Re: INSTALLING DIRECT TPMS IN POLOGT 6R RHD IND
Posted: Mon Jan 31, 2022 7:14 pm
I guess your really do need a new title for this topic. Any suggestions you like to offer?
Probably the Worlds greatest Polo resource
https://uk-polos.net/
I am planning to post new updates, but the present title I feel is bit misleading now, as Tpms installation is done and dusted.iichel wrote: Mon Jan 31, 2022 7:14 pm I guess your really do need a new title for this topic. Any suggestions you like to offer?![]()
Oops.. I wonder I overlooked it.
Oh dear iichel.. you already changed it
Friday,28,January,2022,23:11:59:09269
VCDS Version: 21.9.0.2 (x64) HEX-V2 CB: 0.4555.4
Data version: 20210903 DS330.0
www.Ross-Tech.com
VIN: MEXL15606GT048293 License Plate:
Chassis Type: 60-VW25 (7E0)
Scan: 01 02 03 04 08 09 10 15 17 19 25 37 3C 44 55 5F 65 77
VIN: MEXL15606GT048293 Mileage: 95220km-59166miles
Address 01: Engine (J623-CBZB) Labels:. 03F-906-070-CBZ.clb
Part No SW: 03F 906 070 KC HW: 03F 907 309 AJ
Component: SIMOS10.22AH10 6270
Revision: --H10--- Serial number: 00000000000000 CVN: 461B84FC
Coding: 00250056232400080000
Shop #: WSC 53863 002 104857
ASAM Dataset: EV_ECM12TFS02103F906070KC 004006
ROD: EV_ECM12TFS021_VW25.rod
VCID: 6D84C0CEAD13BD337C7-8038
VINID: 755A1C0451801979001080890C0D0C61A9
Readiness: 0110 0101
Part No SW: 0AM 300 065 N HW: 0AM 927 769 D
Component: GSG DSG AG7 431 6502
Revision: 00043014 Serial number: CU501508317273
Coding: 0000020
Shop #: WSC 01260 002 1048576
VCID: 3A2E3B92A05DDA8BA95-806E
Part No SW: 6R0 907 379 BN HW: 6R0 907 379 AS
Component: ESP9.0i front H03 0001
Serial number: --------------
Coding: 62DD2463422703C8461624724254C0800908
Shop #: WSC 29230 002 1048576
VCID: 0B40AE56B3C71303C23-805E
Serial number: 07022013470235
Coding: 01
Shop #: WSC 00000 000 00000
ROD: EV_LWSKLOVW25X.rod
VCID: 7EA6F782F07536ABD5D-802A
Part No SW: 6R0 907 044 Q HW: 6R0 907 044 Q
Component: Climatronic H12 0615
Revision: V0000000
VCID: 41DC4C7EC18B8953E8F-8014
Part No SW: 7E0 937 090 D HW: 7E0 937 090 D
Component: BCM PQ25 Max4 H82 0762
Revision: B9082001 Serial number: 8601 222180475
Coding: 3AB02FF808A10400013806D17CCB9ED0F2C0670F604D30C1200400030000
Shop #: WSC 00046 123 12345
VCID: 2C020DCA5609743B2B9-8078
Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 130114 05 54 0403
Coding: 0408AD
Subsystem 2 - Part No SW: 6R0 959 802 BH HW: 6R0 959 802 BH Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 003 8612
Serial number: KU0KU015041441050460
Coding: 1400B3
Subsystem 3 - Part No SW: 6R0 959 801 BC HW: 6R0 959 801 BC Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 003 8612
Serial number: KU0KU014041441047765
Coding: 0400B3
Subsystem 4 - Part No SW: 5TA 959 442 HW: 5TA 959 442
Component: E221__MFL-TAT H04 0019
Serial number: 2731410180700922AG1B
Coding: 270000
Subsystem 5 - Part No SW: 6R0 959 811 L HW: 6R0 959 811 L
Component: ------------- 006 5550
Serial number: 13102580150623202239
Coding: 020000
Subsystem 6 - Part No SW: 6R0 959 812 L HW: 6R0 959 812 L
Serial number: 13202581150812164218
Coding: 020000
Address 10: Park/Steer Assist (J446) Labels:| 5Q0-919-294.clb
Part No SW: 1K8 919 472 C HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0480
Revision: -------- Serial number: 39331616005272
Coding: 0001151011
Shop #: WSC 12345 123 12345
ASAM Dataset: EV_EPHVA18VW364GP00 001007
ROD: EV_EPHVA18VW364GP00_VW32.rod
VCID: 372822A69FCFC7E356B-8062
