Page 114 of 333
Posted: Fri Dec 25, 2015 4:22 pm
by tadej
Hi Ciclo.
I actually had some time and got Autoscan with VCDS and took a picture of fuse box. :)
Here is a picture:
Here is an autoscan:
VCDS Version: Release 12.12.0 (x64)
Data version: 20130910
Friday,25,December,2015,17:01:25:62939
Chassis Type: 6R (6N0)
Scan: 01 02 03 08 09 10 15 17 19 25 44 56
VIN: WVWZZZ6RZAY263597
56-Radio -- Status: Cannot be reached 1100
Address 01: Engine (J623-CAYB)       Labels: 03L-906-023-CAY.clb
   Part No SW: 03L 906 023 AH    HW: 03L 906 023 D
   Component: 1,6l R4 CR td H13 9970
   Revision: --H13---    Serial number:
   Coding: 00254016002400080000
   Shop #: WSC 124697 483 00190
   ASAM Dataset: EV_ECM16TDI02103L906023AH 003010
   ROD: EV_ECM16TDI02103L906023AH_VW25.rod
   VCID: 6CD7223B877E2C7E58B-8039
Readiness: 0000 0000
Address 02: Auto Trans        Labels: 0AM-300-04x.lbl
   Part No SW: 0AM 300 049     HW: 0AM 927 769 D
   Component: GSG DSG AG7     402 9060
   Revision: 00040024    Serial number: TFK01004030233
   Coding: 0000020
   Shop #: WSC 23988 000 1048576
   VCID: EED3A833FA625E6EF6F-5000
Address 03: ABS Brakes (J104)       Labels: 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 AF    HW: 6R0 907 379 AF
   Component: ESP8.2i front H05 0005
   Revision: --------
   Coding: 210228E3417300B5842A14EB82D800421300
   Shop #: WSC 02069 000 00000
   VCID: 820BEC8319FA4A0E027-80D7
   Part No SW: 6R0 907 044 B    HW: 6R0 907 044 B
   Component: Climatronic   H08 0305
   Revision: V0000000
   VCID: 326BFC436DDABA8E527-8067
1 Fault Found:
00819 - High Pressure Sensor (G65)
            009 - Open or Short to Ground - Intermittent
                    Fault Status: 00101001
                    Fault Priority: 3
                    Fault Frequency: 2
                    Reset counter: 103
                    Mileage: 16596 km
                    Time Indication: 0
                    Date: 2000.14.13
                    Time: 09:07:05
Address 09: Cent. Elect. (J519)       Labels: 6R0-937-08x-09.clb
   Part No SW: 6R0 937 087 D    HW: 6R0 937 087 D
   Component: BCM PQ25 H+4  H46 0207
   Revision: BF046001    Serial number: 0147 092100027
   Coding: 3CB02BBF48A10000013806003CAB0FD00080410F60842000200000000000
   Shop #: WSC 07150 298 85912
   VCID: 3E73D873A9826EEEA6F-806B
   Subsystem 1 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Component: RLS 040410 05  54  0403
   Coding: 0005F3
   Subsystem 2 - Part No SW: 6R0 959 801 R    HW: 6R0 959 801 R  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  006 0903
   Coding: 18BC30
   Subsystem 3 - Part No SW: 6R0 959 802 T    HW: 6R0 959 802 T
   Component: J387__TSG_BT  006 0902
   Coding: 08BC30
   Subsystem 4 - Part No SW: 5K0 959 542     HW: 5K0 959 542
   Component: E221__MFL-TAS  H05 0010
   Coding: 020000
   Subsystem 5 - Part No SW: 6R0 959 811 F    HW: 6R0 959 811 F
   Component: J388__TSG_HL  006 0902
   Coding: 08BC32
   Subsystem 6 - Part No SW: 6R0 959 812 F    HW: 6R0 959 812 F
   Component: J389__TSG_HR  006 0902
   Coding: 08BC32
1 Fault Found:
00901 - Back-Up Lamps
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 88
                    Mileage: 17170 km
                    Time Indication: 0
                    Date: 2000.14.25
                    Time: 16:56:07
Address 10: Park/Steer Assist (J446)       Labels: 6R0-919-475.clb
   Part No SW: 6R0 919 475     HW: 6R0 919 475
   Component: PARKHILFE 4K  H07 0008
   Revision: --------    Serial number: 71391009039009
   Coding: 100101
   ASAM Dataset: EV_VW250ParkiAssis2 S01006
   ROD: EV_VW250ParkiAssis2.rod
   VCID: FBF5916772103BC6411-80AE
   Component: VW10Airbag00G H08 0020
   Revision: --------    Serial number: 003GX0014B1Q
   Coding: 003047
   ROD: EV_AirbaVW10BPAVW250_VW24.rod
   VCID: 4A9B84A3ED4AD24E0A7-801F
   Crash sensor for side airbag; driver side:
   Serial number: 3572SRB40000B22CDAFN
   Crash sensor for side airbag; passenger side:
   Serial number: 3582SRB40000B238A2E9
   Crash sensor for side airbag; rear driver side:
   Serial number: 3515RRB405D6Q5D6GOR9
   Crash sensor for side airbag; rear passenger side:
   Serial number: 3525RRB405F6Q5D6I8N.
