
Airbag
4UF
Airbag for driver and front passenger
with front passenger airbag
deactivation
Side airbag
4X3
Side airbag in front, with curtain
airbag
Door/side storage compartment in rear
4YB
Storage compartment in rear
(door and side panel)
Glove compartment
4Z5
Glove compartment door with light
Decorative trims
4ZA
Standard decorative trims
Body measures
5C8
Additional measures for the body
Carrier frequency for remote control
5D1
Carrier frequency 433.92 to 434.42 Mhz
Rear spoiler
5J0
Without rear spoiler
Paint preservation/transport protection
5K5
Transport protection film with
additional transport protection measures
Grab handles at roof frame
5N2
Folding grab handles at roof frame
Right exterior mirror
5RQ
Exterior mirror, right, convex
Left exterior mirror
5SJ
Left exterior mirror, convex
Fire extinguisher
6A0
without fire extinguisher
Center armrest
6E3
Center armrest in front
Additional body protective covers, side
6EA
Without additional side body covers
(stone guard)
Components with special surfaces
6FF
Exterior mirror housing and various attachments
colour coded to vehicle
Door handles/inserts
6JE
Chromed door handles (smooth)
Radiator grille
6KJ
Radiator grille with chrome molding
Fresh air system/vents
6LH
Comfort vent
Tie down straps/net/pocket
6M4
Load protection system
Hand brake lever
6PE
Hand brake lever handle in leather
Gearshift knob/gearshift handle
6Q2
Gearshift knob/handle in leather
Gearshift boot/gearshift trim
6R1
Leatherette gearshift lever boot
Luggage compartment floor covering
6SJ
Luggage compartment mat (rubber/fabric)
Exterior mirror adjustment
6XD
Exterior mirrors, power-adjustable/
heated
Theft protection system
7AA
Electronic immobilizer
Thermal energy storage system/auxiliary
heater
7E0
Without heat accumulator/auxiliary
heater
Tire pressure monitoring system
7K6
Start-stop system/regenerative braking
7L3
Without start-stop system without
Scuff plates
7M5
Without impact protection film for door sill
Emission standard
7MJ
Emission standard EU5 plus
Storage compartment
7N2
spectacles holder
Lumbar support in backrests
7P0
Without lumbar support
in seat backrests
Platform group class
7PC
Platform group class 3
Navigation system
7Q0
not with navigation system
CD-ROM/DVD/SD card
7QA
Without CD/DVD for navigation
Inserts
7TH
Decorative inserts
Park distance control
7X1
Radios
8DR
Radio
Alternators
8GG
Alternator 110 A
Main headlamps
8JM
Antennas
8L5
Roof antenna and diversity window
antenna
Wiper and washer system for rear windows
8M1
Rear window wiper washer system with
intermittent wipe
Intermittent windshield wiper control/
light/rain sensor
8N4
Windshield wiper intermittent control
with potentiometer (four speeds)
Headlight range control
8Q1
Key for locking system
8QD
Loudspeaker installation
8RL
6 speakers (passive)
Rear combination lamps
8SA
Rear combination lamp, standard design
cruise control system
8T2
Electronic cruise control system (CCS)
cigarette lighter
8V1
cigarette lighter
Washer fluid level indicator
8W0
not with washer fluid level indicator
Front fog lamps/additional headlamps
8WB
Front fog lamps
Headlamp washer system
8X0
Without headlamp washer system
Horns
8Y1
Two-tone horn
Engine cooling
8Z6
Hot country
Heating system/air conditioning system
9AK
Climatronic with impact pressure
control, CFC-free
Headlight control
9C6
Separate daytime running light
Interior light in cab
9GG
Two interior lights with contact switch
on the doors
Malfunction display
9HA
Without additional malfunction display
Smoker's/non-smoker's version
9JC
Smoker's package
Seat belt reminder
9P1
Seat belt reminder, electric contact in
buckle
Multi-function display/trip computer
9Q2
with check control
Heated washer nozzles
9T0
Without heated washer nozzles
