ciclo. Wife's Golf MK7.5 Ready2Go 1.0 TSI 6MT 200Nm/l 115HP. 🧙‍♂️
Locked
Re: ciclo. Wife's Golf MK7.5 Ready2Go 1.0 TSI 6MT 200Nm/l 115HP
Golf 7.5 OEM LED light in front storage compartment. 'Images'.
:arrow: viewtopic.php?f=58&t=72376&start=135#p574361
I took some images of the light emitted by the LED light that I installed in the front storage compartment, but as you all know it is very difficult to obtain a clear image of a dim light (ambient) if it is taken with a smartphone.
The light emitted from this ambient light is exactly the same as the light emitted by the OEM footwell lights in ambient light mode. It looks perfect in the real world, without extridencies.
Like the ambient lights, increase and decrease the brightness with the menu for the instruments and lights of switches.
My intention is to show that there are no light leaks if the compartment is closed.
My apologies for the quality of the images:
It looks a bit yellowish in these pictures, but I promise it's white, exactly like the LED footwell lights.
exantas
Drives: Skoda Fabia 5J 1.2 TSI
Post by exantas »
Is the light that you show connected on the footwell lights? Or it is on its own zone, as the similar light on Tiguan?
Sent from my Mi Note 10 Pro using Tapatalk
It is connected to the wire for the LED light that I installed in the 12V socket on the center console, as you can see in the links.
This signal is '58xs dimmer' which is the same signal I use to illuminate the footwell lights in ambient lights mode, as you can see here: viewtopic.php?f=58&t=72376&start=120#p573840
dcgumis
Post by dcgumis »
Fernando Beautiful modifications :D :D , you have blind spot assist installed already ?
Thank you.
BSD+RTA and PLA 3.0 are destined to be installed at the end of this fast-paced and exciting summer of mods at my wife's Golf. Between this week and the next they will already be installed... when my time permits. All indoor wiring for BSD and PLA is already installed.
I decided that mods on the bumpers would be the last thing I would do, as I previously removed the bumpers to install the Replica LED headlights (MORIMOTO LEDS 💎) and other things, that is, I saved the easy part for last. :)
Golf 7.5 Adding the wires for the BSD warning light in the mirror.
Passenger Door.
info :arrow: viewtopic.php?f=58&t=72376&start=60#p571441
Once we have crimped the appropriate terminals, we install everything in reverse order. In other words, I did not take more images because they are very simple tasks.
I changed the corrugated tubes for new ones, here I should comment something, but I prefer not to... viewtopic.php?f=58&t=72376&start=75#p571691 :)
I apologize for my 3D drawing of the inside of the door... 😂
edit... Driver's door
Crystal clear. :wink:
Golf 7 5 How to hold/fix/bond/weld/glue the Park Assist side sensors brackets FOREVER! TEST👌
💎Original Video :arrow: :arrow: :arrow: : https://www.youtube.com/embed/h-M5F4vnn ... autoplay=1
FOREVER... :lol:
Golf 7.5 Park Assist Steering Sensors Installation. Front Bumper.
The following video shows how the wiring for Park Aid (8K) is factory installed in the front bumper, in which you can see the marks to install the two side sensors for Park Assist Steering (12K) and the tabs that will hold the new wiring.
💎Original Video :arrow: :arrow: :arrow: : https://www.youtube.com/embed/fhCTNqOEL ... autoplay=1
Watch the video from my previous post to see how I installed the brackets.👌
The exterior appearance of the two sensors and brackets is excellent, but I reserve it for my final results. :)
Golf 7.5 How to install windshield washer jets with heater elements.
💎Original Video :arrow: :arrow: :arrow: : https://www.youtube.com/embed/3rN6vL8oP ... autoplay=1
Info :arrow: viewtopic.php?p=572370#p572370
Coroplast tape.
(BSD)
If you didn't know, you'd say it's from factory
👍Yeah, even I myself am impressed ... 😍
It is not about showing off the work done, it is that the result is simply excellent.
The original VW cutting tool is the key... it's not easy to get, at least for me it wasn't, and at first I thought it was outrageously expensive.
But you know, the results tell when something is expensive or cheap.
The original VW cutting tool for the front sensors I installed on the 6R is quite a bit cheaper, ...the results were also excellent.
ciclo wrote: Tue Sep 22, 2020 11:04 am 👍Yeah, even I myself am impressed ... 😍
The OEM VW cutting tool for normal sensors is only about 25 euros, I have one myself and it had already earned itself back.
I recommend it to everyone that wants to install PDC sensors, it will save you a lot of paint chips.
I can only imagine installing PLA sensors, never did it, but I have no doubt I'd buy the OEM tool too.
Golf 7.5 Park Assist Steering Sensors Installation. Rear Bumper.
The following video shows how the wiring for Park Aid (8K) is factory installed in the rear bumper, in which you can see the marks to install the two side sensors for Park Assist Steering (12K) and the way the wiring is fixed.
💎Original Video :arrow: :arrow: :arrow: : https://www.youtube.com/embed/QPb41Lf-S ... autoplay=1
Watch this video :arrow: https://www.youtube.com/watch?v=h-M5F4vnnq0 to see how I installed the brackets.
The images of the final results once the rear bumper is installed, which will be the same results as for the front bumper. :)
Locked
