H4 to H7 is just at straight swap of the headlights. No coding required. Plug and play.NicoWallmeier wrote:Hi ciclo,
I bought the automatic lights wiring a long time ago - everything still working fineNow I want to change my old H4 lights to H7 lights - therefore I need to change the coding of the BCM - recode byte 18 from 61 to 65 (according to the German forum). Do I have to change more / anything else because of the automatic lights wiring?
Thanks!
Nico
- Mart!n-GTI-DK
- Drives: '14 Polo BlueGT
Mart!n, it's right, as long as the halogen headlights swap is done on a Polo 6R BlueMotion. Non-bluemotion.Mart!n-GTI-DK wrote:H4 to H7 is just at straight swap of the headlights. No coding required. Plug and play.NicoWallmeier wrote:Hi ciclo,
Thanks!
Nico
Hi Nico, I'm glad to hear that the automatic lights wiring works perfectly, I hope it always remain so.
Do you know the reason to change from 61 to 65 Hex in Byte18? Do you have a link to? It is not necessary in your Bluemotion (nor other change due to automatic lights).
federicodrdpro wrote:
Which Headlights we can install?![]()
The solutions?![]()
Thank you very much for all this info. I have yet to see if my xenon headlights have the halo.
Although I still fear more that a VW dealer have to do some work on my 6R...
... (given that a VW dealer is not the same as VW factory)
firegrafik
- Drives: 6R 1,6MPI(CFNA) sedan
Hello, NicoWallmeier.NicoWallmeier wrote:Hi ciclo,
Thanks!
Nico
65 is value of 18 byte on russian Polo 6R with factory bixenon headlights (BCM 7E0937090). If there are H7 halogen headlight with Auto light and RLS 18 byte is 61.
The main feature of the H4 headlights is in switching off the low beam H4 glower while the high beam is active. This is due to inadmissibility of working both glowers into the one bulb.
So when you retrofit your headlights to H7 you should change coding of the 09 Centr.electric to disable deactivation low beam while working high beam. The 18 byte value could be the same - 61
As I know if the 18 byte is 61 and additionally marked bit 2 byte 22 - the low beam doesn't work while high beam is active.
There are my Polo6R configuration of the 09 CentrElectr below. H7 headlights, Auto lights, RLS
https://www.drive2.ru/l/9309752/
Адрес 09: Блок управления бортовой сети (J519) Label: 7E0-937-BCM-V1.clb
Part No SW: 7E0 937 090 HW: 7E0 937 090
Компонент: BCM PQ25 Max4 H80 0733
Ревизия: B9080001 Серийный номер: 0771 139150190
Кодировка: 22904ABF48E1240093380E00FE8B16F02EC8614F60862055220000000000
Мастерская #: WSC 12345 123 12345
VCID: 68D444B99B5B047D3E-803C
Подсистема 1 - Part No: 5K7 955 559 B Label: 5K7-955-559.CLB
Компонент: RLS 260215 03 37 0059
Кодировка: 0714DD
Подсистема 2 - Part No SW: 6R0 959 801 AG HW: 6R0 959 801 AG Label: 6R0-959-801.CLB
Компонент: ------------- 006 5530
Кодировка: 000000
Подсистема 3 - Part No SW: 6R0 959 802 AM HW: 6R0 959 802 AM Label: 6R0-959-802.CLB
Кодировка: 000000
Подсистема 4 - Part No: 1K8 951 171 A
Компонент: DWA-Sensor 00 001 0103
Кодировка: 000000
Подсистема 5 - Part No: 1K0 951 605 C
Компонент: LIN BACKUP HO H05 1501
Кодировка: 000000
Подсистема 6 - Part No: 1K8 951 171 A
Кодировка: 000000
Подсистема 7 - Part No SW: 6C0 959 442 HW: 6C0 959 442
Компонент: E221__MFL-TAT H04 0019
Кодировка: 240000
Подсистема 8 - Part No SW: 6R0 959 811 L HW: 6R0 959 811 L
Кодировка: 020000
Подсистема 9 - Part No SW: 6R0 959 812 L HW: 6R0 959 812 L
Кодировка: 020000
Неисправности не найдены.-
NicoWallmeier
- Drives: Polo 6R MATCH
Hi ciclo,
My current coding of the BCM is
Have a nice remaining weekend,
Nico
The link is http://www.polo6rfreunde.de/index.php/T ... post189892. And I guess that I have to change something because the low beams are switched off if the high beams are activated. Maybe firegrafik already posted the right solution...ciclo wrote:Hi Nico, I'm glad to hear that the automatic lights wiring works perfectly, I hope it always remain so.
