Page 14 of 30
Re: Upgrading my Polo 6R bifuel
Posted: Mon Aug 26, 2019 12:08 pm
by iichel
Most of my interior LEDs are from AliExpress. The quality is acceptable, they usually last a few months to half a year. So far I haven't been able to find LEDs that don't "glow" when they should be off. It has to do with some current leakage I think. But it doesn't bother me.
Posted: Mon Aug 26, 2019 7:05 pm
by ciclo
For the interior lights (roof, footwell, etc)
at least one of the LED bulbs must be with what is called 'CAN bus error free' or something like that
, with small resistor or diode, to avoid that glow when they are off.
I already mentioned this perfect 'solution' in my 6R thread a long time ago. It has also been useful for my Golf MK7.5
The 'CAN Bus error free' LED lights are more expensive.
If you buy them on Aliexpress you should know what you are buying, some LED bulbs/lights/lamps in Ali claim to be 'CAN bus error free' but they are not, so currently I can not recommend any of those that are for sale. (read feedbacks in the items sale)
Posted: Tue Aug 27, 2019 10:42 am
by Franciswat
Thanks guys, I'll make some tests and post here the results.
Posted: Tue Aug 27, 2019 10:19 pm
by ciclo
Some examples of
'CANbus error free'.
They are only examples found with google, ... buy LED bulbs according to your requirements,
type-size.
Posted: Thu Aug 29, 2019 12:38 pm
by Franciswat
Thanks ciclo, I will look for this kind of can bus lamps! I'll keep thread updated!
Yesterday I got the PDC 8K unit which replaced my old 4K unit so I could finally test the front PDC but I encurred a problem: often obstacles are showed when there are not!
Here's a video:
https://youtu.be/o3p6xUWndm4
What do you think will cause the problem?
I thought sensors were dirty but I have cleaned them and problem remanins.
All sensors and PDC unit came from aliexpress so I was thinking problem cluld be related with the bad quality of front sensors (anyway rear sensors came from aliexpress too but they work perfectly).
Posted: Thu Aug 29, 2019 9:18 pm
by ciclo
I think that the Aliexpress PDC units have a new software wirh more functions, check if the words 'ghost detector' is written on the Aliexpress PDC unit.
Now seriously:
According to the video it seems that the problem only happens when the rear sensors are also active.
Check the connections (terminals, wires, connectors) that reach the PDC unit.
https://drive.google.com/drive/folders/ ... sp=sharing
By other side, there is a 6R PDC button that is sold on Aliexpress that is not correct for 6R, maybe this is the problem.
This also happened to another Italian mate, but now I don't remember who.
Posted: Thu Aug 29, 2019 9:56 pm
by ciclo
Now that I check your autoscan, are you sure your PDC unit is fully compatible with PQ25?
Address 10: Park/Steer Assist (J446) Labels: 7E0-919-475.clb
Part No SW: 7E0 919 475 K HW: 56D 919 475
Component: PARKHILFE 8K H02 0106
Revision: -------- Serial number: 20251528901029
Coding: 100001
Shop #: WSC 12345 123 12345
ASAM Dataset: EV_VW75XParaKssis4K 001004
ROD: N/A
VCID: 3A7CE9AABDC4D991E7-806E
No ASAM data for: "EV_VW75XParaKssis4K" (VW25)
Posted: Thu Aug 29, 2019 10:05 pm
by Franciswat
ciclo wrote: Thu Aug 29, 2019 9:18 pm
I didnt think about it
Thank you ciclo, unfortunatelly I noticed front sensors do not work properly even when rear sensors are off (for example sometimes they have so long response time that I hear the beep when I'm nearly to hit the car in the front).
I'll check the connectors and the wirings but I'm pretty sure everything is fine because I checked them several times.
Maybe I can try to disconnect rear sensor connector and see if that affects the front sensors
Anyway I read that a single faulty sensor may make the control unit go crazy so maybe a possible solution could be replace them all..
ciclo wrote: Thu Aug 29, 2019 9:18 pmBy other side, there is a 6R PDC button that is sold on Aliexpress that is not correct for 6R, maybe this is the problem.
