JayW
Post by JayW »
Thanks iichel
I'll take the steering rear cover off then and have a look to see where i can earth to in there.
firegrafik
Drives: 6R 1,6MPI(CFNA) sedan
Post by firegrafik »
iichel wrote:These are the functions of byte 23 that I know:
byte 23
bit 0 Alternative voltage supply for high beam and T58d (button illumination)
bit 1
bit 2 Cornering lights as DRL and LED DRL off - xenon only
bit 3 Low beam as DRL and LED DRL off - xenon only
bit 4 LED DRL off with handbrake on - xenon only
bit 5
bit 6 DRL active
bit 7 LED DRL off unilateral with indicator on - xenon only
New discovery
Byte 23 bit 1 - Deactivate rear fog light while high beam is working
BCM Max only.
but I think it makes no sense. What do you think?
Hmm...another change that I noticed for rear fog light:
When Byte22 Bit6 (Clutch Message) is marked my rear fog light go off in any light switch position. :?:
My IC: 6R0 920 870 C
firegrafik
Agree with you. This bit is not useful, anyway this is a next step to uncover each bit in 09CentrElectr long coding
firegrafik wrote:Agree with you. This bit is not useful, anyway this is a next step to uncover each bit in 09CentrElectr long coding
Yes :wink:, anyway... here go Image :
Long code (almost all Bits) BCM PQ25 (German)
*Please I need a good friend to translate from German to English all BCM Bits descriptions and share with all us. Please do it accurately. TIA
Warning: You have to know perfectly what is the electric wiring configuration of your car. There are even differences between BCMs Max (old and new models).
2nd warning: If your car does not have a rocket not try to encode for rocket ignition... just kidding. :lol:
;LC,00,0,Selektive Zentralverriegelung (Einzelt?rentriegelung)
;LC,00,1,Zentralverriegelung ohne Safe-Funktion verbaut
;LC,00,2,Schlosstyp (0 = 1-Motoren-Schloss / 1 = 2-Motoren-Schloss)
;LC,00,3,Auto-Unlock (Annahme des alten Zustandes nach abziehen des Z?ndschl?ssels)
;LC,00,4,Auto-Lock (autom. verriegeln bei ab 15 km/h)
;LC,00,5,Zentralverriegelung verbaut
;LC,00,6,Zentralverriegelung ?ber Schlie?zylinder aktiv
;LC,00,7,Zentralverriegelung ohne Safe-Funktion
;LC,01,0,Aktivierung Zentralverriegelung Gep?ckraum nach 0.8s aktiv
;LC,01,1,Schlossr?ckmeldung Schiebet?r rechts (0 = via Hardware / 1 = via CAN)
;LC,01,2,Zentralverriegelung/Heckklappe: Zeitbegrenzte Heckfreigabe nach externer Verriegelung
;LC,01,3,Zentralverriegelung/Heckklappe: "Security Lock" (Geschwindigkeits basierte Verriegelung)
;LC,01,4,Zentralverriegelung/Heckklappe: Gep?ckraumdeckel mit automatischer Ausstellung inaktiv
;LC,01,5,Zentralverriegelung mit Steuerung ?ber Kontakt Gep?ckraumverriegelung an Raste(n) aktiv
;LC,01,7,Zentralverriegelung/Heckklappe: Heckklappe ?ber Zentralverriegelung ver-/entriegelt
;LC,02,0,Zentralverriegelung/Heckklappe: Softtouch (direkter Auswurf/keine Freigabe)
;LC,02,1,T?ren (0 = 2-t?rig / 1 = 4-t?rig)
;LC,02,2,Funkfernbedienung (FFB) bei "Klemme 15 EIN" aktiv
;LC,02,3,Zentralverriegelung/Heckklappe: ZV-Regler in eine Richtung verbaut
;LC,02,4,Zentralverriegelung/Tankklappe: ZV-Regler in eine Richtung verbaut
;LC,02,5,Zentralverriegelung/Heckklappe: Schloss mit vorheriger Verriegelung verbaut
;LC,02,6,Entriegelungstaster Heckklappe nicht verbaut
;LC,02,7,Schiebe-/Ausstelldach (interne Steuerung) verbaut
;LC,03,0,Komfort?ffnen Schiebe-/Ausstelldach (SAD) aktiv
