ciclo. Wife's Golf MK7.5 Ready2Go 1.0 TSI 6MT 200Nm/l 115HP. 🧙♂️
exantas
Re: ciclo. Wife's Golf MK7.5 Ready2Go 1.0 TSI 6MT 200Nm/l 115HP
Starting on the basis that each person is responsible on each change that they decide to do on the car.
Say you have your new T-roc that comes with rain sensor, electric windows and a bcm that is compatible. The car comes without the option to automatically close the windows when it detect rain, but you know how to code this with VCDS, Odis-e or whatever tool and you enable it outside an authorised workshop.
From what you might have read or heard, will something like that fall under the category to void your cars warranty?
I'm not talking about messing the coding, but say your electric folding mirrors stop working because the motor gave up a year after you bought the car.
dcgumis
- Drives: polo 1.4 85KM CGGB/GOLF 7.5
nice color
This is already the fourth car?
I fully understand what you mean and it is the concern of many car owners, but I assure you that I have no concerns about warranties, ... I don't know how to say without seeming strange or arrogant (please take account) that my time is more valuable than make use of the warranty because the electric motor of a mirror is broken or does not work and have to take the car to the dealer to be repaired after making an appointment that only the masters of the universe know when it will be possible for them to accept my car for repair.exantas wrote: Wed Sep 02, 2020 8:08 pm Starting on the basis that each person is responsible on each change that they decide to do on the car.
I buy a new mirror, damper, or whatever is broken and change it myself in a couple of hours ... fixed and everyone happy in time and space.
I have to say that I made use of the warranty (with the warranty expired) for an A3 air intake flap which was a recognized problem, and both Customer Service and the Dealer solved it perfectly. I had to wait for the appointment they gave me, but if I had known the price of the part beforehand I would have repaired it myself without a doubt, without having to think about strange things (occupying my mind) during the wait until its repair... take the car to the dealer, repair time, pick it up, etc ... too long for me.
Thank you very much dcgumis!
Yes, but the 6R doesn't count because it's my toy.
Golf 7.5 Passenger seat installation after installing the heating elements.
I apologize for the quality of the images, I did not take pictures of the four bolts or the insulation/security system of the airbag connectors while the seat remains removed (cloth tape
As I did with the 6R, I take the opportunity to vacuum and clean the interior with the seats removed.
Neat job Fernando, looks as clean as it should be. Very nice, very OEM
Thank you Michel, everything is on the right track, although I should have all the improvements finished by now, ... I guess I'll finish next week.
However I'm enjoying this overhaul, it's easier than with our Polo 6Rs.
I can imagine, having more space makes life a lot easier.
Due Images. Crimp of added wires in an original connector.
viewtopic.php?f=58&t=72376&start=135#p574431
We cut the original wire right at the edge of the contact-terminal and strip the original wire enough to crimp the new contact-terminal together with the wire to be added.
IMHO, the best way to splice, attach, join, 'tap', add a new wire ... you can do it for very little money with excellent result.
The following images are from the three connectors on the air conditioning unit. The feed for the USB HUB is added to the climatronic unit feed after studying if possible (fuse, signal, electrical parameters, etc).
Remember to cut off the power supply before working with wires in the car.
T-Cross delivered!
https://www.youtube.com/watch?v=M7wILCe2khk
Saturday,05,September,2020,12:31:44:32438
VCDS Version: 20.4.2.0 (x64) HEX-V2 CB: 0.4526.4
Data version: 20200730 DS317.0
www.Ross-Tech.com
VIN: WVGZZZC1ZLYCICLOF License Plate: T CROSS
Mileage: 6km-3mi Repair Order:
Chassis Type: C1-VW27 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 17 19 2B 3C 44 47 55 5F 75 A5 D6
D7
VIN: WVGZZZC1ZLYCICLOF Mileage: 6km-3miles
05-Acc/Start Auth. -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
47-Sound System -- Status: OK 0000
75-Telematics -- Status: OK 0000
A5-Frt Sens. Drv. Assist -- Status: OK 0000
D6-Light Ctrl Left 2 -- Status: OK 0000
D7-Light Ctrl Right 2 -- Status: OK 0000
Address 01: Engine (J623-DPCA) Labels: None
Part No SW: 05E 906 018 AQ HW: 05E 907 309 H
Component: R4 1.5l TFS H20 9662
Revision: 8AH20000
Coding: 0125003223641D0810000000000000000000000000000000
Shop #: WSC 00000 000 08192
ASAM Dataset: EV_ECM15TFS01105E906018AQ 003003
ROD: EV_ECM15TFS01105E906018AQ_VW27.rod
VCID: 74B121AC1E3CC4CB46B-8020
Readiness: 1110 0001
Address 02: Auto Trans (J743) Labels: 0CW-927-769.clb
Part No SW: 0CW 300 050 J HW: 0AM 927 769 E
Component: GSG DQ200G2_M H05 1913
Revision: 00005009 Serial number: CU502006295147
Coding: 0014
Shop #: WSC 00788 648 00255
ASAM Dataset: EV_TCMDQ200021 001001
ROD: EV_TCMDQ200021_VW27.rod
VCID: 3C21C98C76EC4C8B4EB-8068
Address 03: ABS Brakes (J104) Labels: None
Part No SW: 2Q0 614 517 AQ HW: 2Q0 614 517 M
Component: ESC_high_vFGS H34 0362
Serial number: 08502444200624
Coding: 92054C3E3D4549B13202BC1912E111A649344D06336A24482454625545488865922CB260CC562412242A46AAA269D64FFF966BF2FF90AC90093509
ASAM Dataset: EV_Brake1BOSCHESPMQBA0 005001
ROD: EV_Brake1BOSCHESPMQBA0_005.rod
VCID: 7DA704882D768583395-8028
Address 05: Acc/Start Auth. (J518) Labels:| 5Q0-959-435.clb
Part No SW: 3Q0 959 435 N HW: 3Q0 959 435 N
Component: VWKESSYMQB 037 1307
Revision: 00037000 Serial number: 0551789745
Coding: 132C0C0723
ASAM Dataset: EV_KessyHellaMQBAB 004052
ROD: EV_KessyHellaMQBAB.rod
VCID: 45D7AC6805260D43215-8010
Address 08: Auto HVAC (J255) Labels:* Redir Fail!
