It is very likely that I have to do a similar process in my R-line.Image
hmthakur
Drives: Polo gt tsi 1.2 dsg
Post by hmthakur »
Hi ciclo,
I am not interested in ACC but the steering i showed you is a CCS. Attaching vcds scan of my car and some photographs.
Monday,16,November,2015,20:00:32:30570
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.3.0 (x64)
Data version: 20140905
VIN: MEXC15608FT079060 License Plate: 4
Chassis Type: 60 (6N0)
Scan: 01 02 03 08 09 15 17 19 25 44
Address 01: Engine (J623-CBZB) Labels: None
Part No SW: 03F 906 070 KC HW: 03F 907 309 AJ
Component: SIMOS10.22AH10 6270
Revision: --H10--- Serial number:
Coding: 00250056230400080000
Shop #: WSC 00793 648 00255
ASAM Dataset: EV_ECM12TFS02103F 004006
ROD: N/A
VCID: 6DD7B9F6BCE6947640B-8038
No ASAM data for: "EV_ECM12TFS02103F" (VW25)
Readiness: 0000 0000
Address 02: Auto Trans Labels: 0AM-927-769.lbl
Part No SW: 0AM 300 062 R HW: 0AM 927 769 D
Component: GSG DSG AG7 431 6201
Revision: 00043014 Serial number: CU501412085377
Coding: 0000020
Shop #: WSC 01324 785 00200
VCID: 3B7347AE7A12CAC68EF-806E
Address 03: ABS Brakes (J104) Labels: None
Part No SW: 6R0 907 379 BH HW: 6R0 907 379 AS
Component: ESP9.0i front H03 0001
Serial number: --------------
Coding: 62DD2463422A03C94614246F4251C0800904
Shop #: WSC 01234 785 00200
ASAM Dataset: EV_Brake1ESP90iBOSCH 003020
ROD: EV_Brake1ESP90iBOSCH_AU21.rod
VCID: 850761560456CC3628B-80D0
Part No SW: 6R0 907 044 P HW: 6R0 907 044 P
Component: Climatronic H12 0614
Revision: V0000000
VCID: 40893042D3F4A91EDBD-8015
Address 09: Cent. Elect. (J519) Labels: 6R0-937-08x-09.clb
Part No SW: 6R0 937 087 R HW: 6R0 937 087
Component: BCM PQ25 H+4 H34 0424
Revision: BF034001 Serial number: 0681 336140556
Coding: 3AB02BBF08A10000003800007C2B9C910040414F608C0000200000000000
Shop #: WSC 124697 483 00190
VCID: 4C911472EFBC7D7E375-8019
Subsystem 1 - Part No SW: 6R0 959 802 AL HW: 6R0 959 802 AL Labels: 6R0-959-802.CLB
Component: ------------- 006 5550
Coding: 010000
Subsystem 2 - Part No SW: 6R0 959 801 AH HW: 6R0 959 801 AH Labels: 6R0-959-801.CLB
Coding: 010000
Subsystem 3 - Part No SW: 6C0 959 442 HW: 6C0 959 442
Component: E221__MFL-TAT H04 0019
Coding: 240000
Subsystem 4 - Part No SW: 6R0 959 811 L HW: 6R0 959 811 L
Coding: 020000
Subsystem 5 - Part No SW: 6R0 959 812 L HW: 6R0 959 812 L
Coding: 020000
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Part No SW: 6R0 959 655 J HW: 6R0 959 655 J
Revision: -------- Serial number: 003GW00XAULG
Coding: 003036
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 499F2D66E8CE68560C3-801C
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 6RF 920 860 Q HW: 6RF 920 860 Q
Component: KOMBI H02 0152
Coding: 140800
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04719
ROD: EV_Kombi_UDS_VDD_RM09_VW21.rod
VCID: 58B9F822236401DE83D-800D
Address 19: CAN Gateway (J533) Labels: 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 6R0 937 087
Component: GW-K-CAN TP20 H34 0424
Revision: BF034001
Coding: 002300
VCID: F0E9208223D4F99EEBD-80A5
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Component: IMMO H02 0152
Serial number:
Shop #: WSC 00000 000 00000
ROD: EV_Immo_UDS_VDD_RM09_SE36.rod
VCID: EADD32EA0D08034EA59-80BF
Address 44: Steering Assist (J500) Labels: 1Sx-909-144-44.clb
Part No SW: 1S2 909 144 P HW: 1S2 909 144 P
Component: EPS_ECU H61 1702
Coding: 0001000000000000
ROD: EV_SteerAssisNSK_SE12.rod
VCID: 418F3546D0FEA016D43-8014
End ---------------------------------------------------------------------
BCM MODULE IN MY CAR
STEERING WHEEL IN MY CAR
Engine bay of my car
Hi hmthakur, you're absolutely right, my apologies, however, I can not clearly see the buttons on the steering wheel of that eBay item.
Anyway, I can not say 100% that CCS on steering wheel will not work in your car because I have no the diagrams for that model of the steering wheel.
There some possibilities for it works on your car, but are not available the necessary diagrams to make a right installation... By mid or end next year they will be available... maybe later ... lately there are many (too many) updates on some products ... :evil: (Eg: BCM, HBA... :mrgreen:)
hmthakur wrote: Address 09: Cent. Elect. (J519) Labels: 6R0-937-08x-09.clb
Coding: 010000
Coding: 010000
Coding: 240000
Coding: 020000
Coding: 020000
But...
Is this the original steering wheel of your car?
If not, please explain how you got the button illumination.
hmthakur
Post by hmthakur »
This is the original steering wheel which came factory fitted with my car. Since Feb 2015 polos come with Mfsw with light illumination.
Ok, thank you very much for the info.
Until now we thought that the backlight of buttons in new steering wheel only was possible from the BCM 6R0937087T.
Now we know that with "R" (2015) also is possible. :wink:
Sent from my big creative computer
hmthakur
Post by hmthakur »
Can you help me with current flow diagram for CCS for bcm of my car and where would I have to connect pins in bcm and Ecuador??
hmthakur
Post by hmthakur »
Sorry connections for ecu and bcm for CCS activation in my car??
Of course, you have all the info you need in this topic:
http://www.uk-polos.net/viewtopic.php?f=56&t=65431
hmthakur
Post by hmthakur »
where can i get this part no.: 6r0953521b. Its Genuine VW Polo 6R steering colum combi switch for models with cruise control system.
gti16
Drives: VW Polo 6r 1.6 TDI
Post by gti16 »
Today I received these gifts :)
Can I connect the instrument panel just to see if it is working? If you return to the original, the keys will function normally?
Then I have to get someone to set me the keys.
Also will replace it to keep the black and white display.
hmthakur wrote:where can i get this part no.: 6r0953521b. Its Genuine VW Polo 6R steering colum combi switch for models with cruise control system.
At the VW dealer, New 120 €. (without ring)
or search on eBay...
Please if you have further questions about CCS use this topic http://www.uk-polos.net/viewtopic.php?f=56&t=65431, information may be useful to other users. Thank you.
gti16 wrote:Today I received these gifts :)
Good improvements for your 6R!! 8) Please keep us informed when you install it.
Sorry I don't know how to adapt an instrument cluster, however there are many workshops they do it, easy and fast.
My instrument cluster was new when I bought, it was installed at the VW dealer.
gti16
Post by gti16 »
I wanted to know if I can connect it only to see it turned on. And his return was to link the original without the problem of losing the memory of the keys in the original.
Can I?
Locked
