Benzinkopf's 2012 VW POLO 6R MK5 1.2TSI 105HP DSG
benzinkopf
Drives: 1.2TSI 105HP DSG7
Re: Benzinkopf's 2012 VW POLO 6R MK5 1.2TSI 105HP DSG
Post by benzinkopf »
PoloBlueGT wrote:Just a quick question what is the interior monitoring button for?
If you re referring to the small button below the B pillar next to the driver’s seat; then the button is to deactivate the interior monitoring & leveling system: in the event you want to leave animal (movements) inside ur car and lock or when you want to tow your car.
benzinkopf
installation in progress!!! 0-0
thanks a lot to everybody involved in sourcing the part and shared information on the processes! RCD510 indeed requested the pincode.
We want more details of this process that you are doing ...
benzinkopf
ciclo wrote:We want more details of this process that you are doing ...
Unfortunately there’s nothing more than just sitting in the car and swapping the cluster. The tech guy in the dealership was doing his job with his official tool. 0-0 means there are no key information and nothing match. The end result will be 2-2 for 2 keys.
benzinkopf
btw in the meantime, i did the first try run to modified eeprom with reference to information from firegrafik post in drive2.ru. after the eeprom mod, cluster staging works immediately without the need to change adaptation channel. interestingly, both channels (staging and indicator celebration) still not available. I think this has to do with the led backlighting which is still not light up while “staging”. maybe there’s another byte to change.
I think the backlight should keep turned off while the needles are being checked.
Play, youtube, and full screen
Apologies for the quality of the video (it was taken with a very old phone).
I don't apologize for the music, it sounds perfectly. :lol: Image
benzinkopf
Oh yes Ciclo. I'm sorry i was referring to the needle backlight. Not the speedo/rpm backlight. Not sure if the modified eeprom will be different in coding for highline MFD (as firegrafik post) because i did the mod with my old cluster. The new cluster already have the adaptation channel.
heres the video
New cluster
[youtube]https://youtu.be/jZfwnwLuwZM[/youtube]
Old cluster - Modified EEPROM for staging active
[youtube]https://youtu.be/ge5pS7vFhCY[/youtube]
Ah okay ... now I understand.
benzinkopf
ciclo wrote:Ah okay ... now I understand.
as u can see from video above. too bad theres no cc display. im waiting for master ciclo’s solution!
benzinkopf wrote: Thu Nov 02, 2017 8:06 am im waiting for master ciclo’s solution!
Me too. :mrgreen:
I am studying it ... while 'm waiting for some tools arrive.
(exciting and maybe some complex the ECU world :twisted:)
benzinkopf
Me too. :mrgreen:
btw ciclo. does the 25327 is working for your cluster only ? or its general code?
General code (unknown function)
benzinkopf
wow! someone is cooking his own ecu!!! change to 250hp? [emoji1360]
benzinkopf wrote: Fri Nov 03, 2017 6:22 am .. change to 250hp?
No. (Golf ECU)
benzinkopf
No. (Golf ECU)
oh yeah. forgot u mentioned it before[emoji1362]
so to enable this gra high function really needs the physical hardway to alter the software or this is for research that could bring the code for us with vcds?