Part No SW: 2G0 907 044 Q HW: 2G0 907 044 Q
Component: Climatronic H05 0701
Coding: 612000000800010001100800524401150110000000000000000000000000
ASAM Dataset: EV_ACClimaBHBMQBA0 004023
ROD: EV_ACClimaBHBMQBA0_VW27.rod
VCID: 323DE7B4A4A88AFB947-8066
Address 09: Cent. Elect. (J519) Labels:. 5Q0-937-08X-V2.clb
Part No SW: 2Q0 937 090 B HW: 2Q0 937 090
Component: BCM A0 Std+ H10 0936
Serial number: 01102021300393
ASAM Dataset: EV_BCMA0 205001
ROD: EV_BCMA0_205.rod
VCID: 313FE8B8A1AEB1E3EDD-8064
Rain Light Recognition Sensor:
Subsystem 1 - Part No SW: 5Q0 955 547 C HW: 5Q0 955 547 C Labels: 5Q0-955-547.CLB
Component: RLHS 054 0206
Serial number: S7Y20M06D16H04M43S41
Coding: 0018DD
Drivers Door Control Module:
Subsystem 2 - Part No SW: 2Q2 959 405 B HW: 2Q2 959 163 B
Component: FHSG_DRV 002 0005
Serial number: 00000000000042125820
Coding: 0380F3
Front Passengers Door Control Module:
Subsystem 3 - Part No SW: 2Q2 959 406 B HW: 2Q2 959 164 B
Component: FHSG_PSG 002 0005
Serial number: 00000000000042144457
Coding: 1980F3
Drivers Door Rear Control Module:
Subsystem 4 - Part No SW: 5Q0 959 407 D HW: 5Q0 959 163 C
Component: FOND_FHSG_DRV 007 0011
Serial number: 00000000000042134336
Coding: 030000
Passengers Rear Door Control Module:
Subsystem 5 - Part No SW: 5Q0 959 408 D HW: 5Q0 959 164 C
Component: FOND_FHSG_PSG 007 0011
Serial number: 00000000000042103471
Coding: 1B0000
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-298.clb
Part No SW: 5QA 919 298 H HW: 5QA 919 298 A
Component: PLA 3.0 12K H08 0061
Serial number: 000150057320174
Coding: 0271167851
ASAM Dataset: EV_EPHVA2CAU3700000 009048
ROD: EV_EPHVA2CAU3700000_VW27.rod
VCID: 55F77C28F586BDC3515-8000
Address 13: Auto Dist. Reg (J428) Labels:| 2Q0-907-572.clb
Part No SW: 2Q0 907 572 R HW: 2Q0 907 572 B
Component: ACCCONTIMQB H03 0372
Coding: 3204678348FF8748949C810580508700000000000000000004
ASAM Dataset: EV_ACCMRRCONTIVW376 003016
ROD: EV_ACCMRRCONTIVW376_003_VW27.rod
VCID: 43D3B2700B1233730F1-8016
Address 15: Airbags (J234) Labels:* None
Part No SW: 2Q0 959 655 AM HW: 2Q0 959 655 AM
Component: VW22Airbag 016 0351
Revision: --------
Coding: 88CCC0C0000000005C5400CF000C40A80065
ASAM Dataset: EV_AirbaVW22BPAVW27X 001020
ROD: EV_AirbaVW22BPAVW27X_VW27.rod
VCID: 0849655C72B4D02B1A3-805C
Belt Pretensioner left:
Subsystem 1 - Part No SW: 654 980 945 A HW: 654 980 945 A
Component: BeltPretRevFL 005 0060
Serial number: 278A.001703082000247
Coding: 303630
Belt Pretensioner right:
Subsystem 2 - Part No SW: 654 980 946 A HW: 654 980 946 A
Component: BeltPretRevFR 005 0060
Serial number: 278A.001705082000197
Coding: 303630
Side Sensor Driver Front:
Subsystem 3 - Part No SW: ----------- HW: 442 062 907 20
Component: SideSensor_Df 1E2 0887
Serial number: 3577Y50A336219F490C6
Coding: 2D2D2D
Side Sensor Passenger Front:
Subsystem 4 - Part No SW: ----------- HW: 442 062 907 20
Component: SideSensor_Pf 1E2 0887
Serial number: 3587Y50AB34FC4F422CR
Coding: 2D2D2D
Side Sensor Driver Rear:
Subsystem 5 - Part No SW: ----------- HW: 442 0B0 406 20
Component: SideSensor_Dr 1C7 0148
Serial number: 3517731A136BE57582DQ
Coding: 2D2D2D
Side Sensor Passenger Rear:
Subsystem 6 - Part No SW: ----------- HW: 442 0B2 005 20
Component: SideSensor_Pr 1C7 0148
Serial number: 3527781C73648F84A38Z
Coding: 2D2D2D
Front Sensor Driver:
Subsystem 7 - Part No SW: ----------- HW: 442 132 006 20
Component: FrontSensor_D 290 118A
Serial number: 355AG11C53450165F5BR
Coding: 2D2D2D
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI3
Part No SW: 2G0 920 790 B HW: 2G0 920 790 B
Component: KOMBI 503 4194
Coding: 04A410186D8800080188620B5001000800000404
ASAM Dataset: EV_DashBoardVDDMQBA0 001042
ROD: EV_DashBoardVDDMQBA0_VW27.rod
VCID: 26150BE49860E65B08F-8072
Address 19: CAN Gateway (J533) Labels:| 3Q0-907-530-V1.clb
Part No SW: 3Q0 907 530 AC HW: 3Q0 907 530 C
Component: GW MQB High 442 4388
Revision: -------- Serial number: 0001025084
Coding: 030100046F085600FB10025C180F00010001070000000000000000000000
ASAM Dataset: EV_GatewNF 013026
ROD: EV_GatewNF_VW27.rod
VCID: 70B92DBC6A24F8EBA23-8024
Alternator:
Component: 5-00-14-00-04
Multi Function Steering Wheel Control Module:
Subsystem 2 - Part No SW: 3G0 959 442 F HW: 3G0 959 442 F
Component: E221__MFL-PR6 H06 0110
Serial number: YLG-0700084183203118
