looks very good firegrafik! do you know if the 6c fog lights fit into the 6r bumper? looks like you changed them to the 6c model, but i'm just curious
they look very good, the 6c bumper and fogs!
firegrafik
- Drives: 6R 1,6MPI(CFNA) sedan
Thank you, iichel! The fog lights are 6C too, my stock foglights have a round shape. New ones with DRL section. 6C0 941 661 and 6C0 941 662.iichel wrote:looks very good firegrafik! do you know if the 6c fog lights fit into the 6r bumper? looks like you changed them to the 6c model, but i'm just curiousthey look very good, the 6c bumper and fogs!
https://www.drive2.com/l/7796984/
https://www.drive2.com/l/10003797/
- CNK
- Drives: 6R
Great change!firegrafik wrote:Hello, Fernando and everyone!
I've started a facelifting mod to 6C look. Additionally retrofit headlight washers and front PDC.
Next step is 6C headlights and grill retrofitting.
When doing it that way:Bachecco wrote:Hi ciclo, I have adopted iichel's solution, and now everything is working perfectly. thanks to both of you.iichel wrote:try like this
One last question, where you have placed the resistors? because they really heat up!
- You have fully lost the diagnosis of turn signals taillights. (bad matter)
- You are playing with the earth (ground) of all lights from your taillights.
- IMHO interleave the resistor on the wire is something better, but... the heat could be a big problem
Clarifications:
I don't like to put resistors in car wiring, consequently (hence), I don't have extra resistors.
Many people do ask on my thread about things I've never done, and then other people (I do not know why) think I have done such a modification on my 6R.
Hi there, Really nice!firegrafik wrote:Hello, Fernando and everyone!
Perhaps,firegrafik wrote: Now question is concerning headlight washer adaptation. What adaptation channels of 09 Cent.Eletr. change washer running time and frequency?
Each 5 cycles (by pulling of wiper stalk) is set from factory.
It's just a suggestion (not tested), but now I have the curiosity about it. We will have to look for it.
firegrafik
iichel, as for possibility to fit the 6C fogs into 6R bumper, I can't be sure, so I could make some photos closer, without grillsiichel wrote:looks very good firegrafik! do you know if the 6c fog lights fit into the 6r bumper? looks like you changed them to the 6c model, but i'm just curiousthey look very good, the 6c bumper and fogs!
- CNK
- Drives: 6R
@firegrafik How you connected the front parking sensors? I found this guide: http://www.motor-talk.de/forum/retrofit ... 39813.html (https://docs.google.com/document/d/1wmk ... sp=sharing)
Next month planning a similar modification (R-Line front bumper + static cornering lights + front/rear PDC/OPS + washers)
firegrafik
I still have not finished with the PDC. My polo has stock rear PDC, but with simple control unit w/o CAN-bus , acoustic only 6R0 919 064 C. First of all I want to change my RCD320G, it can't display PDC information.CNK wrote:@firegrafik How you connected the front parking sensors? ...
For now I have packed and laid additional harness for the front parking sensors and for CAN-bus, PDC-button (6RU927122WHS), front buzzer
Wirimg diagrams is taken from ELSA for new russian polo sedan 2016 (614) with CWVA engine
The post of Hans Hoek is a very good one.
I would recommend to take the CAN from the steering angle sensor, in the steering column. Leave the airbag module there.
Apart from that, the guide is very good!
firegrafik
New discovery.
Rain closing function works not only on a locked car. It works on unlocked car also.
- RekinPoznan
- Drives: 6R
Hi
Ciclo or anybody know where is pin from BCM to drive engine starter relay ? is T73a/55 ?
Thanks for help.
Thanks for help.
