Page 11 of 13
Re: yellow 6n2 progress thread :) (minor updates pg10)
Posted: Wed Feb 02, 2011 9:31 pm
by dub6n2
thanks mate
I really like the brakes, I am now eager to try them after the running in hehe
as for the strut brace I still have to sort out some noise coming from one of the struts after installing the brace!! sound like metal to metal sound but all the nuts are tight properly so I have no clue where the noise is coming from :/ !!
Posted: Tue Mar 15, 2011 6:53 pm
by benmkiv
are your new breaks squeaking?
mine are and its driving me nuts!
Posted: Tue Mar 15, 2011 7:07 pm
by dub6n2
hmm no not at all. When are they squeaking? when pressed or all the time? and did you give them proper running in and so on? what's the brand you are using
Posted: Tue Mar 15, 2011 9:31 pm
by cornishdrummer
Did you spray tint you side lamps black or buy them already done ?
Posted: Tue Mar 15, 2011 9:39 pm
by dub6n2
nahh only used spray tint, the same as used on the tail lights and headlamps
Posted: Tue Mar 15, 2011 9:42 pm
by dub6n2
btw a small update...bought a set of KW 40mm lowering springs
will be getting them on tomorow. hopefully it will look a little tighter. I'am also going to have a look at the tie rods because the steering is rattling so much over every bump
Posted: Tue Mar 15, 2011 10:28 pm
by cornishdrummer
dub6n2 wrote:nahh only used spray tint, the same as used on the tail lights and headlamps
How easy was it todo ?
Posted: Tue Mar 15, 2011 10:36 pm
by dub6n2
very easy. remove the side lamps, clean very well to remove any polish, wax or so and spray. if the spray doesn't hold on the first time wipe off immediately after spraying it and spray again(the spray itself will clean the surface)
Posted: Wed Mar 16, 2011 10:58 am
by cornishdrummer
dub6n2 wrote:very easy. remove the side lamps, clean very well to remove any polish, wax or so and spray. if the spray doesn't hold on the first time wipe off immediately after spraying it and spray again(the spray itself will clean the surface)
Whats the best make to buy ?
And also do you have any pics of your lights on after you tinted them ?
Posted: Wed Mar 16, 2011 12:56 pm
by dub6n2
as for the make I am not sure because I do not have the can any more as far as I know and it's bought from a local store here in Malta so I doubt you will find it there. but any ebay one should do mate
I do not have any pictures with the light on but they show clearly enough through the tint. I will take some pictures late on today dw
Posted: Wed Mar 16, 2011 10:35 pm
by cornishdrummer
dub6n2 wrote:as for the make I am not sure because I do not have the can any more as far as I know and it's bought from a local store here in Malta so I doubt you will find it there. but any ebay one should do mate
I think I will do the tinting thing, rather then mess about with after market lights which dont fit great and cost loads.
Posted: Wed Mar 16, 2011 10:43 pm
by dub6n2
cornishdrummer wrote:dub6n2 wrote:as for the make I am not sure because I do not have the can any more as far as I know and it's bought from a local store here in Malta so I doubt you will find it there. but any ebay one should do mate
yeah I found it to be the best thing to do, and the result is great if done properly
here is the picture of the blinker on
Posted: Wed Mar 16, 2011 10:49 pm
by cornishdrummer
The light can be seen clear as any thing then.
Posted: Wed Mar 16, 2011 10:50 pm
by dub6n2
and some LOWERING at last
on 40mm KW springs
tomorrow I'll take some pictures of the lowered polo
Posted: Wed Mar 16, 2011 10:55 pm
by cornishdrummer
Your car looks great.