Brake pad wear indicator
9U0
without brake wear indicator
Telephone/telematics
9W8
Preparation for telephone
Multimedia/video/DVD/notebook connection
9WC
Without "Multimedia" in vehicle
Outdoor temperature gage
9Y1
Equipment lines
A8D
luxury version
Vehicle type
AZ0
Vehicle with production equipment
Type-approval testing countries/
countries with specific requirements
B20
Type approval country Turkey
Part set for country-specific
prescriptive standards
B3D
Part set, complying with
vehicle type for Turkey, various parts
General operating license additions
C00
Operating permit, initial registration
Wheels
CW8
Alloy wheels 7J x 16
Engine specification
D36
4-cyl. turbo dies. eng. 1.6 l/66 kW
(4V), TDI common rail,
base engine is TF3/TJ1
D36
base engine is TF3/TJ1/TI7
Special editions
E0A
no sales compaign version
Follow-on warranty
EA0
Without follow-on warranty
Vehicle specifications
F0A
No special purpose vehicle, standard
equipment
Paint finish
FB0
Normal paintwork
Transmission specification
G1C
7-speed automatic transmission
Shock absorption in front
G45
Flat-tire spray
GR0
Without flat-tire spray
Tires 215/45 R16 86V
HW1
Tires 215/45 R16 86H
Batteries
J0N
Battery 330 A (61 Ah)
Body forms
K8R
Sportsback
Refrigerant
KK1
Refrigerant R134a
Steering system setup
L0L
Left-hand drive
Weight category for front axle
L41
Suspension range 41
Seat trim covers
N0H
Seat trim covers in fabric
Engine cover
NM0
Without engine cover
PT3
3 spoke multi-function steering wheel wi
th telephone prep. GSM II with BT,withou
t holder, with voice control, "MAXI DOT"
Front seats
Q1Ah
Standard seats in front
Storage compartment package
QE0
Without storage compartment package/box
LongLife Service Regime
QG1
Service indicator
QI6
Service indicator 30 000 km or 2 years
( variable )
Chrome package
QJ1
Chrome package
Drawers under front seats
QN0
Without drawers under front seats
TV reception/digital radio reception
QV0
Without TV reception/digital radio
reception
Base engine
TF3
4-cylinder diesel engine 1.6 l
unit 03L.1
Dashboard inserts
U5A
Instrument cluster, km/h speedometer
Electric interface for external use
UF6
(MEDIA-IN jack)
Hill start assist
UG1
Hill start assist
Tire suppliers
V0A
Tires without specification of tire
brand
Pedal cluster
VF0
Foot pedal unit"standard"
Pedestrian protection
VL1
Extended pedestrian protection measures- ciclo
Thanks for the info.
I assumed it because of the electrical configuration in the original light switch connector, but I'd rather not assume. I've already found that in Skodas the ETKA says one thing and then the reality is another.
According to diagrams (not according to PR-codes) there should be an AUTO light switch for SK Rapid PQ25, but...
This is a nice new challenge as far as BCM Max adaptation is concerned, or at least entertaining.
Sometimes I wonder why the VW group didn't manufacture all PQ25s with BCM Max (technology known years before 2008), I think the VW group would have saved a lot of money in the manufacture of these cars if they had done it this way, I suppose the copper of the wires would be almost free for them as well as differentiating the status of the buyers as well...
- omerkartal
Is your Polo on the PQ25 platform? If so, I can get your auto position headlight switch, if you can tell me the part number. Yes, exactly like this.ciclo wrote: Tue Dec 10, 2024 6:58 pm
I highly doubt the AUTO switch you have is compatible for all platforms, although it would be a pleasant surprise if it were.![]()
ciclo wrote: Tue Dec 10, 2024 7:30 pm You have a big challenge ahead of you, and although it is totally possible, you or your electronics technician friend are going to have to fight hard.
We await your guidance. I believe that we will succeed together.
