ORiOn
Drives: Polo BlueGT / Audi S5
ORiOn
Post by ORiOn »
Yup! That was it! haha #fail
ORiOn wrote:Yup! That was it! haha #fail
Do not worry orIoN, often happens ... :wink:
Today I made the instrument panel factory setting and unfortunately it has not happened anything important. The only good thing was that I learned a bit of German language.
Also a new Autoscan: (after trying some tweaks w/o success)
Wednesday,14,September,2016,14:25:37:06516
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 16.8.0.3
Data version: 20160803 DS255
www.Ross-Tech.com
VIN: WVWZZZ6RZDY0CICLO   License Plate:  TACHO FACTORY SETTING
Mileage:   Repair Order:
Chassis Type: 6R (7E0)
Scan: 01 03 04 08 09 10 15 17 19 20 25 2E 37 44 55 56 77 0B
VIN: WVWZZZ6RZDY0CICLO   Mileage:
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CBZC)       Labels: 03F-906-070-CBZ.clb
   Part No SW: 03F 906 070 GD    HW: 03F 907 309 AJ
   Component: SIMOS10.22AH10 2686
   Revision: --H10---    Serial number: 00000000000000
   Coding: 001100D6202400080000
   Shop #: WSC 00788 648 00255
   ASAM Dataset: EV_ECM12TFS02103F906070GD 004004
   ROD: EV_ECM12TFS02103F906070FJ.rod
   VCID: 6AA7F27C4750C75C24-803E
Readiness: 0110 0101
Address 03: ABS Brakes (J104)       Labels: 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 BE    HW: 6R0 907 379 AF
   Revision: --------
   Coding: 210228E3216D00B5842814EA84D300401700
   Shop #: WSC 40308 002 104857
   VCID: 023FC234AB583704E4-8056
Address 04: Steering Angle (G085)       Labels: 6R0-959-654.clb
   Component: LENKW.SENSOR  H06 0060
   Serial number: 090465LEA0003X
   Coding: 01
   Shop #: WSC 00000 000 00000
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EB3CAB8B7B45FE884-802A
   Part No SW: 6R0 907 044 H    HW: 6R0 907 044 H
   Component: Climatronic   H11 0711
   Revision: V0000000
   VCID: 38695ED68756F3FE54-806C
Address 09: Cent. Elect. (J519)       Labels: 7E0-937-BCM-V1.clb
   Component: BCM PQ25 Max4 H80 0733
   Revision: B9080001    Serial number: 0771 100150209
   Coding: 3CB02FBF48E1240093380E917CEB9FD0DAC0672F600D30D0200000030800
   Shop #: WSC 03607 002 104857
   VCID: 6899FE664726D34ED4-803C
   Subsystem 1 - Part No: 5K7 955 559 B
   Component: RLS 110215 03  37  0059
   Coding: 0728DD
   Subsystem 2 - Part No SW: 6R0 959 801 BD    HW: 6R0 959 801 BD  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  003 8612
   Serial number: KU0KU003041440937042
   Coding: 0200A3
   Subsystem 3 - Part No SW: 6R0 959 802 BF    HW: 6R0 959 802 BF  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  003 8612
   Serial number: KU0KU006031440656541
   Coding: 1000AB
   Subsystem 5 - Part No: 1K8 951 605 B
   Component: LIN BACKUP HO  H11 9005
   Subsystem 7 - Part No SW: 1K8 959 442     HW: 1K8 959 442
   Component: E221__MFL-DC1  H03 0103
   Serial number: 27140003142720054516
   Coding: A4FFFF
   Subsystem 8 - Part No SW: 6R0 959 811 G    HW: 6R0 959 811 G
   Component: J388__TSG_HL  008 1611
   Serial number: KU0KU003051200017821
   Coding: 18BC32
   Subsystem 9 - Part No SW: 6R0 959 812 G    HW: 6R0 959 812 G
   Component: J389__TSG_HR  008 1611
   Serial number: KU0KU010051200012315
   Coding: 18BC32
Address 10: Park/Steer Assist (J446)       Labels: 6R0-919-475.clb
   Part No SW: 6R0 919 475 C    HW: 7E0 919 475
   Component: PARKHILFE 4K  H11 0013
   Revision: --------    Serial number: 47361212601014
   Coding: 308001
   ROD: EV_VW250ParkiAssis2.rod
   VCID: 3E734AF8B774DFA884-806A
   Component: VW10Airbag01M H10 0020
   Revision: --------    Serial number: 003GX01JKVVP
   Coding: 00314D
   Shop #: WSC 01383 785 00200
   VCID: 4A87321CC7B0877C24-801E
   Serial number: 3575HRB405N1C4LI7929
   Serial number: 3585HRB405B1D5MS8GS2
   Serial number: 3515RRB405B17ABS901.
