yes no problem
Adam87
Drives: T5.2
Post by Adam87 »
iichel wrote:yes no problem
Thanks iichel, is there any module best to use?
oh wait sorry, i misread your question.
you can only use them from a polo 6r or 6c
Adam87
Drives: T5.2
Post by Adam87 »
And will they control the window correctly? Run time etc? Any particular part number for most options/max controller?
Hi everyone, here again after making the reforms at home. :D
First some info provided by my dear friend peter_dk25, I think it might be of interest to many people:
BCM PQ25
- How to disable the Safe-Lock warning in the MFA+ when the engine is turned off:
Address 9, Byte 10, Bit 3.
- How to permanently disable Start/Stop System for 6R (others VW?):
Address 9, Byte 20, Bit 4.
... by Netech, VCDS in Denmark. Excellent people, excellent websites.
A nice link from Netech. 8) :lol:
... and now I will try to answer questions asked in my topic, and sales section ... bit to bit ... (the summer heat, 35ºC in the shade here in Spain) Image
hi ciclo, welcome back 8) don't overheat yourself :lol:
a question with low priority:
for a friend on the mypolo.nl forum, we installed the oem bi-xenon headlights together.
now we are figuring out the coding on BCM 088 B (polo bluemotion) with OEM wiring diagram.
We tried the coding 3AB02BBF48A1000000300F317E2F94D80F88670F7E0D1441A00000000000
This works with static cornering lights in headlight unit, xenon and high beam work. But the LEDs do nothing.
Could you give me a hint in the right direction?
iichel wrote:hi ciclo, welcome back 8) don't overheat yourself :lol:
...But the LEDs do nothing.
Howdy! (many thanks :wink: )
BCM coding regarding this seems correct.
Maybe, T17/3 --- 0.5 wire --- T73b/29 Is it present?
Image :lol:
Edit
You also should check:
Byte 16, 5A HEX
Byte 22, Bit2? Do you remember?
Byte 24, Bit 7??? Do you know what makes this Bit? (I have only seen in Jetta)
firegrafik
Drives: 6R 1,6MPI(CFNA) sedan
Post by firegrafik »
ciclo wrote: ....
Hello, Fernando!
Glad to read you again!
Could you explain what the Safe-lock function does. I haven't seen such warning on my MFA+
It's simply advising you that once you exit the car and lock the doors, they're effectively deadlocked and anyone still in the car wouldn't be able to get out in the event of an emergency. The warning message is intentional and nothing to worry about - it's standard.
peter_dk25
Drives: Blue GT
Post by peter_dk25 »
Welcome back, Ciclo - very nice to "see" you Again :D
peter_dk25
Drives: Blue GT
iichel wrote:It's simply advising you that once you exit the car and lock the doors, they're effectively deadlocked and anyone still in the car wouldn't be able to get out in the event of an emergency. The warning message is intentional and nothing to worry about - it's standard.
I don't think it is installed in all Polos.
Mine has it because I have the factory fitted Alarm system in my Blue GT
Hi Alexander, Peter and everyone. :D :wink:
Sorry for the picture, I hope this is helpful. from here
PD: I try to find more time to get into the forum, but it seems impossible to me. I think that until September I will not be fully available. :?
It's a hobby, coming here. Not an obligation ;)
firegrafik
Interesting note. There is new BCM units are mounted 7E0937090B on the new Polo 6R sedans with xenon in Kaluga, Russia. Found the one for sell for €120.
Locked