Part No SW: 6R0 937 088 F HW: 6R0 937 088
Component: BCM PQ25 Re4 H50 0353
Revision: BU050001 Serial number: 0456 140120530
Coding: 3CB02BBF08A1000021300FB16EEB0FD05F80612F7E862441200000000000
Nico
You have a polo bluemotion (88F).
Sometimes it is plug and play, sometimes you need to disable byte 22 bit 2
Schönes Wochenend
Schönes Wochenend
Many thanks Nico, firegrafik, iichel, etc...NicoWallmeier wrote: The link is http://www.polo6rfreunde.de/index.php/T ... post189892. And I guess that I have to change something because the low beams are switched off if the high beams are activated. Maybe firegrafik already posted the right solution...
Nico
According to all this great information due to combination of knowledges, tests, etc...:
You must disable Byte22 Bit2.
You must leave Byte18 as it is, 61Hex.
Please confirm the results.
You guys are the best!
NOW, we all know what enables the Byte22 Bit2, and in what cases it should be used (H4 BlueMotion, BCM Max).
BCM PQ25... "The Thing"
NicoWallmeier
Hi ciclo,
Many thanks for the great support ciclo, firegrafik, iichel, etc...!!!
Have a nice remaining weekend!
Nico
I've just disabled Byte 22 Bit 2 and leaveByte 18 as it is -> it's working perfectly nowciclo wrote: You must disable Byte22 Bit2.
Please confirm the results.![]()
Nico
benzinkopf
- Drives: 1.2TSI 105HP DSG7
Hi guys. Ciclo, any luck on ur study how they did the rainclosing in polo?
Btw. My rear bootlid lock mechanism failed the other day.
Have to 3dprint a new worm gear to repair.
- RekinPoznan
- Drives: 6R
Hello Ciclo
Need some help...
I replaced BCM from 6R0937087K to 7H0937089 , factory my polo is with DRL and Static Cornering lights in foglights
I replaced factory headlamps to xenon headlamps with static cornering lights.
Xenon and Cornering light works good , but DRL LED not working , DRL LED is connected to T73B/3 (LEFT LAMP) and T73A/5 (RIGHT LAMP)
Cornering light in headlamp connected to T73B/9 left ,and T73B/10 right.
Dimmer connector T6/3 removed and isolate , new wire T6/3 ---> T73B/1 , 58d alternatiwe marked. (now dimmer regulation of instrument cluster , radio etc... not working)
Coding is now:3CB02BBF08E32400933008D16EAB0ED0FA8067FF60851040200000010000
Many Thanks for any help
Need some help...
vc-10
- Drives: 2019 Seat Ibiza 1.0 TSI Xcellence Lux
benzinkopf wrote:Hi guys. Ciclo, any luck on ur study how they did the rainclosing in polo?
The future is here!
I really want a 3D printer...
Great!NicoWallmeier wrote:Hi ciclo,
Nico
Thanks to you.
I have not been lucky yet. (also lack of time to check with some encodings that gave me firegrafik, to play with binaries)benzinkopf wrote:Hi guys. Ciclo, any luck on ur study how they did the rainclosing in polo?
I will report if I have luck, you can be sure.
Hi, check Byte 23 again.RekinPoznan wrote:Hello Ciclo
Need some help...
3CB02BBF08E32400933008D16EAB0ED05A8067FF60851041200000010000
I also want.vc-10 wrote: The future is here!![]()
Remove-isolate yellow wire (1.0mm) from T17/3.RekinPoznan wrote: Xenon and Cornering light works good , but DRL LED not working , DRL LED is connected to T73B/3 (LEFT LAMP) and T73A/5 (RIGHT LAMP)
New wire (0.5mm) from T17/3 to T73b/29.
- RekinPoznan
- Drives: 6R
ciclo wrote:Remove-isolate yellow wire (1.0mm) from T17/3.RekinPoznan wrote: Xenon and Cornering light works good , but DRL LED not working , DRL LED is connected to T73B/3 (LEFT LAMP) and T73A/5 (RIGHT LAMP)
Hi Thanks for fast replay
Now remowed T17/3 and isolate , aded new wire from T17/3 ---> T73b/29
Still no results , interior light not working
New coding: 3CB02BBF08E32400933008D16EAB0ED0FA8067FF60851041200000010000
Best Regards Chriss
Please post a full Autoscan. (to check with Elsawin the diagrams)
You need to install the Wiring1 and Wiring2 for BCM Max. See and read the entire post and images (BCM Max).
The problem is in how the signal is sent from T17/16 to T73a/45 with your original installation. You need to do this to fix the problem of Switches and Instruments lights and other lights