Yea I had a talk with that guy sometime ago but I purchased a genuine PDC buttom
Sorry ciclo that autoscan had been made before I changed the PDC unit.
I've not actually a recent autoscan but here are some more details about the unit I received:
https://it.aliexpress.com/item/32977210 ... 4c4dN7u392
Posted: Fri Aug 30, 2019 4:26 pm
by Franciswat
I have finally replaced the faulty alarm horn (
1K0951605C) with a more recent unit (
1K0951605F).
How to remove the alarm horn
viewtopic.php?f=56&t=72126&p=543845#p543845
New autoscan (no more errors)
Friday,30,August,2019,16:56:38:39744
VCDS -- Windows Based VAG/VAS Emulator Running on Windows XP x86
VCDS Version: 17.1.3.0
Data version: 20170203 DS267.2
www.Ross-Tech.com
VIN: WVWZZZ6RZCY540000 License Plate:
Chassis Type: 6R (7E0)
Scan: 01 03 04 08 09 10 15 17 19 25 44 55 56 0B
56-Radio -- Status: OK 0000
Address 01: Engine
Cannot be reached
Address 03: ABS Brakes (J104) Labels: 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 BC HW: 6R0 907 379 AF
Component: ESP8.2i front H05 0002
Revision: --------
Coding: 210224E3217100B5842524E484D700401300
Shop #: WSC 00788 648 00255
VCID: 00085B4297984341E9-8054
Address 08: Auto HVAC (J301) Labels: None
Part No SW: 6R0 820 045 N HW: 6R0 820 045 N
Component: Man AC H02 0202
Revision: 0003SH02
VCID: 397EF6A6B0C2D289EE-806C
Address 09: Cent. Elect. (J519) Labels: 7E0-937-BCM-V1.clb
Part No SW: 7E0 937 090 HW: 7E0 937 090
Revision: B9080001 Serial number: 0771 060161479
Coding: 3CB02BBF08E1240092380E916C6B0DD1DAC0672F608D30D0200000030000
Shop #: WSC 02737 534 00190
VCID: 68D863E29BE89B0141-803C
Subsystem 1 - Part No SW: 6R0 959 801 AB HW: 6R0 959 801 AB Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 008 1611
Serial number: KU0KU004011200011991
Coding: 18BC30
Subsystem 2 - Part No SW: 6R0 959 802 AD HW: 6R0 959 802 AD Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 008 1611
Serial number: KU0KU005011200017885
Coding: 08BC30
Subsystem 3 - Part No: 1K8 951 171 A
Component: DWA-Sensor 00 001 0103
Subsystem 4 - Part No: 1K0 951 605 F
Component: LIN BACKUP HO H01 0008
Subsystem 5 - Part No: 1K8 951 171 A
Subsystem 6 - Part No SW: 1K8 959 442 HW: 1K8 959 442
Component: E221__MFL-DC1 H04 0103
Serial number: 29170002240760027504
Coding: A40000
Subsystem 7 - Part No SW: 6R0 959 811 G HW: 6R0 959 811 G
Component: J388__TSG_HL 008 1611
Serial number: KU0KU010011200012406
Coding: 08BC32
Subsystem 8 - Part No SW: 6R0 959 812 G HW: 6R0 959 812 G
Component: J389__TSG_HR 008 1611
Serial number: KU0KU009011200013136
Coding: 08BC32
Part No SW: 7E0 919 475 L HW: 56D 919 475
Revision: -------- Serial number: 20231629400567
Coding: 108001
ASAM Dataset: EV_VW75XPakrAssis8K 001003
ROD: N/A
VCID: 3B72ECAEB2FEE099FC-806E
No ASAM data for: "EV_VW75XPakrAssis8K" (VW25)
Component: VW10Airbag022 H09 0020
Revision: -------- Serial number: 003GX011W0JJ
Coding: 003232
ASAM Dataset: EV_AirbaV1W0BPAVW250 A01001
ROD: N/A
VCID: 4A9CB96AED24491177-801E
Subsystem 1 - Serial number: 3575HRB4059124B2F99H
Subsystem 2 - Serial number: 3585HRB4061131GQCOUS
Subsystem 3 - Serial number: 3515RRB405P0VC0I5P0W
Subsystem 4 - Serial number: 3525RRB40510VC0IA9B9
