Page 147 of 333
Posted: Tue May 10, 2016 3:10 pm
by federicodrdpro
Thanks iichel for the accurate answer! I think Is convenient install Bixenon Headlights. Headlights with lens is better? If I install Led Headlight, is not necessary install AFS and washer? Polo 6C with Led Headlights have AFS and washer! :roll:
In Bixenon Headlights if you want, you can use the H7 of the static cornering for the double High beam.. :D
Is possible to install Dynamic cornering LED in LED headlight? :shock:
How is correct to spend for the used (but like new) complete Bixenon Headlights version "D"? :?
Posted: Tue May 10, 2016 4:55 pm
by mab6680
ciclo wrote:
mab6680 wrote:
ciclo wrote:Hi mab6680,
I'm sorry not having replied in the other topic. I did not realize. My apologies. :oops:
I send you a PM with my email. You have to send to my email a recent VCDS Autoscan of your 6R. (with last mod, bixenon headlights and BCM)
Please tell me if the DRLs and parking lights in Led module are working correctly, also the static cornering lights within of xenon headlights, and also the fog lamps.
What lamp models for license plate have installed? Original Led tech?
hi i sent you every think to your email
thinks
Thank you.
24 faults in autoscan :shock: , I think is a new world record ... (just a kidding) ... but 24 faults need some time for their solution, I will help you, but you must have patience. Before installing the wiring for automatic lights you/we have to solve all these faults.
I guess Kufatec instructions were not clear to you. :? ... do not worry, I've already lived this story many times.
I think that's record too
I just haven't took time to see what's a problem by using wiki rosstech but it's better to do that together
So when you're ready we began
Posted: Tue May 10, 2016 5:16 pm
by iichel
federicodrdpro wrote:Thanks iichel for the accurate answer! I think Is convenient install Bixenon Headlights. Headlights with lens is better? If I install Led Headlight, is not necessary install AFS and washer? Polo 6C with Led Headlights have AFS and washer! :roll:
I don't know about the rules in Italy. In Switzerland and many European countries, the limit for AFS and washers is 2000 lumens.
The dynamic cornering lights are not available on Polo 6R. At all. Unfortunately.
The price for a set of headlights is very difficult to say. I'd say around 500 euros for a good set, but used.
Posted: Tue May 10, 2016 7:02 pm
by ciclo
mab6680 wrote:So when you're ready we began
Check your email. :wink:
Posted: Tue May 10, 2016 7:36 pm
by ciclo
federicodrdpro wrote: In Bixenon Headlights if you want, you can use the H7 of the static cornering for the double High beam.. :D
Like xenon headlights for VW T5.2 :wink:
I would like this function could be coded in the BCM, something like two static cornering lights ON when High Beam ON.
Anyway I think this is not legal in Europe, I'm not sure because the rules are saying that the static cornering lights can only be turn on at less than 40 Km/h speed when located in the foglights ... then... :?: :)
Posted: Tue May 10, 2016 7:42 pm
by ciclo
Posted: Fri May 13, 2016 3:25 am
by ciclo
Yesterday with strong intermittent rain I had the opportunity to check that ... (blue box)
...being pleasantly surprised at how well it works. :D (Comfort and safety at the same time) wanderlust
Another good reason to make electrical installations (wirings) with original equipment in the right way. (BCM Max :wink: )
There are countless other reasons ...
In perfect combination 8) with ...
...this way the wiper speed depends on the amount of rain on rain sensor. Works continually but varying the wiper speed automatically and it stops when its function is not required.
If you do not have rain sensor (or you have rain sensor but not have Byte14 Bit7 marked) the switch function (A) is not automatic, its function is to modify
the delay between intervals of sweep wiper manually.
Posted: Fri May 13, 2016 5:18 pm
by Mart!n-GTI-DK
Sounds like how mine works stock... :)
Posted: Fri May 13, 2016 8:14 pm
by ciclo
:lol: ... I'll have to recheck again, or maybe it's that I explain evil (most surely).
My Polo 9N3 don't has rain sensor and works just like if I had disabled the Bit7 in my 6R,... Image or maybe I'm wrong (most surely) and it's like you say (most surely).
Posted: Fri May 13, 2016 10:13 pm
by federicodrdpro
A question about Bixenon headlights. I have foud Bixenon Headlights, but It have a circular halo in the lens. The light is proietted into the trasparent plastic of the headlights.
Here the video: https://youtu.be/ttvLcuVZOKc
Is it normal? :roll:
There are two thread about this:
- http://www.polovw.it/foro/viewtopic.php?f=49&t=27952
- http://www.vwgolfcommunity.com/vbulleti ... eno-sporca
Help me
Posted: Sat May 14, 2016 5:40 am
by ciclo
Mart!n-GTI-DK wrote:Sounds like how mine works stock... :)
Therefore, your wipers do the following without marking Byte14 Bit7. :?:
Have you checked?
Remember that you can not check with the vehicle stationary like this one ... It must be checked with the vehicle in motion.
federicodrdpro wrote: Is it normal? :roll:
I do not know, I'll have to check my headlights.
Posted: Sat May 14, 2016 8:25 am
by Mart!n-GTI-DK
Have you checked?
The way I read your post is that when the wiper stalk is at possition 1 the wiper is off until rain hits the sensor. And that is how mine works from the factory.
Posted: Sat May 14, 2016 9:50 am
by ciclo
Mart!n-GTI-DK wrote: The way I read your post is that when the wiper stalk is at possition 1 the wiper is off until rain hits the sensor. And that is how mine works from the factory.
Ok.
Anyway it is not so important, there are alternative methods to operate the wipers:
:lol:
Posted: Sat May 14, 2016 2:54 pm
by federicodrdpro
Thanks! In VW Golf MK7 Forum, VW dealers change the Headlights with the trasparent circle on the lens. The trasparent circle on the lens appear because the interior part of the lens becomes dirty.
VW says the trasparent circle on the lens is a problem and it decreases the light. :roll:
VW Golf MK7 headlights are "Valeo" like VW polo 6R headlights.
Here you can see the circle:
Image Image
- The Circle is caused by rubber suction cup when the headlight is in production.
New Polo 6C headlights are "Hella" and don't have the lens, but: :shock:
http://www.polovw.it/foro/viewtopic.php ... f0669e5188
Which Headlights we can install? :lol:
The solutions? :? :arrow:
Posted: Sat May 14, 2016 7:25 pm
by NicoWallmeier
Hi ciclo,
I bought the automatic lights wiring a long time ago - everything still working fine :D Now I want to change my old H4 lights to H7 lights - therefore I need to change the coding of the BCM - recode byte 18 from 61 to 65 (according to the German forum). Do I have to change more / anything else because of the automatic lights wiring?
Thanks!
Nico
