Mart!n-GTI-DK
Drives: '14 Polo BlueGT
Post by Mart!n-GTI-DK »
gti16 wrote:Hello
Anyone know if the radio 3Q0 035 874 Polo 6C is compatible with Polo 6r?
Thank you
It doesn't even fit in the car... So does it matter?
But to answer your question. No it is not compatible either.
alexanderth
Drives: VW Polo 1.6 TDI 160HP
Post by alexanderth »
Fernando, do you think you would be able to help me out regarding xenon headlights on a 6R 1.6TDI '10?
Peter from DK, told me that you might knew something usefull.
If you have a mail, we could discuss in private? It's regarding flickering on Dectane Dayline xenon headlight, and mounted xenon relay harness.
/A
gti16
Drives: VW Polo 6r 1.6 TDI
Post by gti16 »
Mart!n-GTI-DK wrote:
gti16 wrote:Hello
Thank you
Can you be more specific? Why is not compatible?
I know that the assembly is different, I know very well these radios just do not know if the car will recognize the radio to make use of its features. For example: The Can bus is compatible with Polo 6R?
alexanderth wrote:Fernando, do you think you would be able to help me out regarding xenon headlights on a 6R 1.6TDI '10?
/A
viewtopic.php?f=56&t=68042#p508122
skoukiadakis
Drives: Polo Gti 6R
Post by skoukiadakis »
Hi!
Please contact me via pm!
I would like to buy some products from you for my Polo Gti 6R!
gti16 wrote:Hello
Thank you
It utilizes a different canbus protocol so it is not able to communicate with the rest of the Radio. It's like someone who only talks chinsese tries to talk to someone who only speaks english.
The Radio will operate like it is on a battery power only and not integrated.
Problems you'll face:
You cannot remove component protection
Radio will not Switch on or off automatically
PDC will not work
The Radio will not know the car is in reverse, i.e. for the reverse camera
Steering wheel controls will not work
Visualisation in your Instrument Cluster of Radio Station etc will not work
You will not be able to Diagnose Errors though VCDS
etc etc
skoukiadakis wrote:Hi!
Please first tell me you would like to do in your GTI.
current BCM, current headlights? Thanks.
skoukiadakis
Drives: Polo Gti 6R
Guess that I have to make a vcds full scan to see the BCM!
As for the headlights I have factory fitted xenon!
I want to install rain sensor,autodimming mirror and perhaps auto lights if possible!
Yes, you first need to install the light sensor along with auto dimming mirror.
This may help: https://drive.google.com/file/d/0B2nv91 ... sp=sharing
Once installed, automatic lights are possible in your GTI.
Look at your inbox. :wink:
gti16
Post by gti16 »
iichel wrote:
gti16 wrote:
Mart!n-GTI-DK wrote: It doesn't even fit in the car... So does it matter?
PDC will not work
etc etc
thanks iichel
CNK
Drives: 6R
Post by CNK »
firegrafik wrote:
federicodrdpro wrote:......
Before I decide to buy a 7E0 version of BCM :twisted:, I would know the wirings changes and which are the possible retrofit with 7E0 version of BCM in a VW Polo.
There is report concerning 7E0937090 BCM intergration on Polo from Russian Polo owner
https://www.drive.net/l/9344124/
You could also read mine reports
https://www.drive.net/l/7318540/
https://www.drive.net/l/8632361/
https://www.drive.net/l/9309752/
What happened with the drive.net website? New site, and links aren't work.. :(
firegrafik
Drives: 6R 1,6MPI(CFNA) sedan
Post by firegrafik »
CNK wrote: ......
I don't know what happens with the site's international version. Works only russian. So those links are:
https://www.drive2.ru/l/9344124/
https://www.drive2.ru/l/7318540/
https://www.drive2.ru/l/8632361/
https://www.drive2.ru/l/9309752/
Great video, thanks! 8)
Some Updates, maybe they help to someone:☼ All Polo 6R (EU). WIRINGS. BCM Max. Automatic lights. Light Assist. ☼
firegrafik
ciclo wrote: Great video, thanks! 8)
Thanks, Fernando. I appreciate your assessment.
CNK wrote: ....
I've found out, that http://www.drive.net moved to http://www.drive2.com.
New links are:
https://www.drive2.com/l/9344124/
https://www.drive2.com/l/7318540/
https://www.drive2.com/l/8632361/
https://www.drive2.com/l/9309752/
shpunt
Drives: Polo 6R
Post by shpunt »
hello.
any1 give me pls electro wire diagramm for driver and passenger connector J386 and J387.
a connector is responsible for what.
Locked
