Introducing my Lightning McQueen LM95
ag69
Drives: 1.2TSi 77Kw 7DSG
Re: Introducing my Lightning McQueen LM95
Post by ag69 »
Can someone help me with wiring diagram for this map sensor connector?
I could not find any other color on white wires. ie orange on white or sort.
ag69
Post by ag69 »
After going through elsa, here is what i found:
https://en.kolhosniki.ru/elsaonline&ver ... m#id500014
Check No. 34 / 7
G42 and G71 connector have 4 wires
T4d/1 -- br -- Brown -- 283 (Earth Point 2)
T4d/2 -- ws -- White -- T60/42 -- J263
T4d/3 -- sw -- Black -- D141 (5V)
T4d/4 -- ws -- White -- T60/55 -- J263
Since both wires are white -- It is guess to which it should be connected.
Does anyone can help me understand T60/42 and T60/55 of J623 ie ECU does?
As there is no current flowing -- there is no harm in connecting them in any way.
Any advise on how to distinguish it from harness side -- would be welcome.
/55 is a pressure transducer which probably will probably be a variable voltage output between 0 and 5V
/42 is a temperature sensor with a PTC or NTC over GND
Best practice is to disconnect T60 and find T60/55 (easiest) and connect it to T4d/4
And 'tother goes to T4d/2
ag69
Post by ag69 »
Thank you very much iichel.
ag69
Post by ag69 »
6RF035187C aka R 340G (PQ)
Finally, after a lot of searches, patience, being fooled by sellers, here is a legit used 6RF035187C.
Super packing 1
Super packing 2
Super packing 3
Super packing 4 / Box
Super packing 5
First Glimpse
Device in hand
Device in car
Device in car with illumination
This is an OEM Visteon unit (Manufactured in June 2021) which came in Polo. Seller sold his car, and I was prompt and lucky to be first in line to buy it.
No user manual was provided. However, anti-theft code was provided.
After opening all the packing took radio in car.
Removed existing stereo and unplugged ISO connectors and radio antenna cable.
Connected ISO to Quadlock adapter (with additional CAN+ and CAN - wires) to radio side.
Connected ISO to car ISO connector.
Turned Ignition turned ON.
Powered on radio with left round button.
Presented with "Anti-theft code" screen.
Entered Code
and got radio playing.
Pressed APP button and all three "android auto", "apple carplay" and "mirror link" options were present.
Connected VCDS and here is scan
Wednesday,24,January,2024,07:49:21:47040
VCDS Version: 23.3.1.0 (x64)  HEX-V2 CB: 0.4631.4
Data version: 20230421 DS346.2
www.Ross-Tech.com
VIN: WVWL14601FT043293   License Plate: MH12LM0095
Mileage: 13060km-8115mi   Repair Order:
Chassis Type: 60-VW25 (6N0)
Scan: 01 02 03 04 08 09 15 17 19 25 44 56
VIN: WVWL14601FT043293   Mileage: 13060km-8115miles
56-Radio -- Status: Not registered 0001
Address 01: Engine (J623-CBZB)       Labels:. 03F-906-070-CBZ.clb
   Part No SW: 03F 906 070 KC    HW: 03F 907 309 AJ
   Component: SIMOS10.22AH10 6270
   Revision: --H10---    Serial number:                CVN: 9408DB59
   Coding: 00250056232400080000
   Shop #: WSC 00793 648 00255
   ASAM Dataset: EV_ECM12TFS02103F906070KC 004006
   ROD: EV_ECM12TFS02103F906070FP.rod
   VCID: 6D84C0DFDD1A8262D4D-8038
   VINID: 9E69DC0441800569001030890CB4E08725
Readiness: 0000 0000
Address 02: Auto Trans        Labels: 0AM-927-769.clb
   Part No SW: 0AM 300 065 N    HW: 0AM 927 769 D
   Component: GSG DSG AG7     431 6561
   Revision: 00043014    Serial number: CU501407085037
   Coding: 0000020
