Thanks iichel !
ORiOn
- Drives: Polo BlueGT / Audi S5
I know ciclo is a busy person, but i also know that there are a lot of user that visit this post that may know the answer. hehe
Thanks iichel !
Thanks iichel !
@RVC problem: i dont understand. you try to fit coding into module 10 park/steer assist (== PDC) but you don't have PDC?
or you try to fit coding into your RNS?
- Ugabista
- Drives: Vw Polo 6R 1.6TDI 90CV CAYB
Re: RE: Re: ciclo's Polo. R-line 1.2 TSI 90hp 119gr.
I don't have PDC/Sensor Park in my Polo 6R.iichel wrote:@RVC problem: i dont understand. you try to fit coding into module 10 park/steer assist (== PDC) but you don't have PDC?
With RNS315 camera rear view emblem works fine, but i changed for RNS510 and actived camera in module radio (56) but don't work in radio. Camera open when i put gear rear, but don't see image of radio.
masterofpolo
- Drives: 1.2 TSI DSG Lounge
Dear İichel or Ciclo,iichel wrote:the button is part number 6Q0962109B
you need the door sill trim LHD 6R4853371H (left, 5-doors, with alarm PR code 7AS) or 6R3853371A (3-door, I'm not sure it makes a difference for 3 doors?)
connector is 8E0971832
the wiring diagrams, you can find in ESLAWIN
the parts are in ETKA -> http://www.ifiinterface.com --> http://ifinterface.com/prog/car/prog2/inprog.php
can I use this part for installing alarm for my polo 6c ? It seems compatible with iichels comments and expression but I want to ensure about that thank you for your help.
http://tr.aliexpress.com/item/VW-Car-Se ... 261.h1kWBx
no, this part is not for polo 6c (hint: the correct part number is on your own image)
iichel many thanks.
Soon I'm with all of you again ... of course. With something new...
(next week)
Update:
viewtopic.php?f=56&t=58703&p=504965#p504965
Second image. It's now perfect for all 6R in order to install BCM Max... and other things.
A guide soon...
(next week)
Update:
A guide soon...
Excellent! thanks for sharing.benji58 wrote:hi ciclociclo wrote: New mod
Changing the upper speed threshold for static cornering light.
VCDS
Address 09 Cent Elect, Adaptation, Channel 32, default 40 km/h.
I set the upper speed threshold at 55 km/h.
Impressive performance along with HBA during the test.
Works like a charm.
Remember they are static cornering lights, not dynamic cornering lights.
good mod ! I tested it works perfectly. since the time I was looking for, thank you !![]()
- Mart!n-GTI-DK
- Drives: '14 Polo BlueGT
Can't wait to see what you have in your goodiebag for us Ciclo.
Your last goody will be most impressive.Mart!n-GTI-DK wrote:Can't wait to see what you have in your goodiebag for us Ciclo.
Would have wished to share the process but it has been impossible ... next week the info. I will try to make a video or something similar...
ORiOn
I have another question... hehe
Will the 5G0941431BE switch work with your automatic lights?
Thank you!
Thank you!
masterofpolo
Dear All,
I want to install another switch to my car. As you know that polo 6c lounge models does not have ESP switch button for the control menu. It can be close via car menu settings but for the easy using and visual improvement, ı want to install it like blue GT's control menu switches. Do you know the correct BCM pin slot and wiring diagram for this button? (Part Number is 927 117) Is it possible to install it? By the way sorry for my bad english,I appriciate for your help icchel and ciclo
[url=http://postimg.org/image/jcl3b7mpv/]
My dear friend ORiOnORiOn wrote:I have another question... hehe
Thank you!
1- Backlighting color is white.
2- Would fit twisted (different angle) in housing Polo 6R.
You can see fleetingly in this video:
3- You should change 10-pin black connector by a 10-pin red connector.
But if these reasons are not enough for you, you buy it.
I know what you're looking for, I will try to find a solution for this.
Hi masterofpolo,masterofpolo wrote:Dear All,
ESP button in Polo 6R communicates directly with the ABS control unit and this in turn to the BCM through CAN lines.
I do not have diagrams Polo 6C, I'm sorry. Maybe iichel can help you with diagrams (BlueGT 6C).
ORiOn
Nah, it's fine! ahahciclo wrote:My dear friend ORiOnORiOn wrote:I have another question... hehe
Thank you!, there are three reasons why you should not buy 5G0941431BE lights switch.
But if these reasons are not enough for you, you buy it....
Thank you!!
Waiting a connector
