iichel wrote:Happy Silvester ciclo!
Thanks my friend Image
It's a good way to start the year although where I live it is said that running is for cowards ... :lol: (I love running)
Mart!n-GTI-DK
Drives: '14 Polo BlueGT
Post by Mart!n-GTI-DK »
ciclo wrote:My year-end gift for everyone. :mrgreen:
​BCM 7E0, Adaptation, channel 54, from 0 to 1.
Happy New Year to everybody.ImageImage
So now everything works with your automatic highbeam project???
tadej
Drives: 6R 1.6TDI DSG
Post by tadej »
Happy new year! :)
Mart!n-GTI-DK wrote: So now everything works with your automatic highbeam project???
Unfortunately not, it just is a first step to run 7E0 stalks with return spring (video), it just is possible with BCM 7E0.
6R0 stalks have no return spring, and it is necessary with HBA.
BCM 7H0 937 090-090A-090B don't have available the channel 54 (checked).
tadej wrote:Happy new year! :)
Thanks! Beautiful picture. 8)
New mod High Beam Assist OEM
:lol: Logo for tshirts :lol:
Video
How does it work?
User manual: https://drive.google.com/file/d/0B2nv91 ... sp=sharing
And exactly as explained in the following videos.
Live perfomance
Info:
- Parts
BCM, Stalks, mirror 8G1, etc...: 7E0 from VW T6(2016)
Choose what you need: http://ifinterface.com/page/page3.php?langid=2
Pr codes PDF: http://vag-codes.info/files/options/vag ... -codes.pdf
http://www.uk-polos.net/viewtopic.php?f ... 13#p466570
In my case:
:arrow: BCM
Image Image Image Image
Stalks for my R-line with :arrow: MFSW
:arrow: Mirror-camera, RLS
- Diagrams, wirings.
1-Lights:
ciclo's r-line https://drive.google.com/file/d/0B2nv91 ... sp=sharing
WRC https://drive.google.com/file/d/0B2nv91 ... sp=sharing
It is necessary to codify BCM, see BCM coding in VCDS Autoscan below.
2-Mirror-camera-BCM-IC:
Click here to enlarge, download, etc...: https://drive.google.com/file/d/0B2nv91 ... sp=sharing
http://www.a4-freunde.com/showwiki.php? ... uebersicht
In POLO 6R BlueMotion is necessary to remove the external Gateway (forever) in case it has installed from the factory (not in all Bluemotion).
All communication lines must be connected to communication Network of the new BCM. If you have questions about it, make your questions to iichel :wink:
Example external Gateway (remove glove box):
- VCDS (labels are not available for BCM, Gateway nor RLS)
BCM coding
Byte28 Bit3 enabled
BCM Adaptation
53 from 0 to 1 ... HBA
54 from 0 to 1 ... 7E0 stalk with return spring
Friday,15,January,2016,21:45:42:06516
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 15.7.3.0
Data version: 20151216
www.Ross-Tech.com
VIN: WVWZZZ6RZDY0CICLO   License Plate:
Mileage: 17310km-10755mi   Repair Order:
Chassis Type: 6R (7E0)
Scan: 01 03 08 09 10 15 17 19 20 25 2E 37 44 55 56 77
VIN: WVWZZZ6RZDY0CICLO   Mileage: 17310km-10755miles
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CBZC)       Labels: 03F-906-070-CBZ.clb
   Part No SW: 03F 906 070 GD    HW: 03F 907 309 AJ
   Component: SIMOS10.22AH10 2686
   Revision: --H10---    Serial number: 00000000000000
   Coding: 001100D6202400080000
   Shop #: WSC 00788 648 00255
   ASAM Dataset: EV_ECM12TFS02103F906070GD 004004
   ROD: EV_ECM12TFS02103F906070FJ.rod
   VCID: 6A1F7AE4CFD85FA88D-803E
Readiness: 0000 0000
Address 03: ABS Brakes (J104)       Labels: 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 BE    HW: 6R0 907 379 AF
   Revision: --------
   Coding: 210228E3216D00B5842814EA84D300401700
   VCID: 02B74ABC23A0CF80CD-8056
   Part No SW: 6R0 907 044 H    HW: 6R0 907 044 H
   Component: Climatronic   H11 0711
   Revision: V0000000
   VCID: 38E1E65E1FDE8B0A1D-806C
Address 09: Cent. Elect. (J519)       Labels: None
   Component: BCM PQ25 Max4 H80 0733
   Revision: B9080001    Serial number: 0771 100150209
   Coding: 3CB02FBF08E1240093380E917CEB9FD0DAC0672F600D30D0200000030800