   Shop #: WSC 63002 002 1048576
   VCID: 3A2E3B83D054E5DA01F-806E
   Part No SW: 6R0 907 379 BH    HW: 6R0 907 379 AS
   Component: ESP9.0i front H03 0001
   Serial number: --------------
   Coding: 62DD2463422703C3461624724254C0800904
   Shop #: WSC 00788 648 00255
   ASAM Dataset: EV_Brake1ESP90iBOSCH 003020
   VCID: 0554987FE5AA5A223CD-8050
   Serial number: 14081404650280
   Coding: 01
   Shop #: WSC 00000 000 00000
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EA6F793807C09FA7D7-802A
   Part No SW: 6R0 907 044 P    HW: 6R0 907 044 P
   Component: Climatronic   H12 0614
   Revision: V0000000
   VCID: 40DA496BBA88BF0A4FB-8014
   Part No SW: 6R0 937 087 R    HW: 6R0 937 087
   Component: BCM PQ25 H+4  H34 0424
   Revision: BF034001    Serial number: 0681 233141094
   Coding: 3AB82BBF08B30000003800006C2B049000C0414F608C0000200000000000
   Shop #: WSC 124697 483 00190
   VCID: 4CC26D5B86C06B6AA33-8018
   Subsystem 1 - Part No SW: 6R0 959 802 AL    HW: 6R0 959 802 AL  Labels: 6R0-959-802.CLB
   Component: -------------  006 5550
   Serial number: 13102576140821120301
   Coding: 010000
   Subsystem 2 - Part No SW: 6R0 959 801 AH    HW: 6R0 959 801 AH  Labels: 6R0-959-801.CLB
   Serial number: 13202579140804112607
   Coding: 010000
   Subsystem 3 - Part No SW: 6C0 959 442     HW: 6C0 959 442
   Component: E221__MFL-TAT  H03 0015
   Serial number: 1201410594800708AA1B
   Coding: 250000
   Subsystem 4 - Part No SW: 6R0 959 811 L    HW: 6R0 959 811 L
   Serial number: 13102580140812095241
   Coding: 020000
   Subsystem 5 - Part No SW: 6R0 959 812 L    HW: 6R0 959 812 L
   Serial number: 13202581140821150004
   Coding: 020000
   Revision: --------    Serial number: 003GW00VFBN2 Dataset Number: 00000000000 0001
   Coding: 003036
   VCID: 49CC544F89327E42985-801C
   Part No SW: 6RF 920 860 Q    HW: 6RF 920 860 Q
   Component: KOMBI         H02 0152
   Coding: 140800
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04719
   VCID: 58EA810B429817CA17B-800C
   Part No SW: 6N0 909 901     HW: 6R0 937 087
   Component: GW-K-CAN TP20 H34 0424
   Revision: BF034001
   Coding: 002300
   VCID: 70BAD9ABCAA86F8AFFB-8024
1 Fault Found:
            000 - -
                    Fault Status: 01100000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Time Indication: 0
   Component: IMMO          H02 0152
   Serial number:
   VCID: 6A8ECBC3ECF4955AB1F-803E
Address 44: Steering Assist (J792)       Labels:* 6Rx-909-144-V1.clb
   Part No SW: 6RF 909 144 K    HW: 6RF 909 144 J
   Component: EPS_ECU       H44 0401
   Dataset Number: 6RF074v____ 6010
   Coding: 0000
   ASAM Dataset: EV_SteerAssisUDSNSK 005005
   ROD: EV_SteerAssisUDSNSK.rod
   VCID: 54F2753B5E7033AAFB3-8000
   Part No SW: 6RF 035 187 C    HW: 6RF 035 187 C
   Component: Radio         557 5536
   Revision: --------    Serial number: VWZ7Z2V5102817
   Coding: 0E00044000000F
   Shop #: WSC 31245 005 1048576
   VCID: 49CC544F89B27E42985-801C
End----------(Elapsed Time: 01:09, VBatt start/end: 12.0V/12.0V)-----------
Surprisingly, my last VCDS scan here :arrow:
Tuesday,23,May,2023,15:36:34:47040
www.Ross-Tech.com
Mileage: 12140km-7543mi   Repair Order:
VIN: WVWL14601FT043293   Mileage: 12140km-7543miles
This did not have 56 Radio module installed/enabled.
And latest scan has it enabled.
Good upgrade!👍
giannis20vt
Post by giannis20vt »
One of the best upgrades anyone can do. And easy.