   Serial number: 3525RRB405B181TUDPKC
   Part No SW: 6R0 920 870 C    HW: 6R0 920 870 C
   Component: KOMBI         H05 0607
   Coding: 140E01
   Shop #: WSC 00233 572 91226
   ROD: EV_Kombi_UDS_VDD_RM09_VW25.rod
   VCID: 356A58DF935901EB7C-8060
   Component: GW-K-CAN TP20 H80 0733
   Revision: B9080001
   Coding: 002200
Address 20: High Beam Assist. (J844)       Labels: 8S0-857-511.clb
   Revision: AA001001
   Coding: 0404001C00000000000000
   VCID: 2E636AC877043F3804-807A
   Component: IMMO          H05 0607
Address 2E: Media Player 3 (J650)       Labels: 5N0-035-342.lbl
   Part No SW: 5N0 035 342 F    HW: 5N0 035 342 F
   Component: SG EXT.PLAYER H18 0530
   Revision: A1001003    Serial number: 7662584630
   Coding: 010100
   VCID: 2A6772BC4F10471C24-807E
Address 37: Navigation (J0506)       Labels: 1T0-035-680.clb
   Part No SW: 1T0 035 680 L    HW: 1T0 035 680 C
   Component: RNS-MID       H06 5218
   Revision: AB001001    Serial number: VWZ6Z7L7654213
   Coding: 04000442040000A10001
   Shop #: WSC 12345 123 12345
   VCID: 37685CD58353F5F94C-8062
   Subsystem 1 - Part No: 1T0 919 859 B
   Component: EU West V13  8348
   Part No: 6R0 423 156 B
   Coding: 11250
   Shop #: WSC 00788
   VCID: 2F606CCDF73B25C10C-807A
Address 55: Headlight Range (J431)       Labels: 6R0-907-357.clb
   Revision: --------    Serial number: --------------
   Coding: 0112000001000000
   VCID: 77A8DC958B9375394C-8022
Address 56: Radio (J0506)       Labels: 1T0-035-680.clb
Address 77: Telephone (J412)       Labels: 7P6-035-730.clb
   Part No SW: 7P6 035 730 L    HW: 7P6 035 730 L
   Component: TELEFON       H15 3200
   Revision: 1B001001    Serial number: 00007664158506
   Coding: 0501000000010110
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA.rod
   VCID: 3B7454E1BB47ED95AC-806E
End-------------------------(Elapsed Time: 04:03)--------------------------
Maybe I will activate the two static cornering lights when turn on the front fog lights (Polo 6R factory Bi-xenon only, not other VW models), hmm... the next time. (Assistance lights front fog lights) :mrgreen:
This month I will go back again to the VW dealer to try to update some units of my VW --- BCM, Gateway, ECU and Intruments --- to try to get some changes in MFA functions (GRA_High, etc...).
Du, kluge Spanische Mann, sprichst und verstehst ja gar gut Deutsch! ;)
Michel, please can you explain me the difference between 'verbaut' and 'sollverbau'?
Verbaut = installed (the verb 'verbauen' is 'to install')
'soll' comes from the verb 'sollen' which compares to the verb 'to shall'. 'ich soll verbauen' is translated into 'i should install'
So the word sollverbau is a contraction of soll and verbauen.