;LC,03,1,Komfortschlie?en Schiebe-/Ausstelldach (SAD) aktiv
;LC,03,2,Komfortfunktion Schiebe-/Ausstelldach (SAD) aktiv
;LC,03,3,Komfortfunktion elektrische Fensterheber (eFH) via Schlie?zylinder aktiv
;LC,03,4,Komfortfunktion elektrische Fensterheber (eFH) via Schalter Fahrerseite aktiv
;LC,03,5,Komfortfunktion elektrische Fensterheber (eFH) via Funkfernbedienung (FFB) aktiv
;LC,03,6,Spiegelanklappung geschwindigkeitsabh?ngig (0 = immer aktiv / 1 = nicht aktiv ?ber X km/h)
;LC,03,7,Komfortfunktion aktiv
;LC,04,0,Deaktivierung Diebstahlwarnanlage (DWA) f?r Campingbetrieb m?glich/verbaut
;LC,04,1,Ansteuerungswiederholung bei Schlossfehler
;LC,04,2,Intern verriegeln ?ber Schlossr?ckmeldung Fahrert?r
;LC,04,3,Freigabenachlauf elektrische Fensterheber (eFH) bzw. Schiebe-/Ausstelldach (SAD) bei Z?ndung AUS
;LC,04,4,Ausf?hrung Schliesszylinder Fahrert?r (0 = SZ R codiert 180 Ohm / 1 = SZ Zweidraht)
;LC,04,5,Zentralverriegelung Wiederverriegelung (nach 30 Sekunden) aktiv
; Automatische Wiederveriegelung der ZV 30s nach Entriegelung ?ber Funk
;LC,04,6,Regenschlie?en aktiv
;LC,04,7,"Hot-Key" Funktion aktiv (derzeit nur f?r SEAT)
;LC,05,0,Ver-/Entriegelung optisch (Blinklicht) best?tigen
;LC,05,1,Verriegelung akustisch (Horn) best?tigen
;LC,05,2,Anpassung akustische (Horn) Best?tigung gesperrt
;LC,05,3,Akustische (Horn) Best?tigung von 40 ms auf 20 ms verk?rzt
;LC,05,4,Entriegelung akustisch (Horn) best?tigen
;LC,05,5,Komfortschlie?en optisch (Blinklicht) best?tigen
;LC,05,6,Sirenenschnittstelle Diebstahlwarnanlage (DWA) aktiv (0 = Horn verbaut / 1 = Backup-Horn (LIN) verbaut)
;LC,05,7,Diebstahlwarnanlage (DWA) sch?rfen akustisch (Horn) best?tigen
;LC,06,0,Sirenen Tontyp (0 = frequenzmoduliert / 1 = diskontinuierlich)
;LC,06,1,Sirenen Alarmtyp (0 = 10 Alarme (GB/Irland) / 1 = 1 Alarm (RDW))
;LC,06,2,Diebstahlwarnanlage (DWA) verbaut
;LC,06,3,Deaktivierung Diebstahlwarnanlage (DWA) ?ber Schlie?zylinder aktiv
;LC,06,5,Alarmverz?gerung Diebstahlwarnanlage (DWA bei Entriegelung ?ber Schlie?zylinder (0 = ab T?r?ffnung / 1 = ab Schliesszylinder AUF)
;LC,07,0,Zentralverriegelung/Fond: Schiebet?r links verbaut
;LC,07,1,Zentralverriegelung/Fond: Schiebet?r rechts verbaut
;LC,07,2,Zentralverriegelung/Fond: "letzte T?r nur hinten rechts"
;LC,07,3,Funkfernbedienung inaktiv
;;LC,07,4,Heckklappenschloss mit Safe -> entf?llt zuk?nftig
;;LC,07,5,Motor f?r Zentralverriegelung Heckklappe NICHT verbaut
;;LC,07,6,Schlie?zylinder Beifahrerseite/Heckklappe NICHT verbaut
;;LC,07,7,Trennfunktion (MFG) aktiv
; {Byte 08: LIN Datenbus Teilnehmer}
;LC,08,0,Regen-/Lichtsensor (RLS) verbaut
;LC,08,1,Neigungssensor (NGS) verbaut
;LC,08,2,Verbau Rollo SG
;LC,08,3,Schiebe-/Ausstelldach (externe Steuerung) verbaut
;LC,08,4,Innenraum?berwachung (IR?) verbaut
;LC,08,5,Verbau Feuchtesensor separat am Dach LIN
;LC,08,7,Sounder f?r Diebstahlwarnanlage (DWA) ?ber LIN verbaut
; {Byte 09: LIN Datenbus Teilnehmer}
;LC,09,5,Elektrische Fensterheber (eFH) vorne verbaut
;LC,09,4,Elektrische Fensterheber (eFH) hinten verbaut
;LC,09,3,Multifunktionslenkrad (MFL) verbaut
;LC,10,0,Funktion externes Start-Stop
;LC,10,1,Leaving-Home (LH) aktiv
;LC,10,2,Coming-Home (CH) aktiv
;LC,10,3,Verbau Verdeck Cabrio
;LC,10,4,Verdecksteuerung Cario
;LC,10,5,Tankdeckelsteuerung NAR
;LC,10,6,Negierung der Drehfallenkontakte der hinteren Schiebet?ren
;LC,10,7,Schlossr?ckmeldung Schiebet?r links
; {Byte 11: Leuchtenkonfiguration}
