6R 1.6TDI 90HP CAYB 2009
Ugabista
Drives: Vw Polo 6R 1.6TDI 90CV CAYB
Re: 6R 1.6TDI 90HP CAYB 2009
Post by Ugabista »
Hello friends,
For my Polo 6R with DRL in headlights, wich cables is great for upgrade DRL for fog lights? (with hole for drl);
This:
http://www.ebay.it/itm/191430324664
or this;
http://www.ebay.es/itm/201229178988
Basicly, the diference is the fuse??
[emoji5]
But maybe you need to change the light switch. (search on ETKA online)
There are five ways to connect the DRL's (TFL) for Polo 6R. :lol: :lol: (Depends on equipment... BCM model, Light Switch, etc...)
Your current one is like 5 in diagramas, and because of your BCM-High you need to install like 1 (via SB56 fuse).
Ugabista
Re: RE: Re: 6R 1.6TDI 90HP CAYB 2009
Post by Ugabista »
ciclo wrote:http://www.ebay.es/itm/201229178988
There are five ways to connect the DRL's (TFL) for Polo 6R. [emoji38] [emoji38] (Depends on equipment... BCM model, Light Switch, etc...)
Jesus Christ ... it is better to get off this idea of ​​the head, I have the chinese light module, that must make the mod impossible...[emoji85]
It's just the opposite :twisted: ... :lol: , now it's perfect, you should not worry about the light switch anymore.
The black box from aliexpress kit should have a relay dedicated to the DRL's.
This is what you have to do:
- Route the wires from the DRLs to the fuse box.
- Connect this wires (wire) to SB56b slot.
- Connect the new 1.0 mm wire (at least) to T17/3 light switch connector. (isolate original T17/3)
- Route the new wire to the fuse box into the SB56a slot.
- Install a 15 Amp fuse.
Info:
a = INPUT
b = OUTPUT
And now you can enjoy your DRL's. (beside fog lights, without BCM control)
+ info:
No BCM control because your BCM does not have the 3b, 5a pins.
Ugabista
Post by Ugabista »
ciclo wrote:It's just the opposite :twisted: ... [emoji38] , now it's perfect, you should not worry about the light switch anymore.
Info:
a = INPUT
b = OUTPUT
+ info:
[emoji46] Brilliant friend!! [emoji75]
I regained interest in mod. [emoji3] [emoji111]
Ugabista
Post by Ugabista »
So with these equipments ....
https://www.aliexpress.com/item/For-VW- ... 13afad26e8
http://www.ebay.com/itm/201229178988?_t ... EBIDX%3AIT
http://www.ebay.com/itm/12V-21w-Scheinw ... xyCGNTLrTP
Even with the chinese module, when it dims and switches on the headlights, it will erase the DRLs, is that it? [emoji5]
If i do, it can be, right? [emoji5]
Ugabista
Post by Ugabista »
Can it be done so[emoji780] [emoji102]
Hmm... Yes
If you mean the following in the diagram:
- Switch, Lights, Original = original light switch connector
- Fog Light = new DRL
You have to keep in mind that people copy the diagrams and then they do weird things ...
Ugabista
Post by Ugabista »
ciclo wrote:Hmm... Yes
Yes, you right friend!!...[emoji1]
Sorry for all that amazing poison diagram...[emoji33] [emoji38]
Ugabista
Post by Ugabista »
I would like to put speakers on the doors behind in my Polo 5 doors. Anybody know what I might need material to do?
2x 6R0035453C
2x 1K8971798
And what else? What threads are needed? I can not understand ETKA. :cry:
To connect to RNS510.
Thank you in advance. :)
Ugabista
Post by Ugabista »
One question; Air vents, left and right (no center), the Polo 6C are Plug&play in Polo 6R?
Yes sir
Ugabista
Post by Ugabista »
iichel wrote:Yes sir
Thank you Sir! [emoji4]
Ugabista
Post by Ugabista »
Ugabista wrote:So with these equipments ....
Correction. [emoji4] Image
Ugabista
Post by Ugabista »
DONE! 8)
Thanks friend @Ciclo :)