BCM
Plug Pin Cross-section Cable color Terminal
A 1 - - High beam relay output (Kl.56b) (When retrofitting high beam assist system)
A 2 2.5 ge / sw Left low beam output (Kl.56bL) (only for vehicles with stop-start system or for vehicles with gas discharge lamps)
A 3 - - Battery cut-off relay output
A 4 0.35 br / sw Output signal Interior light, door contact switch
A 5 0.5 gr Lamp for LED daytime running light right
A 5 1.0 ge / br Lamp daytime running light right
A 6 1.0 gr / ws Output rear fog lamp (only for vehicles with automatic stop-start system or retrofit headlights)
A 7 1.5 wh / ye / ye Input signal switch for fog lights
A 8 - - Output isolation relays for CAN-bus drive
A 9 - - -
A 10 0.5 gray / red Output motor for tailgate
A 11 1.5 vi / ws Output motor for central locking "lock" for all doors
A 12 1.0 vi / gr Output motor for central locking, driver's door
A 13 1.5 br / rt Output motor for central locking "safe" for all doors
A 14 2.5 br Input signal mass (31), Central
A 15 1.0 vi / ye Output motor for central locking, passenger door and rear doors
A 16 2.5 rt Input supply (30), Central
A 17 0.5 gn / rd Input unit for central locking, rear left door
A 18 0.5 gn / gr Input unit for central locking, rear right door
A 19 0.35 br / ye Input signal drivers side door switch
A 20 0.35 br / rt Door switch input signal, passenger side
A 21 0.5 green / yellow Input unit for central locking, passenger door
A 22 0.5 gn / bl Input unit for central locking, driver's door
A 23 0.5 vi / ws Input signal button for unlocking in the tailgate handle
A 24 0.5 green / yellow Central input signal, the driver's door
A 25 0.35 br / gn Input signal Interior Locking Button
A 26 0.5 br / ws Door switch input signal, rear right door
A 27 0.5 sw / gn Input signal bonnet contact switch
A 28 0.5 bl / ye Input signal hazard light button
A 29 0.35 br / sw Input signal horn activation
A 30 0.5 gn / bl Input signal tailgate lock, position 2
A 31 0.5 bl / rd Input tailgate lock, position 1
A 32 0.35 sw / gn Input signal indicator switch right
A 33 0.35 black / white Input signal indicator switch left
A 34 0.35 br / gr Door switch input signal, rear left door
A 35 - - Output control unit for sliding roof
A 36 0.5 rd / ye Signal off seat heating
A 37 - - Input signal switch for automatic light control (Kl.AFL)
A 38 1.0 bl / bl Output heated exterior mirrors
A 39 - - Input signal ground (terminal 31)
A 40 0.5 gray / red Output signal lamps for parking light right (Kl.58R)
A 41 0.5 gr / sw Output signal lamps for parking light left (Kl.58L)
A 42 0.5 bl / br Input supply (Kl.86s) for Ignition
A 43 0.35 black / red Input signal brake pedal position sensor
A 44 0.5 bl / bl / black / yellow Input, plus compound 2 (Kl.15a) in interior wiring harness
A 45 0.5 gr / ye Input signal for parking light, light switch position "parking light" and "headlight" / (Kl.58_in)
A 46 - - -
A 47 - - -
A 48 - - Output control unit for sliding roof
A 49 0.5 vi Output relay for headlight washer system
A 50 - - -
A 51 - - Output relay for entry-level and footwell lights
A 52 0.5 bl / ye Output relay for fuel supply
A 53 - - -
A 54 0.5 black / red Input supply (75a) for Zündanlassschalter1)
A 55 0.5 vi / gr Output relay for starter interlock (only vehicles with automatic transmission)
A 56 0.35 gr / bl Output signal indicator for warning lights
A 57 0.35 bl / gn Output indicator light for indoor surveillance shutdown
A 58 0.35 red / black Output indicator light for SAFE operation of the Central
A 59 0.35 br / gr Output indicator light for interior locking
A 60 0.35 wh / ye Output indicator light for heated rear window
A 61 - - -
A 62 0.5 wh / gn Output high beam (+ Kl.56aL Kl56aR) (only for vehicles with stop-start system or for vehicles with gas discharge lamps)
A 63 2.5 - Input supply (30), left headlight (only for vehicles with stop-start system)
A 64 1.0 black / red Input supply (30), heated outside mirrors
A 65 1.0 red / black Output power (30G), interior light and trunk light
A 66 1.0 rt / vi Input supply (30), Indoor Lighting
A 67 - - -
A 68 2.5 rd / ye Input supply (30), windshield (only for vehicles with stop-start system)
A 69 2.5 ws / sw Output wipers, position 1
A 70 2.5 br Input signal for wiper mass
A 71 2.5 green / yellow Output wipers, 2 position
A 72 1.5 black / yellow Output signal horn
A 73 2.5 rd / ye Input supply (30), horn
B 1 1.0 gray / red Input control for switch and instrument lighting (58)