;LC,11,0,Fernleuchtenkombination (Bit 2),01 = Shutter (12 W)
;LC,11,1,Fernleuchtenkombination (Bit 1),00 = 65 W
;LC,11,4,Ansteuerung R?ckfahrleuchten ?ber PWM
;LC,11,5,Ansteuerung Kennzeichenleuchten ?ber PWM
;LC,11,6,Lampenausfallerkennung f?r R?ckfahrlicht aktiv
;LC,11,7,Lampenausfallerkennung f?r Kennzeichenbeleuchtung aktiv
;LC,12,0,Standlicht EIN bei "Klemme 15 EIN"
;LC,12,1,Tagfahrlicht vom Fahrer aktivierbar
; 0: "Affengriff" geht nicht, 1: Aktivierbarkeit des Tagfahrlichts ?ber MMI/Affengriff/Kombimen?, (nur wenn Byte 23, Bit 6 "Tagfahrlicht" = 1)
;LC,12,2,Innenbeleuchtung nach Abziehen des Z?ndschl?ssels aktiv
;LC,12,3,Notbremsblinken aktiv
;LC,12,4,Warnblinkanlage aktiv
;LC,12,5,Komfortblinken aktiv
;LC,12,6,Abbiegelicht verbaut/aktiv
;LC,12,7,Notbremswarnblinken f?r Anh?nger aktiv
;LC,13,0,Parklicht EIN nur ohne Z?ndung EIN m?glich
;LC,13,1,Funktion Parklicht aktiv
;LC,13,2,Bremslicht mit Klemme 15 AUS aktiv
;LC,13,3,Bremslichtansteuerung via BCM
;LC,13,4,Funktion freilaufendes Warnblinken
;LC,13,5,Einschalten Innenlicht ?ber Heckdeckel
;LC,13,6,Comming-Home (CH) / Leaving-Home (LH) Ausf?hrung (0 = Nebelscheinwerfer / 1 = Abblendlicht)
; nur wenn Byte/Bit 10/1 bzw. 10/2 aktiv
;LC,13,7,Funktion Lichtsensor aktiv
;LC,14,0,Scheinwerferreinigungsanlage (SRA) verbaut
;LC,14,1,Funktion Regensensor aktiv
;LC,14,2,Serviceposition Frontwischer aktiv
;LC,14,3,Komfortfunktion Heckwischen aktiv
;LC,14,4,Tr?nenwischen aktiv
;LC,14,7,Fahrgeschwindigkeitsabh?ngige Wischstufenr?ckschaltung aktiv
;LC,15,0,Push-to-Talk Funktion ?ber Multifunktionslenkrad (MFL) aktiv
;LC,15,2,Ansteuerung Heckscheibenheizung via CAN aktiv
;LC,15,3,Au?enspiegelheizung EIN bei Heckscheibenheizung EIN
;LC,15,4,Energiemanagement: Eingriff /Abschaltung beheizbare Sitze m?glich
;LC,15,5,Beheizbare Frontscheibe verbaut
;LC,15,6,Beheizbare Au?enspiegel verbaut
;LC,15,7,Beheizbare Heckscheibe verbaut
; {Byte 16: Vorgehalten f?r Diagnose}
;LC,16,0,Ansteuerung Abblendlicht ?ber PWM
;LC,16,1,Ansteuerung Nebelschlu?leuchten ?ber PWM
;LC,16,2,Ansteuerung Tagfahrleuchten ?ber PWM
;LC,16,3,Ansteuerung Fernleuchten ?ber PWM
;LC,16,4,Lampenausfallerkennung f?r Abblendlicht aktiv
;LC,16,5,Lampenausfallerkennung f?r Nebelschlu?licht aktiv
;LC,16,6,Lampenausfallerkennung f?r Tagfahrlicht aktiv
;LC,16,7,Lampenausfallerkennung f?r Fernlicht aktiv
;LC,17,0,Anforderung elektrische Kraftstoffpumpe (EKP) via CAN m?glich
;LC,17,1,Funktion Anlasswiederholsperre aktiv
;LC,17,2,Geschwindigkeitsregelanlage (GRA) ?ber MFL verbaut
;LC,17,3,Signalhorn bei Klemme 15 AUS inaktiv
;LC,17,4,Ansteuerung Batterietrennrelais aktiv
;LC,17,5,Freigabe Sonderfunktionen (MFG)
;LC,17,6,Ansteuerung elektrische Kraftstoffpumpe (EKP) ?ber Fahrert?r (nur Ottomotoren)
;LC,17,7,Geschwindigkeitsregelanlage (GRA) verbaut
;LC,18,0~7,00,Leuchtenkonfiguration: Standard/Parametrierung (EEPROM)
;LC,18,0~7,41,Leuchtenkonfiguration: Typ 1
;LC,18,0~7,60,Leuchtenkonfiguration: Typ 2
;LC,18,2=,Bitte f?hren Sie an diesem Byte nur ?nderungen durch wenn unbedingt notwendig.
;LC,18,3=,Unter Umst?nden kann es andernfalls zu Fehlfunktionen am Steuerger?t bzw. am
;LC,18,4=,Fahrzeug kommen welche gegebenenfalls nicht r?ckg?ngig zu machen sind.
;LC,18,6=,Sollten bereits ?nderungen durchgef?hrt worden sein welche Probleme
;LC,18,7=,hervorgerufen haben so kontaktieren Sie bitte Ihren VCDS Vertriebspartner.
