If you buy the aliexpress stalks you have to install your current steering ring on them.
:arrow: VCDS is a good diagnostic tool. (for example)
chinesia75
Drives: VW POLO 6R
Post by chinesia75 »
Hallo ciclo,
I found the stalks 6r0953521c used; okay for my car, you advised me on 6r0953507c; can the cables be purchased separately?
chinesia75
Drives: VW POLO 6R
ok Ciclo thanks, so fine 6r0953521c ?
chinesia75 wrote: Fri Oct 27, 2017 4:30 pm ok Ciclo thanks, so fine 6r0953521c ?
Yes
chinesia75
Drives: VW POLO 6R
hello cycle, as I wrote earlier tried to steal my car by damaging it, only now after buying all the components to fix it, I took the opportunity to buy the components to add the cruise control, i bought the bcm 6r0937087p, stalks 6r0953521c, kufatech cables, cable vag.com version 17.8 for obd. I wanted to ask you in particular pin 28 of connector T41, it should be connected to bcm or directly to fuse box (in what position)? soon they sent me photo editing, and maybe they would ask for some help; Thanks in advance .
chinesia75
Drives: VW POLO 6R
sorry ciclo , I called you cycle; I used the ITA / UK translator.
ciclo = cycle
noun
A single complete execution of a periodically repeated phenomenon. For example, a spin around the sun ...or the galaxy.
As long as we understand each other, you can name me as you prefer. :wink:
Now,
look these pictures (3,4):
and click here :arrow: Image
select the +15 vacant slot in the fuse box that you prefer.
Info help :arrow: Image
chinesia75
Drives: VW POLO 6R
thanks again ciclo; ciclo is also a word used in Italian es. ciclomotore ; ciclo = 2 * π * r 😁
τ = 2π = 6.28318...
One/full turn
According to diameter
Image 6.28318...
According to the radius
Image 6.28318...
τau
Will Tau replace Pi forever? :lol:
chinesia75
Drives: VW POLO 6R
good cycle, know that you like science, are you an engineer? I studied engineering for three years, then I changed my way to medicine ... but I'm fascinated by math, geometry and the sciences in general ... they open the mind !!
ciclo wrote: Mon Nov 20, 2017 4:21 am Will Tau replace Pi forever? :lol:
https://www.youtube.com/watch?v=OEMA6jhi5Qo&t=302s
chinesia75
Drives: VW POLO 6R
hello Ciclo , of course, also greetings to all the guys here in the forum;
this week I proceed to the installation of cruise control; I wanted to know, when replacing the bcm, how should I proceed with the vag? do I have to recode the car keys? some cosinglio because I'm not very experienced thanks from Savino Italy !!
You have to do exactly as explained in this link:
http://wiki.ross-tech.com/wiki/index.ph ... eplacement
chinesia75
Drives: VW POLO 6R
thanks Ciclo, yesterday I installed the program vag.com (tech-ross); I did my first auto scan, I realized that there are 4 errors, engine, brakes, air conditioning and radio; even if I do not have warning lights and everything works perfectly (at least it seems so). as soon as I have some free time I'll run the ccs ... I'll also take some pictures of the work, greetings by Savino from Italy
