Page 11 of 17
Posted: Thu Mar 10, 2005 10:29 am
by M@Turner
The plastic trim/centre console was the hardest bit to do. There's 2 torx screws (1 in each footwell) which need removing and then theres 2 other bolts which you need a 10mm wrench for which you can see when you remove the gater. After this, pull the trim upwards starting from the rear. There's then 2 clips which attach this to the part where your drink and tray part is. The Climate Control and cigarette lighter is attached to the bit you remove, but there's enough slack in the wire to move the trim far enough. I detached the climate control for ease of manouverability??SP
Sorry if you're lost with my description, i'm not very good at describing things, but it is very easy! 8)
I'll try and get some pics of just how little the stick now moves. Other than that it looks bog standard.
Dubpolo: You really should purchase one, they're ace and you would love it with the way you drive! :twisted:
Posted: Thu Mar 10, 2005 12:34 pm
by neilw
That Makes perfect sence M@Tuner! I knew about the two torx screws but was'nt sure where else it was attached. That will be a great help, thanks alot. Got a week off work at the end of the month so I'll have ago at fitting it then :D
Posted: Thu Mar 10, 2005 5:18 pm
by dubpolo
@JBS - can i get one abit later on in the year, say in a month or two?
the way i drive? :lol:
Posted: Fri Mar 11, 2005 2:12 pm
by Jordan
Yeah me too i would like one as well didn't have the cash just then. :D
Posted: Sat Mar 12, 2005 5:13 pm
by neilw
Fitted mine today :D
Posted: Sat Mar 12, 2005 11:57 pm
by M@Turner
NeilW: what do you think?
I'm extremely impressed with mine. :D
Posted: Sun Mar 13, 2005 2:15 pm
by neilw
Yeh seems good, althought i hav'nt driven far with it yet. Was alot easier too fit that it looks aswell.
Posted: Mon Mar 14, 2005 9:12 pm
by JBS AUTO DESIGNS
Hi
It seems that we have 1 more left in stock
We are at the moment off line at work , so I am doing all postings at home , but if you want to give me a call on 01246 550400 I can see what I can do for you.
Ask for me , Sarah
Posted: Mon Mar 14, 2005 11:10 pm
by cyhliu
Hey Sarah,
I hope the one left isn't mine! I still want it, just not had time to arrange for me to pop back up to Chesterfield! ha ha ha!
Chris
Posted: Tue Mar 15, 2005 1:27 pm
by Jordan
Would screwing of your gear knob then cutting your gear stick down a bit, then putting your gear knob back on not just do the same job. :D
Posted: Tue Mar 15, 2005 5:32 pm
by neilw
No. Because the B&M raises the Pivot point. The stick lenght is the same as it was before.
Posted: Wed Mar 16, 2005 6:07 pm
by cyhliu
Ah but would doing both make the gear change even better? But then I guess raising the pivot point is shortening the length of stick!
Posted: Thu Mar 17, 2005 12:38 pm
by neilw
I personally wouldnt shorten the stick, I'm not sure how well it would work after. I'll try and take a pic of it on my phone and post it up here later.
Posted: Thu Mar 17, 2005 2:01 pm
by neilw
Ok i borrowed work 10billion megapixcel camera. (I've reduced the size)
The blue anodised bit you can see is the raised pivot point, is hard too see in the pics tho.
Heres my car sunbathing while im stuck in the office :P
Posted: Thu Mar 17, 2005 10:29 pm
by cyhliu
Ah so that is what it looks like underneath? ha ha ha! I'm comtemplating attempting to fit it myself...
