Page 2 of 7
Re: Skoda Rapid BCM 6R093708P upgrade 7h0937090d BUT!
Posted: Tue Dec 10, 2024 1:54 pm
by ciclo
Have you checked that this AUTO switch fits correctly in your SK Rapid? Please take a photo already installed.
I'm afraid that switch is for PQ26/MQB, it won't work for PQ25, the electronics are not compatible.
SK PQ25 viewtopic.php?p=558939#p558939
Posted: Tue Dec 10, 2024 2:24 pm
by omerkartal
ciclo wrote: Tue Dec 10, 2024 1:54 pm Have you checked that this AUTO switch fits correctly in your SK Rapid? Please take a photo already installed.
Türkiye also has this piece. I put it on and it fits. I'm away from the car now.
The headlight switch you shared is not sold in Türkiye. Skoda Rapid appears on Aliexpres.
Posted: Tue Dec 10, 2024 2:42 pm
by ciclo
Sure, I'm sure it fits, but correctly?
I don't know what the internal shape of the Rapid PQ25 dashboard is where the switch fits, but on all VW Group PQ25s the AUTO letters are on the top of the switch.
If it fits crooked, it's not compatible.
The connector that corresponds to it is a red 10 pin connector (not the usual black one we use on PQ25), it indicates that it is for other models, PQ26/MQB.
I've seen it on Ali, it says for Rapid, but which one? PQ25 or PQ26?
Very few Ali sellers know what they sell, they don't have the slightest idea.
I even think that I am the only one on the entire planet who knows absolutely everything about this model of switches, I even know of some atrocities that are sold on Ali with VW original part number for one platform and then turn out to be for another ...which implies... blah, blah, blah...
Posted: Tue Dec 10, 2024 2:48 pm
by omerkartal
ciclo wrote: Tue Dec 10, 2024 2:42 pm Sure, I'm sure it fits, but correctly?
You are so right. Well, can you find the appropriate key from the chassis? I also agree that you are a genius :)
Posted: Tue Dec 10, 2024 4:08 pm
by omerkartal
Hello again, I added the pictures of the headlight switch to Google Drive. I think what you said is true, this switch is not PQ25. I tried it on a Skoda Scala brand vehicle the other day and it worked. Can you tell me the part number of the headlight switch on your Polo? I think its substructure is PQ25.
Posted: Tue Dec 10, 2024 6:58 pm
by ciclo
Ok, this is very interesting, the switch you show fits perfectly. It is not turned/twisted/croocked, so it is the correct one in terms of the way it fits into the dash, even though the AUTO position icon is not on the top.
Now you'll have to verify if it is electronically compatible once the wiring adaptation for BCM Max has been carried out. Obviously you should first test with AUTO switches that we know work correctly (ALL functions) for the PQ25, it doesn't matter if they are VW or SK, but the ones we know work would not be compatible with your dashboard. 🤦‍♂️
I highly doubt the AUTO switch you have is compatible for all platforms, although it would be a pleasant surprise if it were.🤷‍♂️
Posted: Tue Dec 10, 2024 7:30 pm
by ciclo
You have a big challenge ahead of you, and although it is totally possible, you or your electronics technician friend are going to have to fight hard.
I will soon begin to explain my interpretation for the adaptation of BCM Max wiring and Auto lights for your 2014 SK Rapid Spaceback PQ25.
By the way, what type of headlights does your SK Rapid have, H7 or H4?