No ASAM data for: "EV_AirbaV1W0BPAVW250" (VW25)
Part No SW: 6R0 920 871 A HW: 6R0 920 871 A
Component: KOMBI H03 0505
Coding: 140E01
ASAM Dataset: EV_KombiU_DS_VDD_RM09 A04113
ROD: N/A
VCID: 3460C7929FA02FE13D-8060
No ASAM data for: "EV_KombiU_DS_VDD_RM09" (VW36 *)
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 7E0 909 901 HW: 7E0 937 090
Revision: B9080001
Coding: 002200
Component: IMMO H03 0505
Serial number:
Shop #: WSC 00000 000 00000
VCID: 6ADC19EA8DE4A91157-803E
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11250
Shop #: WSC 00788
VCID: 2F6AC8FEEA860C3940-807A
Address 55: Headlight Range (J431) Labels: 6R0-907-357.clb
Part No SW: 6R0 907 357 HW: 6R0 907 357
Component: LWR-ECU H02 0070
Revision: -------- Serial number: --------------
Coding: 0110000001000000
ASAM Dataset: EV_HealdRegulVWLWRPt 001004
ROD: N/A
VCID: 77FA309ECE5604F9D8-8022
No ASAM data for: "EV_HealdRegulVWLWRPt" (VW25)
Address 56: Radio (J503) Labels: None
Part No SW: 6RD 035 187 B HW: 6RD 035 187 B
Component: Radio 541 5314
Revision: -------- Serial number: VWZZZ4K6200530
Coding: 16000400040005
Shop #: WSC 127395 840 08317
VCID: 46848D5AF13CAD7193-8012
End-------------------------(Elapsed Time: 03:18)--------------------------
Posted: Fri Aug 30, 2019 7:31 pm
by ciclo
Great!
I suppose the best thing would have been to change the alarm horn since the original horn began to fail, however you already have the experience of installing the batteries in this model of alarm horns.
It has been a great idea to install the 'F' model, which is the one that replaces the 'C' model (etka).
There is something in your autoscan that confuses me
HW: 56D 919 475
Coding: 108001
ROD: N/A
Such HW is for other platforms (Passat B7, Golf 6, etc.).
Has it been flashed?
Posted: Fri Aug 30, 2019 8:10 pm
by Franciswat
ciclo wrote: Fri Aug 30, 2019 7:31 pm
Great!
Thanks Fernando, in the end I had to follow your suggestion and replacing the whole unit since replacing the battery did not solve the problem with the old alarm..
I just hope purchasing a more recent replacement decreases the risk to face again the same problem very soon!
Sorry but I don't know If it had been flashed.
Is there any way to know If It had been?
When you talk about flash are you refering to the software?
Posted: Fri Aug 30, 2019 8:25 pm
by ciclo
Well, reading that HW could also be a mistake in your VCDS cable.
With flashing I mean update/modify the original software.
In the image in your previous posts it seems clear that the unit has not been flashed, you will have to investigate the malfunction in the PDC sensors.
Posted: Mon Sep 02, 2019 11:04 pm
by Franciswat
Thanks ciclo, I'll follow your suggestion checking the PDC sensors.
I've also ordered some canbus leds for interiors.. I hope they are good, I will let you know my impression.
Posted: Fri Sep 06, 2019 3:39 pm
by Franciswat
PDC Update
Hi guys, after replacing the brand new sensors purchased on aliexpress with a genuine used set, font PDC works correctly.
Be carefull buying cheap replacement from China! You risk to spend money twice.
Posted: Fri Sep 06, 2019 3:42 pm
by iichel
True advice
