Marjacic
Drives: Polo 6R 1,6 TDI 105 hk Highline
Post by Marjacic »
iichel wrote:the 6Q0 will not return to center. look at the arrow, the rearward arrow is solid white. that means it will stay back. if it is only a white outline, it is returning to center.
the 6Q0 is the same part number as originally fitted on 6R.
Ups :!: :oops:
Sry my mistake :roll: ..
wamba
Drives: polo 1.2tsi
Post by wamba »
hello ciclo
I hope you okay
I need your help for the security access engine controller in VCDS Polo GTI 6R 2011 ( 03C 906 027 AR )
thank's
wamba
Drives: polo 1.2tsi
Post by wamba »
:D
No problem, sometimes mistakes are necessary.
Here you could have checked:
http://www.uk-polos.net/viewtopic.php?f ... 95#p499595
Anyway the adaptation of HBA on a 6R is not over, anyone (I think) can tell it's possible.
Everything would be extremely easy for me (and for everyone) if the software was available to do this at home :) , just like in the various tutorials and guides online to install HBA in other VW models that they already have available this system from the factory, but HBA never was available from factory for 6R and the software information is not available and I fear it will be not available for a long time (already checked :twisted:).
However, I hope good results soon and I hope it will be the last step.
ciclo wrote:Many polo 6R can activate "Coming Home" regardless of whether they can or can not install the automatic lights OEM.
Coming Home OEM in the polo 6R no works automatically, once activated by VCDS, it only works through the stalk of lights on the steering column by pulling from it once with the key removed from the ignition. (ignition off)
http://www.uk-polos.net/viewtopic.php?f ... 09#p478727
The gift is for first person that can get activate Coming Home with VCDS to the removing the ignition key, without be needed pulling the stalk of lights. That easy.
A different issue is that your polo 6R can not install the automatic lights OEM, but you win a kit valued at 110 euros.
The present is not exchangeable for the money, you can sell the Kit later.
For example:
In the POLO 6C can be done in adaptation of the BCM.
Do you think that it can maybe done with 7E0 BCM? :-)
wamba wrote:hello ciclo
I hope you okay
thank's
Hey there! :wink:
I do not know it, I tried to find something about it but without success.
It would be fantastic, although I prefer as it is. PUSH ... Image
wamba
Drives: polo 1.2tsi
Post by wamba »
thank's
I also found nothing
For sale: Genuine rear tailgate handle. 6R6827469B http://www.uk-polos.net/viewtopic.php?f ... 70#p503070
ciclo wrote:... with music:
:wink:
Imagelast clue :
Ok, another clue: from-to
... so the replay is not a replay ...Image
from 30 to 31?
you really do like to play games, don't you? :mrgreen:
masterofpolo
Drives: 1.2 TSI DSG Lounge
Post by masterofpolo »
Dear Ciclo,
I am reading your posts excitedly and absolutely you're a big luck for polo users. First of all thank you for your all help for vw polo and this forum. I want to learn something about your seat heating oem mod. I want to buy seat harness cable set from your link (you gave adresss before) but ı dont know it's fit for Polo 6c. Can I use that cable set for polo 6c? (you can see set below the link) Also where did you buy seat heating mats for polo? If you give me a link I appriciate you. I understand that I need these equipments to Install Seat heating for polo.
1) Seat Heating Harness;
http://www.kufatec.com.tr/shop/tr/volks ... t-ibiza-6j
2) 1 unit seat control module;
http://tr.aliexpress.com/item/Heated-Se ... eb201560_8
3)2 Seat Heating switch;
http://tr.aliexpress.com/item/PAIR-OF-G ... eb201560_8
4) Seat Heating Mats?? ( I don't know where can I buy)
If I buy these ıtems and ıf I coded them to bcm, I understand that İt will works. Could you help me for this issue please? Thank you for your help.
Yes the Kufatec wiring set will work. But it is made for 6R so you need to slightly modify te connectors to the switches.
They have some distinctive shapes to only fit into the correct buttons.
You need to remove some edges on the connetor
Hello masterofpolo.
Thank you very much for your words, are very valuable to me.
Apart from the already mentioned by iichel (easier it would be also buy the right connectors for these switches and exchange them for those of Kufatec), you also have to take into account that the control unit you say is not correct, correct is:
6R0959772D
... and also, because 6C BCM is different from 6R BCM, connections are also different, you must ask to iichel for the exact pins (slots) of this system.
I have no links to the heating elements. I'm sorry.
iichel wrote:from 30 to 31?
:?: NO, the change it's only a digit.
iichel wrote:you really do like to play games, don't you? :mrgreen:
:mrgreen:
masterofpolo
Dear ciclo and iichel,
Thank you for your kind replies. I understand the situation but now, how can I find heat seating pads :D I already have switch buttons 6C and I modified edges to use with 6R ( I bought from aliexpress).Now I need an adress or a link for buying seat heating pads for polo :cry: :cry: Where did you buy these parts :?: After your post I found and bought 6R0959772D part from ebay, I hope that it is suitable with polo 6c bcm, but I didn't find seat heating pads yet. In addition, İcchel do you know what is the exact pins (slots) of polo 6c bcm system?
Locked
