DJ wrote:1. Remove the tube on the right side
2. Remove the engine cover...
3. turn the cover up side down..
4. Loosen the screw (From no. 1-11)
5. open the Lid..
I've chosen this Simota's induction Kit
I'v noticed a better responce while accelerating and a nise moan while speeding. Sorry for my bad English, I tried my best!
Thanx for the welcome, and you would be right, if I hadn't installed a pipe from the hole you see on the left of the induction kit, to the front for some cool air. Sorry that I did't post some pics with the kit finished.
Im also intreseted in getting a replacement air filter or cold air kit for my 1.9 tdi. Am I correct in thinking that the BMC CDA kits are for track use only? Has anyone fitted one?
mfa-polo wrote:Im also intreseted in getting a replacement air filter or cold air kit for my 1.9 tdi. Am I correct in thinking that the BMC CDA kits are for track use only? Has anyone fitted one?
the stock air intake on your tdi is already a cold air kit! If you want to improve it, you might consider the ibiza cupra intake hose and a drop-in filter. A cold air intake like the BMC will not do much for the tdi.
Not many people make induction kits. Found it really hard to find one!! I know k & n make them but.... dont really want one of those.
I've been told to wait a while until they do make them.