It means a component should be installed
Michel, you are the best Image
Curiosity: BCM PQ25 Byte18 Bit6 (7E0937090)
Conditions: Polo 6R with 6C LED headlights and 6C taillights.
The warning light of instruments come on only when the brake pedal is actuated... with the following coding.
Solved with:
So Byte18 Bit6 is affecting the brake lights performance. :wink:
Byte 18 is closely related to lighting. What I think
Xenon + LED DRL = Hex 67 (polo 6R)
LED + LED DRL = Hex 73 (T6), I have used this value too
Halogen H7 = Hex 41 or 65
Halogen H4 = Hex 61 (polo trendline and bluemotionn)
iichel wrote:Byte 18 is closely related to lighting.
Crossfox = Hex 62 or 42 Image...
New Ibiza
Great! 8)
Ah yes, I forgot: (Sorry, but lately I have the fish memory (3-5 sec) :lol:, I can not even remember the speed at which I SET the cruise control and then be able to RESume)
ciclo wrote:This month I will go back again to the VW dealer to try to update some units of my VW --- BCM, Gateway, ECU and Intruments --- to try to get some changes in MFA functions (GRA_High, etc...).
On October 6th
similar to this
peter_dk25
Drives: Blue GT
Post by peter_dk25 »
:D
govindsharma
Drives: polo 1.2 petrol HighLine
Post by govindsharma »
Dear ciclo you had said that i have to change my car BCM for xenon headlight and auto fold side mirror,dear please suggest me which BCM i will buy and can i replace mine with myself and code with VCDS, can my car accept new BCM without any error.
Thank you
favi
Drives: 6R
Post by favi »
On the German forum for VW POLO i read that in the window motor is the most important code PR-6XE if you want to run the function folding.
Ciclo do this modification on 6R0959801BD Z0D, 6R0959802BF Z03.
On etka.cc found many motors code PR-6XE. Is anyone doing this modification to the motors 6R0959801BC Z03 and 6R0959802BH Z0D? Will this work?
Coding VCDS will be the same?
peresurin
Drives: 2015 - 6C (Lounge)
Post by peresurin »
hello ciclo,
first of all i am very impressed of your skills and technical knowledge. I read all this subject from start to end. I have some questions. you stated that you used below LEDs;
viewtopic.php?f=56&t=58703&start=285#p479470
But i can not find them anymore (actually i found one but I just want to be sure), is it possible to use below products for this fog-lamp mod;
1) https://www.aliexpress.com/item/A-Pair- ... c6236caef3
2) https://www.aliexpress.com/item/Night-L ... c6236caef3
or this one>
3) https://www.aliexpress.com/item/1set-60 ... f826051b1b
The third one is your product i think? I kindly ask you to advise which one fits well w/o error.
Thank you in advance for your reply.
govindsharma wrote:Dear ciclo you had said that i have to change my car BCM for xenon headlight and auto fold side mirror,dear please suggest me which BCM i will buy and can i replace mine with myself and code with VCDS, can my car accept new BCM without any error.
Thank you
To change your BCM High by Max you need rewiring of most of its lights. This rewiring is required if you want OEM Bi-xenon headlamps, OEM LED headlights, OEM Automatic lights, etc ... but not for OEM automatic folding mirrors.
Therefore there is no such BCM which you refer in your previous question --->Plug & Play
favi wrote:On the German forum for VW POLO i read that in the window motor is the most important code PR-6XE if you want to run the function folding.
Favi only by testing will be possible give an answer to your question.
You should never forget to do this after coding
:arrow: viewtopic.php?f=56&t=58703&p=481352#p481352
Coding should work: Folding mirror with remote--> (J386) Byte2 Bit1 enable.
Example LHD
Example RHD --- if J386 1000A1 ---> 1000A3
peter_dk25 wrote: :D
I even thinking about buy a new 6C 1.0 (LED headlights) to replace the 9N3 ...
A-Polo ---> a very attractive version sold in Spain, to achieve the moon and perhaps Mars. Image (by gravitational effect, I guess :lol: )
Locked