lamp type h4 and h15
just like thatiichel wrote: Tue Dec 10, 2024 7:57 pm i think H7 + H15 (ntegrated DRL into high beam)
Main headlamps
8JM
Doors 0A2 4 doors Front stabilizer bar 0AS Front stabilizer bar Rear stabilizer bar 0BC Rear stabilizer bar CO2 variant 0C0 Standard Vehicle class differentiation powertrains/platform parts 0CA Vehicle class differentiation -605- Installation differentiation for vehicle parts 0EG Installation differentiation for dual-clutch transv. transmission DQ200 -- vehicle components -- Fuel systems 0F9 Cooled fuel system for diesel engine Differentiation for manufacturing process 0FA Standard manufacturing sequence Rear axle 0N5 Standard rear axle Tailpipes 0P0 Rear exhaust tailpipe (standard) Nameplate set 0PZ Nameplate set "R" Ignition locking system/electronic steering column lock 0RA Without ignition/starter switch locking system Special labels 0SS Labels in English and French foot mats 0TD Front and rear floor mats Owner's manuals 0XA Information kit in Turkish Climate zones 0Y2 Tropical zones Weight category for rear axle 0YC Weight range 3 installation control only, no requirement forecast Brand-specific/class-specific features 0Z6 SKODA brand-specific/class-specific features Brake systems 1AT Electronic stability control (ESC) Antifreeze agent 1C1 Antifreeze up to -25 degree Celsius tolerance up to -30 degree C Trailer hitch 1D0 Without trailer hitch Activated carbon canister/gasoline particulate filter 1E0 Without activated carbon canister Identification labels 1EX Special identification label for EC for M1 passenger vehicles Spare wheel/breakdown kit 1G1 Space-saving spare wheel Shock absorption in rear 1JA Rear shock absorption, basic version 1 Rear brakes 1KT Disc brakes in rear (Geomet D) Steering system 1N3 Speed-related variable steering assist (Servotronic) Wheel trims 1NL Trims for alloy wheels Lockable wheel bolts 1PF Standard wheel bolts Vehicle tools and jack 1S6 Tool kit and heavy-duty jack Front-end underbody cladding 1SA Without additional front underbody guard First aid kit/warning triangle 1T0 Without first aid kit and warning triangle Cool box 1W2 Glove compartment cooling system Fuel filling volume 1Z2 Increase in initial standard fuel filling Front brakes 1ZC Disc brakes in front (Geomet D) Delivery equipment 2A0 Without delivery equipment Sound insulation measures for outside noises 2B1 Additional exterior noise insulation Steering column systems 2C5 Axial and vertical adjustable steering column Tank filler neck for unleaded fuel/fuel type 2G5 Filler neck module 1 without insert Bumper 2JG bumper in colour of vehicle Fuel tank material treatment 2LA Fuel tank without special material treatment Steering wheels 2PP Leather-wrapped multi-function steering wheel Fresh air intake for vehicle interior (with particle filter) 2V5 Fresh air intake system with combination filter Fuel cap/fuel filler door closing mechanism 2W6 Fuel filler cap Additional tires (snow tires) 2WA without spare tyre Additional child seat anchorage 3B3 Child seat anchors Center seat belts in rear 3C7 Three-point inertia reel belt for rear centre seat Partition 3CA with no partition Roof insert/convertible top 3FA Without roof insert (standard roof) Luggage/load compartment floor in rear 3GA Without luggage compartment floor Backrest release 3H0 Without backrest release for front seats Head restraints 3J1 Hight-adjustable head restraints for front seats Seat adjustment 3L3 Manual height adjustment for front seats Flaps/storage compartments in the luggage compartment 3N3 Storage compartments in trunk Rear seats 3NZ Rear bench seat, not split, split backrest, folding Head restraints in rear 3Q6 3 rear head restraints Rear doors/tailgate/trunk lid 3RC Tailgate with window aperture Sound insulation measures for interior noises 3W6 Additional interior noise suppression Outer seat belts in rear 3ZB 3-point seat belts, outer rear with ECE label seat heater 4A0 without seat heater Door and side trim panels 4AM door and side trim panels Protective side molding 4B0 with no protective side strip Windshield 4GF Heat-reflecting windshield Door and tailgate/trunk lid locking mechanism 4I2 Central locking w/ radio remote control, interior controls, without SAFELOCK Side and rear windows 4KF heat protective glass for door, side and rear windows, darkened from b-pillar Breakaway interior rearview mirror 4L2 Breakaway interior rearview mirror, dimming