   Shop #: WSC 03607 002 104857
   VCID: 681186EEDFAE6BBA9D-803C
   Subsystem 1 - Part No: 5K7 955 559 B
   Component: RLS 110215 03  37  0059
   Coding: 0228EE
   Subsystem 2 - Part No SW: 6R0 959 801 BD    HW: 6R0 959 801 BD  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  003 8612
   Coding: 0200A3
   Subsystem 3 - Part No SW: 6R0 959 802 BF    HW: 6R0 959 802 BF  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  003 8612
   Coding: 1000AB
   Subsystem 5 - Part No: 1K8 951 605 B
   Component: LIN BACKUP HO  H11 9005
   Subsystem 7 - Part No SW: 1K8 959 442     HW: 1K8 959 442
   Component: E221__MFL-DC1  H03 0103
   Coding: A4FFFF
   Subsystem 8 - Part No SW: 6R0 959 811 G    HW: 6R0 959 811 G
   Component: J388__TSG_HL  008 1611
   Coding: 18BC32
   Subsystem 9 - Part No SW: 6R0 959 812 G    HW: 6R0 959 812 G
   Component: J389__TSG_HR  008 1611
   Coding: 18BC32
Address 10: Park/Steer Assist (J446)       Labels: 6R0-919-475.clb
   Part No SW: 6R0 919 475 C    HW: 7E0 919 475
   Component: PARKHILFE 4K  H11 0013
   Revision: --------    Serial number: 47361212601014
   Coding: 308001
   ROD: EV_VW250ParkiAssis2.rod
   VCID: 3EEBD2603FFC575CED-806A
   Component: VW10Airbag01M H10 0020
   Revision: --------    Serial number: 003GX01JKVVP
   Coding: 00314D
   Shop #: WSC 01383 785 00200
   ROD: EV_AirbaVW10BPAVW250_SE25.rod
   VCID: 4AFFBA844F381F888D-801E
   Crash sensor for side airbag; driver side:
   Serial number: 3575HRB405N1C4LI7929
   Crash sensor for side airbag; front passenger side:
   Serial number: 3585HRB405B1D5MS8GS2
   Crash sensor for side airbag; rear; driver side:
   Serial number: 3515RRB405B17ABS901.
   Crash sensor for side airbag; rear; passenger side:
   Serial number: 3525RRB405B181TUDPKC
   Part No SW: 6R0 920 870 C    HW: 6R0 920 870 C
   Component: KOMBI         H05 0607
   Coding: 140E01
   Shop #: WSC 00233 572 91226
   ROD: EV_Kombi_UDS_VDD_RM09_SK35.rod
   VCID: 35E2E0471BA1991F25-8060
   Component: GW-K-CAN TP20 H80 0733
   Revision: B9080001
   Coding: 002200
Address 20: High Beam Assist. (J844)       Labels: 8S0-857-511.clb
   Revision: AA001001
   Coding: 0404001C00000000000000
   VCID: 2EDBF230FF8CB7CC6D-807A
   Component: IMMO          H05 0607
   Shop #: WSC 00000 000 00000
   ROD: EV_Immo_UDS_VDD_RM09_SE25.rod
Address 2E: Media Player 3 (J650)       Labels: 5N0-035-342.lbl
   Part No SW: 5N0 035 342 F    HW: 5N0 035 342 F
   Component: SG EXT.PLAYER H18 0530
   Revision: A1001003    Serial number: 7662584630
   Coding: 010100
   VCID: 2ADFFA24C798DFE88D-807E
Address 37: Navigation (J0506)       Labels: 1T0-035-680.clb
   Part No SW: 1T0 035 680 L    HW: 1T0 035 680 C
   Component: RNS-MID       H06 5218
   Revision: AB001001    Serial number: VWZ6Z7L7654213
   Coding: 04000442040000A10001
   Shop #: WSC 12345 123 12345
   VCID: 37E0E45D1BDB8D0D15-8062
   Subsystem 1 - Part No: 1T0 919 859 B
   Component: EU West V13  8348
   Part No: 6R0 423 156 B
   Coding: 11250
   Shop #: WSC 00788
   VCID: 2FD8F4356F83BDC555-807A
Address 55: Headlight Range (J431)       Labels: 6R0-907-357.clb
   Revision: --------    Serial number: --------------
   Coding: 0112000001000000
   VCID: 7720641D131B0DCD15-8022
Address 56: Radio (J0506)       Labels: 1T0-035-680.clb
Address 77: Telephone (J412)       Labels: 7P6-035-730.clb
   Part No SW: 7P6 035 730 L    HW: 7P6 035 730 L
   Component: TELEFON       H15 3200
   Revision: 1B001001    Serial number: 00007664158506
   Coding: 0501000000010110
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA.rod
   VCID: 3BECDC6903CF6571F5-806E
End-------------------------(Elapsed Time: 03:19)--------------------------
Address 19: CAN Gateway
Go to installation list, select High Beam Assist. Save coding.
