Page 145 of 333
Posted: Sat Apr 30, 2016 5:45 pm
by RekinPoznan
Hello
New here... great mods very impressiv
I installed today, xenon headlights am looking for the best way to keep the wiring harness to the controller range Xenon can someone something to help.
The second issue is very short wires from the connectors t73a and t73b very hard to get to the cable beam.
Best Regards Chriss
Posted: Sat Apr 30, 2016 6:49 pm
by ciclo
Hello, thanks for your comments.
Where have you purchased the wiring? links, images, etc... more info means more and better help. :wink:
Posted: Sat Apr 30, 2016 10:31 pm
by Mart!n-GTI-DK
Bachecco wrote:Hi ciclo, you can take a photo of the skirt's adaptator. Number 12 in the picture.
Because I'm trying to figure out how to install side skirts. ThanksImage
This picture is of a Mk5 Golf GTI. And those (number 12) is not used on a Polo.
Posted: Sun May 01, 2016 2:44 pm
by RekinPoznan
ciclo wrote:Hello, thanks for your comments.
Thank you for your answer, the beam did the same on the basis of ELSA,with auto leveling system, found on earlier modifications of your cable gland for the coolant reservoir unless that road is good.
Posted: Mon May 02, 2016 4:09 am
by ciclo
I wish I could help you better, but I do not understand what you want (your English is very difficult for me, please write what you want in Polish).
However, read the next links, perhaps help you.
viewtopic.php?f=56&t=68178#p509214
https://drive.google.com/folderview?id= ... =drive_web
viewtopic.php?f=62&t=67799#p505742
viewtopic.php?f=56&t=68034&hilit=washer+system
viewtopic.php?f=56&t=67705
Posted: Mon May 02, 2016 5:49 pm
by ciclo
Monday,02,May,2016,12:00:36:06516
VCDS Version: 15.7.4.1
Data version: 20160216
www.Ross-Tech.com
VIN: WVWZZZ6RZDY0CICLO   License Plate:
Mileage:    Repair Order:
Chassis Type: 6R (7E0)
Scan: 01 03 08 09 10 15 17 19 20 25 2E 37 44 55 56 77 0B
VIN: WVWZZZ6RZDY0CICLO   Mileage:
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CBZC)       Labels: 03F-906-070-CBZ.clb
   Part No SW: 03F 906 070 GD    HW: 03F 907 309 AJ
   Component: SIMOS10.22AH10 2686
   Revision: --H10---    Serial number: 00000000000000
   Coding: 001100D6202400080000
   Shop #: WSC 00788 648 00255
   ASAM Dataset: EV_ECM12TFS02103F906070GD 004004
   ROD: EV_ECM12TFS02103F906070FJ.rod
   VCID: 6AD7C2AC97609770CA-803E
Readiness: 0110 0101
Address 03: ABS Brakes (J104)       Labels: 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 BE    HW: 6R0 907 379 AF
   Revision: --------
   Coding: 210228E3216D00B5842814EA84D300401700
   Shop #: WSC 40308 002 104857
   VCID: 026F9264FB6807480A-8056
   Part No SW: 6R0 907 044 H    HW: 6R0 907 044 H
   Component: Climatronic   H11 0711
   Revision: V0000000
   VCID: 38992E06D766C3D25A-806C
Address 09: Cent. Elect. (J519)       Labels: 7E0-937-BCM-V1.clb
   Component: BCM PQ25 Max4 H80 0733
   Revision: B9080001    Serial number: 0771 100150209
   Coding: 3CB02FBF48E1240093380E916CEB97D0DAC0672F600D30D0200000030800
   Shop #: WSC 03607 002 104857
   VCID: 68C9CE969776A302DA-803C
   Subsystem 1 - Part No: 5K7 955 559 B
   Component: RLS 110215 03  37  0059
   Coding: 0714DD
   Subsystem 2 - Part No SW: 6R0 959 801 BD    HW: 6R0 959 801 BD  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  003 8612
   Coding: 0200A3
   Subsystem 3 - Part No SW: 6R0 959 802 BF    HW: 6R0 959 802 BF  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  003 8612
   Coding: 1000AB
   Subsystem 5 - Part No: 1K8 951 605 B
   Component: LIN BACKUP HO  H11 9005
   Subsystem 7 - Part No SW: 1K8 959 442     HW: 1K8 959 442
   Component: E221__MFL-DC1  H03 0103
   Coding: A4FFFF
   Subsystem 8 - Part No SW: 6R0 959 811 G    HW: 6R0 959 811 G
   Component: J388__TSG_HL  008 1611
   Coding: 18BC32
   Subsystem 9 - Part No SW: 6R0 959 812 G    HW: 6R0 959 812 G
   Component: J389__TSG_HR  008 1611
   Coding: 18BC32
Address 10: Park/Steer Assist (J446)       Labels: 6R0-919-475.clb
   Part No SW: 6R0 919 475 C    HW: 7E0 919 475
   Component: PARKHILFE 4K  H11 0013
   Revision: --------    Serial number: 47361212601014
   Coding: 308001
   ROD: EV_VW250ParkiAssis2.rod
   VCID: 3EA31A28C784AF242A-806A
   Component: VW10Airbag01M H10 0020
   Revision: --------    Serial number: 003GX01JKVVP
   Coding: 00314D
   Shop #: WSC 01383 785 00200
   ROD: EV_AirbaVW10BPAVW250_SE25.rod
   VCID: 4AB7024C17C05750CA-801E
   Crash sensor for side airbag; driver side:
   Serial number: 3575HRB405N1C4LI7929
   Crash sensor for side airbag; front passenger side:
   Serial number: 3585HRB405B1D5MS8GS2
   Crash sensor for side airbag; rear; driver side:
   Serial number: 3515RRB405B17ABS901.
