Page 127 of 333
Posted: Sun Jan 24, 2016 1:04 pm
by CNK
iichel wrote:funny how the guy has a very large dutch accent as well as calling a 5-speed manual a 6-speed manual LOL
Hahah, maybe R is the sixth gear :) :lol:
Posted: Sun Jan 24, 2016 1:18 pm
by iichel
yes, because it's a polo Reverse-line
Posted: Sun Jan 24, 2016 1:36 pm
by ciclo
CNK wrote: I am also plans to install ambient lights in footwells, but I want to do it like in the Passat CC (two color: white & red) :wink:
It is already solved the enigma of buttons. The number 2 (if possible :twisted:) only, and if not installed the ACC.
NÂș2---5G0959442Q
For ambient light (red):
A relay:
1 signal from T73b/7 BCM
2 Ground
3 Input +30
5 Output to ambient lights.
White, the connections are the same like in the dome lights. :wink:
Posted: Sun Jan 24, 2016 1:49 pm
by iichel
what about 6C0959442C?
PR codes for flat bottom steering wheel + cruise control 8T2
Posted: Sun Jan 24, 2016 2:39 pm
by CNK
ciclo wrote:
CNK wrote:White, the connections are the same like in the dome lights. :wink:
I meant footwell lights like this:
(Skoda)
They are factory-installed in the Passat CC :P
open doors:
closed doors and lights on:
These are photos from the Golf 5 ;)
Posted: Sun Jan 24, 2016 6:12 pm
by ciclo
CNK wrote: I meant footwell lights like this:
https://www.youtube.com/watch?v=ekZ62slNltA
Exactly.
Posted: Sun Jan 24, 2016 6:18 pm
by ciclo
iichel wrote:what about 6C0959442C?
They seem to be the same buttons. (sports steering wheel) ... I have not had time to verify.
My ref number is also to DSG.
Posted: Sun Jan 24, 2016 6:20 pm
by ciclo
iichel wrote:Image
Posted: Sun Jan 24, 2016 6:21 pm
by CNK
ciclo wrote:Exactly.
I've heard that red light can be connected to the gray cable from cigarette lighter socket :)
Posted: Sun Jan 24, 2016 6:28 pm
by ciclo
In such case you will have the ambient lights lighted whenever you start the car, day and night, bad business. You need 58 signal, not +15 signal.
Posted: Sun Jan 24, 2016 6:42 pm
by CNK
ciclo wrote:In such case you will have the ambient lights lighted whenever you start the car, day and night, bad business. You need 58 signal, not +15 signal.
Hmm .. Backlight lighter lit only when lights are turn on :)
In Golf 5 it is grey-blue cable so I think in Polo it is similar.. :?:
Posted: Sun Jan 24, 2016 6:47 pm
by ciclo
You're right, but that signal is 58d,... and not is the same as 58.
Posted: Sun Jan 24, 2016 6:51 pm
by CNK
ciclo wrote:You're right, but that signal is 58d,... and not is the same as 58.
Could you tell me what is difference? :oops:
Posted: Sun Jan 24, 2016 6:57 pm
by ciclo
For example:
58d ... interior lights through dimmer.
58 ... license plate light, you need this signal to activate the relay.
Posted: Sun Jan 24, 2016 7:07 pm
by CNK
But when I connect it to lighter (grey-blue), I will be could change light through dimmer :)
I've seen that in other cars and it works well :D