B 2 2.5 gr / vi Right low beam output (Kl.56bR) (only for vehicles with stop-start system or for vehicles with gas discharge lamps)
B 3 0.5 gr / ye Lamp LED daytime running lights left (Kl.TFL)
B 3 1.0 ge / br Lamp daytime running light left (Kl.TFL)
B 4 - - -
B 5 0.5 gn Parking light, front left (Kl.58l)
B 6 0.5 gn / ws Auxiliary light right (Kl.58r)
B 7 1.0 gr / bl Plus connection (58) panel wiring, parking and driving light position light switch T17/16 (only with stop-start system)
B 8 - - -
B 9 1.5 wh / ye Output signal lamp for fog lamp left
B 9 1.0 wh / ye Output signal lamp for cornering left for vehicles with gas discharge headlights, Kl.ABL_L
B 10 1.5 wh / ye Output signal lamp for fog lamp right
B 10 1.0 vi Output signal lamp for cornering right for vehicles with gas discharge headlights, Kl.ABL_R
B 11 1.0 sw / gn Input supply (30), fog lamps for
B 12 0.35 bl / bl Output signal reversing lights (cars with automatic or automatic light retrofit)
B 13 1.5 rd / ye Input supply (30), flashing light and brake light
B 14 1.5 black / white Output signal flashing left (class L)
B 15 1.5 sw / gn Output signal flashing light right (Kl.R)
B 16 1.0 ws Output signal brake lights
B 17 0.35 vi / ws LIN bus, door control unit in the steering wheel and shift lever
B 18 0.35 or / br CAN low drive
B 19 0.35 or / sw CAN high, drive
B 20 0.35 or / gn CAN high, comfort
B 21 0.35 or / br CAN low, comfort
B 22 0.35 or / br CAN low diagnostic
B 23 0.35 or / sw CAN high, diagnosis
B 24 0.35 vi / ws LIN bus control unit for sliding adjustment, rain and light sensor for detection, sensor for indoor surveillance
B 25 - - Input contact closed door left
B 26 - - Input contact closed sliding door right
B 27 0.5 wh / gn Wiper input signal, position 1
B 28 0.5 bl / ye Central input signal, passenger door
B 29 0.5 gr / vi Input, "0" position light switch
B 30 0.35 vi Input signal switch for deactivation of the interior monitoring
B 31 0.35 wh / rd Input signal switch for heated rear window
B 32 0.5 gn / bk Limit switch input signal for windshield wipers
B 33 - - -
B 34 0.5 gr / bl Output signal lighting - Switches and instruments (58d)
B 35 - - -
B 36 0.5 vi / ws LIN bus, alarm horn
B 37 0.5 gr / ws Signal (K) Diagnosis
B 38 1.5 br Input to ground (31), for electronic
B 39 0.5 red / white Input signal supply (30) for electronic
B 40 - - -
B 41 - - -
B 42 0.35 sw / gn Brake contact switch input signal
B 43 0.35 gr / sw Input signal switch for rear fog light (Kl.NSL)
B 44 0.35 bl / ye Input Signal "set" speed control system
B 45 0.35 ws Input signal "on / off" cruise control
B 46 0.5 bl / vi Input signal "reset" cruise control
B 47 0.35 bl / wh Input Signal "Cancel" cruise control
B 48 0.5 bl / bl Input signal switch for reversing light
B 49 0.5 bl (L) signal generator
B 50 0.5 red / black Input signal Starterrelais1)
B 51 0.5 black / red Input supply (75a) for Ignition
B 52 0.5 ws Input signal power washer pump / switch for driving lights (Kl.FL)
B 53 0.5 green / yellow Wiper input signal, position 2
B 54 - - -
B 55 0.5 vi / sw Starter interlock signal (only for vehicles with automatic transmission and without start-stop system)
B 56 - - Input clamping unit for tailgate
B 57 - - -
B 58 0.35 sw / gn Input signal switch heated mirrors
B 59 0.5 rd / ye Input signal for the reference voltage (30)
B 60 0.5 br Input signal for mass - reference voltage (31)
B 61 0.5 gn / rd Output motor for washer pump and motor for rear window wiper
B 62 0.35 br / gn Input signal intermittent wiper circuit
B 63 2.5 ws Output heated rear window
B 64 - - -
B 65 - - -
B 66 - - -
B 67 2.5 rd / ye Input supply (30), heated rear window
B 68 1.5 red / white Input supply (30), headlight right1)
B 69 - - -
B 70 - - -
B 71 - - -
B 72 - - -
B 73 - - -
A 9 - - -
A 46 - - -
A 47 - - -
A 50 - - -
A 53 - - -
A 61 - - -
A 67 - - -
B 4 - - -
B 8 - - -
B 33 - - -
B 35 - - -
B 40 - - -
B 41 - - -
B 54 - - -
B 57 - - -
B 64 - - -
B 65 - - -
B 66 - - -
B 69 - - -
B 70 - - -
B 71 - - -
B 72 - - -
B 73 - - -
- RekinPoznan
- Drives: 6R
Many thanks
- RekinPoznan
- Drives: 6R
Dear Ciclo
Coding and wiring corectly (mayby not coding) , auto lights via light sensor dont work and CH/LH dont work any sugesstions ?
Coding BCM: 3CB02BBF08E3240093300ED16EEB0ED0FA8067FF60851041200000010000
Coding RLS: 0305F3
Many thanks for any help
Best Regards Chriss
Coding RLS: 0305F3
Best Regards Chriss
enable byte 22 bit 5
RLS: 1F302D
RLS: 1F302D
