Skoda Fabia VRS 2012. Auto lights retrofit OEM
Re: Skoda Fabia VRS 2012. Auto lights retrofit OEM
Easy.
You have to install your old ring with 6Q0953513AN (as indicated by exantas) and test if with the old ring there is communication between the new BCM 7E0 and the J745 unit.
https://www.google.com/search?q=6Q09535 ... 96&bih=657
Remember that the rings have to have the same number of turns for one side as for the other. The connector at the top is the center, the mark of the steering column at the top, and the wheels must be completely straight.
If you do not install it correctly the inner wire of the ring will break and the ring will be unusable.
If you want and before you buy the AN stalks, and as a test, you can install your old ring with your old stalks (factory) to check if there is already communication with the J745 unit.
Logically there will be a fault because the ECU will not find the CC switch (E45). This will be solved when you install the AN stalks or by disabling the CC in the ECU.
VASILEIOS1972
- Drives: Polo 6R 1.2 tsi , Skoda Fabia 5J Vrs 1.4
Tell me Fernando , how will understand that there is communication ?ciclo wrote: Thu Oct 24, 2019 4:22 pm If you want and before you buy the AN stalks, and as a test, you can install your old ring with your old stalks (factory) to check if there is already communication with the J745 unit.
Can i see it from diagnosis when select address 55 and there are no errors?
When will turn the steering wheel and turn the lights ?
When I turn on the flash lights one right and one left ?
Regards
Vasilis
exantas
Lets see what the test will show
@ciclo
I have been looking around in my favorite parts site. There I found the car that has the dynamic turning lights and 5J0907357B.
I then searched for all parts that they have from that car https://www.google.com/search?q=site:bi ... 0&bih=1307
It looks me that the car came with the 6R type of slipring when I see what version of stalks it had.
@ciclo
When you see the unit J745 data at address 55 in the autoscan. Only that.VASILEIOS1972 wrote: Thu Oct 24, 2019 6:44 pmTell me Fernando , how will understand that there is communication ?ciclo wrote: Thu Oct 24, 2019 4:22 pm If you want and before you buy the AN stalks, and as a test, you can install your old ring with your old stalks (factory) to check if there is already communication with the J745 unit.
Regards
Vasilis
It can show faults/errors or not.
Yes, that seems, but keep in mind that the SK Roomster shown is 'E' Model Year (2015).exantas wrote: Thu Oct 24, 2019 8:03 pm Lets see what the test will show
@ciclo
The slip ring (G85) is involved in almost all powertrain units, ABS, IC, BCM/GW, etc... and these units have evolved over time.
Vasilis VRS is a 'C' Model Year with old slip ring from factory for all that units.
I guess we are the first to try to make compatible the parts that Vasilis tries to make work in his VRS.
There is a gigantic lack of info on the net for this retrofitting.
As you say, lets see what the test will show.
VASILEIOS1972
Hello my friends the test became unsuccess auto scan above
Friday,25,October,2019,18:06:42:38567
VCDS Version: 19.6.2.0
Data version: 20190930 DS308.0
www.Ross-Tech.com
Workshop Code: 123 12345 012345
VIN: TMBEP25J2C30XXXXX License Plate:
Mileage: 66720km-41457mi Repair Order: old stalk oem
Chassis Type: 5J-SK25 (7E0)
Scan: 01 02 03 04 08 09 10 15 17 19 25 37 44 55 56
VIN: TMBEP25J2C30XXXXX Mileage: 66720km-41457miles
55-Headlight Range -- Status: Cannot be reached 1100
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CAVE) Labels:. 03C-907-309-V1.clb
Part No SW: 03C 906 027 CE HW: 03C 906 027 CE
Component: 1.4l R4 TSI H15 9971
Revision: L2H15--- Serial number:
Coding: 00250012002400000000
Shop #: WSC 53850 001 1048576
ASAM Dataset: EV_ECM14TSI01103C906027CE 001013
ROD: EV_ECM14TSI01103C906027CE.rod
VCID: 66C3ED1499F16A7F3D-8032
Readiness: 0000 0000
Part No SW: 0AM 300 060 A HW: 0AM 927 769 D
Component: GSG DSG AG7 431 6563
Revision: 00043014 Serial number: TFK01108310139
Coding: 0000020
VCID: 285FA32C9B65BC0FCF-807C
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 AL HW: 6R0 907 379 AF
Revision: --------
Coding: 410148DB437300B3822712E9C2D200411700
Shop #: WSC 13765 790 00049
VCID: 081FC3ACBFA59C0FEF-805C
1 Fault Found:
00778 - Steering Angle Sensor (G85)