;LC,19,0,Ansteuerung Nebel-/Abbiegeleuchten ?ber PWM aktiv
;LC,19,1,Ansteuerung BegrenzungSchlussleuchten ?ber PWM aktiv
;LC,19,2,Ansteuerung Bremsleuchten ?ber PWM aktiv
;LC,19,3,Ansteuerung Blinkleuchten ?ber PWM aktiv
;LC,19,4,Lampenausfallerkennung f?r Blinkleuchten aktiv
;LC,19,5,Lampenausfallerkennung f?r NebelAbbiegeleuchten aktiv
;LC,19,6,Lampenausfallerkennung f?r Begrenzung-Schlussleuchten aktiv
;LC,19,7,Lampenausfallerkennung f?r Bremse aktiv
;LC,20,0,Full Hybrid verbaut
;LC,20,1,Funktion Rekuperation
;LC,20,2,BDM verbaut
;LC,20,3,LIN Generator verbaut
;LC,20,4,Funktion "internes Start/Stop"
;LC,20,5,Energiemanagement aktiv
;LC,20,6,Funktion Ruhespannungsanzeige bei aktivem Transportmodus (TRA) aktiv
;LC,20,7,PTC_LLA (Leerlaufanhebung), proaktive LLA bei PTC
;LC,21,0,Tagfahrleuchtenkombination, 0 = 20 W, 1 = LED
;LC,21,1,Schalterdimmung ?ber Festwert aktiv
;LC,21,2,Abbiegelicht auch ?ber Blinker aktivierbar
;LC,21,3,beidseitiges Abbiegelicht bei R?ckw?rtsfahrt
;LC,21,4,Verbau Dachblinkleuchten
;LC,21,5,Blockierung Nebellicht bei Fernlicht
;LC,21,6,(Beidseitiges Parklicht aktiv), Seitenmarkierungsleuchten verbaut
;LC,21,7,Nebelscheinwerfer (mit Abbiegelicht) verbaut
; {Byte 22: Vorgehalten f?r Bordnetz}
;LC,22,0,Standlichtreduzierung bei "ZV zu"
;LC,22,1,GRA_High_mit_ACC
;LC,22,2,Funktion "kein Abblendlicht bei Fernlicht"
;LC,22,3,Tagfahrlicht mit Positionslicht
;LC,22,4,Nebelschlu?leuchten bei "Kofferraum auf" ausschalten
;LC,22,5,Assistenzfahrlicht aktiv
;LC,22,6,Anzeige Interlock (Kupplungsanzeige) im Schalttafeleinsatz aktiv
;LC,22,7,MFL- Blinker ?berstimmt Blinkhebel vom Lenkstockschalter
; {Byte 23: Vorgehalten f?r Bordnetz}
;LC,23,0,Alternative Spanungsversorgung f?r Fernlicht- und Klemme 58d
;LC,23,1,kein Nebelschlusslicht bei Fernlicht
;LC,23,2,Tagfahrlicht Ausgabe (Bit 2), 10: TFL ?ber Abblendlicht, 11: TFL ?ber Standlicht
;LC,23,3,Tagfahrlicht Ausgabe (Bit 1), 00: TFL ?ber TFL, 01: TFL ?ber Nebelscheinwerfer
;LC,23,4,Tagfahrlicht abschalten bei gezogener Handbremse
;LC,23,5,Tagfahrlicht bei Standlicht
;LC,23,6,Funktion "Tagfahrlicht" aktiv
; ggf. im Zusammenhang mit Byte/Bit 12/1
;LC,23,7,Tagfahrlicht beim Blinken abschalten
;LC,24,3,Verbauliste inaktiv
;LC,24,4,Transportprotokoll CAN-Datenbus Antrieb (0 = TP 1.6 / 1 = TP 2.0)
;LC,24,5,CAN-Antrieb "Schleife" aktiv
;LC,24,6,Wake-Up Leitung "austauschbar"
;LC,24,7,L?fterschalter nach CAN ausgeben
; {Byte 26: Vorgehalten f?r KESSY}
;LC,25,1,KESSY Wieder?ffnung ESchiebet?r
;LC,25,3,KESSY ?ffnung Heckdeckel bei Wiederentriegelung
;LC,25,4,KESSY Komfort-Reichweitenbegrenzung Verdeck
;LC,25,5,Komfortschlie?en ?ber Kessy
;LC,25,6,Komfort?ffnen ?ber Kessy
;LC,25,7,Verbau Kessy
; {Byte 26: Vorgehalten f?r Gateway}
;LC,26,0,Motorsteuerger?t - Sollverbau
;LC,26,1,Getriebeelektronik - Sollverbau
;LC,26,2,Bremsensteuerger?t - Sollverbau
;LC,26,3,Schalttafeleinsatz - Sollverbau
;LC,26,4,Airbagsteuerger?t - Sollverbau
;LC,26,5,Lenkhilfe - Sollverbau
;LC,26,6,Lenkwinkelsensor - Sollverbau
;LC,26,7,Leuchtweitenregelung - Sollverbau
; {Byte 27: Vorgehalten f?r Gateway}
;LC,27,0,Parkhilfe - Sollverbau
;LC,27,1,Climatronik - Sollverbau
;LC,27,2,Multifunktions-SG
;LC,27,3,Anhaengersteuerger?t - Sollverbau
;LC,27,4,Digitales Soundpaket - Sollverbau
;LC,27,5,MDI - Sollverbau
;LC,27,6,Navigation (RNS) - Sollverbau
;LC,27,7,TV - Tuner - Sollverbau
; {Byte 28: Vorgehalten f?r Gateway}
;LC,28,0,Radio - Sollverbau
;LC,28,1,Telefon (Handy-Vorbereitung) - Sollverbau
;LC,28,2,elektrische Zentralelektrik / BCM - Sollverbau
;LC,28,3-7,Distanzregelung - Sollverbau
; {Byte 29: Vorgehalten f?r Gateway}
;LC,29,0,Anzeige-/ Bedieneinheit Dach - Sollverbau
;LC,29,1,Schiebet?r links - Sollverbau
;LC,29,2,Schiebet?r rechts - Sollverbau
;LC,29,3,Zu-/Standheizung - Sollverbau
;LC,29,4,DVE - Sollverbau
;LC,29,5,Rearview - Sollverbau
;LC,29,6,Quersperre - Sollverbau
;LC,29,7,Kessy - Sollverbau
; {Byte 30: Vorgehalten f?r Gateway}
;LC,30,0,Spurwechselassistent - Sollverbau
;LC,30,1,Verdeck-SG - Sollverbau
Share with us your findings whatever your VW, Seat, Skoda from anywhere in the world... Image
:?: GRA High, Cruise control display.