   Part No SW: 6R0 920 861 D    HW: 6R0 920 861 D
   Component: KOMBI         H13 0024
   Serial number: 00000002312652
   Coding: 140E00
   Shop #: WSC 12469 483 00190
   ASAM Dataset: EV_DashBoardUDSJCIPQ25 A01004
   ROD: EV_DashBoardUDSJCIPQ25_VN81.rod
   VCID: 3663C05389B2A6AE7EF-8063
Address 19: CAN Gateway (J533)       Labels: 6N0-909-901-6R.clb
   Part No SW: 6N0 909 901     HW: 6R0 937 087 D
   Component: GW-K-CAN TP20 0207
   Coding: 002200
   VCID: F0EFB64B2356489EE43-80A5
1 Fault Found:
01304 - Radio
            004 - No Signal/Communication
                    Fault Status: 01100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 137
                    Mileage: 10834 km
                    Time Indication: 0
                    Date: 2061.14.28
                    Time: 08:54:24
Address 25: Immobilizer (J285)       Labels: 5K0-920-xxx-25.clb
   Component: IMMO          H13 X005
   Serial number:
   ASAM Dataset: EV_ImmobUDSJCIPQ25 A01001
   ROD: EV_ImmobUDSJCIPQ25_SK25.rod
   Part No: 6R0 423 156 B
   Coding: 11230
   Shop #: WSC 00788
   VCID: 2F6DF537EAE897663D9-807A
Address 56: Radio
Cannot be reached
End   ---------------------------------------------------------------------
I hope I did everything as you said. :)
Posted: Fri Dec 25, 2015 4:26 pm
by gpeixoto109
ciclo wrote:Meanwhile ... another one of my latest creations.
Image :lol:
Previously requested by a mate in this forum.
Thank you for all your help, Fernando! :D
Posted: Sat Dec 26, 2015 1:07 am
by Marjacic
https://www.youtube.com/watch?v=WZSKZsT ... e=youtu.be
Did it :!: :D :mrgreen:
It would be nice if it was possible to have the navigation futures in it to, to show the road when navigation is on, compass and that stuff.. :cry: :roll:
happy holidays :lol:
Posted: Sat Dec 26, 2015 4:40 am
by gpeixoto109
Marjacic wrote:https://www.youtube*.com/watch?v=WZSKZsTZ ... e=youtu.be
Did it :!: :g :mrgreen:
Hello Marjacic what is the reference of your tacho? Did you used the amarok tacho or you found a reference for the polo?
If the amarok one how did you changed the circumference of the wheel, the volume of the deposit tank and how did you changed the pictogram for the image of the polo?
Thank you! :D
Posted: Sat Dec 26, 2015 9:13 am
by ciclo
iichel wrote:So the problem was a mistake from myself. I have re-done the auto-wiring loom and in the process some contacts went loose.
That has caused the headlight washer system not to work. I was very surprises because it was factory equipment.
At the BCM connector, the plastic arount T73b/4 went a little bad from removing and re-inserting the terminal connector.
So it was also a bad loose contact. But that is fixed now. So now the retrofit of the 7E0 BCM and stalks is complete.
Before the stalks and wiring, sometimes the low beam had some problems after high beam had been on.
For example, after high beam flash (pull back), the low beam also went off shortly. Now that is completely fixed.
Bit 18 is coded as '73' HEX.
For checking coding, I have made an excel sheet with all the functions I know and that is also how I code the BCM since there are no labels.
I will investigate the software you suggested for sure.
Thank you very much ciclo for your time. I promise today I will not bother you with my f**k-ups :p
Merry christmas!
Good Job!
iichel, you can bother me with your f**k-ups whenever you want because I hope able to bother you with my f**k-ups whenever I want ...Image
I would have to read the user manual from a VW T6 before publishing this video here, however ...
What do you think? :mrgreen:
tadej wrote:Hi Ciclo.
Hi tadej, it's perfect.
First of all, your BCM 6R0937087D supports static cornering light, and VCDS version 12.12 is more than enough for your 6R.