005 - No or Incorrect Basic Setting / Adaptation
Fault Status: 01100101
Fault Priority: 0
Fault Frequency: 1
Reset counter: 24
Mileage: 66729 km
Time Indication: 0
Date: 2014.03.17
Time: 18:01:21
Hex Value: 0x0007
Hex Value: 0x0002
Hex Value: 0x3051
Hex Value: 0x1BB1
Hex Value: 0x00FF
Hex Value: 0x7F7F
Hex Value: 0x7F00
Address 08: Auto HVAC (J255) Labels: 6Q0-907-044.lbl
Part No SW: 5J0 907 044 C HW: 5J0 907 044 C
Component: Climatronic H08 0103
Revision: K0000000
VCID: 2A5B592445698E1FD9-807E
Part No SW: 7E0 937 090 C HW: 7E0 937 090 C
Revision: B9082001 Serial number: 4000 122170091
Coding: 7A980B3848010000013806B03EEB9BC052C0621F60002041200400020000
Shop #: WSC 12345 123 12345
VCID: 2B555C204A93971722-807E
Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 230714 05 54 0403
Coding: 0230AD
Subsystem 2 - Part No SW: 6R0 959 801 M HW: 6R0 959 801 M Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 002 3211
Coding: 020000
Subsystem 3 - Part No SW: 6R0 959 802 P HW: 6R0 959 802 P Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 002 3211
Coding: 020000
Subsystem 4 - Part No SW: 3T0 959 537 E HW: 3T0 959 537 E
Component: E221__MFL-URO H07 0012
Serial number: 2164426
Coding: 810000
Subsystem 5 - Part No SW: 6R0 959 811 D HW: 6R0 959 811 D
Component: J388__TSG_HL 002 3211
Coding: 020000
Subsystem 6 - Part No SW: 6R0 959 812 D HW: 6R0 959 812 D
Component: J389__TSG_HR 002 3211
Coding: 020000
Address 10: Park/Steer Assist (J446) Labels:| 7E0-919-475.clb
Part No SW: 7E0 919 475 S HW: 7N0 919 475
Component: PARKHILFE 8K H06 0210
Revision: -------- Serial number: 28261530202208
Coding: 108101
Shop #: WSC 44700 231 72242
ASAM Dataset: EV_VW75XParkAssis8K 001011
VCID: 428B1184D519765FF1-8016
Component: VW10AirbagT20 H09 0020
Revision: -------- Serial number: 003GX00UUUCP
Coding: 003230
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 4A9B39A4ED29AE1F39-801E
Serial number: 3495RRB40590NHDIJH62
Serial number: 3505RRB40590NHDIAOG2
Part No SW: 5J0 920 841 F HW: 5J0 920 841 F
Component: KOMBI H04 0305
Coding: 120C01
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
VCID: 2D5152387C8799273C-8078
1 Fault Found:
13639168 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 24
Mileage: 66729 km
Date: 2019.10.25
Time: 18:02:07
Part No SW: 7E0 909 901 HW: 7E0 937 090 C
Revision: B9082001
Coding: 032204
VCID: 68DFE32C9BE57C0F0F-803C
1 Fault Found:
01771 - Control Module for Headlight Range (J431)
004 - No Signal/Communication
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 24
Mileage: 66729 km
Time Indication: 0
Date: 2014.03.17
Time: 18:02:18
Component: IMMO H04 0305
Shop #: WSC 00000 000 00000
ROD: EV_Immo_UDS_VDD_RM09.rod
VCID: 6ADB99248DE94E1F19-803E
Address 37: Navigation (J794) Labels:| 1K0-035-27x-37.clb
Part No SW: 5JA 035 193 E HW: 5JA 035 193 E
Component: RNS315-EU H85 0501
Serial number: SKZAZ2R0659899
Coding: 040000110400000000000000
ASAM Dataset: EV_RNS315EUV2UDS 001705
ROD: EV_RNS315EUV2UDS.rod
VCID: 3A7B6964BDC93E9FA9-806E
Data medium:
Subsystem 1 - Part No: 3AA 919 866
Component: EUR_W_V11 0073
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11241
Shop #: WSC 13765
VCID: 2F6D4830EA8BEB370E-807A
Address 55: Headlight Range
Cannot be reached
End-------------------------(Elapsed Time: 02:57)--------------------------
Best regards
Vasilis
www.Ross-Tech.com
Coding: 0000020
Revision: --------
1 Fault Found:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 24
Mileage: 66729 km
Time Indication: 0
Date: 2014.03.17
Time: 18:01:21
Hex Value: 0x0007
Hex Value: 0x0002
Hex Value: 0x3051
Hex Value: 0x1BB1
Hex Value: 0x00FF
Hex Value: 0x7F7F
Hex Value: 0x7F00
Revision: K0000000
Coding: 0230AD
Coding: 020000
Coding: 020000
Coding: 810000
Coding: 020000
Coding: 020000
Coding: 108101
Coding: 003230
Coding: 120C01
1 Fault Found:
U1111 00 [009] - -
Fault Priority: 6
Fault Frequency: 1
Reset counter: 24
Mileage: 66729 km
Date: 2019.10.25
Time: 18:02:07
Revision: B9082001
Coding: 032204
1 Fault Found:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 24
Mileage: 66729 km
Time Indication: 0
Date: 2014.03.17
Time: 18:02:18
Data medium:
Coding: 11241
Shop #: WSC 13765
Cannot be reached
Best regards
Vasilis
You have to do the G85 Basic Setting at address 03 ABS brakes, please post a new autoscan again whitout faults at address 03.
