Page 156 of 333
Posted: Tue Jun 21, 2016 9:49 pm
by benzinkopf
Ciclo,iichel,
To my surprise, i managed to enable rain closing in a 3 doors Polo GTi yesterday and the BCM accepted the code. But, it only works and closes the sunroof. Not the windows. I'll share the autoscan later.
Posted: Wed Jun 22, 2016 4:26 am
by firegrafik
benzinkopf, food for thought:
Some time ago I've played with 09centr.electr coding and took some byte values from new polo 6R sedan 2016. With this coding:
22904ABF48E1240093380E00FE8B16F02EC8614F60862055220000000000
I'd found out the rain closing didn't work at all (I don't have the sunroof, only windows)
But with this coding
22904ABF48E1240093380E007ECB16F000C8614F60842055220000000000
It works
Posted: Wed Jun 22, 2016 7:54 am
by benzinkopf
The diff in both your codes above:
1. Byte 12, Bit 3 = 0 "Emergency Flashing Turn Signal Active"
2. Byte 13, Bit 2 = 1 "Brake light off with ignition off"
3. Byte 16, Bit 1 = 0 "Emergency brake flashing via brake light active"
4. Byte 17, Bit 5-7 = 0 "no labels for Bit 5, 6. Bit 7="Cruise control installed"
5. Byte 22, Bit 5 = 0 "Assistant Driving Light ADL active"
If VCDS labels are correct, only changes in Byte 17-Bit 5,6 is relevant for Rain Closing to be active.
Posted: Wed Jun 22, 2016 8:24 am
by iichel
I think, but I'm not sure, that also the RLS coding somehow is involved. I can't remember where I read it though.
Since some people (firegrafik, ciclo, myself) are running a different RLS, the 5K7 955 559, maybe that also is involved?
Posted: Wed Jun 22, 2016 8:39 am
by benzinkopf
Heres the autoscan from the 3Doors GTi with sunroof
Address 09: Cent. Elect. (J519) Labels: 6R0-937-08x-09.clb
Part No SW: 6R0 937 087 H HW: 6R0 937 087
Component: BCM PQ25 H+4 H46 0230
Revision: BF046001 Serial number: 0394 024110738
Coding: 24B029BF08A10000092808003D2B0ED000C0410F60060000200000000000
Shop #: WSC 29698 002 1048576
VCID: 42814528DDB4132E28-8016
Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 080111 05 54 0403
Coding: 03302D
Subsystem 2 - Part No SW: 6R0 959 802 AB HW: 6R0 959 802 AB Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 007 1621
Coding: 08BC30
Subsystem 3 - Part No SW: 6R0 959 801 AD HW: 6R0 959 801 AD
Component: J387__TSG_BT 007 1621
Coding: 08BC30
Subsystem 4 - Part No SW: 6R0 959 591 A HW: 7P0 959 591
Component: J245 PS72.015 H05 0006
Coding: 081001
Subsystem 5 - Part No SW: 5K0 959 542 HW: 5K0 959 542
Component: E221__MFL-TAS H06 0010
Coding: 830000
Posted: Wed Jun 22, 2016 12:44 pm
by jastr
how did you get the amarok cluster working in the polo?
Posted: Thu Jun 23, 2016 11:32 am
by benzinkopf
jastr wrote:how did you get the amarok cluster working in the polo?
Jastr, u re asking me?
I read somewhere amarok cluster is exactly the same design with polo. So it fits just nice.
Posted: Tue Jun 28, 2016 11:39 am
by Bachecco
ciclo wrote:Sport rear springs
Factory measures
Looking for a balance between performance, "comfort" and aesthetics.
My R-line: (without sport chassis -15mm)
Front Axle from factory
L: 355mm
R: 355mm
Rear Axle from factory. Basic rear springs. 6Q0511115CD PR-1JP+0YE
L: 375mm
R: 375mm
The height of the rear axle is horrendous.
With Eibach Pro Kit (for tests)
Eibach Pro Kit Front Axle
L: 330mm
R: 330mm
Eibach Pro kit Rear Axle
L:345mm
R:345mm
Good performance, but my front bumper slashing on the unusually big ramp (hill) of my garage.
I removed and sold it.
And finally and my selected option:
Front Axle from factory.
L: 355mm
R: 355mm
Rear Axle. Sport rear springs. 6Q0511115CK PR-1JS+0YE
L: 360mm
R: 360mm
Lowered -15mm rear axle.
Improves performance of the rear axle, It is very noticeable.
I'm very satisfied with this configuration of springs. Above all it is comfortable.Image
hi ciclo,
I have a question, I have on my polo the standard springs from factory (1.2 petrol, not TSI), but I want to install r-line springs -15mm.
I must change all springs + shock absorber or the shock absorber is the same of the sport chassis -15mm?
In this case this is the code for my chassis 6Q0511115CK PR-1JS+0YE?
Posted: Tue Jun 28, 2016 12:08 pm
by iichel
You'll be ok if you only replace the springs and keep the shocks.
Posted: Wed Jun 29, 2016 9:47 am
by Bachecco
thank you iichel,
but the springs are the same for all motorization? On ETKA i have found a lot of codes for it.
Posted: Wed Jun 29, 2016 10:20 am
by iichel
on the front axle there are many differences due to the engines having different weights.
on the rear axle the differences are a lot smaller. you basically have the 3-doors and 4-doors (4-doors is heavier, about 40kgs) and the GTI has the battery at the rear.
Posted: Fri Jul 01, 2016 11:19 pm
by Ste2302
ciclo wrote:New Mod
Lower grill and fog covers RLine 6C. OEM.
Parts:
Lower grill R-line 6C
6C0853677J 041
Fog covers R-line 6C
6C0853665F 041
6C0853666F 041
PR-041 gloss black from factory
CHE SPETTACOLO! :D
Upper grill R-line 6C
Hey where did you but this from? I can't find any for sale anywhere :(
Posted: Sat Jul 02, 2016 10:32 am
by iichel
I believe ciclo often buys at http://www.kfzteile-profis.de/ :-)
Posted: Thu Jul 07, 2016 2:12 pm
by AlexR
Your car looks great! :)
Posted: Fri Jul 08, 2016 1:49 pm
by Adam87
Just a though, would polo door modules fit/work in a T5 (2015) to them have mirrors fold on lock?
