Page 12 of 13
Re: yellow 6n2 progress thread :) (minor updates pg10)
Posted: Wed Mar 16, 2011 10:57 pm
by dub6n2
thanks loads mate :) it looks really better now that it is lowered, though it would have needed some more on the front :roll: ... hope it doesn't give the impression of a reversed rake set up
btw I really need help on this one!! I forget to put on the washer seen in the picture. It is the lowest piece that goes onto the rear shock absorber!! just underneath the large metal plate sort of thing. Can I do without it or do I have to remove the suspension again and put it back in!!??
Re: yellow 6n2 progress thread :) (KW springs-40mm lower :)
Posted: Thu Mar 17, 2011 9:30 am
by alexperkins
It needs to go in. It stops the shock pushing through the bush!
Take it out and refit it as soon as you can.
Posted: Thu Mar 17, 2011 11:09 am
by dub6n2
alexperkins wrote:It needs to go in. It stops the shock pushing through the bush!
thanks loads alex :)
done already this morning, I really do not want any more damage to happen. How I hate doing the same job twice for a stupid mistake! :x
btw talking about damage, my steering seems to rattle with every bump I go over, do you think its a worn tie rod problem or something in the steering shaft or rake??
Posted: Thu Mar 17, 2011 11:13 am
by dub6n2
cornishdrummer wrote:
dub6n2 wrote:very easy. remove the side lamps, clean very well to remove any polish, wax or so and spray. if the spray doesn't hold on the first time wipe off immediately after spraying it and spray again(the spray itself will clean the surface) :wink:
Whats the best make to buy ?
And also do you have any pics of your lights on after you tinted them ?
found the can of the tint spray I used...it's a Motip brand(tuning line) was the cheapest I found and did an awesome job. and it almost stops no light at all.
http://www.motip.nl/?page=23&id=538
Posted: Thu Mar 17, 2011 11:19 am
by alexperkins
The steering rattle could be a few things. It could be a tie rod, but id get your steering rack checked to make sure its mounted securely in the engine bay and under the dash.
Posted: Thu Mar 17, 2011 4:54 pm
by dub6n2
alexperkins wrote:The steering rattle could be a few things. It could be a tie rod, but id get your steering rack checked to make sure its mounted securely in the engine bay and under the dash.
as for the rack I checked for myself and it should be mounted correctly. Went to the local garage to ask him and he said that it's most probably the tie rods. I am taking it next week for a timing belt change and he'll check it once there.
Posted: Thu Mar 17, 2011 6:10 pm
by dub6n2
I am planning on prying open the headlamps and side lamps so that I can spray some of the chrome and give them a darker look(also on one of the side lamps the chrome is flaking). does anyone know how to open them?? I am assuming that I have to do it the oven way as they do on the other cars no? heat it up so to melt the glue that holds the clear cover from the rest?
Posted: Fri Mar 18, 2011 12:56 am
by dub6n2
pictures after lowering. the back looks neater but the front still seems high and I have the impression that it's in reverse rake which it terribly BAD!!!
FRONT :/
some work on the front end ... ended up ruining a side lamp :/
so is there some freken way I will be able to slightly lower the front end a tad more so at least I get the front level with the rear end? maybe modify something from the top mounts or remove something that seems to be useless?
Posted: Fri Mar 18, 2011 8:05 am
by alexperkins
Not for that much drop. Either chop the spring or take the weight out the boot!
With regard to opening the headlights - thats an oven job. The indicators are bonded and youd have to cut them apart
Posted: Fri Mar 18, 2011 8:40 am
by 6N2 GTI 00
What Alex said was spot on whichever way you go about it wont be brilliant.
The rear springs normally lower the car 25-30mm whereas the front should be 35-40mm.
Cutting the front springs down slightly will drop it to the same height
Posted: Fri Mar 18, 2011 2:34 pm
by red6n2
i havent poset in a while mate nice to see the progress you have made, :)
Posted: Fri Mar 18, 2011 2:40 pm
by dub6n2
hehe thanks mate, yeah slowly slowly progressing, although if I find the opportunity I sell the car and go for a better one, ie more powerful and with extras...
hmm :/ would not like to mess with the springs like that ... I measured from the arch to the floor and the rear dropped exactly 40mm and as for the front I forgot to measure before! so to balance it I may go the light weight route...no rear seats and stuff and no bass box ... maybe...
as for the oven job I'll skip it...tried it on an indicator and when heating it to close it back I ended up with a plastic pancake stupid me :roll:
Posted: Sat Mar 19, 2011 10:11 pm
by cornishdrummer
dub6n2 wrote: as for the oven job I'll skip it...tried it on an indicator and when heating it to close it back I ended up with a plastic pancake stupid me :roll:
That aint good 8)
Posted: Sun Mar 20, 2011 12:28 am
by dub6n2
hehe not at all :? ... could have spent the money else where on the polo.
Today I am attending for the first time a small VW meet here in Malta :D hope all goes well as we are crossing the channel to the other small island Gozo
Posted: Sat Aug 13, 2011 2:49 pm
by dub6n2
heyy long time not posts...not much going on my polo apart from the usual maintenance. Have just fitted a pair of k&n panel filters, modified the airbox for more airflow and changed the fuel filter. Now what I would like to fix is my dodgy fuel meter...after a good run (pedal to the metal :P ) the gauge has a tendency of marking as empty and the light will turn on even if it is half or a little less full ... and it would remain stuck like that for as much as it likes, usually 2-3 days and goes back up!! I use to swipe the gauges with vag-com and that would solve the problem but it is not very convenient to scan it every time!! So does anyone know if it is a pump/sender problem or an instrument cluster problem??
