Cornishdrummer's Progress Thread -Im back(pg 34)
cornishdrummer
Re: Cornishdrummer's Progress Thread - New Goodies (pg 10)
Post by cornishdrummer »
Thats fine.
Thanks for your help once again.
benmkiv
Post by benmkiv »
alexperkins wrote:Pence mate
If you want good ones, osram nightbreakers
But to be fair, they are just fogs and get used once in a blue moon.
This should say To be fair they are just fogs and SHOULD get used once in a blue moon" :p
8)
cornishdrummer
So the same type as I use in my headlights will do then ?
correct. Just H7 bulbs same as your dipped beam
cornishdrummer
alexperkins wrote:correct. Just H7 bulbs same as your dipped beam
Thanks Once again Mate.
Will get down to VW dealer in the next few days, and should have them fitted and working after that. :D
6N2 GTI 00
Post by 6N2 GTI 00 »
Nice update mate :)
Gald to see you have invested in the Honeycombe fog surrounds too, you just need the lower honeycombe grill now to complete the set 8)
cornishdrummer
Thanks mate its getting there slowly.
cornishdrummer
Where abouts are the wires that go into the fogs, and has anyone got a pic of the push in mounts ?
Re: Cornishdrummer's Progress Thread - Fog Help (pg 11)
Put your hand up inside through the bumper hole. Youll find a wire thats plugged into a stub going upwards - ie it plugs into a holder with no wires coming out the other end. A torch will help
cornishdrummer
alexperkins wrote:Put your hand up inside through the bumper hole. Youll find a wire thats plugged into a stub going upwards - ie it plugs into a holder with no wires coming out the other end. A torch will help
Brill thanks found them this morning, Do I just need to unclip them when im ready to fit the fogs.
I still need to get the items from Vw dealer.
Yes
cornishdrummer
Do i need to unclip all of it, or just a part of it. I dont want to mess up or break anything.
I just found the number for my local TPS so i will give them a ring on monday regarding the screws and securing nuts
Just unclip the plug from its stub thats mounted onto the chassis - you cant mess it up
cornishdrummer
Thanks Alex.
Anyone happen to know the part numbers of the bits I need to get from the dealer ?