Well done!
Excellent packing :o
ag69
Post by ag69 »
ciclo wrote: Wed Jan 24, 2024 8:10 pm Good upgrade!👍
Thank you ciclo
giannis20vt wrote: Thu Jan 25, 2024 6:21 am One of the best upgrades anyone can do. And easy.
Well done!
Thank you Giannis20vt
Finally, could get 56 Radio enabled and changed one coding for radio
0E00044000000F
to:
0E00040000000F
So now no more come this once reverse gear is enagaged:
Also in addition to existing angled aux cable got this angled USB cable.
It is 9" odd long. So iPhone can be put upside down in compartment under climate control.
Just a precaution to avoid any damage.
Great, so now we know that Byte3 Bit6 enables RVC (I think I read this info in a thread from some D2 wizard a million years ago)... someone recently asked me about the possibility of enabling/disabling with VCDS the RVC and the OPS in this radio model.
By the way, does your model have RDS? shows radio stations?
I don't have this radio model but I find it very interesting and a good upgrade for 6R models... I'm going to investigate to see if I can get the latest FW. Wish me luck! 😄
Update. Instructions:
https://www.drive2.ru/l/590711523584775820/
ag69
Post by ag69 »
Hey ciclo
Nope this does not get RDS.
I had downloaded the images from some VW site.
Some video had shown to go on radio screen and settings icon you get option to upload and then assign them.
— this was not for RCD340
I will click some more photos and also all VCDS screenshots if you want.
And a small video of all functions.
OK thanks. I saw in some of Ali's pictures of these radio models that they had the ability to display the tuned radio station.
For example... BBC CWR, in an Ali buyer review for 6RD035187B (PQ Platforms):
Component: Radio 541 5814
If you want you can make a 'collage' with screenshots of the VCDS label with the definitions/descriptions of the Bits. It's made in D2, but not everyone knows Russian, so it would be nice to have it in English for users who visit your thread (which has many views).👍
ag69
Post by ag69 »
Correction
Radio Lable are displayed for couple of stations.
List view
I misunderstood about image/icon for stations. I think it is displayed like this:
Here VCDS 56 Radio screenshots
01
02
03
04
05
06
07
Here are my RCD System information:
For quick download/viewing. :)
For my CM and DM I downloaded the logos, I think from here https://www.phonostar.de/vw/de/download, unzipped them to an SD and added them with the Radio Settings. There are video tutorials on YT (easy).
I assume that the logos and the procedure for adding them will be the same for your radio model.
Related:
https://www.volkswagen.co.uk/en/owners- ... t-nav.html
ag69
Post by ag69 »
this is one of YT
however i doubt it works with PQ.
One observation is I could only get 8GB micro SD popped in SD card adapter working
Another one with 32 GB formatted to fat32 does not work. Shows "Device error" message.
ag69
Post by ag69 »
Here is actual player with OEM information sticker.
Here are Advanced Information from VCDS:
Sunday,04,February,2024,10:45:14:47040
VCDS Version: 23.11.0.0 (x64)  HEX-V2 CB: 0.4643.4
Data version: 20231027 DS351.0
www.Ross-Tech.com
VIN: WVWL14601FT043293   License Plate: MH12LM0095-RCD340G
                Address 56: Radio
Control Module Part Number: 6RF 035 187 C
  Component and/or Version: Radio         557 5536
           Software Coding: 0E00040000000F
            Work Shop Code: WSC 31245
                      VCID: 49CC544F89B27E42B8D-801C
Advanced Identification
     Identification: VNA-VEI
     Revision: --------
     Date: 27.06.21
     Manufacturer number: 0799
     Test stand number: 2817
Flash Status
     Flash Date: 0000.00.00
Software
     OSEK Net: 03.46.03
     Unknown: 02.00.01
     Diag: 01.03.00
     TP 2.0: 03.05.01
     KWP2000: 03.00.00
     BAP: 01.07.01
Misc.
     Hardware number: 6RF 035 187 C
     Workshop System Name: J503
     Equipment/PR Code: 0000000000000000
     Dataset Number: -----------
     Dataset Version: ----
     End of Line Equipment Level: --------------------
VCDS Info:
       Labels: 5M0-035-1XX-56.CLB