Perhaps the problem will be on pin T94/86 ECU (petrol) ??? Old wire (K-line) info from DSG to ECU, T73b/37 BCM and T16/7 OBD2 :?:
VW T6 switch clutch with four pins... :?: for manual transmission.Image
CNK
Drives: 6R
Post by CNK »
ciclo wrote::?: GRA High, Cruise control display.
This works in Polo 6R (2010) 1.2 TSI 105hp without DSG, too. But i can't find any info, about required ECU.. My friend unfortunatelly sold his 6R so I can't check this.. :cry:
some bits and bytes I need to disagree with for 7E0 BCM Max:
Byte 22
bit 4 Led module installed for LED or bi-xenon headlights
byte 27
bit 0 LED licence plate lights
bit 1 Terminal 58d trough different pin (T73b/4 to dimmer)
BCM PQ25 = 'The Thing'
It is surprising that no one has yet deciphered the entire functions and adaptations of this thing, it is somewhat disappointing.
As you know some Byte-Bits functions depends on what you selected in other Byte-Bits and factory wiring configuration, especially those are related to the parking lights and DRL (within the same module).
By the way, have you solved this issue?
Monday,15,August,2016,17:40:13:62066
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x64(VMWare)
VCDS Version 16.8.0.3 (x64)
Data version: 20160803 DS255
www.Ross-Tech.com
VIN: WVWZZZ6RZ   License Plate:
Chassis Type: 6R (7E0)
Scan: 01 03 04 08 09 10 15 17 19 20 25 2E 37 44 55 56 61 69 6C 77
          0B
VIN: WVWZZZ6RZ
56-Radio -- Status: OK 0000
69-Trailer -- Status: OK 0000
Address 01: Engine (J0000-CFWA)       Labels: 03P-906-021-CFW.clb
   Part No SW: 03P 906 021 B    HW: 03P 907 425
   Component: R3 1.2 DCM3.7 H06 8510
   Revision: 12005001    Serial number:
   Coding: 00114036033401080000
   Shop #: WSC 12345 123 12345
   ASAM Dataset: EV_ECM12TDI03103P906021B 001026
   ROD: EV_ECM12TDI03103P906021B.rod
   VCID: 2757FDE35E1F667AC1-8073
Readiness: 0000 0000
Address 03: ABS Brakes (J104)       Labels: 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 AK    HW: 6R0 907 379 AF
   Revision: --------
   Coding: 210248E3416F00B7842B12E782D500521300
   Shop #: WSC 00788 648 00255
   VCID: 07179D63B2DF467AE1-8053
   Part No SW: 6R0 907 044 E    HW: 6R0 907 044 E
   Component: Climatronic   H09 0609
   Revision: V0000000
   VCID: 356B27AB9CB304EA43-8061
1 Fault Found:
00457 - Control Module for Network (J519)
            004 - No Signal/Communication
                    Fault Status: 01100100
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 98
                    Mileage: 147781 km
                    Time Indication: 0
                    Date: 2016.08.15
                    Time: 17:33:27
Address 09: Cent. Elect. (J519)       Labels: 7E0-937-BCM-V1.clb
   Component: BCM PQ25 Max4 H80 0733
   Revision: B9080001    Serial number: 0771 092150183
   Coding: 3CB02FBF28E32400933806917DEB9FD0DAC073AF608D30D0200000030800
   Shop #: WSC 18752 008 00032
   VCID: 68D5BEDF9B81A90208-803D
   Subsystem 1 - Part No: 5K7 955 559 B
   Component: RLS 140415 03  37  0059
   Coding: 0228EE
   Subsystem 2 - Part No SW: 6R0 959 801 BD    HW: 6R0 959 801 BD  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  003 8611
   Serial number: KU0KU011111300010103
   Coding: 0200A3
   Subsystem 3 - Part No SW: 6R0 959 802 BF    HW: 6R0 959 802 BF  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  003 8611
   Serial number: KU0KU007111300016463
   Coding: 1000AB
   Subsystem 7 - Part No SW: 1K8 959 442     HW: 1K8 959 442
   Component: E221__MFL-DC1  H03 0103
   Serial number: 27140002547420014516
   Coding: A4FFFF
   Subsystem 8 - Part No SW: 6R0 959 811 B    HW: 6R0 959 811 B
   Component: J388__TSG_HL  002 0803
   Serial number: KU0-KU008.06.0910897
   Coding: 08BC32
   Subsystem 9 - Part No SW: 6R0 959 812 B    HW: 6R0 959 812 B
   Component: J389__TSG_HR  002 0803
   Serial number: KU0-KU004.06.0913330
   Coding: 08BC32
Address 10: Park/Steer Assist (J446)       Labels: 7E0-919-475.clb
   Part No SW: 7E0 919 475 L    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0106
   Revision: --------    Serial number: 28231422402620
   Coding: 318001
   ROD: EV_EPHVA18VW250GPCS.rod
   VCID: 3B7F3193B297D29AB5-806F
   Component: VW10Airbag01M H10 0020
   Revision: --------    Serial number: 003GX0142TCE
   Coding: 00314D
   Shop #: WSC 01383 785 00200
   VCID: 4A916457ED4D7B123E-801F
   Serial number: 3575HRB40650BI7U48C8
   Serial number: 3585HRB405J09RECEOUJ
   Serial number: 3515RRB405T0BTBEF9G7