Coding: 2D1D00
Subsystem 3 - Part No SW: 2Q0 915 181 B HW: 2Q0 915 181 B
Component: J367-BDMBOSCH H02 2012
Serial number: 100D32D5
Address 2B: Steer. Col. Lock (J764) Labels:* 5Q0-905-861.clb
Part No SW: 2Q0 905 861 A HW: 2Q0 905 861 A
Component: ELV-MQBB H08 0021
Serial number: 20000111927007
Coding: 0800000000000000
ASAM Dataset: EV_ELVMarqMQBA0 002002
ROD: EV_ELVMarqMQBA0_VW27.rod
Address 3C: Lane Change (J1086) Labels:* None
Part No SW: 2Q0 907 686 A HW: 2Q0 907 686 A
Component: HRE3_Kl15_Mst H05 0052
Serial number: 14520003204568
Coding: 50014500
ASAM Dataset: EV_HREntryHellaGen3Kl15 001009
ROD: EV_HREntryHellaGen3Kl15_001_VW48.rod
VCID: 3829D59C42D460ABAA3-806C
Address 44: Steering Assist (J792) Labels:* None
Part No SW: 2Q1 909 144 M HW: 2Q1 909 144 F
Component: TRW_G4L_MQBA0 611 6041
Serial number: 01980672CP3L230
Coding: 010001010100000101010201010001000000010101
ASAM Dataset: EV_SteerAssisTRWG4LMQBA0 011016
ROD: EV_SteerAssisTRWG4LMQBA0.rod
Address 47: Sound System (J525) Labels:* None
Part No SW: 5Q6 035 456 HW: 5Q6 035 456
Component: KonzernAmp 8K H01 2427
Revision: -------- Serial number: A1117A00225732
Coding: 0202000000AAAA00000000000000
ASAM Dataset: EV_AMPCAN8C1PASE 001015
ROD: EV_AMPCAN8C1PASE.rod
VCID: 73B322B01B32C3F35F1-8026
Address 55: Headlight Range (J745) Labels:| 7P6-907-357.clb
Part No SW: 7P6 907 357 E HW: 7P6 907 357 A
Component: AFS-ECU H07 0080
Revision: -------- Serial number: --------------
Coding: 068A000001200003
ASAM Dataset: EV_HeadlRegulAFSMQBMAX 001001
ROD: EV_HeadlRegulAFSMQBMAX_VW27.rod
VCID: 41DFB878110E21631DD-8014
Address 5F: Information Electr. (J794) Labels:* None
Part No SW: 2GM 035 874 HW: 2GM 035 874
Component: MU-S-ND-ER H42 0478
Serial number: VWZAZ2X0881064
Coding: 02120601AA0000004111010300880A211F0510F401200000CE
ROD: EV_MUStd4CTSAT_VW27.rod
VCID: 015F7878518EE1635DD-8054
Operating And Display Unit 1:
Subsystem 1 - Part No SW: 5G6 919 605 B HW: 5G6 919 605 B
Component: ABT_Std-2_Nav 361 8214
Serial number: VWZ6ZHX2042614
Data medium:
Subsystem 2 - Part No SW: 5NA 919 866 S HW: -----------
Component: ECE1 2020 --- 1310
Address 75: Telematics (J949) Labels:| 5QE-035-285.clb
Part No SW: 5NA 035 284 C HW: 5NA 035 284 C
Component: OCULowMQBLGE H19 0827
Revision: --------
Coding: 022106016AB6140D0100040000354003804600
ASAM Dataset: EV_OCULowMQBLGE 004049
ROD: EV_OCULowMQBLGE_004_VW27.rod
VCID: 3D27C4886DF64583795-8068
Address A5: Frt Sens. Drv. Assist (R242) Labels:| 3Q0-980-65X-A5.clb
Part No SW: 3Q0 980 654 R HW: 3Q0 980 654 A
Component: MQB_B_MFK H13 0460
Serial number: 29072012P11995
Coding: 000207060000040100221354C156440084000E20002000
ASAM Dataset: EV_MFKBoschMQBB 002041
ROD: EV_MFKBoschMQBB_002.rod
VCID: 46D5AB643820065B28F-8012
Address D6: Light Ctrl Left 2 (A31) Labels: 7PP-941-572.clb
Part No SW: 992 941 571 AC HW: 992 941 571 A
Component: LED1L H08 9201
ASAM Dataset: EV_LLPGen3LKEBODPO68X 001003
ROD: EV_LLPGen3LKEBODPO68X_VW27.rod
VCID: 639352F0ABD253732F1-8036
Address D7: Light Ctrl Right 2 (A27) Labels: 7PP-941-572.clb
Component: LED1R H08 9201
ASAM Dataset: EV_LLPGen3RKEBODPO68X 001003
End----------(Elapsed Time: 01:25, VBatt start/end: 12.4V/12.4V)-----------
El holandés ha llegado
First sensations:
This T-Cross is very comfortable to drive (its extensive factory equipments helps), the multifunction steering wheel is pleasant to handle, but I cannot say that it is better or worse than the previous ones like the one on my wife's Golf ... I think at the same level of handling.
In terms of construction it is quite far from the utility cars and closely approximates the Golf mk7.5, ... very good sensations in this first contact according to several relatives. It is fine for large people.
The electric parking brake with all its functions is missing, inside you breathe Golf atmosphere until you have to put the handbrake ... but it's the same feeling that happens to me when I drive my wife's Golf and then the 6R.
El holandés looks pretty in the sun.
exantas
Enjoy Ciclo
Question on the Mib system in the Golf or the TRoc. Do you connect it to the Internet? What I'm wondering if you have managed to get the VW navigation system show traffic status on the street, like you get on Google maps (green, yellow, red street because of traffic jam).