   Crash sensor for side airbag; rear; passenger side:
   Serial number: 3525RRB405B181TUDPKC
   Part No SW: 6R0 920 870 C    HW: 6R0 920 870 C
   Component: KOMBI         H05 0607
   Coding: 140E01
   Shop #: WSC 00233 572 91226
   ROD: EV_Kombi_UDS_VDD_RM09_SK35.rod
   VCID: 359A280FA369D1E772-8060
   Component: GW-K-CAN TP20 H80 0733
   Revision: B9080001
   Coding: 002200
Address 20: High Beam Assist. (J844)       Labels: 8S0-857-511.clb
   Revision: AA001001
   Coding: 0404001C00000000000000
   VCID: 2E933AF887540F94AA-807A
   Component: IMMO          H05 0607
   Shop #: WSC 00000 000 00000
   ROD: EV_Immo_UDS_VDD_RM09_SE25.rod
Address 2E: Media Player 3 (J650)       Labels: 5N0-035-342.lbl
   Part No SW: 5N0 035 342 F    HW: 5N0 035 342 F
   Component: SG EXT.PLAYER H18 0530
   Revision: A1001003    Serial number: 7662584630
   Coding: 010100
   VCID: 2A9742EC9F2017B0CA-807E
Address 37: Navigation (J0506)       Labels: 1T0-035-680.clb
   Part No SW: 1T0 035 680 L    HW: 1T0 035 680 C
   Component: RNS-MID       H06 5218
   Revision: AB001001    Serial number: VWZ6Z7L7654213
   Coding: 04000442040000A10001
   Shop #: WSC 12345 123 12345
   VCID: 37982C05D363C5D562-8062
   Subsystem 1 - Part No: 1T0 919 859 B
   Component: EU West V13  8348
   Part No: 6R0 423 156 B
   Coding: 11250
   Shop #: WSC 00788
   VCID: 2F903CFD274BF58DA2-807A
Address 55: Headlight Range (J431)       Labels: 6R0-907-357.clb
   Revision: --------    Serial number: --------------
   Coding: 0112000001000000
   VCID: 77D8ACC5DBA3459562-8022
Address 56: Radio (J0506)       Labels: 1T0-035-680.clb
Address 77: Telephone (J412)       Labels: 7P6-035-730.clb
   Part No SW: 7P6 035 730 L    HW: 7P6 035 730 L
   Component: TELEFON       H15 3200
   Revision: 1B001001    Serial number: 00007664158506
   Coding: 0501000000010110
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA.rod
   VCID: 3BA42411CB97BD3942-806E
End-------------------------(Elapsed Time: 03:20)--------------------------
Posted: Mon May 02, 2016 7:09 pm
by iichel
ok ok you have the recent VCDS too :p
and you also have this 0B adress at the top of your autoscan
Posted: Mon May 02, 2016 7:50 pm
by ciclo
:wink: yes, just to report to many people that they know I'm doing... about my failures ... :mrgreen:
I return to the previous state with all OK, all works like a charm. Some changes in some units.
Posted: Mon May 02, 2016 8:15 pm
by iichel
sometimes, you must take 2 steps back to go 1 forward. :oops:
Posted: Mon May 02, 2016 9:16 pm
by firegrafik
iichel wrote:ok ok you have the recent VCDS too :p
I have this 0B adress too on my autoscan. It appeared after I had upgraded my VCDS version to the latest version.
Posted: Tue May 03, 2016 5:22 am
by ciclo
BCM PQ25 :?: Question
If you active Byte21 Bit4 the direction indicators work correctly but the warning indicator lights on the instrument cluster flashes quickly, also it is detected a fault in the lights on the instrument cluster by yellow warning light on rpm sphere.
To me it means that there is too much consumption in the direction indicators with standard bulbs.
Does this mean that if LED bulbs are installed on blinkers and you active Byte21 Bit4 everything will work correctly?
Does anyone with LED bulbs for blinkers would do the test? :mrgreen:
Posted: Tue May 03, 2016 8:40 am
by iichel
I did the test, and no good result (front only, rear only, left only, right only or all together)
Posted: Tue May 03, 2016 12:03 pm
by ciclo
Many thanks iichel, you're the best.
Perhaps the Byte21 Bit4 is for VW T5 which they have additional blinkers on the roof, and when it is activated (in 6R) what is really detecting is low power consumption.
And this leads me to have a new idea... :idea:
:lol:
What do you think? ... original parts and perfect coding in case of faults ...
Posted: Tue May 03, 2016 12:23 pm
by iichel
The low consumption I think is correct.
I will try to fix some wiring loom together with some extra power users. Let's see what that byte is doing. :mrgreen:
The extra indicators, I'm not sure about it. It would be quite easy to do, change the fog light units to OEM fog units with DRL.
Then change the P21W for a orange light (maybe a P21W LED with orange color?). But it is very pricy, since new fog lights are around 75 euros per piece.
And I'm not so sure about the looks. I don't super like it, I think. Some French cars already have it, and I'm always looking for the blinker light. All the way down there :shock:
Posted: Tue May 03, 2016 12:40 pm
by ciclo
I guess it would be like this (similar) but without DRL.
I like the idea because the additional blinkers would be more outward and they wouldn't be influenced by illunination of headlights (as in the case of xenon).
Anyway it is just an idea...
