Dashboard swap! Seat Toledo Instrument Cluster on Cross Polo 6R
spacewalker
- Drives: Just a VW
Re: Dashboard swap! Seat Toledo Instrument Cluster on Cross Polo 6R
06xx is not old
and ok
and ok
nithishsabapathi
- Drives: Ameo TDI (polo 6r compact sedan!)
The thing is, i am looking to install direct TPMS in my car, I was told that this firmware does not support TPMS display, so i am looking to upgrade.
Daniel Ben
- Drives: 2010 6R
Sorry if I'm late to this post
and I'm new to this IC mods.
I see that you've just read your IMMO data and wrote it to the new IC. That's enough or do we need to copy some other data from Old IC to the new one?
Also if the polo 6R doesn't have ABS. How does it affect this swap?
Thank you,
Dan
Thank you,
Dan
The cluster doesn't care about ABS, it is just a display of all incoming messages like ABS, engine, airbag etc.
Daniel Ben
- Drives: 2010 6R
Ohh okay, thanks.
So just coding the Immo is enough?
yes, transfer the immo data, transfer mileage and set the correct codings for seat belt warning, tpms, mfa, etc and your maintenance intervals.
- til3tsio
- Drives: Seat Toledo KG
I need help from the masters !
long story sort ....
I updated my toledo's 6JA SW:711 cluster with amarok 2H0 SW:729.
The problem is that the mfsw’s right wheel that used to control up and down on MFD screen does not work, it works only in the phone menu.
All other buttons work ok, everything else seems ok, also tried 7E0 SW:720, also tried restoring backed up original SEAT eeprom with no luck.
SEAT and Skoda use wheels for volume and mfd up/down and seems that something is missing there, but why work only on one menu is a mystery. Also came to the conclusion that 6JA 711 firmware was in clusters that were produced long after the VW x7xx firmware, but together with the x8xx.
As I do not have access to my original frf file as it was not available on Erwin disks, using newer VW files x8xx or 100x seems a promising solution. There are references that people used these files but they are kept secret so I cannot find them.
I am open to suggestions / directions of any kind.
Perhaps eeprom adjustment for mfsw type?
- til3tsio
I restored even the whole eeprom backup but still the same , works only on phone menu.
Don't know exactly what to change for that.
If I remember correctly you have access to VDO editor, any change that it has any options for that ?
Yes it does have several options for the mfsw type. You could also hold some buttons while turning the key on. Iirc it's left, down and OK.
spacewalker
- Drives: Just a VW
post eeprom dump is working the best for you
spacewalker
- Drives: Just a VW
- til3tsio
thanks but it did not workspacewalker wrote: Mon Aug 29, 2022 6:18 am try this EPP
https://mega.nz/file/FdtGzAYL#aIr6k1y7J ... TF31ef0U5A
spacewalker
- Drives: Just a VW
cluste SW is too old , or BT module update SW
- til3tsio
I updated cluster software and everything worked in the end.
thanks