Sent from my Mi Note 10 Pro using Tapatalk
Thank you.
exantas, it is a VW T-Cross (VW27 -POLO AW- platform), NOT a VW T-Roc (VW37 -GOLF- platform).
Maybe you're joking and I don't get the point of your joke, which I think is great
, but this is the second time I've told you that it is a T-Cross.
The VW MIB Gen2.5 navigation system takes into account alerts/warnings/traffic information according to the GPS and the radio station chosen for these alerts, which can be displayed in a specific menu of the infotainment system, and the navigation can be configured to choose alternative routes to avoid traffic jams, etc.
This is also done by my RNS510 which is installed in my 6R since a long time ago.
I don't like being connected while driving for compelling reasons, but I tend to choose the WAZE for real-time 'traffic information'...
, although I'm not one of those who interacts while driving...
Golf 7.5 Installation of Climatronic Unit with buttons for heated seats. OK! (Heated Seats)
Note:
- Touch Climatronic Unit 5NA907044AJ (EU model) and G935 sensor at the end of this post.
Previous infomation:
Parts
viewtopic.php?f=58&t=72376&start=90#p572441
BCM
viewtopic.php?f=58&t=72376&start=120#p573716
Fuse
viewtopic.php?f=58&t=72376&start=135#p574274
Heating elements
viewtopic.php?f=58&t=72376&start=150#p574833
Seat installation
viewtopic.php?f=58&t=72376&start=165#p574894
Note: Touch Climatronic Unit 5NA907044AJ at the end of this post.
Once the Climatronic unit is installed we see with the diagnostic tool (VCDS) that we have two or more faults in Address 08. The A/C button does not work/does not light up.
1- Do this,
https://www.youtube.com/watch?v=KJhaL65HL9Q
2- and this,
http://wiki.ross-tech.com/wiki/index.ph ... )_Climatic
I had to do it twice. The second time it worked after having taken a ride with the car.
You must modify (without modifying - same value) the adaptation channel indicated for the basic setting.
Clear the faults.
Check that everything works correctly both in the Climatronic Unit and through the MENU for Infotainment system.
If you installed the BCM correctly, you will see that the buttons on the heated seats light up briefly and turn off in about 2 seconds.
In other words, the heated seats do not work.
To operate the heated seats, the values of the following adaptation channels of the BCM must be modified in the same way. Choose the one that suits you best.
From CE to CF:
Address 08: Auto HVAC (J255) Labels:| 5G0-907-044.clb
Part No SW: 5G0 907 044 CF HW: 5G0 907 044 CF
Component: Climatronic H04 1801
Revision: 00001K08
Coding: 00020003200110011005004000101022
Shop #: WSC 00028 028 00068
ASAM Dataset: EV_ACClimaBHBVW37X 006145
ROD: EV_ACClimaBHBVW37X_006_VW37.rod
VCID: 6D8734C87D161503895-8038
Fresh Air Blower Front:
Geber für Kältemitteldruck/Kältemitteltemperatur:
Air quality sensor:
Works like a charm.
Edit...
ctober 7, 2021
Golf 7.5 Touch Climatronic Unit 5NA907044AJ. EU model 'SYNC button'. Coding process with VCDS.
Video.
Original Video
: https://www.youtube.com/embed/6Mga9ZPwB ... autoplay=1
Touch Climatronic Unit 5NA907044AJ...
https://www.drive2.com/market/offers/1085300
Gray frame ... from Ali
https://es.aliexpress.com/item/40011907 ... 63c0P5Ei33
VCDS Coding:
I'm sure that Ross-tech will be able to debug and explain (wiki) the basic setting for these air conditioning units much better than the one I have done here, ... I just try to help so that my experience may be useful to verify these processes.
The Basic Setting process with the VCP is in the same way and for OBDII there is a good video on youtube (search by part number).
With the VAS5054 I didn't even try because I am in the update process...
Address 08: Auto HVAC (E87) Labels:| 5G0-907-044.clb
Part No SW: 5NA 907 044 AJ HW: 5NA 907 044 AJ
Component: AC Automat H50 1301
Revision: 20K03000 Serial number: 00000A00202735
Coding: 000200032001100D110500400010142A
Shop #: WSC 12345 123 12345
ASAM Dataset: EV_ACTouchPrehVW37X 001010
ROD: EV_ACTouchPrehVW37X_VW37.rod
VCID: 074B66607FAADF53E6B-8052
Air quality sensor:
Works like a charm.
I've done a bit of research on that Air quality sensor, which I think suits me ... there are still too many nasty squid active spilling their foul ink.
Autoscan
It takes 10 seconds less to perform an Autoscan with this Touch Climatronic installed. Super fast.🏎
In the following video you can see the enormous amount of time it takes to read/diagnose the old/original HVAC unit (knurled buttons).
https://youtu.be/S242_zhWfCI?t=65
From G238 5Q0907643C External Air quality sensor to G935 4H0907658D External air quality and air humidity sensor.
Video. Installation.
Original Video
: https://www.youtube.com/embed/csb-8XHtj ... autoplay=1
Coding.
VCDS
VAS
Coding: 000200032001100D1115004C0018542A
VCID: 074B66607FAADF538E5-8052
Air quality sensor:
Humidity sensor: exterior:
Subsystem 2 - Part No SW: 4H0 907 658 D HW: 4H0 907 658 D
Component: G935 MuFu H05 0010
Serial number: AAE88B8400PAG0MUFU05
As my magic is not enough to create the climatic conditions to verify the operation of this Exterior humidity sensor, its operation will be verified over time...
G935 is factory installed on VW MQB vehicles like the Arteon, Passat, etc...
Note:
Parts
BCM
Fuse
Heating elements
Seat installation
1- Do this,
2- and this,
Clear the faults.
