BCM High to BCM Max, AFS, LED Headlights and HBA
federicodrdpro
Drives: White Polo 6R TDI
Re: BCM High to BCM Max, AFS, LED Headlights and HBA
Post by federicodrdpro »
ciclo wrote: Tue Apr 10, 2018 4:46 am ..
You clearly despise my work and my help. You throw a question to outer space as if I didn't exist.
You bite the only hand that feeds you, this is only done by one type of person.
You have made a very serious mistake doing this.
Not related:
Speaking of Humility ...
Oh, yes, here they are.
Do you have any kind of prejudice with me? again, you make a very serious mistake.
Good luck with solving your problems ... please keep us informed. Thanks.
Ciclo, I don't have any prejudice with you. I'm sorry if you thought this. Thank you for your clarify and thank you for your help. I was only waiting to finish this work on my 6R to thank you properly. You are free not to believe it.
iichel wrote: Tue Apr 10, 2018 8:14 am ..
I suspect he is mentioning the wiring scheme, to find out what coding is needed, since ciclo's suggestion is aiming at a bit (so something in the coding).
I noted a difference in the HBA coding, the second 04 in federico's scan is a an 0C in my scan (high beam type laser) but I changed it back to LED and there is no difference.
I don't know where the problem is coming from, but the wiring is OK.
Exactly.
I tried "High Beam Laser" and it work worse then "LED PR 8IT".
firegrafik wrote: Tue Apr 10, 2018 11:04 am I also have some issues with HBA
There is last year video of this with high beam flashing with HBA activated.
https://photos.app.goo.gl/7F5YLkjo09LLqD2r2
Sometimes it work only one high beam light (right or left, and sometimes no one works but blue light on IC work) also sometimes the same fault appears, for only right or left high beam
Before LED headlights I used HBA with H7 halogen headlights and it worked like charm.
I tried many coding variants for 09 and 20 units but problem hasn't gone, so the one thing I have not checked is adaptation channels values from T6 with LED headlights and HBA from the factory.
The same problem. :wink:
kartikhere_2498
Drives: 2011 VW vento (polo sedan) 1.6mpi MT
Post by kartikhere_2498 »
Hello Folks,
Where can I buy BCM MAX (for Vento, polo sedan POLO 6R) from in Germany?
I am from India and luckily one of my friend happens to be in Germany as of now so he can buy it for me :D
A little help would be much appriciated :)
Options are to source it from, i.e. ebay.de or a parts broker (new/used). Or get a 7E0 BCM from a Polo Sedan from Russia, i.e. through firegrafik or the folks on drive2.ru.