Tip: It is enough with delete the last 5 digits of the VIN, the other visible digits will help others to help you.
VASILEIOS1972
Hello Fernando , I tried to make basic settings in g85 , seven times but nothing . In all attempts I used 40168 secret code .ciclo wrote: Fri Oct 25, 2019 5:45 pm You have to do the G85 Basic Setting at address 03 ABS brakes, please post a new autoscan again whitout faults at address 03.
For some reasons ,the old stalk and old g85 denied basic setting and the result was NOT OK .
When Install new stalk everything works fine with no errors , and g85 made basic setting immediately
Thank for the vin
Best regards
Vasilis
G85 Basic setting sometimes has some mysteries that I am not able to understand either.
I have always been successful in this Basic Setting, although I have to confess that sometimes I had to take a short walk with my 6R for a while (also taking the steering wheel to the two ends) in order to finish/do the Basic setting with VCDS.
It should be possible to finish the Basic Setting with your old slip ring (G85).
- The wires for J745 were checked. (Multimeter)
- The BCM/GW was checked. (7H0/7E0)
- The slip ring was checked. (6Q0/6R0)
The only thing that has not been checked is other J745 unit ...
VASILEIOS1972
Good morning my friend Fernando .ciclo wrote: Sat Oct 26, 2019 12:58 am G85 Basic setting sometimes has some mysteries that I am not able to understand either.
Did you noticed something in auto scan ? Address 4 is not displayed ............
I have all ready bought another J745.
The module is his way to Greece.
I will report soon .
One last question, if we ever solve this matter with j745 , can you help me to convert day lights to work like fog lights ?
Is it possible ? I think it is the only way to have cornering lights .
Best regards
Vasilis
exantas
Idea. If the changes that you guys made in the wiring don't make it incompatible, why don't you try to test J745 with the 087 BCM you had in the car before?
The autoscans Valiseios posted had 087. If the new wiring can work with old BCM you could do an extra test to the J745 module.
It won't be a permanent solution since 087 doesn't cover all functions you want,but you have it already in hand anyway.
For example if you have the same abs unit as the autoscans you posted, you copy the codings they have just for testing
Yes, the old slip rings are not shown in the Autoscan, there are no VCDS labels for these rings.VASILEIOS1972 wrote: Sat Oct 26, 2019 7:14 am
Perfect.VASILEIOS1972 wrote: Sat Oct 26, 2019 7:14 am I have all ready bought another J745.
DRLs are mandatory and more important than SCLs. Conversion is possible, but I don't agree with this conversion.VASILEIOS1972 wrote: Sat Oct 26, 2019 7:14 am One last question, if we ever solve this matter with j745 , can you help me to convert day lights to work like fog lights ?
Best regards
Vasilis
Your DRLs are perfect as they are, maybe they are the first SK FII VRS DRLs worldwide managed by the BCM instead of a button.
Let's focus on getting the DCLs.
The modifications in the wiring are perfect for BCM Max, it makes no sense to undo these modifications.exantas wrote: Sat Oct 26, 2019 2:27 pm Idea. If the changes that you guys made in the wiring don't make it incompatible, why don't you try to test J745 with the 087 BCM you had in the car before?
The BCM Max software covers all the possibilities BCM High software, but the BCM High hardware doesn't cover all the possibilities of BCM Max hardware.
It makes no sense to lose all the functions and possibilities offered by a BCM Max.
The test can be performed, the autoscan will throw failures, which is not a problem if all you want to know is if the J745 unit can be recognized, not as a permanent installation.
exantas
OC I don't talk about undoing the wiring. Is more a temp test where you use HW parts and coding that you know that came in that combination from factory.ciclo wrote: Sat Oct 26, 2019 3:57 pm The modifications in the wiring are perfect for BCM Max, it makes no sense to undo these modifications.
This way you test the J745 until the replacement part arrives.
My way of thinking is that if DCL work on a setup as close as possible to factory setup, you have a base line and you know that all parts are working together.
If you get DCL work with the factory coding and the OLD BCM, you can then switch to the Max version BCM and set the coding that you know it works with the old BCM.
If DCL continue to work , you change the bits for the extra functions that you want, where you already know how to code those.
