Now we need to find the right combination to dim the DRL (if indicator on) without lighted tail lights for driving legally in all other countries (oh yeah...in Europe
Excellent iichel
, this is fine for the Scandinavian countries (not all of them, Peter
peter_dk25
- Drives: Blue GT
ciclo wrote:Excellent iichel, this is fine for the Scandinavian countries (not all of them, Peter
Now we need to find the right combination to dim the DRL (if indicator on) without lighted tail lights for driving legally in all other countries (oh yeah...in Europe).
DRL dim on Polo 6R
enabled: byte 12 bit 0
enabled: byte 23 bit 5
enabled: byte 23 bit 7
this is with light switch in setting '0'
- Mart!n-GTI-DK
- Drives: '14 Polo BlueGT
Looks sweet.
Just got around to testfitting the LED indicator bulbs I bought waaaaaaaaay back... Heres is to compare to the stock bulb. Looks awesome but needs a resistor too.
The arrow in the speedo is flashing waaay to fast.
Yes I also had to use resistances. Sucks but maybe I'll find good LED indicators
ORiOn
- Drives: Polo BlueGT / Audi S5
If any of you find good leds for the indicator, i'm more then thankful!
Hi guys! I am driving a Polo 6C 1.2 TSI BM DSG and recently bought the new LED headlights and have them installed in my car but do not work properly. My current BCM is 6C0937089A. Shall I have to change the bcm with a newer version (B or C ending) or i can solve the issue with a proper coding?
How exactly did you install them? Wiring diagram? New topic?
I installed them phisically, without any wiring connections
There is one wire 12v that should be connected to the BCM. I did a scan with vcds and there is no choice of LED headlights...just halogen or bixenon. Ibwas told that i may have to change the bcm...is there anyone that did this swap?
gpeixoto109
- Drives: 2013 Polo 6R 1.2TDI
Beautiful!
hello ciclo
I need help, I install an soundsystem, I need to power the amplifier to the battery. Do you know how can I get the power cable, from the inside towards the engine compartment
(Other than the right side hole at bonnet)
thank you
thank you
- Mart!n-GTI-DK
You need to give me a list of parts, partnumbers, prices and where to buy to get that Ciclo.
firegrafik
- Drives: 6R 1,6MPI(CFNA) sedan
Awesome. One step closer!
I wonder if the kombi cluster's display could show the CCS activity like on this instruction. If so I am afraid it could be deactivated and it will need to edit EEPROM. Then the main question will be to find out the right bit address to be edited for this.
Maybe for HBA indicating activation there has the same solution.
did you make it work, ciclo?
