CNK wrote:But when I connect it to lighter (grey-blue), I will be could change light through dimmer :)
I've seen that in other cars and it works well :D
Yeah, but I can not write here that's right and then someone burns his car because he installed 50,000,000 watts in ambient lights bulbs.
CNK
Drives: 6R
Post by CNK »
It only few LEDs, dont worry about that ;)
I will show you my led modules when I create my topic :D
ciclo wrote:
iichel wrote:what about 6C0959442C?
PR codes for flat bottom steering wheel + cruise control 8T2
They seem to be the same buttons. (sports steering wheel) ... I have not had time to verify.
My ref number is also to DSG.
5G0959442Q and 6C0959442C, after verification of PR codes, I am not able to see the difference between the two. (Top sports, bla, bla, bla...)
However if your sports steering wheel comes from Golf choose buttons from the Golf, and 6C buttons if they are for Polo 6C sw. :mrgreen:
Yes, the only concern I have is the button lighting, red or white
Exactly.Image
Idea for a new mod:
The Audi A1 has an emergency pull for the fuel filler flap, if the locking motor fails. The do quite a lot on the Polo 6R in cold weather.
So I guess you are safe. But just as a suggestion. I think I already told you before, but I'm not sure. And of course for the others:
Take out the lock mechanism of the fuel filler flap. To do this, there is 1 screw to be removed and the connector is below right tail light.
The cord of audi A1 will fit on the rubber 'switch' .
It needs some love with a stanley knife on the plastic, but it will fit. The preparation is there for Polo 6R.
The cord you can not buy individually. The part of the entire audi lock is 8V0862153A
master991
Drives: polo
Post by master991 »
Hello iichel
You are also registered at the polo6rfreunde forum. Use the forum search (notentriegelung is the search key word) and you get the answer how it works.
I did this mod more than a year ago.
Cheer's
edit here is the link http://www.polo6rfreunde.de/index.php/T ... post286822
you can buy the plastic wire only --> 8V0 862 165 A
Very interesting, thanks for the information.
iichel, now I'm doing a information guide for some mates because no one did it. :mrgreen:
Creative part:
All info soon...
That's not something of a mod that's already done, right? I don't recognize it really. :p
gpeixoto109
Drives: 2013 Polo 6R 1.2TDI
Post by gpeixoto109 »
Wiring for all lights controlled by BCM iichel :D
Ah right, I already thought something like that with the red wire, maybe to loop the high beam relay. :mrgreen: Good job guys
gpeixoto109
iichel wrote:Ah right, I already thought something like that with the red wire, maybe to loop the high beam relay. :mrgreen: Good job guys
Exactly! It is for that. :)
Some time ago many People have asked me to do a guide on how to install the automatic lights "OEM" on Polo 6R without factory xenon and non Bluemotion in easy way.
Polo 6R. Automatic lights OEM with halogen headlights, non BlueMotion.
From now, in all Polo 6R model (Europe) can be installed automatic lights OEM " in an easier way ".
As this guide is set for Original Equipment (BCM) it is a breakthrough to facilitate the installation of original xenon headlights. In this case additional modifications in original wiring are required.
gpeixoto109
ciclo wrote:Some time ago many People have asked me to do a guide on how to install the automatic lights "OEM" on Polo 6R without factory xenon and non Bluemotion in easy way.
Excelent work Ciclo! :mrgreen:
gpeixoto109 wrote:Excelent work Ciclo! :mrgreen:
:wink:
Good tools to install these wirings (examples):
Mandatory
Laser 3932 Terminal Tool http://www.ebay.co.uk/sch/i.html?_from= ... ol&_sop=15
SN-02C http://www.aliexpress.com/wholesale?cat ... ext=sn-02c
Of course there are better and expensive tools, but these listed above perform their function perfectly.
I will open a new topic in the sales section to sell these wirings, limited quantity and some conditions. Please be patient.
Locked