Posted: Tue Dec 10, 2024 7:57 pm
by iichel
i think H7 + H15 (ntegrated DRL into high beam)
Main headlamps
8JM
Twin headlamps for driving on the
right, with integrated high beam
Doors
0A2
4 doors
Front stabilizer bar
0AS
Rear stabilizer bar
0BC
Rear stabilizer bar
CO2 variant
0C0
Standard
Vehicle class differentiation
powertrains/platform parts
0CA
Vehicle class differentiation -605-
Installation differentiation for
vehicle parts
0EG
dual-clutch transv. transmission DQ200
-- vehicle components --
Fuel systems
0F9
Cooled fuel system for diesel engine
Differentiation for manufacturing
process
0FA
Standard manufacturing sequence
Rear axle
0N5
Standard rear axle
Tailpipes
0P0
Rear exhaust tailpipe (standard)
Nameplate set
0PZ
Nameplate set "R"
Ignition locking system/electronic
steering column lock
0RA
Without ignition/starter switch locking
system
Special labels
0SS
Labels in English and French
foot mats
0TD
Front and rear floor mats
Owner's manuals
0XA
Information kit in Turkish
Climate zones
0Y2
Tropical zones
Weight category for rear axle
0YC
Weight range 3
installation control only, no
requirement forecast
Brand-specific/class-specific features
0Z6
SKODA brand-specific/class-specific
features
Brake systems
1AT
Electronic stability control (ESC)
Antifreeze agent
1C1
Antifreeze up to -25 degree Celsius
tolerance up to -30 degree C
Trailer hitch
1D0
Without trailer hitch
Activated carbon canister/gasoline
particulate filter
1E0
Without activated carbon canister
Identification labels
1EX
Special identification label for EC
for M1 passenger vehicles
Spare wheel/breakdown kit
1G1
Space-saving spare wheel
Shock absorption in rear
1JA
Rear shock absorption, basic version 1
Rear brakes
1KT
Disc brakes in rear (Geomet D)
Steering system
1N3
Speed-related variable steering assist
(Servotronic)
Wheel trims
1NL
Trims for alloy wheels
Lockable wheel bolts
1PF
Standard wheel bolts
Vehicle tools and jack
1S6
Tool kit and heavy-duty jack
Front-end underbody cladding
1SA
Without additional front underbody guard
First aid kit/warning triangle
1T0
Without first aid kit and warning
triangle
Cool box
1W2
Glove compartment cooling system
Fuel filling volume
1Z2
Increase in initial standard fuel
filling
Front brakes
1ZC
Disc brakes in front (Geomet D)
Delivery equipment
2A0
Without delivery equipment
Sound insulation measures for outside
noises
2B1
Additional exterior noise insulation
Steering column systems
2C5
Axial and vertical adjustable steering
column
Tank filler neck for unleaded fuel/fuel
type
2G5
Filler neck module 1 without insert
Bumper
2JG
bumper in colour of vehicle
Fuel tank material treatment
2LA
Fuel tank without special material
treatment
Steering wheels
2PP
Leather-wrapped multi-function steering
wheel
Fresh air intake for vehicle interior
(with particle filter)
2V5
Fresh air intake system with combination
filter
Fuel cap/fuel filler door closing
mechanism
2W6
Fuel filler cap
Additional tires (snow tires)
2WA
without spare tyre
Additional child seat anchorage
3B3
Child seat anchors
Center seat belts in rear
3C7
Three-point inertia reel belt for rear centre seat
Partition
3CA
with no partition
Roof insert/convertible top
3FA
Without roof insert (standard roof)
Luggage/load compartment floor in rear
3GA
Without luggage compartment floor
Backrest release
3H0
Without backrest release for front seats
Head restraints
3J1
Hight-adjustable head restraints for
front seats
Seat adjustment
3L3
Manual height adjustment for front seats
Flaps/storage compartments in the
luggage compartment
3N3
Storage compartments in trunk
Rear seats
3NZ
Rear bench seat, not split, split backrest, folding
Head restraints in rear
3Q6
3 rear head restraints
