Test 3 (excellent progress 8))
New mirror 7E0 857 511 G
New rain light sensor 5K7 955 559 B
Only test (overlaid/plugged).
:!: HBA/RLS codings could be modified in the future. :wink:
VCDS Version: 15.7.0.2
Data version: 20150820
VIN: WVWZZZ6RZDY0CICLO   License Plate: NEW MIRROR 7E0 / RLS 5K7
Mileage:                 Repair Order: ciclo's rare stuff
Chassis Type: 6R (7E0)
Scan: 01 03 08 09 10 15 17 19 20 25 2E 37 44 55 56 77
VIN: WVWZZZ6RZDY0CICLO   Mileage:
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CBZC)       Labels: 03F-906-070-CBZ.clb
   Part No SW: 03F 906 070 GD    HW: 03F 907 309 AJ
   Component: SIMOS10.22AH10 2686
   Revision: --H10---    Serial number: 00000000000000
   Coding: 001100D6202400080000
   Shop #: WSC 00788 648 00255
   ASAM Dataset: EV_ECM12TFS02103F906070GD 004004
   ROD: EV_ECM12TFS02103F906070FJ.rod
   VCID: 6AC3D4C3DC7F10D2A14444D-803E
Readiness: 0110 0101
Address 03: ABS Brakes (J104)       Labels: 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 BE    HW: 6R0 907 379 AF
   Revision: --------
   Coding: 210228E3216D00B5842814EA84D300401700
   VCID: 02139C63C40FE8520974CCD-8056
   Part No SW: 6R0 907 044 H    HW: 6R0 907 044 H
   Component: Climatronic   H11 0711
   Revision: V0000000
   VCID: 38673E8BD25372C2E750BE5-806C
Address 09: Cent. Elect. (J519)       Labels: None
   Component: BCM PQ25 Max4 H80 0733
   Revision: B9080001    Serial number: 0771 100150209
   Coding: 7CB02FBF08E1240093380FD17CEB9FF0DAC0672F600D30D0200000030800
   Shop #: WSC 03607 002 104857
   VCID: 68C7AECBC2732242B770AE5-803C
   Subsystem 1 - Part No: 5K7 955 559 B
   Component: RLS 260215 03  37  0059
   Coding: 028877
   Subsystem 2 - Part No SW: 6R0 959 801 BD    HW: 6R0 959 801 BD  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  003 8612
   Coding: 0200A3
   Subsystem 3 - Part No SW: 6R0 959 802 BF    HW: 6R0 959 802 BF  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  003 8612
   Coding: 1000AB
   Subsystem 5 - Part No: 1K8 951 605 B
   Component: LIN BACKUP HO  H11 9005
   Subsystem 7 - Part No SW: 1K8 959 442     HW: 1K8 959 442
   Component: E221__MFL-DC1  H03 0103
   Coding: A4FFFF
   Subsystem 8 - Part No SW: 6R0 959 811 G    HW: 6R0 959 811 G
   Component: J388__TSG_HL  008 1611
   Coding: 18BC32
   Subsystem 9 - Part No SW: 6R0 959 812 G    HW: 6R0 959 812 G
   Component: J389__TSG_HR  008 1611
   Coding: 18BC32
Address 10: Park/Steer Assist (J446)       Labels: 6R0-919-475.clb
   Part No SW: 6R0 919 475 C    HW: 7E0 919 475
   Component: PARKHILFE 4K  H11 0013
   Revision: --------    Serial number: 47361212601014
   Coding: 308001
   ROD: EV_VW250ParkiAssis2.rod
   VCID: 3E6B2893F0774C722D0C78D-806A
   Component: VW10Airbag01M H10 0020
   Revision: --------    Serial number: 003GX01JKVVP
   Coding: 00314D
   Shop #: WSC 01383 785 00200
   ROD: EV_AirbaVW10BPAVW250_SE25.rod
   VCID: 4A837443BCBFF0D28184E4D-801E
   Crash sensor for side airbag; driver side:
   Serial number: 3575HRB405N1C4LI7929
   Crash sensor for side airbag; front passenger side:
   Serial number: 3585HRB405B1D5MS8GS2
   Crash sensor for side airbag; rear; driver side:
   Serial number: 3515RRB405B17ABS901.