   Serial number: 3525RRB405R0BTBEKPFQ
   Part No SW: 6R0 920 861 F    HW: 6R0 920 861 F
   Component: KOMBI         H05 0304
   Coding: 540E00
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04086
   ROD: EV_Kombi_UDS_VDD_RM09_VW25.rod
   VCID: 38752E9F83A1F98258-806D
   Component: GW-K-CAN TP20 H80 0733
   Revision: B9080001
   Coding: 042200
Address 20: High Beam Assist. (J844)       Labels: 8S0-857-511.clb
   Revision: AA001001
   Coding: 0404001C00000000000000
   VCID: 2E5908C771E5373202-807B
   Component: IMMO          H05 0304
   Serial number:
   Shop #: WSC 00000 000 00000
   VCID: 6AD1C4D78D8D9B121E-803F
Address 2E: Media Player 3 (J650)       Labels: 5N0-035-342.lbl
   Part No SW: 5N0 035 342 G    HW: 5N0 035 342 G
   Component: SG EXT.PLAYER H19 0770
   Revision: A1001003    Serial number: 7666620365
   Coding: 010100
   VCID: 2B5F01D34AF7421A25-807F
Address 37: Navigation (J0506)       Labels: 1T0-035-680.clb
   Part No SW: 1T0 035 686 E    HW: 1T0 035 686 H
   Component: RNS-MID       H26 6276
   Revision: AB001001    Serial number: VWZ6Z7P1950254
   Coding: 00000402010000A10001
   VCID: 366920A781B50FF24A-8063
   Subsystem 1 - Part No: 1T0 919 859 B
   Component: EU West V13  8348
   Part No: 6R0 423 156 B
   Coding: 11220
   Shop #: WSC 00788
   VCID: 2F6715C3EAEF3E3A09-807B
Address 55: Headlight Range (J431)       Labels: 6R0-907-357.clb
   Revision: --------    Serial number: --------------
   Coding: 0192000001000000
   VCID: 77F7EDA3CE3F36FA91-8023
Address 56: Radio (J0506)       Labels: 1T0-035-680.clb
Address 61: Battery Regul. (J840)       Labels: 1K0-907-534.clb
   Part No SW: 7E0 907 534     HW: 7E0 937 090
   Component: Batt.regelung H80 Batt.regelung H80 07330733
   Coding: 030F1A5A
   Subsystem 1 - Part No: 6R0 915 181 B
   Component: J367-BDM
No Faults Found
  or DTCs not supported by controller
  or a communication error occurred
Address 69: Trailer (J345)       Labels: 1K0-907-383-MY8.lbl
   Part No SW: 1K0 907 383 E    HW: 1K0 907 383 E
   Component: Anhaenger     H07 0080
   Revision: 3A002002    Serial number: 00000116932377
   Coding: 4100000100000000
   Shop #: WSC 00028 028 00001
   VCID: 2F6715C37EEF3E3A09-807B
Address 6C: Back-up Cam.        Labels: 5N0-907-441.clb
   Part No SW: 7E0 907 441     HW: 7E0 907 441
   Component: J772__Rearview      0040
   Revision: 00H08000    Serial number: 525PA8-J060533
   Coding: 0030016
   Shop #: WSC 02757 790 00000
   VCID: 65CBB7EBAC93B46A33-8031
Address 77: Telephone (J412)       Labels: 3C8-035-730-A.clb
   Part No SW: 3C8 035 730 E    HW: 3C8 035 730 E
   Component: Telefon       025 0983
   Revision: --------    Serial number: 35502105254406
   Coding: 020100000100010000000101
   ASAM Dataset: EV_UHVPremi 002709
   ROD: EV_UHVPremi_VW32.rod
   VCID: 254BF7EB2413746AF3-8071
End-------------------------(Elapsed Time: 05:20)--------------------------
Perhaps it is related to Byte 27. Test with Bit1, as suggestion.
Other different matters. :?:s
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Coding: 540E00 :?:
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 7E0 909 901 HW: 7E0 937 090
Revision: B9080001
Coding: 042200 :?:
My last autoscans:
Friday,19,August,2016,09:48:27:06516
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 16.8.0.3
www.Ross-Tech.com
VIN: WVWZZZ6RZDY0CICLO   License Plate:
Mileage:                              Repair Order:
Scan: 01 03 04 08 09 10 15 17 19 20 25 2E 37 44 55 56 77 0B
VIN: WVWZZZ6RZDY0CICLO   Mileage:
Address 01: Engine (J623-CBZC)       Labels: 03F-906-070-CBZ.clb
   Part No SW: 03F 906 070 GD    HW: 03F 907 309 AJ
   Component: SIMOS10.22AH10 2686
   Revision: --H10---    Serial number: 00000000000000
   Coding: 001100D6202400080000
   ASAM Dataset: EV_ECM12TFS02103F906070GD 004004
   ROD: EV_ECM12TFS02103F906070FJ.rod
   VCID: 6A0F8AD4DFA86FC44C-803E
Readiness: 0110 0101
   Part No SW: 6R0 907 379 BE    HW: 6R0 907 379 AF
   Revision: --------
   Coding: 210228E3216D00B5842814EA84D300401700
   Shop #: WSC 40308 002 104857
   VCID: 02A75AAC33B0DFEC0C-8056
Address 04: Steering Angle (G085)       Labels: 6R0-959-654.clb
   Component: LENKW.SENSOR  H06 0060
   Serial number: 090465LEA0003X
   Coding: 01
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7E1B62100F0CE7502C-802A
   Part No SW: 6R0 907 044 H    HW: 6R0 907 044 H
   Component: Climatronic   H11 0711
   Revision: V0000000
   VCID: 38D1F64EEFAE9B66FC-806C