Address 20: HBA Adaptation (if you want)
Activation speed for high beam assistant, default 38 km/h (I set at 30km/h)
Check other very useful and very cool adaptations. 8)
HBA security access: 20103 (if you need)
Works like a charm.Image
From here http://www.uk-polos.net/viewtopic.php?f ... 20#p499181 up to this point you have a lot of information about the project that has become reality, images, videos, info, etc ... with the mistakes and the successes. Always keep in mind that the final information is here.
benji58
Drives: 6R R-Line 1.2 TDI
Post by benji58 »
ciclo wrote: Take a good picture when you install the LED bulbs and show us please... .
I have for sale my BCM 7H0. Make me an offer, I would prefer to sell to someone with a certain technical knowledge. Image Image
Has markings without importance, they were made with connectors when it was removed and installed several times.
http://www.uk-polos.net/viewtopic.php?f ... 68#p501914
The important thing is inside. 8)
Happy New Year everybody !
I installed the LED bulbs, the light power is similar, really slightly higher than standard bulbs W16W:
Ok, I don't know, this mod was not anticipated now. Unless you make me a good price :mrgreen:
diskoboy
Drives: 1.6 TDI BMT
Post by diskoboy »
Does the Polo 6C windscreen have the new rainsensor or is it the same as in 6R ?
Awesome work ciclo. The last step was only to change the channel 53?
I believe I have the same wiring but not the same mirror/light sensor. I guess now I have to order the mirror :-)
benji58 wrote: Happy New Year everybody !
[/img]
Thank you very much for the picture, looks good. Do you have a link to LEDs bulbs? in case others could be interested.
About BCM 7H0937089F, make me an offer when be possible to you. :wink: (better make the offer in the section of sale, thanks)
diskoboy wrote:Does the Polo 6C windscreen have the new rainsensor or is it the same as in 6R ?
Yes, Polo 6C has new rain light sensor, but it is not the same T6 rain light sensor.
T6 rain light sensor (5K7 955 559 B) works perfectly with HBA on my 6R with BCM 7E0...(Automatic lights and CH/LH, Automatic wiper) ...with all possible codings for both.
iichel wrote:Awesome work ciclo. The last step was only to change the channel 53?
Thanks iichel, and yes, channel 53 only. :lol:
Correct, you need mirror, retaining plate and RLS, etc from T6.
diskoboy
Drives: 1.6 TDI BMT
Post by diskoboy »
I'll think I'll have to change the windscreen to the one from 6C (6RU 845 011 J NVB). It has the retaining plate for the mirror that Transporter uses...
diskoboy wrote:I'll think I'll have to change the windscreen to the one from 6C (6RU 845 011 J NVB). It has the retaining plate for the mirror that Transporter uses...
Yes it is the same retaining plate.
Remove factory windshield? Image... pfff ... not a good solution.
You can do this: (read this page)
http://www.uk-polos.net/viewtopic.php?f ... start=1620
In workshop manual (6R MK5) you have the process clearly explained.
By the way, yesterday, it was the test of the HBA system during a travel with lots of rain, it works like a charm ... FANTASTIC!Image
wamba
Drives: polo 1.2tsi
Post by wamba »
good works ciclo
the next mode is ACC :wink:
Thank you very much wamba. :wink:
I think ACC is also possible, but I fear I will not install on my R-line.
T73b/36 lin, a relay in CAN lines powertrain, T73a/8 relay signal to ground... etc :lol:
If i remember correctly, the T6 BCMs were indicated with PR codes (this part I'm sure about, lol) but there were different versions with normal and active cruise control
You're right, but it is possible... click, click, click, done. :lol:
Locked