Golf 2019 A/C manual
IDE06089-ENG246993-Seat heater level current consumption allocation-SIH_PWM_Teiler,0 ,30
IDE06089-ENG141976-Seat heater level current consumption allocation-Sitzheitzung_CAN,Heizmatten am BCM ,30
IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss,1 s,30
IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss,0.00 °C,30
IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle,22.50 °C,30
IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle,21.50 °C,30
IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle,22.50 °C,30
IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle,21.50 °C,30
IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle,35.00 °C,30
IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle,33.00 °C,30
IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle,35.00 °C,30
IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle,33.00 °C,30
IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle,51.00 °C,30
IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle,50.00 °C,30
IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle,51.00 °C,30
IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle,50.00 °C,30
IDE06089-ENG154774-Seat heater level current consumption allocation-Sitzheizung.Aufheizphase HI,Keine_Spannungsanforderung ,30
IDE06089-ENG154775-Seat heater level current consumption allocation-Sitzheizung.Regelbetrieb LO,Keine_Spannungsanforderung ,30
IDE06089-ENG141977-Seat heater level current consumption allocation-Sitzheizungsfreigabe,not installed ,30
IDE06089-ENG154785-Seat heater level current consumption allocation-Spannungsoffset SIH_75,15.7 V,30
Golf Variant 2019 Climatronic
IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle,36.00 °C,30
IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle,34.00 °C,30
IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle,36.00 °C,30
IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle,34.00 °C,30
IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle,50.00 °C,30
IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle,49.00 °C,30
IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle,50.00 °C,30
IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle,49.00 °C,30
Golf GTI 2019 Climatronic
IDE06089-ENG246993-Seat heater level current consumption allocation-SIH_PWM_Teiler 0 30
IDE06089-ENG141976-Seat heater level current consumption allocation-Sitzheitzung_CAN Heizmatten am BCM 30
IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss 1 s 30
IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss 0.00 ∞C 30
IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle 22.50 ∞C 30
IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle 21.50 ∞C 30
IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle 22.50 ∞C 30
IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle 21.50 ∞C 30
IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle 38.00 ∞C 30
IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle 36.00 ∞C 30
IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle 38.00 ∞C 30
IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle 36.00 ∞C 30
IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle 56.00 ∞C 30
IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle 54.00 ∞C 30
IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle 56.00 ∞C 30
IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle 54.00 ∞C 30
IDE06089-ENG154774-Seat heater level current consumption allocation-Sitzheizung.Aufheizphase HI Keine_Spannungsanforderung 30
IDE06089-ENG154775-Seat heater level current consumption allocation-Sitzheizung.Regelbetrieb LO Keine_Spannungsanforderung 30
IDE06089-ENG141977-Seat heater level current consumption allocation-Sitzheizungsfreigabe not installed 30
IDE06089-ENG154785-Seat heater level current consumption allocation-Spannungsoffset SIH_75 15.7 V
From CE to CF:
Revision: 00001K08
Air quality sensor:
Saturday,05,September,2020,18:44:17:32438
www.Ross-Tech.com
VIN: WVWZZZAUZKPCICLOW License Plate: HEATED SEATS GOLF OK!
Mileage: 33072km-20549mi Repair Order:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 03 08 09 10 13 15 17 19 20 42 44 52 5F 65
VIN: WVWZZZAUZKPCICLOW Mileage: 33072km-20549miles
42-Door Elect, Driver -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
Address 01: Engine (J623-DKRF) Labels:. 04E-907-309-V1.clb
Part No SW: 04C 906 025 L HW: 04C 907 309 BB
Component: R3 1.0l TFS H20 6198
Revision: D7H20000
Coding: 01190032234415082000
Shop #: WSC 00046 028 00070
ASAM Dataset: EV_ECM10TFS01104C906025L 002003
ROD: EV_ECM10TFS01104C906025L_002.rod
VCID: 290F00D8897EC92325D-807C
Readiness: 0000 0000
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-IPB-V1.clb
Part No SW: 5Q0 614 517 DD HW: 5Q0 614 517 AC
Component: ESC H25 0424
Revision: 00000000 Serial number: 51998000000173
Coding: 01FA6AA114202170477B060560CA2580562884E26006A4733420F0084002430B00000012121212B835351919323200
Shop #: WSC 00046 123 12345
ASAM Dataset: EV_Brake1UDSContiMK100IPB 037009
ROD: EV_Brake1UDSContiMK100IPB_037_VW37.rod
VCID: 76B51BA40840D6DB78F-8022
Revision: 00001K08
Air quality sensor:
Part No SW: 5Q0 937 084 DD HW: 5Q0 937 084 CG
Component: BCM MQBAB H H38 0273
Serial number: 00001822001136
Coding: 000000000000000000000000000000000000000000000000000000000000
Shop #: WSC 01357 011 00200
ASAM Dataset: EV_BCMMQB 019001
ROD: EV_BCMBOSCH_019.rod
Control Unit For Wiper Motor:
Subsystem 1 - Part No SW: 5G1 955 119 A HW: 5G1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 180621 043 0551