Rear doors/tailgate/trunk lid
3RC
Tailgate with window aperture
Sound insulation measures for interior
noises
3W6
Additional interior noise suppression
Outer seat belts in rear
3ZB
3-point seat belts, outer rear with ECE
label
seat heater
4A0
without seat heater
Door and side trim panels
4AM
door and side trim panels
Protective side molding
4B0
with no protective side strip
Windshield
4GF
Heat-reflecting windshield
Door and tailgate/trunk lid locking
mechanism
4I2
Central locking w/ radio remote control,
interior controls, without SAFELOCK
Side and rear windows
4KF
heat protective glass for door, side and rear
windows, darkened from b-pillar
Breakaway interior rearview mirror
4L2
Breakaway interior rearview mirror,
dimming
Controls (steering wheel/steering column)
4LC
Controls for radio and telephone
Beverage holders
4M4
Beverage holder in center console
Rear floor panel platform module
4P4
Rear floor panel module, type 5
Restraint systems in front
4QU
3-point seat belts in front, with
pretensioner and electric height
adjustment
Window regulator
4R3
Power windows with comfort operation
Vanity mirror on the left
4SB
Vanity mirror left
Vanity mirror on the right
4TB
Vanity mirror, right
Luggage net/bag on backrest(s)
4U4
Luggage pocket on backrest
Airbag
4UF
Airbag for driver and front passenger
with front passenger airbag
deactivation
Side airbag
4X3
Side airbag in front, with curtain
airbag
Door/side storage compartment in rear
4YB
Storage compartment in rear
(door and side panel)
Glove compartment
4Z5
Glove compartment door with light
Decorative trims
4ZA
Standard decorative trims
Body measures
5C8
Additional measures for the body
Carrier frequency for remote control
5D1
Carrier frequency 433.92 to 434.42 Mhz
Rear spoiler
5J0
Without rear spoiler
Paint preservation/transport protection
5K5
Transport protection film with
additional transport protection measures
Grab handles at roof frame
5N2
Folding grab handles at roof frame
Right exterior mirror
5RQ
Exterior mirror, right, convex
Left exterior mirror
5SJ
Left exterior mirror, convex
Fire extinguisher
6A0
without fire extinguisher
Center armrest
6E3
Center armrest in front
Additional body protective covers, side
6EA
Without additional side body covers
(stone guard)
Components with special surfaces
6FF
Exterior mirror housing and various attachments
colour coded to vehicle
Door handles/inserts
6JE
Chromed door handles (smooth)
Radiator grille
6KJ
Radiator grille with chrome molding
Fresh air system/vents
6LH
Comfort vent
Tie down straps/net/pocket
6M4
Load protection system
Hand brake lever
6PE
Hand brake lever handle in leather
Gearshift knob/gearshift handle
6Q2
Gearshift knob/handle in leather
Gearshift boot/gearshift trim
6R1
Leatherette gearshift lever boot
Luggage compartment floor covering
6SJ
Luggage compartment mat (rubber/fabric)
Exterior mirror adjustment
6XD
Exterior mirrors, power-adjustable/
heated
Theft protection system
7AA
Electronic immobilizer
Thermal energy storage system/auxiliary
heater
7E0
Without heat accumulator/auxiliary
heater
Tire pressure monitoring system
7K6
Start-stop system/regenerative braking
7L3
Without start-stop system without
Scuff plates
7M5
Without impact protection film for door sill
Emission standard
7MJ
Emission standard EU5 plus
Storage compartment
7N2
spectacles holder
Lumbar support in backrests
7P0
Without lumbar support
in seat backrests
Platform group class
7PC
Platform group class 3
Navigation system
7Q0
not with navigation system
CD-ROM/DVD/SD card
7QA
Without CD/DVD for navigation
Inserts
7TH
Decorative inserts
Park distance control
7X1
Radios
8DR
Radio
Alternators
8GG
Alternator 110 A
Main headlamps
8JM
Antennas
8L5
Roof antenna and diversity window
