Page 117 of 333
Posted: Wed Dec 30, 2015 5:58 pm
by ciclo
aaygen wrote:Hi ciclo, do you know if 6C BCM's are compatible with Bi-Xenon and LED headlights straight away with a halogen to hid adapter and coding?
Hi aaygen, I don't know, iichel has more experience with the lights 6C.
iichel, what do you think?
Posted: Wed Dec 30, 2015 7:48 pm
by benji58
ciclo wrote: As you can see in the scheme of tempo84 you have connected the LED module to power supply wire of sidelights. Therefore, consumption is too high because front and rear sidelights in your 6R are in the same line.
6R with factory xenon have individual power supply wires from BCM for front and rear sidelights.
okay, thank you for the explanation ! I tested by having to disconnect the headlight and it works. I order two LED bulbs W16W, awaiting reception :D
Thank you for your help.
I think later change my BCM for 7H for OEM wiring, if you have good plans I'm interested :lol:
Posted: Wed Dec 30, 2015 9:30 pm
by mthoosen82
Hi Ciclo, thank you so much, info was helpfull, just hope I will be able to order the springs from VW as I am from South Africa and VW always gives us issues on ordering suspension parts, they say it's not for our country.
Sent from my SM-N9005 using Tapatalk
Posted: Thu Dec 31, 2015 11:58 am
by iichel
I'm not sure to be honest.
I do think it is possible, because in ETKA (the parts catalogue where all parts are listed) there are not many variations in the 6C BCMs.
Most of the 6C Polos are bluemotion technologies, meaning they have start stop. And start stop means that the lights all go through the BCM.
In comparison, the 6R has many varieties in BCM because of start/stop, trim level and factory options. But I cannot find this many variation in the 6C BCM list.
I've retrofitted Polo 6C halogen to xenon only once and that BCM was the 6C0 937 090 and it had all the pins for the OEM xenon headlights and OEM LED headlights.
But the coding was more difficult, we simply put a coding of a different 6C into the BCM and it worked. But this is not very nice of course. Better is to have proper coding.
It was still in the time that VCDS did not have labels for the Polo 6C BCM, maybe now it is more easy.
The most easy way to find out if your BCM does have the necessary equipment is to make a photo of the BCM while it is not in the car.
This way the pins are all exposed and we can see if the necessary pins are present.
Posted: Thu Dec 31, 2015 6:53 pm
by ciclo
mthoosen82 wrote:Hi Ciclo, thank you so much, info was helpfull, just hope I will be able to order the springs from VW as I am from South Africa and VW always gives us issues on ordering suspension parts, they say it's not for our country.
Keep in mind the color coding of springs for 6R GTI (SA). Some links that can be helpful (if you need):
ETKA online: http://ifinterface.com/page/page3.php?langid=2 from here http://www.uk-polos.net/viewtopic.php?f ... 13#p466570
PR-codes: http://prsearch.planetvag.com/ also in PDF to download http://www.eftermontera.se/pdf_nerladdning/PR-koder.pdf
For example: Click to enlarge :wink:
Posted: Thu Dec 31, 2015 7:55 pm
by CNK
iichel wrote:I've retrofitted Polo 6C halogen to xenon only once and that BCM was the 6C0 937 090 and it had all the pins for the OEM xenon headlights and OEM LED headlights.
So you don't have 7E0 BCM?
Posted: Thu Dec 31, 2015 7:56 pm
by iichel
We are taking about 6C not 6R
Posted: Thu Dec 31, 2015 8:01 pm
by ciclo
Take a good picture when you install the LED bulbs and show us please... .
I have for sale my BCM 7H0. Make me an offer, I would prefer to sell to someone with a certain technical knowledge. Image Image
Has markings without importance, they were made with connectors when it was removed and installed several times.
http://www.uk-polos.net/viewtopic.php?f ... 68#p501914
The important thing is inside. 8)
Posted: Thu Dec 31, 2015 8:12 pm
by mthoosen82
Hi Ciclo Is it possible to supply the part numbers of the sports springs, which you fitted to your vehicle
Posted: Thu Dec 31, 2015 8:15 pm
by iichel
The part numbers are mentioned in the topic ;-)
Posted: Thu Dec 31, 2015 8:17 pm
by CNK
iichel wrote:We are taking about 6C not 6R
Ok, sorry, my mistake - I don't read it :oops:
Posted: Thu Dec 31, 2015 8:37 pm
by ciclo
ciclo wrote:
ciclo wrote:... with music:
:wink:
Imagelast clue :
Ok, another clue: from-to
... so the replay is not a replay ...Image
Solution:
My year-end gift for everyone. :mrgreen:
​BCM 7E0, Adaptation, channel 54, from 0 to 1.
Happy New Year to everybody.ImageImage
Posted: Thu Dec 31, 2015 8:52 pm
by iichel
Happy Silvester ciclo!
Posted: Fri Jan 01, 2016 8:52 am
by ciclo
mthoosen82 wrote:Hi Ciclo Is it possible to supply the part numbers of the sports springs, which you fitted to your vehicle
NO. You have to take into account the factory shock absorbers currently installed in your 6R GTI.
Physically you check the current color code of factory springs (color points on springs), also the reference number of the shock absorbers. You need this info.
With PR-codes and ETKA (links I gave you previously) you should find what you are looking for. :wink:
Posted: Fri Jan 01, 2016 8:56 am
by mthoosen82
Cool Thank you so much[THUMBS UP SIGN]