Serial number: 180705074106
Coding: 0E4DDD
Subsystem 2 - Part No SW: 5Q0 955 547 B HW: 5Q0 955 547 B Labels: 5Q0-955-547.CLB
Component: RLHS 052 0107
Serial number: SBY18M08D06H04M32S34
Coding: 06A8DD
Steering Column Switch:
Subsystem 3 - Part No SW: 5Q1 953 507 HW: 5Q1 953 549
Component: J527 SMLS MQB 004 0060
Serial number: 00000002081804401346
Address 10: Park/Steer Assist (J446) Labels:| 5Q0-919-294.clb
Part No SW: 5QA 919 294 C HW: 5QA 919 294
Component: PDC 8 KanalH07 0050
Serial number: 000308418018193
Coding: 0471151801
Shop #: WSC 00046 000 00000
ASAM Dataset: EV_EPHVA18AU3700000 009039
ROD: EV_EPHVA18AU3700000_009_VW37.rod
VCID: 4CC1994C264CFC0BFEB-8018
Address 13: Auto Dist. Reg (J428) Labels:| 3Q0-907-572.clb
Part No SW: 5Q0 907 572 P HW: 3QF 907 572 A
Component: ACC BOSCH MQB H11 0682
Coding: 2B00670119FFC728949C810560400600000000000000000004
ASAM Dataset: EV_ACCBOSCHVW416 002008
ROD: EV_ACCBOSCHVW416_002_VW37.rod
VCID: 44D1B16C0E1C344B36B-8010
Address 15: Airbags (J234) Labels:| 5Q0-959-655.clb
Part No SW: 5Q0 959 655 BJ HW: 5Q0 959 655 BJ
Component: AirbagVW21 006 0339
Serial number: 003VWR4F1CUQ
Coding: 98CCC000000000005C0000CF000800000065
Shop #: WSC 00028 028 00064
ASAM Dataset: EV_AirbaVW20SMEVW37X 002160
ROD: EV_AirbaVW20SMEVW37X_VW37.rod
VCID: 094F605869BEA92305D-805C
Subsystem 1 - Part No SW: 5G0 980 945 B HW: 5G0 980 945 B
Component: BeltPretRevFL H37 0350
Serial number: 34169667E30071820325
Coding: 333135
Subsystem 2 - Part No SW: 5G0 980 946 B HW: 5G0 980 946 B
Component: BeltPretRevFR H37 0350
Serial number: 34169668E31071830145
Coding: 333135
Subsystem 3 - Part No SW: ----------- HW: 480 002 307 18
Component: SideSensor_Df 001 0887
Serial number: 35700000000F8745C23S
Coding: 2D2D2D
Subsystem 4 - Part No SW: ----------- HW: 480 002 807 18
Component: SideSensor_Pf 001 0887
Serial number: 358000000000EC18233G
Coding: 2D2D2D
Subsystem 5 - Part No SW: ----------- HW: 480 403 107 18
Component: SideSensor_Dr 003 6149
Serial number: 3510001A729FD154210-
Coding: 2D2D2D
Subsystem 6 - Part No SW: ----------- HW: 480 403 107 18
Component: SideSensor_Pr 003 6149
Serial number: 3520001A929FD1515577
Coding: 2D2D2D
Subsystem 7 - Part No SW: ----------- HW: 480 402 306 18
Component: FrontSensor_D 003 6149
Serial number: 3550001A326704A3C63.
Coding: 2D2D2D
Part No SW: 5G1 920 750 D HW: 5G1 920 750 D
Component: KOMBI 310 2700
Coding: 07A52A802680000801887A051401000000000000
Shop #: WSC 00200 935 01530
ASAM Dataset: EV_DashBoardVDDMQBAB 009068
ROD: EV_DashBoardVDDMQBAB_009_VW37.rod
VCID: 280905DC9274F02B3A3-807C
Part No SW: 3Q0 907 530 AA HW: 3Q0 907 530 C
Component: GW MQB High 433 4368
Revision: -------- Serial number: 0006434834
Coding: 030100047F085700DA000258080F00010001070000000000000000000000
ASAM Dataset: EV_GatewNF 013025
ROD: EV_GatewNF_VW37.rod
VCID: 6E8533C47010EE1BB0F-803A
Alternator:
Component: 0-00-00-00-00
Subsystem 2 - Part No SW: 5G0 959 442 AB HW: 5G0 959 442 AB Labels: 3C8-959-537.CLB
Component: E221__MFL-MD9 H18 0052
Serial number: 39190002063230049307
Coding: 2CFFFF
Subsystem 3 - Part No SW: 5Q0 915 181 K HW: 5Q0 915 181 K
Component: J367-BDMHella H10 9070
Serial number: 9353818504
Address 20: High Beam Assist. (J844) Labels:| 8S0-857-511.clb
Part No SW: 3G0 857 511 BD HW: 3G0 857 511 BD
Component: FLA H01 0010
Revision: AA001001
Coding: 0404000000000000000000
ASAM Dataset: EV_HighBeamAssisAU33X 001019
ROD: EV_HighBeamAssisAU33X_VW37.rod
VCID: 6B833AD043021B33971-803E
Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-X93-42.clb
Part No SW: 5Q4 959 593 F HW: 5Q4 959 593 F
Component: TSG FS 006 0246
Serial number: 0000305474246
Coding: 00150320D000048000001000
Shop #: WSC 00020 999 12345
ASAM Dataset: EV_DCU2DriveSideMAXHCONT 001005
ROD: EV_DCU2DriveSideMAXHKLO.rod
VCID: 48C9A55C3234102BDA3-801C
Subsystem 1 - Part No SW: 5Q4 959 811 F HW: 5Q4 959 811 F Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG DRV 010 0004
Serial number: 00000000000009798407
Coding: 010000
Address 44: Steering Assist (J500) Labels:| 5Q0-909-144.clb
Part No SW: 5Q0 909 144 AA HW: 5Q0 909 144 AA
Component: EPS_MQB_ZFLS 131 1081
Coding: 011F0000
ASAM Dataset: EV_SteerAssisMQB 015157
ROD: EV_SteerAssisMQB_015.rod
Address 52: Door Elect, Pass. (J387) Labels:| 5QX-959-X92-52.clb
Part No SW: 5Q4 959 592 F HW: 5Q4 959 592 F
Component: TSG BFS 006 0246
Serial number: 0000336638884
Coding: 00150320DE00048000001000
ASAM Dataset: EV_DCU2PasseSideMAXHCONT 001005
ROD: EV_DCU2PasseSideMAXHKLO.rod
VCID: 47CBA6603F2A1F53D39-8012
Subsystem 1 - Part No SW: 5Q4 959 812 F HW: 5Q4 959 812 F Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG PSG 010 0004
Serial number: 00000000000009846262
Coding: 090000
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD2.clb
Part No SW: 3Q0 035 874 C HW: 3Q0 035 874 C
Component: MU-S-ND-ER 853 0891
Serial number:
Coding: 02731001FF0000005111010100880A001F0500D401200100CF
ASAM Dataset: EV_MUStd4CDELP 001001
ROD: EV_MUStd4CDELP_VW37.rod
Component: ABT_Std-2_Nav H52 8130
Serial number: VWZ6ZHV2691212
Data medium:
Subsystem 2 - Part No SW: 5NA 919 866 AR HW: -----------
Component: ECE AS 20/21 --- 1430
Address 65: Tire Pressure (J502) Labels: 3AA-907-273.clb
Part No SW: 5Q0 907 273 B HW: 5Q0 907 273
Component: RDKBERU30 H04 0009
Serial number: 30000000250801
ASAM Dataset: EV_RDKBERU30 006001
ROD: EV_RDKBERU30_006_VW37.rod
VCID: 3431E1AC5EBC84CB86B-8060
End----------(Elapsed Time: 01:18, VBatt start/end: 13.4V/13.4V)-----------
Edit...
