govindsharma
Drives: polo 1.2 petrol HighLine
Post by govindsharma »
Sir today i had changed coding of Subsystem 2 - Part No SW: 6R0 959 802 EF HW: 6R0 959 802 EF Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 020 2551
Coding: 000000 to RHD after that master switch in driver door for window changed and from from right button left window rolls up and from left to right and side view mirror also working in opposite direction means one open and other closing .After that i had changed it to 000000 means no coding but it does not goes back please help in this regard.
Thank you.
From factory: viewtopic.php?f=56&t=58703&start=2370#p512299
Keep in mind that your VCDS is not perfect (12.12.3) so you must try to put the coding as many times as necessary.
Hmmm... :?: What if you open a new topic? It will be easiest to help you.
E.g: govindsharma's Polo. (car pictures, autoscan, etc...)
JayW
Post by JayW »
Hi Ciclo
Which fuse is for the 12v accessory socket in the r-line?
6R or 6C?
6R, I guess. SB42 15Amp
favi
Drives: 6R
Post by favi »
The seller gave me probably the English version switch mirrors (no item number). I have a problem that the whole control it vice versa. Switch position "down" - changes the position of the mirror up. Does anyone Announcement of cables / pins switch mirrors?
Is there a chance that swapping pins is enough to operate it properly, or do I have to buy a switch to a version of the LHD.
favi wrote:The seller gave me probably the English version switch mirrors (no item number). I have a problem that the whole control it vice versa. Switch position "down" - changes the position of the mirror up. Does anyone Announcement of cables / pins switch mirrors?
Buy new one
LHD
CLICK: 6RD 959 565 B for example.
favi
Drives: 6R
Post by favi »
bought. :>
also for LHD
6RD959565D
JayW
Post by JayW »
ciclo wrote:6R, I guess. SB42 15Amp
Hi Ciclo
Yes its the 6R,
Thanks!
Freddie 1942
Drives: 2008 1.4 tdi bluemotion
Post by Freddie 1942 »
:oops:
ciclo wrote:also for LHD
6RD959565D
Can anybody help with a break disc problem retainer screw damaged cannot remove tried centre punch still un movable any ideas
Needs to be drilled out and retapped
Freddie 1942
Yes thought it would but what about an extractor drill
JayW
Post by JayW »
Hi again
Is there anywhere in the fusebox compartment where i can earth a wire? Im using a fuse tap to connect my boost gauge lighting so would prefer somewhere close by for the earthing point as well.
Jay
you can take the steering rack as an earthing point. there are many earthing points next to the pedals in the centre console.
you could also splice a wire into the RNS..
Locked