Model Year "A" (2010) with CAYB engine has different configurations of electrical wiring within this year, this only happens with this engine and this year, it is a somewhat special case. This is good in any case.
Due to the configuration of the fuses from your 6r i guess your 6R wasn't manufactured between September and October 2009. POLO 6R with engine CAYB which were manufactured between these months are very special, they can install automatic lights just like those with xenon and bluemotion (BOOM for others that read this...LOL!), but it's necessary to change BCM.
Now...your fuse box
SB54= foglights without BCM control
SB56= DRL without BCM control
SB57= foglights with BCM contol (static cornering lights)
So here's something strange, but good anyway. Sometimes factory wiring exists although not have the equipment which corresponds to the wiring. I think it's because your 6R is the first year of production.
You have to do a simple test to unravel this mess that is not contemplated in Elsawin in a direct way.
- Extract fuse SB57, check all lights, one by one, tell us the outcome of this test, it is likely that nothing happens.
- Make a VCDS autoscan with the fuse removed. Tell us if there are any changes.
In any case, for you, will always be easier to get the static cornering lights than for other Polo's owners from different year.
Please take two pictures of wires on light switch connector (both sides). Remove light switch, take out connector, take pics...easy. :wink:
Excellent, very good jobImage, enjoy it. 8)
However your wiring is this: http://www.uk-polos.net/viewtopic.php?f ... 15#p501845 :lol:
Great! 8)
Navigation features :?: , with RNS or compatible.
Posted: Sat Dec 26, 2015 9:42 am
by Marjacic
Thank you! :D
Hello gpeixoto109
i used the tacho from an Amarok part no. 2H0920871 without any letter at the end, if you buy ex: 2H0920871"A" then it is not possible to fit because of the software is to new.
But you have to find a guy in the German forum called potatodog, he have the tools to fix the tachos and do som Eeprom and change the pictogram :lol:
Posted: Sat Dec 26, 2015 9:43 am
by iichel
You can mail me whenever you want :oops: :P
Posted: Sat Dec 26, 2015 9:54 am
by Marjacic
Yes Navigation features, with Rns 510 , like in the pics you see
maybe i have to do some wiring from the rns to the tacho? :roll:
Example:
Posted: Sat Dec 26, 2015 10:44 am
by gpeixoto109
Thank you! :D
Hello gpeixoto109
And how did it worked? You sent the tacho to him, he did everything and sent you again?
Posted: Sat Dec 26, 2015 10:46 am
by ciclo
iichel wrote:You can mail me whenever you want :oops: :P
:wink:
Marjacic wrote:Yes Navigation features, with Rns 510 , like in the pics you see
Do you have RNS510 installed?
http://www.uk-polos.net/viewtopic.php?f ... 50#p502972
VCDS scan?
For this reason is why it is important that all of you build a new topic dedicated your 6R with photos, videos, autoscan, etc ... this way is easier to help.
I have not an infinite memory for remember everything that all of you write ...Image
Posted: Sat Dec 26, 2015 12:11 pm
by tadej
ciclo wrote: Please take two pictures of wires on light switch connector (both sides). Remove light switch, take out connector, take pics...easy. :wink:
Ciclo thank you very much for that kind of information. I can't thank you enough what you guys do here. :)
So I just remove light switch and take picture of connectors? Put the light switch in 0 position, push in, and put on sidelights and then pull out? :)
Thank you again :) you guys rock 8)
Posted: Sat Dec 26, 2015 12:30 pm
by Marjacic
:wink:
VCDS scan?