1 Fault Found:
12718592 - Databus
U1121 00 [009] - Missing Message
[SteuergerΓ€t fΓΌr LenksΓ€ulenelektronik-J527/BCM - mZAS_1 - kein Signal/keine Kommunikation]
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 202
Mileage: 95220 km
Date: 2022.01.28
Time: 23:09:33
Part No SW: 6R0 959 655 J HW: 6R0 959 655 J
Revision: -------- Serial number: 003GW0118WCJ
Coding: 003036
Shop #: WSC 01234 785 00200
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 49CC545EF93B411330F-801C
Part No SW: 6RD 920 870 A HW: 6RD 920 870 A
Component: KOMBI H05 0805
Coding: 141C01
VCID: 47C85266EF2FB76326B-8012
Part No SW: 7E0 909 901 HW: 7E0 937 090 D
Component: GW-K-CAN TP20 H82 0762
Revision: B9082001
Coding: 002304
VCID: 688AB1DA8271981B0F1-803C
Component: IMMO H05 0805
VCID: 6A8ECBD29CFDAA0B195-803E
Address 37: Navigation
Cannot be reached
Address 3C: Lane Change (J1086) Labels:. 5Q0-907-686.clb
Part No SW: 5Q0 907 686 C HW: 5Q0 907 686 C
Component: HRE_Master H12 0081
Serial number: 0529820662
Coding: 03031202
ROD: N/A
VCID: 3D24308EBDF3EDB38C7-8068
No ASAM data for: "EV_HREntryHella" (VW25)
Address 44: Steering Assist (J500) Labels:| 1Sx-909-144-44.clb
Part No SW: 1S2 909 144 P HW: 1S2 909 144 P
Component: EPS_ECU H61 1702
Coding: 0001000000000000
ROD: EV_SteerAssisNSK_014_VW12.rod
VCID: 41DC4C7EC10B8953E8F-8014
Address 55: Headlight Range (J431) Labels:. 6R0-907-357.clb
Part No SW: 6R0 907 357 HW: 6R0 907 357
Component: LWR-ECU H02 0070
Revision: -------- Serial number: --------------
Coding: 0116000001000000
VCID: 77A8E2A6DF4F07E396B-8022
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD2.clb
Part No SW: 5C0 035 680 F HW: 5C0 035 680 F
Component: MU-S-N-ER H41 0478
Serial number: VWZAZ2U0986183
Coding: 02620001FF00000011110001010808001F0100D6002001004E
ROD: EV_MUStd4CTSAT_VW26.rod
VCID: 2412E5EA3E59BC7BE39-8070
Data carrier:
1 Fault Found:
U1101 00 [009] - Active
[Anti-theft protection - component protection active (0xEA6300)]
Fault Priority: 4
Fault Frequency: 1
Reset counter: 202
Mileage: 95220 km
Date: 2022.01.28
Time: 23:09:32
Voltage terminal 30: 11.8 V
Address 65: Tire Pressure (J502) Labels: 3AA-907-273.clb
Part No SW: 3AA 907 273 F HW: 5Q0 907 273
Component: RDKBERU30 H04 0011
Serial number: 40000000058983
ROD: EV_RDKBERU30_005.rod
Address 77: Telephone
Cannot be reached
End----(Elapsed Time: 01:30, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
Please correct me -- you could router the fuse wire from back of fuse box?Fusebox: ( small fuses slots are already full)
Were they just plug and play? or you had to change guide profile 6RG807393B&C, 6RG807863A for rear and also for front <could not find part number>?Front and Rear bumper
I am speechless, a magnificent POST, and an excellent job.
Thank you for your kind words dear Master.
iichel thank you.iichel wrote: Tue Feb 01, 2022 7:50 am Patil, I'm highly impressed. Excellent job and congratulations on a great upgrade.
Thank you ag for your appreciation.ag69 wrote: Tue Feb 01, 2022 4:56 amPlease correct me -- you could router the fuse wire from back of fuse box?Fusebox: ( small fuses slots are already full)
I tried that but ended up with fuse tap option.
So unlike your neat and clean, I have not sort of "altered" car look![]()
-- No wonder you were not active on forum.
Quite a lot of work.
But fantastic. Car looks like it has taken a new birth with new bumper and color!!!!
Happy more miling![]()