Controls (steering wheel/steering column) 4LC Controls for radio and telephone Beverage holders 4M4 Beverage holder in center console Rear floor panel platform module 4P4 Rear floor panel module, type 5 Restraint systems in front 4QU 3-point seat belts in front, with pretensioner and electric height adjustment Window regulator 4R3 Power windows with comfort operation Vanity mirror on the left 4SB Vanity mirror left Vanity mirror on the right 4TB Vanity mirror, right Luggage net/bag on backrest(s) 4U4 Luggage pocket on backrest Airbag 4UF Airbag for driver and front passenger with front passenger airbag deactivation Side airbag 4X3 Side airbag in front, with curtain airbag Door/side storage compartment in rear 4YB Storage compartment in rear (door and side panel) Glove compartment 4Z5 Glove compartment door with light Decorative trims 4ZA Standard decorative trims Body measures 5C8 Additional measures for the body Carrier frequency for remote control 5D1 Carrier frequency 433.92 to 434.42 Mhz Rear spoiler 5J0 Without rear spoiler Paint preservation/transport protection 5K5 Transport protection film with additional transport protection measures Grab handles at roof frame 5N2 Folding grab handles at roof frame Right exterior mirror 5RQ Exterior mirror, right, convex Left exterior mirror 5SJ Left exterior mirror, convex Fire extinguisher 6A0 without fire extinguisher Center armrest 6E3 Center armrest in front Additional body protective covers, side 6EA Without additional side body covers (stone guard) Components with special surfaces 6FF Exterior mirror housing and various attachments colour coded to vehicle Door handles/inserts 6JE Chromed door handles (smooth) Radiator grille 6KJ Radiator grille with chrome molding Fresh air system/vents 6LH Comfort vent Tie down straps/net/pocket 6M4 Load protection system Hand brake lever 6PE Hand brake lever handle in leather Gearshift knob/gearshift handle 6Q2 Gearshift knob/handle in leather Gearshift boot/gearshift trim 6R1 Leatherette gearshift lever boot Luggage compartment floor covering 6SJ Luggage compartment mat (rubber/fabric) Exterior mirror adjustment 6XD Exterior mirrors, power-adjustable/ heated Theft protection system 7AA Electronic immobilizer Thermal energy storage system/auxiliary heater 7E0 Without heat accumulator/auxiliary heater Tire pressure monitoring system 7K6 Tire pressure monitoring system Start-stop system/regenerative braking 7L3 Without start-stop system without regenerative braking Scuff plates 7M5 Without impact protection film for door sill Emission standard 7MJ Emission standard EU5 plus Storage compartment 7N2 spectacles holder Lumbar support in backrests 7P0 Without lumbar support in seat backrests Platform group class 7PC Platform group class 3 Navigation system 7Q0 not with navigation system CD-ROM/DVD/SD card 7QA Without CD/DVD for navigation Inserts 7TH Decorative inserts Park distance control 7X1 Park distance control Radios 8DR Radio Alternators 8GG Alternator 110 A Main headlamps 8JM Twin headlamps for driving on the right, with integrated high beam Antennas 8L5 Roof antenna and diversity window antenna Wiper and washer system for rear windows 8M1 Rear window wiper washer system with intermittent wipe Intermittent windshield wiper control/ light/rain sensor 8N4 Windshield wiper intermittent control with potentiometer (four speeds) Headlight range control 8Q1 Headlight range control Key for locking system 8QD Key for locking system Loudspeaker installation 8RL 6 speakers (passive) Rear combination lamps 8SA Rear combination lamp, standard design cruise control system 8T2 Electronic cruise control system (CCS) cigarette lighter 8V1 cigarette lighter Washer fluid level indicator 8W0 not with washer fluid level indicator Front fog lamps/additional headlamps 8WB Front fog lamps Headlamp washer system 8X0 Without headlamp washer system Horns 8Y1 Two-tone horn Engine cooling 8Z6 Hot country Heating system/air conditioning system 9AK Climatronic with impact pressure control, CFC-free Headlight control 9C6 Separate daytime running light Interior light in cab 9GG Two interior lights with contact switch on the doors Malfunction display 9HA Without additional malfunction display Smoker's/non-smoker's version 9JC Smoker's package Seat belt reminder 9P1 Seat belt reminder, electric contact in buckle Multi-function display/trip computer 9Q2 Multi-function display/trip computer