Video.
VCDS Coding:
Coding
Coding information is found using the Long Coding Helper while connected to the vehicle with VCDS.
When replacing a module it is recommended to save the original coding and transfer it to the new module.
Transfer old unit long coding to new unit long coding + Check*
*Coding
[LN]_Climate zones second seat row: [VN]_not installed ... Byte7 Bits2,3 ... enable (drop down menu: experimental label)
Only in case you don't have a climate control unit for the rear row, for example Golf 7.5
*Adaptation (if you want)
ENG248446-HMI_View_Switch,Yes ,1 ... from NO to YES!
***Basic Setting***
Note: The basic setting needs to be performed, when the Climatic control module (J301) or flap motor(s) have been replaced.
Adapt flap end stops
Necessary when flap motors are replaced -or- when a self check needs to be performed for self diagnosis of faulty motors.
[Select]
[08 - Heating/Air Conditioning]
[Basic Settings - 04]
Select IDE01546-ENG167462 "Adapt flap/door end stops" from the drop-down list
[Go!]
The basic setting takes approximately 20 seconds.
Finished Correctly should be displayed
[Stop]
[Done, Go Back]
[Close Controller, Go Back - 06]
Clear DTCs!!!
AC Compressor First Run-In
Necessary when the Climatic control module (J301) is replaced.
Prerequisites to start the basic setting A/C compressor first run:
Engine at idle
Transmission in Park or Neutral
Do not cycle the ignition
Basic setting was performed for the flaps
Inside blower motor is switched on
Air vents fully open
Load management not active
"AC Compressor First Run-In" Steps:
1- Start engine and allow it to Idle.
2- Go to adaptation and change the values of these two channels to 120s:
IDE01503-Running time of basic setting for compressor break-in,120 s,1 ...120 you must do the process/change even if it already has the value of 120 s.
IDE03176-Duration of compressor run in,60 s,1 ...120
3- Close/Exit Controller/unit 08, Close/Exit VCDS, Turn off the engine, ***Wait between 30 seconds to a minute***, Turn on the engine again,
Open the VCDS again and re-enter unit 08, Go to adaptation and re-enter the original values, 120 and 60 respectively.
4- Go to Basic Settings.
Select IDE02259-ENG167462 "Compressor run/break in: ***automatic start***" from the drop-down list.
[Go!]
Wait 120 sec (2 Min), observe the flashing A/C button light on the HVAC panel.
After the Basic Settings has completed, the A/C light turns off and the process is finished.
[Stop]
Check DTCs. Clear if necessary.
Exit control unit 08.
Check that the A/C button works/lights up.
Air quality sensor:
Works like a charm.
Autoscan
Thursday,07,October,2021,13:04:26:32438
VCDS Version: 21.9.0.2 (x64) HEX-V2 CB: 0.4555.4
Data version: 20210903 DS330.0
www.Ross-Tech.com
VIN: WVWZZZAUZKPCICLOW License Plate: TOUCH CLIMATE UNIT OK!
Mileage: 40739km-25314mi Repair Order:
Scan: 01 03 08 09 10 13 15 17 19 29 39 3C 42 44 4B 52 5F 65 6C A5
A9 D6 D7
VIN: WVWZZZAUZKPCICLOW Mileage: 40739km-25314miles
29-Left Light -- Status: OK 0000
39-Right Light -- Status: OK 0000
4B-Multifunc. Module -- Status: OK 0000
A9-Struct. Borne Sound -- Status: OK 0000
Revision: D7H20000 CVN: 92B19492
VCID: 290F00D8897EC923D0F-807C
VINID: 9E69EAAAA465A9B8000041051C011774D2
Coding: 01FA6AA114202170477B060560CA2580562884E26006A4733420F00A40AA430B00000012121212B835351919323200
VCID: 76B51BA40840D6DB8DD-8022
Air quality sensor:
Part No SW: 5Q0 937 084 DH HW: 5Q0 937 084 CG
Component: BCM MQBAB H H40 0312
Serial number: 72007150025702
ASAM Dataset: EV_BCMMQB 020001
ROD: EV_BCMBOSCH_020.rod
VCID: 015F7878518EE163A8F-8054
Wiper motor control module:
Coding: 0F4DFD
Rain/Light Recognition Sensor:
Serial number: S5Y20M05D14H05M53S24
Coding: 06A8DD
Anti-theft alarm system sensor:
Subsystem 3 - Part No SW: 5Q0 951 172 HW: 5Q0 951 172
Component: Sensor, DWA 005 0316
Serial number: 000000000ZY191251XZQ
Alarm horn:
Subsystem 4 - Part No SW: 5QD 951 605 HW: 5QD 951 605
Component: Sirene, DWA 005 0313
Serial number: 00002854456462182207
Subsystem 5 - Part No SW: 5Q1 953 507 HW: 5Q1 953 549
Part No SW: 5QA 919 298 D HW: 5QA 919 298 A
Component: PLA 3.0 12KH07 0050
Serial number: 000308417318277
Coding: 0271167841
ASAM Dataset: EV_EPHVA2CAU3700000 009041
ROD: EV_EPHVA2CAU3700000.rod
VCID: 51FF8838C16ED1E378F-8004
Address 13: Auto Dist. Reg (J428) Labels:* None
Part No SW: 5Q0 907 572 S HW: 3QF 907 572 A
Component: ACC BOSCH MQB H11 0780
Coding: 2B056FE35DFFC728979D81A461400600000000000010000004
ASAM Dataset: EV_ACCBOSCHVW416 003015
ROD: EV_ACCBOSCHVW416_003_VW37.rod
VCID: 47CBA6603F2A1F5326B-8012
VCID: 094F605869BEA923F0F-805C
Left seat belt tensioner:
Coding: 333135
Right seat belt tensioner:
Coding: 333135
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Part No SW: 5G1 920 791 B HW: 5G1 920 791 B
