Page 12 of 17
Posted: Thu Mar 17, 2005 10:33 pm
by cyhliu
M@Turner, I'm still waiting for the second instalment of your fitting guide...my trim is off but waiting for you give me instructions on how to actually install the quick-shifter! ha ha ha!
No seriously, some more advice on how to fit would be greatly appreciated as then I would be able to judge whether I can handle the work required! Cheers!
Posted: Thu Mar 17, 2005 11:16 pm
by M@Turner
Well then Chris, if you've got the instructions with you, just read through them a couple of times and then give it a go. I was bricking it before i attempted mine but if you've got a couple of hours spare give it a try.
It would be handy to have a second person giving you a hand as i kept forgetting where i'd put things and how i'd taken some of the things off. If your up and around Sheffield any time soon, i'd happily fit it for you.
Mat
Posted: Fri Mar 18, 2005 10:47 am
by neilw
The instructions you get with it are really easy too follow. I was abit unsure about doing it myself. Took about an hour and a half with a tea break, and most of that was spent working out out to take out the centre console. Tip.... pull out the little tray above the climatronic, and remove the trox screws! Then i unscrewed the climatronic face, didnt fancy disconnecting any or the wires. The other bit thats a tiny bit annoying is the clip that holds the gear knob to the stick, is kinda a bit of metal thats just crushed onto the stick to clamp it on.
Posted: Fri Mar 18, 2005 7:48 pm
by JBS AUTO DESIGNS
Hi Chris
No worries it is not yours that I have got a list of people looking in to.
Yours is still waiting for you.
Sorry we had a couple of the lads ill , but we are all back strong now.
Will save it for as long as you want.
Posted: Wed Mar 23, 2005 8:57 pm
by mikegti
I got round to fitting mine today, pretty pleased with it!
the trim was by far the most awkward part, and i can confirm that you can disconnect the climatronic with no ill effects.
The pivot rod did foul on a bolt head (which i removed) and then on the metal lip and carpet behind it.
I've got to give that metal clip that holds the gear knob on the shaft another tweak, as the gear knob still rotates. Theres no key-way like on the original stick.
Posted: Thu Mar 24, 2005 6:48 am
by Josh_PoloGTi
Huh?
I just screwed my gearknob down to the shaft?
I didn't have to use the clip
Posted: Thu Mar 24, 2005 8:38 am
by neilw
Dont bother with that stupid clip, I couldnt do mine back up tight enuf, the knob kept spinning around and moving. Get hold of one of those clips you use on hosing and put that on. think its called a jubliee clip, you screw it up and it gets tighter. Works much better.
Posted: Fri Mar 25, 2005 2:48 am
by mikegti
yep, jubilee clip, that's the monkey! good tip neilw.
Posted: Wed Apr 06, 2005 10:43 am
by neilw
Another tip....
Make sure you bend the clip that holds on the rod which goes to the gear box so that it is impossible for it to fall off. Mine did and i got stuck in 5th, managed to get home ok, and sorted it.
Posted: Wed Apr 06, 2005 1:44 pm
by Jordan
So what is it like is it better or just a wee bit. Is it worth the purchase.
Posted: Wed Apr 06, 2005 6:00 pm
by mikegti
neilw, do you mean the split pin type thing?
you're making me worry now cos i'm 160 miles away from home... haha
Posted: Wed Apr 06, 2005 8:47 pm
by neilw
Yeh that one
Posted: Sat Apr 09, 2005 5:50 pm
by cyhliu
Jordan,
I've just had mine fitted and it does make a difference and worth getting, it makes the gearchange more precise, its a little stiffer so it a nicer study feel to it and the throw has been reduced considerably! So much so that I sometimes wonder if I'm in gear and not actually in neutral (well not to that extent but you wonder if you have engaged gears properly!). Gives it a real sporty feel...
Thanks for JBS for fitting and supplying the shifter, class job fitting, no hassle, dropped it off and left it to them.
Posted: Sat Apr 09, 2005 5:55 pm
by Si_GTi
Nice one Chris
Now I can't wait until September
Posted: Thu Apr 14, 2005 1:37 pm
by JBS AUTO DESIGNS
Hi Chris
Good to know that its all good for you.
You had it fitted the hassle free way.
Let someone else have the headache.
But good to meet you , even though you came back the next day
(with your car a little cleaner)
See you again.
Sarah