with check control Heated washer nozzles 9T0 Without heated washer nozzles Brake pad wear indicator 9U0 without brake wear indicator Telephone/telematics 9W8 Preparation for telephone Multimedia/video/DVD/notebook connection 9WC Without "Multimedia" in vehicle Outdoor temperature gage 9Y1 Outdoor temperature gage Equipment lines A8D luxury version Vehicle type AZ0 Vehicle with production equipment Type-approval testing countries/ countries with specific requirements B20 Type approval country Turkey Part set for country-specific prescriptive standards B3D Part set, complying with vehicle type for Turkey, various parts General operating license additions C00 Operating permit, initial registration Wheels CW8 Alloy wheels 7J x 16 Engine specification D36 4-cyl. turbo dies. eng. 1.6 l/66 kW (4V), TDI common rail, base engine is TF3/TJ1 Engine specification D36 4-cyl. turbo dies. eng. 1.6 l/66 kW (4V), TDI common rail, base engine is TF3/TJ1/TI7 Special editions E0A no sales compaign version Follow-on warranty EA0 Without follow-on warranty Vehicle specifications F0A No special purpose vehicle, standard equipment Paint finish FB0 Normal paintwork Transmission specification G1C 7-speed automatic transmission Shock absorption in front G45 Shock absorption in front Flat-tire spray GR0 Without flat-tire spray Tires 215/45 R16 86V HW1 Tires 215/45 R16 86H Batteries J0N Battery 330 A (61 Ah) Body forms K8R Sportsback Refrigerant KK1 Refrigerant R134a Steering system setup L0L Left-hand drive Weight category for front axle L41 Suspension range 41 installation control only, no requirement forecast Seat trim covers N0H Seat trim covers in fabric Engine cover NM0 Without engine cover PT3 3 spoke multi-function steering wheel wi th telephone prep. GSM II with BT,withou t holder, with voice control, "MAXI DOT" Front seats Q1Ah Standard seats in front Storage compartment package QE0 Without storage compartment package/box LongLife Service Regime QG1 LongLife Service Regime Service indicator QI6 Service indicator 30 000 km or 2 years ( variable ) Chrome package QJ1 Chrome package Drawers under front seats QN0 Without drawers under front seats TV reception/digital radio reception QV0 Without TV reception/digital radio reception Base engine TF3 4-cylinder diesel engine 1.6 l unit 03L.1 Dashboard inserts U5A Instrument cluster, km/h speedometer Electric interface for external use UF6 Electric interface for external use (MEDIA-IN jack) Hill start assist UG1 Hill start assist Tire suppliers V0A Tires without specification of tire brand Pedal cluster VF0 Foot pedal unit"standard" Pedestrian protection VL1 Extended pedestrian protection measures
We trust you.ciclo wrote: Tue Dec 10, 2024 8:29 pm Thanks for the info.
H7 + H15
SK LS Auto (PQ25)
SK LS Auto (PQ25)
- omerkartal
Hello
You are a genius.
I did some research last night. Someone in Turkey made an Auto Light for a 6R Polo Gti vehicle. The Auto featured headlight switch code he shared there is 3C8 941 431 A. Does this switch work for us? The headlight switch you shared is 5ja941431a, unfortunately it is not available in Turkey.
You don't need to try the VW switch 3C8941431A anymore. There are up to 5 more VW models, but I didn't want to share them with you because it didn't make sense until I verified the appropriate SK model for your SK.
The 5JA941431A is the correct one for your SK Rapid PQ25 and the one you have to install, it is compatible with your dash and electronically.
Get it from your SK dealer or wherever is appropriate, I have seen a few online on all kinds of websites.
It is not necessary to click on "quote" all the time, reading is quite uncomfortable for users, and especially for me who has to use the mouse scroll a thousand times to post images that I am sure you like a lot.
If you make it difficult for me I will not continue (I'm not kidding).
At the bottom of the page you have the 'Post Reply' button instead of 'quote' (").
- omerkartal
Unfortunately my friend. I called all Skoda dealers in ISTANBUL. They said that they never had the part numbered 5JA941431A in stock. I think we will try 3C8 941 431 A on this key. Can you see the platform of this key?
I ordered the product 3C8 941 431 A . It appears on the pq25 platform. I can find it in Turkey. I think the friend in the video below bought the materials from you
https://www.youtube.com/@aditya.khaitan
Sorry for the warning about quoting. I'll be careful.