Component: KOMBI 404 4191
Coding: 07A532806E8C000801887A0F5401000080000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009058
ROD: EV_DashBoardVDDMQBAB_009_VW26.rod
VCID: 2B03FAD08382DB33223-807E
Component: GW MQB High 521 5388
Serial number: 09012020001767
Coding: 030100047F085700DB0002FE080F00010001070000000000000000000000
GVL: 014E3C100000000040CC80000002480000000000000200000000000000000000
VCID: 70B92DBC6A24F8EB571-8024
Generator:
Component: 4-01-02-01-04
Multifunction steering wheel control module:
Coding: 2CFFFF
Address 29: Left Light (J1018) Labels: 8V0-907-399.clb
Part No SW: 8V0 907 399 D HW: 8V0 907 399 D
Component: LCM_MLBevoH08 0014
ASAM Dataset: EV_LCMLeftHELLAAU736 001012
ROD: EV_LCMLeftHELLAAU736_VW37.rod
Address 39: Right Light (J1023) Labels: 8V0-907-399.clb
ASAM Dataset: EV_LCMRightHELLAAU736 001012
Address 3C: Lane Change (J1086) Labels:| 5Q0-907-686.clb
Part No SW: 5Q0 907 686 C HW: 5Q0 907 686 C
Component: HRE_Master H12 0081
Serial number: 0519386082
Coding: 02011103
ROD: EV_HREntryHella_VW37.rod
VCID: 3D27C4886DF645838C7-8068
Lane change assistance control module 2:
Subsystem 1 - Part No SW: 5Q0 907 685 C HW: 5Q0 907 685 C
Component: HRE_Slave H12 0081
Serial number: 0519601132
Coding: 020111
Coding: 00150220D000048000001001
ROD: EV_DCU2DriveSideMAXHCONT_VW37.rod
VCID: 48C9A55C3234102B2F1-801C
Rear Driver Side Door Control Module:
Coding: 010000
Coding: 931F0000
Shop #: WSC 12345 102 209715
VCID: 73B322B01B32C3F3AA3-8026
Address 4B: Multifunc. Module (J745) Labels:| 3Q0-907-338-V2.clb
Part No SW: 3Q0 907 338 E HW: 3Q0 907 338 E
Component: FCM MQB Low 003 0367
Serial number: 01081930001280
Coding: 00000005090016C200205F03020000000000000000000000000000000000
ASAM Dataset: EV_MultiModulContiVW48X 003003
ROD: EV_MultiModulContiVW48X_003_VW27.rod
VCID: 372BD6A04FCA6FD356B-8062
Coding: 00150220DE00048000001001
ROD: EV_DCU2PasseSideMAXHCONT_VW37.rod
Rear Passenger Door Control Module:
Coding: 090000
Serial number:
Coding: 02731001FF0000005111000100880A001F0507E401200400CF
ROD: EV_MUStd4CDELP_VW26.rod
VCID: 323DE7B4A4A88AFB615-8066
Display and control head 1 for information electronics:
Data carrier:
VCID: 3431E1AC5EBC84CB739-8060
Address 6C: Back-up Cam. (J772) Labels:| 5Q0-980-556.clb
Part No SW: 5Q0 980 556 B HW: 5Q0 980 556 B
Component: RVC Compact H18 0231
Coding: 01844201C600201F000060
ASAM Dataset: EV_CamSysRVRVCPANAMQBAB 006009
ROD: EV_CamSysRVRVCPANAMQBAB.rod
VCID: 392FD09879DE79A3A0F-806C
Part No SW: 3Q0 980 654 L HW: 3Q0 980 654 A
Component: MQB_B_MFK H10 0610
Serial number: 28011912K23389
Coding: 000307000000040100221354C156A90094000E33004000
VCID: 40D9BD7C1A04286BE71-8014
Address A9: Struct. Borne Sound (J869) Labels: 4H0-907-159.clb
Part No SW: 5F0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H07 Z001
Serial number: 181027201414
ASAM Dataset: EV_SoundActuaGen2AU64X 003010
ROD: EV_SoundActuaGen2AU64X.rod
VCID: 6A8D3FD44CF8023B195-803E
Part No SW: 7P5 941 572 A HW: 7P5 941 572 A
Component: LED1L H06 0002
ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
ROD: EV_LEDMinMaxL_KEBODAVW481.rod
Component: LED1R H06 0002
ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
ROD: EV_LEDMinMaxRKEBODVW481.rod
End----------(Elapsed Time: 01:34, VBatt start/end: 13.3V/13.3V)-----------
Coding.
VCDS
VAS
ECU: 0008 - Climate Control Module
Coding:
[LN]_sensor_for_air_quality_outside: [VN]_installed
[LN]_sensor_for_air_humidity_inside: [VN]_installed
[LN]_sensor_for_air_humidity_outside: [VN]_not installed ...[VN]_installed
[LN]_Reduction of window misting outside at high humidity: [VN]_close over characteristic
Adaptation:
[VN]_Reduction of window misting outside at high humitity:
[LN]_param_Reduction_of_window_misting_outside_at_high_humitity: [VN]_Matching coding
Air quality sensor:
exantas
Sorry for the mistake Ciclo. I honestly thought you got a T-Roc. I had it in my mind that it was replacing T-Cross in the VW line up. I wouldnt have noticed if you have not pointed it out. The joke is on meciclo wrote:Thank you.
Maybe you're joking and I don't get the point of your joke, which I think is great, but this is the second time I've told you that it is a T-Cross.[emoji1696] [emoji38]
I don't like being connected while driving for compelling reasons, but I tend to choose the WAZE for real-time 'traffic information'...[emoji2957], although I'm not one of those who interacts while driving...
For the connection part. I don't want to phaph with the phone when I am driving, that's why I try to get this info on the cars map. I know the car nav theoretically come with this option, so I use an app on my phone.
Not sure if anyone is using the rSAP Bluetooth option to connect to the Internet (or some other method) , so the car get the traffic info.
