I got rid of flimsy one and replaced with 3Q0 955 455
I could hardly make any difference between 3Q0 955 455 and 4M0 955 267 except price.
Posted: Mon Nov 20, 2017 2:52 pm
by DACA
Can one of you let me have the part numbers for front and rear mud flaps. For a 2015 Polo 1.4 Tdi bluemotion no side skirts please.
Posted: Tue Nov 21, 2017 10:02 am
by DACA
Good morning I am new to this forum and was wondering if I can get some help and advice please. Are oem mudflaps available for a 2015 (65) polo 1.4 tdi bluemotion? If so what are the part numbers for front and rear. I do not have side skirts just the normal sill. Thanks for your help
Posted: Thu Dec 28, 2017 8:02 am
by DACA
Just thought i would add that i was rather disappointed with the lack of replies here
I have now bought a set of short mudflaps from China via Alibaba for 20 dollars. The front ones are spot on and the rear ones need me to drill a hole for the lower fixing. Just what the dr ordered really
Posted: Tue Jan 02, 2018 5:44 pm
by DACA
Rear ones fitted. A good fit and quality is the same. Didn't take long to get from China to the uk and a great price at just over £15 from alibaba. Very happy with my buy.
Posted: Mon Jan 22, 2018 12:26 pm
by HappyGoLucky
Hi there,
Does anyone know where I can get Gloss black badges with red inserts for my 2016 Polo GTI?
Thanks in advance
Posted: Mon Mar 05, 2018 4:23 pm
by BOAK
Would anyone have the part number for a Turbo Actuator on the Blue GT?
Posted: Thu Apr 05, 2018 7:26 am
by ag69
I am looking for "Engine Start Stop Button" illuminating in Red color to be retrofitted in Polo 6R.
VW
Audi
The attachment audi-engine-start-stop.JPG is no longer available
Could anyone of you please confirm if which of these would glow Red?
Passat has a 3G1959839
Golf has a 5G1959839
or any other from VW group you can list would help too. xxx 959 839
Posted: Thu Apr 05, 2018 7:48 pm
by iichel
5K0959839A and 5C7959839A are red, i got the 5K0 in my polo
5G1 is very likely white
Posted: Fri Apr 06, 2018 7:42 am
by ag69
Thank you iichel.
If you get some time may be post a video of it.
I have seen image. One q is can we remove the actual button from black colored plastic cone? I am not sure where to place it but may be making a hole in dash or around gear lever.
Posted: Fri Apr 06, 2018 11:02 am
by iichel
it's probably not super difficult to separate the button and the body, most VW switches are very modular and can be taken apart easily.
i expect the start/stop button not to be different.
Posted: Wed Apr 11, 2018 6:54 pm
by ag69
thank you iichel,
Posted: Wed Apr 11, 2018 7:07 pm
by ag69
Would any vw reverse emblem camera work with RCD330G/340G?
5GM827469g -- from golf
3G0827469 -- from passat
size of emblem is 110mm so passat ( or any other model) emblem camera can fit in polo. (correct me)
But any idea about the connector?
Do we need to make any wire/connector alterations?
(iichel has :
OEM 5K Golf 6/T6 badge rear view camera Highline --> 5K0827469H + 7E0907441 + wiring
I am not sure if we need camera module with RCD330G and above.
Posted: Tue Apr 17, 2018 1:32 pm
by iichel
I think the RCD330G works with a 2-wire system to the camera with a composite signal. My RNS510 (and the RCD510 and RNS315) works with the 26-pin connector and 4 wires with an sRGB signal.
Now in my case, the camera is also the version with a composite signal but goes to a module first, where it's converted to sRGB.
So 5K0827469H would work.
Posted: Tue Apr 17, 2018 2:59 pm
by benzinkopf
iichel wrote:I think the RCD330G works with a 2-wire system to the camera with a composite signal. My RNS510 (and the RCD510 and RNS315) works with the 26-pin connector and 4 wires with an sRGB signal.
How accurate the guidelines and how significant it provides compared to camera view without the dynamic guidelines? mind sharing a bit?