yes i know but i haven“t got time for it yet .. will do soon! :)
and thanks again :)
my autoscan
Chassis Type: 6N0
Scan: 01 03 08 09 15 17 19 25 37 44 56 69 77
VIN: WVWZZZ6RZBYMARJACIC
56-Radio -- Status: OK 0000
69-Trailer -- Status: OK 0000
Address 01: Engine (J623-CAYC)       Labels: None
   Part No SW: 03L 906 023 MC    HW: 03L 907 425 B
   Component: 1,6l R4 CR td H33 9971
   Revision: --H33---    Serial number:
   Coding: 00114016002400080000
   Shop #: WSC 00788 648 00255
   ASAM Dataset: EV_ECM16TDI02103L906023MC 003011
   ROD: EV_ECM16TDI02103L906023MC.rod
   VCID: 73EFC115DAAE091
Address 03: ABS Brakes (J104)       Labels: 6J0-907-37x-ESP.clb
   Part No SW: 6R0 907 379 AK    HW: 6R0 907 379 AF
   Revision: --------
   Coding: 210248E3417100B2842E12EB82D900421300
   VCID: 871705C53236951
Address 08: Auto HVAC (J255)       Labels: None
   Part No SW: 6R0 907 044 E    HW: 6R0 907 044 E
   Component: Climatronic   H09 0609
   Revision: V0000000
   VCID: 356B3F0D9C5A571
   Part No SW: 6R0 937 087 H    HW: 6R0 937 087
   Component: BCM PQ25 H+4  H46 0230
   Revision: BF046001    Serial number: 0394 049111171
   Coding: 3CB82FB868210000013808247E8C1FD1D08041BF60862041000000000000
   Shop #: WSC 00070 123 12345
   VCID: 428154D1DD94F09
   Component: RLS 170211 05  54  0403
   Coding: 07302D
   Subsystem 2 - Part No SW: 6R0 959 801 AB    HW: 6R0 959 801 AB  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  007 1611
   Coding: 18BC30
   Subsystem 3 - Part No SW: 6R0 959 802 AD    HW: 6R0 959 802 AD
   Component: J387__TSG_BT  007 1611
   Coding: 08BC30
   Subsystem 4 - Part No SW: 5K0 959 542 A    HW: 5K0 959 542 A
   Component: E221__MFL-TAS  H07 0013
   Coding: 020000
   Subsystem 5 - Part No SW: 6R0 959 811 G    HW: 6R0 959 811 G
   Component: J388__TSG_HL  007 1611
   Coding: 08BC32
   Subsystem 6 - Part No SW: 6R0 959 812 G    HW: 6R0 959 812 G
   Component: J389__TSG_HR  007 1611
   Coding: 08BC32
   Part No SW: 6R0 959 655 L    HW: 6R0 959 655 L
   Component: VW10Airbag022 H09 0020
   Revision: --------    Serial number: 003GY002L1ZQ
   Coding: 003232
   VCID: 4B9F79F5E2DE311
   Serial number: 3575HRB40650C15I38NV
   Serial number: 3585HRB405V0BI7S4G7Z
   Serial number: 3515RRB4055058P0KPJN
   Serial number: 3525RRB405T0G2I2L8O.
   Part No SW: 2H0 920 871     HW: 2H0 920 871
   Component: KOMBI         H04 0705
   Coding: 140E00
   Shop #: WSC 12345 123 12345
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04721
   ROD: EV_Kombi_UDS_VDD_RM09_VW25.rod
   VCID: E5CB2F4DE47A671
   Component: GW-K-CAN TP20 0230
   Coding: 002200
   VCID: F0E54E1923B8B29
   Component: IMMO          H04 0705
   Serial number:
   Shop #: WSC 00000 000 00000
   ROD: EV_Immo_UDS_VDD_RM09_VW25.rod
   VCID: EAD15C710D64489
Address 37: Navigation (J0506)       Labels: 1T0-035-680.clb
   Part No SW: 1T0 035 680 Q    HW: 1T0 035 680 Q
   Component: RNS-MID       H10 5270
   Revision: AB001001    Serial number: VWZ6Z7L8054171
   Coding: 00000402000000012000
   ASAM Dataset: ------------------------- ------
   VCID: 3C7D2A29BF70869
   Subsystem 1 - Part No: 1T0 919 859 B
   Component: EU West V12  8195
Address 44: Steering Assist        Labels: 6Q0-423-156.lbl
   Coding: 11230
   Shop #: WSC 00788
   VCID: 2F670D65EA066D1
Address 56: Radio (J0506)       Labels: 1T0-035-680.clb
Address 69: Trailer (J345)       Labels: 1K0-907-383-MY8.lbl
   Part No SW: 1K0 907 383 F    HW: 1K0 907 383 F
   Component: Anhaenger     H09 0100
   Revision: 3A001001    Serial number: 00000144299947
   Coding: 0100000100000000
   Shop #: WSC 00070 000 00000
   VCID: 30650E196338729
Address 77: Telephone (J412)       Labels: 7P6-035-730.clb
   Part No SW: 7P6 035 730 N    HW: 7P6 035 730 N
   Component: TELEFON       H15 4217
   Revision: 1B001001    Serial number: 00007699999999
   Coding: 0200000000010110
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA_VW25.rod
   VCID: 3D7B272DAC6A8F1
Posted: Sat Dec 26, 2015 12:31 pm
by Marjacic
gpeixoto109 wrote:
Thank you! :D
Hello gpeixoto109
check PM 8)
Posted: Sat Dec 26, 2015 1:18 pm
by ciclo
Marjacic
Rns510 New coding
00000402000000812000
Check MFD
Tell us the results...
Posted: Sat Dec 26, 2015 1:38 pm
by Marjacic
ciclo wrote:Marjacic
Rns510 New coding
Check MFD
nothing happend :(