antenna
Wiper and washer system for rear windows
8M1
Rear window wiper washer system with
intermittent wipe
Intermittent windshield wiper control/
light/rain sensor
8N4
Windshield wiper intermittent control
with potentiometer (four speeds)
Headlight range control
8Q1
Key for locking system
8QD
Loudspeaker installation
8RL
6 speakers (passive)
Rear combination lamps
8SA
Rear combination lamp, standard design
cruise control system
8T2
Electronic cruise control system (CCS)
cigarette lighter
8V1
cigarette lighter
Washer fluid level indicator
8W0
not with washer fluid level indicator
Front fog lamps/additional headlamps
8WB
Front fog lamps
Headlamp washer system
8X0
Without headlamp washer system
Horns
8Y1
Two-tone horn
Engine cooling
8Z6
Hot country
Heating system/air conditioning system
9AK
Climatronic with impact pressure
control, CFC-free
Headlight control
9C6
Separate daytime running light
Interior light in cab
9GG
Two interior lights with contact switch
on the doors
Malfunction display
9HA
Without additional malfunction display
Smoker's/non-smoker's version
9JC
Smoker's package
Seat belt reminder
9P1
Seat belt reminder, electric contact in
buckle
Multi-function display/trip computer
9Q2
with check control
Heated washer nozzles
9T0
Without heated washer nozzles
Brake pad wear indicator
9U0
without brake wear indicator
Telephone/telematics
9W8
Preparation for telephone
Multimedia/video/DVD/notebook connection
9WC
Without "Multimedia" in vehicle
Outdoor temperature gage
9Y1
Equipment lines
A8D
luxury version
Vehicle type
AZ0
Vehicle with production equipment
Type-approval testing countries/
countries with specific requirements
B20
Type approval country Turkey
Part set for country-specific
prescriptive standards
B3D
Part set, complying with
vehicle type for Turkey, various parts
General operating license additions
C00
Operating permit, initial registration
Wheels
CW8
Alloy wheels 7J x 16
Engine specification
D36
4-cyl. turbo dies. eng. 1.6 l/66 kW
(4V), TDI common rail,
base engine is TF3/TJ1
D36
base engine is TF3/TJ1/TI7
Special editions
E0A
no sales compaign version
Follow-on warranty
EA0
Without follow-on warranty
Vehicle specifications
F0A
No special purpose vehicle, standard
equipment
Paint finish
FB0
Normal paintwork
Transmission specification
G1C
7-speed automatic transmission
Shock absorption in front
G45
Flat-tire spray
GR0
Without flat-tire spray
Tires 215/45 R16 86V
HW1
Tires 215/45 R16 86H
Batteries
J0N
Battery 330 A (61 Ah)
Body forms
K8R
Sportsback
Refrigerant
KK1
Refrigerant R134a
Steering system setup
L0L
Left-hand drive
Weight category for front axle
L41
Suspension range 41
Seat trim covers
N0H
Seat trim covers in fabric
Engine cover
NM0
Without engine cover
PT3
3 spoke multi-function steering wheel wi
th telephone prep. GSM II with BT,withou
t holder, with voice control, "MAXI DOT"
Front seats
Q1Ah
Standard seats in front
Storage compartment package
QE0
Without storage compartment package/box
LongLife Service Regime
QG1
Service indicator
QI6
Service indicator 30 000 km or 2 years
( variable )
Chrome package
QJ1
Chrome package
Drawers under front seats
QN0
Without drawers under front seats
TV reception/digital radio reception
QV0
Without TV reception/digital radio
reception
Base engine
TF3
4-cylinder diesel engine 1.6 l
unit 03L.1
Dashboard inserts
U5A
Instrument cluster, km/h speedometer
Electric interface for external use
UF6
(MEDIA-IN jack)
Hill start assist
UG1
Hill start assist
Tire suppliers
V0A
Tires without specification of tire
brand
Pedal cluster
VF0
Foot pedal unit"standard"
Pedestrian protection
VL1
Extended pedestrian protection measures
Posted: Tue Dec 10, 2024 8:29 pm
by ciclo
Thanks for the info.