   Revision: B9080001    Serial number: 0771 100150209
   Coding: 3CB02FBF48E1240093380E917CEB9FD0DAC8672F600D30D0200000030800
   Shop #: WSC 03607 002 104857
   VCID: 680196DEAFBE7B367C-803C
   Component: RLS 110215 03  37  0059
   Coding: 0728DD
   Component: J386__TSG_FT  003 8612
   Serial number: KU0KU003041440937042
   Coding: 0200A3
   Component: J387__TSG_BT  003 8612
   Serial number: KU0KU006031440656541
   Coding: 1000AB
   Subsystem 5 - Part No: 1K8 951 605 B
   Component: LIN BACKUP HO  H11 9005
   Serial number: 27140003142720054516
   Coding: A4FFFF
   Subsystem 8 - Part No SW: 6R0 959 811 G    HW: 6R0 959 811 G
   Component: J388__TSG_HL  008 1611
   Serial number: KU0KU003051200017821
   Coding: 18BC32
   Subsystem 9 - Part No SW: 6R0 959 812 G    HW: 6R0 959 812 G
   Component: J389__TSG_HR  008 1611
   Serial number: KU0KU010051200012315
   Coding: 18BC32
Address 10: Park/Steer Assist (J446)       Labels: 6R0-919-475.clb
   Part No SW: 6R0 919 475 C    HW: 7E0 919 475
   Component: PARKHILFE 4K  H11 0013
   Revision: --------    Serial number: 47361212601014
   Coding: 308001
   ROD: EV_VW250ParkiAssis2.rod
   VCID: 3EDBE2500FCC67102C-806A
   Revision: --------    Serial number: 003GX01JKVVP
   Coding: 00314D
   VCID: 4AEFCA745F082FE44C-801E
   Serial number: 3575HRB405N1C4LI7929
   Serial number: 3585HRB405B1D5MS8GS2
   Serial number: 3515RRB405B17ABS901.
   Serial number: 3525RRB405B181TUDPKC
   Part No SW: 6R0 920 870 C    HW: 6R0 920 870 C
   Component: KOMBI         H05 0607
   Coding: 140E01
   Shop #: WSC 00233 572 91226
   VCID: 35D2F037EBB1A953E4-8060
   Revision: B9080001
   Coding: 002200
   Revision: AA001001
   VCID: 2ECB0220CF9CC7A0AC-807A
   Component: IMMO          H05 0607
   Part No SW: 5N0 035 342 F    HW: 5N0 035 342 F
   Component: SG EXT.PLAYER H18 0530
   Revision: A1001003    Serial number: 7662584630
   Coding: 010100
   VCID: 2ACF0A14D768EF844C-807E
   Part No SW: 1T0 035 680 L    HW: 1T0 035 680 C
   Component: RNS-MID       H06 5218
   Revision: AB001001    Serial number: VWZ6Z7L7654213
   Coding: 04000442040000A10001
   VCID: 37D0F44DEBAB9D61F4-8062
   Coding: 11250
   Shop #: WSC 00788
   VCID: 2FC804255F93CDA9B4-807A
   Coding: 0112000001000000
   VCID: 7710740DE3EB1DA1F4-8022
Address 77: Telephone (J412)       Labels: 7P6-035-730.clb
   Part No SW: 7P6 035 730 L    HW: 7P6 035 730 L
   Component: TELEFON       H15 3200
   Revision: 1B001001    Serial number: 00007664158506
   Coding: 0501000000010110
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA.rod
   VCID: 3BDCEC5913DF757DD4-806E
End-------------------------(Elapsed Time: 04:16)--------------------------
VCP+K v7.0.0 21.07.2016 Cute Kitty Protocolo Autoscan 2016-08-15 12:43:26.048
Adressword  : 01 (Electrónica del motor} - J623  SIMOS10.22A
VAG no.     : SW: 03F906070GD HW: 03F907309AJ
Version SW   : 2686
# Codificación      : 001100D6202400080000
ASAM: UDS, EV_ECM12TFS02103F906070GD 004004
DATASET:
>>> No se han encontrado errores
Adressword  : 03 (Electrónica de los frenos} - J104 ESP8.2i front
VAG no.     : SW: 6R0907379BE HW:
Version SW   : 0001
# Codificación      : 210228E3216D00B5842814EA84D300401700
ASAM: TP1.6, CANT=7A3 CANE=7A0
DATASET:
Adressword  : 17 (Cuadro de instrumentos} - J285  KOMBI
VAG no.     : SW: 6R0920870C  HW: 6R0920870C
Version SW   : 0607
# Codificación      : 140E01
ASAM: UDS, EV_Kombi_UDS_VDD_RM09 A04716
DATASET: -----------
Adressword  : 15 (Airbag} - J234  VW10Airbag01M
VAG no.     : SW: 6R0959655K  HW: 6R0959655K
Version SW   : 0020
# Codificación      : 00314D
ASAM: UDS, EV_AirbaVW10BPAVW250 A01001
DATASET: v00305696R0
Adressword  : 44 (Dirección asistida} - LenkhilfeTRW        V277
VAG no.     : SW: 6R0423156B   HW:
Version SW   :
# Codificación      : 0011250
ASAM: TP1.6, CANT=7A9 CANE=7A0
DATASET:
Adressword  : 04 (Sensor de ángulo de dirección} - G085  LENKW.SENSOR
VAG no.     : SW: 6R0959654   HW: 6R0959654
Version SW   : 0060
# Codificación      : 01
ASAM: UDS, EV_LWSKLOVW25X 005001
Adressword  : 55 (del alcance de las luces} - J431  LWR-ECU
VAG no.     : SW: 6R0907357   HW: 6R0907357
Version SW   : 0070
# Codificación      : 0112000001000000
ASAM: UDS, EV_HeadlRegulVWLWRPt 001004
DATASET: 6R0036v____
Adressword  : 10 (Aparcamiento asistido 2} - J446  PARKHILFE 4K
VAG no.     : SW: 6R0919475C  HW: 7E0919475
Version SW   : 0013
# Codificación      : 308001
ASAM: UDS, EV_VW250ParkiAssis2 S01008