   Crash sensor for side airbag; rear; passenger side:
   Serial number: 3525RRB405B181TUDPKC
   Part No SW: 6R0 920 870 C    HW: 6R0 920 870 C
   Component: KOMBI         H05 0607
   Coding: 140E01
   Shop #: WSC 00233 572 91226
   ROD: EV_Kombi_UDS_VDD_RM09_SK35.rod
   VCID: 357937BFC5418F2AFC769F9-8060
   Component: GW-K-CAN TP20 H80 0733
   Revision: B9080001
   Coding: 002200
Address 20: High Beam Assist. (J844)       Labels: 8S0-857-511.clb
   Revision: AA001001
   Coding: 040400E200000000000000
   Shop #: WSC 12345 123 12345
   VCID: 2E4B18D32017BCF2BDAC28D-807A
   Component: IMMO          H05 0607
   Shop #: WSC 00000 000 00000
   ROD: EV_Immo_UDS_VDD_RM09_SE25.rod
Address 2E: Media Player 3 (J650)       Labels: 5N0-035-342.lbl
   Part No SW: 5N0 035 342 F    HW: 5N0 035 342 F
   Component: SG EXT.PLAYER H18 0530
   Revision: A1001003    Serial number: 7662584630
   Coding: 010100
   VCID: 2A4314C31CFFD05261C404D-807E
Address 37: Navigation (J0506)       Labels: 1T0-035-680.clb
   Part No SW: 1T0 035 680 L    HW: 1T0 035 680 C
   Component: RNS-MID       H06 5218
   Revision: AB001001    Serial number: VWZ6Z7L7654213
   Coding: 04000442040000A12001
   VCID: 37653DB7DF4D7DBAEE4AB51-8062
   Subsystem 1 - Part No: 1T0 919 859 B
   Component: EU West V9  7918
   Part No: 6R0 423 156 B
   Coding: 11250
   Shop #: WSC 00788
   VCID: 2F7505D7271DBC3AB6BADD1-807A
Address 55: Headlight Range (J431)       Labels: 6R0-907-357.clb
   Revision: --------    Serial number: --------------
   Coding: 0112000001000000
   VCID: 77E5FDB79FCDBD3A2ECAF51-8022
Address 56: Radio (J0506)       Labels: 1T0-035-680.clb
Address 77: Telephone (J412)       Labels: 7P6-035-730.clb
   Part No SW: 7P6 035 730 L    HW: 7P6 035 730 L
   Component: TELEFON       H15 3200
   Revision: 1B001001    Serial number: 00007664158506
   Coding: 0501000000010110
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA.rod
   VCID: 3B6D2187E365595A0A32591-806E
End-------------------------(Elapsed Time: 03:15)--------------------------
I have yet to find Adaptation-coding of stalks 7E0 to set the beam headlights when it is pushed and comes back to center position...
you. are. crazy
gti16
Drives: VW Polo 6r 1.6 TDI
Post by gti16 »
you will replace the light and rain sensor?
Yes, I'll do it...in process. 28mm diameter.
Image... :twisted:
Clip and cover cap for wires from VW T6 need slight modification to fit on VW 6R (more schoolwork :)).
Edit:
Clip modified to test.
With clip to test. 8)
During installation process I have damaged gel pad that is attached on rain sensorImage... I will have buy new one (8U0955609).
... this is the result pending to solve the problem with gel pad in order to improve the aspect of the circle visible in this image.
IMHO it is a minor problem because the whole has very good appearance... despite of this the rain light sensor works perfectly, tested.
Edit:
With new gel pad.
...but bad weather day to take pictures with phone.
so... you removed the old sensor bracket and sensor, painted your front window for a part, used all the primers etc, glued the new holder on, attached the new light sensor, clipped on new mirror, modded covers and installed it all?
wow...
and take the pictures... :lol:
I have also solved the problem of the stalks with the fixing of the high beams...
I have to edit a poor quality video I made ...one of these days... :twisted: :twisted: :twisted:
- double post -
could you want to tell me how you managed that? then i can fit the 7e0 stalks too :-) didn't do it yet because i need high beam when i drive in the evening/morning here
The first of the world with this feature on a 6R.Image
iichel better we talk by email tomorrow. :wink:
CNK
Drives: 6R
Post by CNK »
ciclo wrote:The first of the world with this feature on a 6R.Image
OMG :shock: Does it works? :?:
Locked