I assumed it because of the electrical configuration in the original light switch connector, but I'd rather not assume. I've already found that in Skodas the ETKA says one thing and then the reality is another.
According to diagrams (not according to PR-codes) there should be an AUTO light switch for SK Rapid PQ25, but...🤷‍♂️
This is a nice new challenge as far as BCM Max adaptation is concerned, or at least entertaining.😊
Sometimes I wonder why the VW group didn't manufacture all PQ25s with BCM Max (technology known years before 2008), I think the VW group would have saved a lot of money in the manufacture of these cars if they had done it this way, I suppose the copper of the wires would be almost free for them as well as differentiating the status of the buyers as well...
Posted: Tue Dec 10, 2024 10:12 pm
by omerkartal
ciclo wrote: Tue Dec 10, 2024 6:58 pm Image
Is your Polo on the PQ25 platform? If so, I can get your auto position headlight switch, if you can tell me the part number. Yes, exactly like this.
ciclo wrote: Tue Dec 10, 2024 7:30 pm You have a big challenge ahead of you, and although it is totally possible, you or your electronics technician friend are going to have to fight hard.
We await your guidance. I believe that we will succeed together.
lamp type h4 and h15
iichel wrote: Tue Dec 10, 2024 7:57 pm i think H7 + H15 (ntegrated DRL into high beam)
Main headlamps
8JM
Doors
0A2
4 doors
0AS
Rear stabilizer bar
0BC
Rear stabilizer bar
CO2 variant
0C0
Standard
0CA
vehicle parts
0EG
Fuel systems
0F9
process
0FA
Rear axle
0N5
Standard rear axle
Tailpipes
0P0
Nameplate set
0PZ
Nameplate set "R"
0RA
system
Special labels
0SS
foot mats
0TD
Owner's manuals
0XA
Climate zones
0Y2
Tropical zones
0YC
Weight range 3
0Z6
features
Brake systems
1AT
Antifreeze agent
1C1
Trailer hitch
1D0
particulate filter
1E0
1EX
1G1
1JA
Rear brakes
1KT
Steering system
1N3
(Servotronic)
Wheel trims
1NL
1PF
1S6
1SA
1T0
triangle
Cool box
1W2
Fuel filling volume
1Z2
filling
Front brakes
1ZC
Delivery equipment
2A0
noises
2B1
2C5
column
type
2G5
Bumper
2JG
2LA
treatment
Steering wheels
2PP
wheel
2V5
filter
mechanism
2W6
Fuel filler cap
2WA
without spare tyre
3B3
Child seat anchors
3C7
Partition
3CA
with no partition
3FA
3GA
Backrest release
3H0
Head restraints
3J1
front seats
Seat adjustment
3L3
luggage compartment
3N3
Rear seats
3NZ
3Q6
3RC
noises
3W6
3ZB
label
seat heater
4A0
without seat heater
4AM
4B0
Windshield
4GF
mechanism
4I2
4KF
4L2
dimming
4LC
Beverage holders
4M4
4P4
4QU
adjustment
Window regulator
4R3
4SB
Vanity mirror left
4TB
4U4
Airbag
4UF
deactivation
Side airbag
4X3
airbag
4YB
Glove compartment
4Z5
Decorative trims
4ZA
Body measures
5C8
5D1
Rear spoiler
5J0
5K5
5N2
5RQ
5SJ
Fire extinguisher
6A0
Center armrest
6E3
6EA
(stone guard)
6FF
6JE
Radiator grille
6KJ
6LH
Comfort vent
6M4
Hand brake lever
6PE
6Q2
6R1
6SJ
6XD
heated
7AA
heater
7E0
heater
7K6
7L3
Scuff plates
7M5
Emission standard
7MJ
Storage compartment
7N2
spectacles holder
7P0
in seat backrests
7PC
Navigation system
7Q0
CD-ROM/DVD/SD card
7QA
Inserts
7TH
Decorative inserts
7X1
Radios
8DR
Radio