DATASET:
Adressword  : 08 (Electrónica del aire acondicionado/de la calefacción} - J255 Climatronic
VAG no.     : SW: 6R0907044H  HW: 6R0907044H
Version SW   : 0711
# Codificación      : 00000
ASAM: TP2.0, CANT=300 CANE=33C
DATASET:
Adressword  : 2E (Media Player 3} - J650 SG EXT.PLAYER
VAG no.     : SW: 5N0035342F  HW: 5N0035342F
Version SW   : 0530
# Codificación      : 010100
ASAM: TP2.0, CANT=300 CANE=4EC
DATASET:
Adressword  : 37 (Navegación} - J0506RNS-MID
VAG no.     : SW: 1T0035680L  HW: 1T0035680C
Version SW   : 5218
# Codificación      : 04000442040000A10001
ASAM: TP2.0, CANT=300 CANE=4D8
Adressword  : 56 (Radio} - J0506RNS-MID
Version SW   : 5218
ASAM: TP2.0, CANT=300 CANE=4DA
Adressword  : 77 (Teléfono} - J412  TELEFON
VAG no.     : SW: 7P6035730L  HW: 7P6035730L
Version SW   : 3200
# Codificación      : 0501000000010110
ASAM: UDS, EV_UHVNA 002720
DATASET: 7P6035730L
Adressword  : 09 (Centralita eléctrica electrónica} - J519 BCM PQ25 Max4
VAG no.     : SW: 7E0937090   HW: 7E0937090
Version SW   : 0733
# Codificación      : 3CB02FBF48E1240093380E917CEB9FD0DAC8672F600D30D0200000030800
ASAM: TP2.0, CANT=300 CANE=338
DATASET:
Adressword  : 19 (Interfaz de diagnóstico para el bus de datos} - J533 GW-K-CAN TP20
VAG no.     : SW: 7E0909901   HW: 7E0937090
Version SW   : 0733
# Codificación      : 002200
ASAM: TP2.0, CANT=300 CANE=32E
DATASET:
Adressword  : 25 (Inmovilizador} - J334  IMMO
VAG no.     : SW: 5K0953234   HW: 5K0953234
Version SW   : 0607
# Codificación      : 000000
ASAM: UDS, EV_Immo_UDS_VDD_RM09 A03709
Adressword  : 20 (Asistente de luz de carretera} - J844  FLA
VAG no.     : SW: 7E0857511G  HW: 7E0857511E
Version SW   : 0003
# Codificación      : 0404001C00000000000000
ASAM: UDS, EV_HighBeamAssisAU316 001004
CNK wrote: This works in Polo 6R (2010) 1.2 TSI 105hp without DSG, too. But i can't find any info, about required ECU.. My friend unfortunatelly sold his 6R so I can't check this.. :cry:
I think the important thing is to find what was changed from 6R 2010 models compared with ours. Maybe GRA High might be present in all 6R ECUs (petrol) but its operation is conditioned to the 6R 2010 models.
Change the ECU is not an option, nor copy the full firmware from another ECU. :evil:
So the 042200 is a fix for the problem with the reversing camera.
The reversing camera highline was installed to this Polo. After installation it gave an error about incorrect software version.
I went to compare different versions of T5 GP autoscans and Polo autoscans. I found some differences in the CAN gateway coding.
With the 002200 I kept this error:
   Coding: 0030015
1 Fault Found:
01043 - Control Module; Incorrect Software Version
            000 -  -
                    Fault Status: 01100000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 90
                    Time Indication: 0
Also the RNS showed 'Rearview camera not available'.
The solutions was:
CAN coding from 002200 to 042200
The Park assist module needed some changes in the adaptation as well, but that's the same for the camera low.
A clue to this solution, I already found in the guide of carsystems.pl. They have a guide for Golf, where can gateway is set to offroad.
Unfortunately the climatronic issue, I have checked some things but it did not fix it.
The wiring is all done correctly. The unit also receives CAN info I think, since the backlight goes on and it's approachabe with VCDS.
About the cruise control high, I have talked to forum member JIC_Cracked who knows a thing about the tacho firmware.
This function depends on:
- Engine ECU. Since there are cars that share engines with the polo, but do have this function, I think the ECU is maybe not the problem.
(i.e. 1.2TSI in Golf/Octavia, 1.6TDI in Golf/Octavia/Superb, 1.4TSI in many models)
- Tacho. There is an adaptation channel that is called 'GRA High display' or something like that in my tacho.
- BCM. The transporter T6 for example I believe supports this function. So we have the good ECU.
All these factors probably were set correctly to the tacho of roffie89
I will check the byte 27 bit 1 and also have a look at the tacho coding.
Ok. :wink:
the option
peter_dk25
Drives: Blue GT
Post by peter_dk25 »
I have the WRC Tacho in my Blue GT 6R and it says that the channel for CC display High isn't present :-(
Also in my tacho, Channel not available, but it is not important, the important thing is communication with the ECU.
Locked