Alternators
8GG
Alternator 110 A
Main headlamps
8JM
Antennas
8L5
antenna
8M1
intermittent wipe
light/rain sensor
8N4
8Q1
8QD
8RL
8SA
8T2
cigarette lighter
8V1
cigarette lighter
8W0
8WB
Front fog lamps
8X0
Horns
8Y1
Two-tone horn
Engine cooling
8Z6
Hot country
9AK
control, CFC-free
Headlight control
9C6
9GG
on the doors
Malfunction display
9HA
9JC
Smoker's package
Seat belt reminder
9P1
buckle
9Q2
with check control
9T0
9U0
9W8
9WC
9Y1
Equipment lines
A8D
luxury version
Vehicle type
AZ0
B20
B3D
C00
Wheels
CW8
D36
D36
Special editions
E0A
Follow-on warranty
EA0
F0A
equipment
Paint finish
FB0
Normal paintwork
G1C
G45
Flat-tire spray
GR0
HW1
Batteries
J0N
Body forms
K8R
Sportsback
Refrigerant
KK1
Refrigerant R134a
L0L
Left-hand drive
L41
Suspension range 41
Seat trim covers
N0H
Engine cover
NM0
PT3
Front seats
Q1Ah
QE0
QG1
Service indicator
QI6
( variable )
Chrome package
QJ1
Chrome package
QN0
QV0
reception
Base engine
TF3
unit 03L.1
Dashboard inserts
U5A
UF6
(MEDIA-IN jack)
Hill start assist
UG1
Hill start assist
Tire suppliers
V0A
brand
Pedal cluster
VF0
VL1
just like that
ciclo wrote: Tue Dec 10, 2024 8:29 pm Thanks for the info.
We trust you.
Posted: Wed Dec 11, 2024 4:27 am
by ciclo
H7 + H15
SK LS Auto (PQ25)
Posted: Wed Dec 11, 2024 5:06 am
by omerkartal
ciclo wrote: Wed Dec 11, 2024 4:27 am H7 + H15
SK LS Auto (PQ25)
Hello
You are a genius.
I did some research last night. Someone in Turkey made an Auto Light for a 6R Polo Gti vehicle. The Auto featured headlight switch code he shared there is 3C8 941 431 A. Does this switch work for us? The headlight switch you shared is 5ja941431a, unfortunately it is not available in Turkey.
Posted: Wed Dec 11, 2024 5:23 am
by ciclo
You don't need to try the VW switch 3C8941431A anymore. There are up to 5 more VW models, but I didn't want to share them with you because it didn't make sense until I verified the appropriate SK model for your SK.😉
The 5JA941431A is the correct one for your SK Rapid PQ25 and the one you have to install, it is compatible with your dash and electronically.
Get it from your SK dealer or wherever is appropriate, I have seen a few online on all kinds of websites.
Posted: Wed Dec 11, 2024 5:36 am
by ciclo
It is not necessary to click on "quote" all the time, reading is quite uncomfortable for users, and especially for me who has to use the mouse scroll a thousand times to post images that I am sure you like a lot.
If you make it difficult for me I will not continue (I'm not kidding).🤷‍♂️
At the bottom of the page you have the 'Post Reply' button instead of 'quote' (").
Posted: Wed Dec 11, 2024 6:18 am
by omerkartal
Unfortunately my friend. I called all Skoda dealers in ISTANBUL. They said that they never had the part numbered 5JA941431A in stock. I think we will try 3C8 941 431 A on this key. Can you see the platform of this key?
I ordered the product 3C8 941 431 A . It appears on the pq25 platform. I can find it in Turkey. I think the friend in the video below bought the materials from you :)
https://www.youtube.com/@aditya.khaitan
Sorry for the warning about quoting. I'll be careful.
